MZR DISI Ringland Failures Quote:
I am pretty sure I blew my ringlands in cylinder 1 on my stock motor. Pulling it on Friday and should have pictures by saturday. |
Man I would love to plot this data in a stats program I have but I'm not sure if we have enough data points for anything to be statistically significant. Maybe I'll give it a try anyway but the more people who provide data the better. I see what people were posting in the beginning of the thread but it everything that would be needed, off the top of my head, would be: Year, mileage, which cylinder(s) had cracked ringlands, meth, e85, ~whp, peak boost, peak timing, car tracked?... can't think of anything else atm. |
if he could measure the ring gaps as they are that would be swell since I am about to install OEM chit in my new block. @SPEED6 KILLAH; what would be interesting to know is if they are at the max end of spec or in the middle or tight. That will give me a guestimation of how much I might want to open up the brand new rings. yes this would only be one motor but still just slightly better than a shot in the dark. |
http://img.tapatalk.com/d/13/03/21/u7are9e4.jpg |
yeah no problem either way it will be good forensic information to have. if you are measuring the ring gaps have them 1/2 way down the bore to make the measurement. |
Did a compression test Saturday and cylinder 1 had a pool of oil on top of the cylinder. 2 was 150 psi. 3 was 50 psi 4 was 180 psi. She went down fighting at 26.5 lbs and 332whp on VD on a BNR S3 and just 91. 14.5 degrees of timing. No racing. |
Most BNRs I tune on the cali 91 barely break 21psi and 8-10* at redline to stay safe |
Mine was doing good. No knock at all. And then this happened. |
50 psi on cyl 3 is pretty low. It didn't run like crap? And what was cyl# 1? And by the Hp numbers you posted I think one could tell there was something wrong. 26 psi and 14* of timing should get you in the 370 whp range on a mustang dyno even with BATs in the 110 range. |
MZR DISI Ringland Failures @Micha; your compression numbers were something like 160, 160, 160, 180 when we installed the turbo right? Makes me think your motor was already critically wounded before the tune started based on the compression numbers we pulled Saturday. |
Honestly, I am not mad at all that the motor went. I expected it to happen sooner or later. Thanks for the help guys. I will post up pictures after we pull her and take her apart. |
If you weren't running a shit load of meth there is just no way IMO that a stock motor would not knock with that boost and timing + 91 oct . Doesn't matter if you have an intercooler the size of Texas. Did anyone modify your knock tables? You might also want to check the knock sensor is working properly if you are going to build the motor. Edit: I guess a good amount of Eth would let you get away with it. |
Sorry to hear about your zzb @Micha; Hope you get her back up and running soon!!! |
Bottom was ring .014 on taf0422 motor I will do some measure on the ring gap. |
MZR DISI Ringland Failures Right on! I'll be checking my new gen2 gaps as well when I install the Carrillos. Tappin |
Re: MZR DISI Ringland Failures That is just crazy how small the factory ring gap is. A piece of paper is only .003" so the ring gap is essentially 2 pieces of paper in thickness. Sent from your couch |
Yeah that's bullshit. |
Re: MZR DISI Ringland Failures Quote:
Sent via smokey turbo. |
The compression and power output seem decent. :D Sent via smokey turbo. |
as todd said a leakdown, if you care to go through the process, is your next step but at 10psi lower I don't think I would worry about it. |
As far as leakdown is concerned, its not my car, I don't have compressed air, and I don't have a wrench to turn the crankshaft with.:D Sent via smokey turbo. |
Driver side to Passenger side (I forget the numerical order) 182-176-174-177 4.5% delta between max/min. I can live with that at ~500whp. http://i77.photobucket.com/albums/j6...psde7696a8.jpg I love these motors... |
So only one car running stock boost levels has experienced ringland failure? |
I SUSPECT I may have a cracked ringland. Model/Year: 2008 Mazdaspeed 3 Mileage: 90000 miles Compression Results: 180 180 150 180 Cylinder /w SUSPECTED Cracked Ringlands: 3 Suspected Event Causing Failure, Condition of Affected Cylinder(s) and Other Info: IDKSOLOL, not making the power I'd expect given timing and boost with ethanol, also oil in vc vent-> intake. Have always had some oil in the intake track, so not sure how long I've had this issue. Pictures: http://momofftrack.com/wp-content/up...4/sad-face.jpg |
I've recently started burning oil and my cylinder #3 spark plug is covered in what looks to be burned oil and has wet, black threads. Compression was 150PSI about 3K miles ago, but I couldn't actually do one today because the HF tester I bought a few months ago didn't work at all. Anyways, does this point to a cracked ringland since the oil residue seems to only be on that one plug? I suppose if I had a bent rod, that would "cock" the piston in its bore and create a similar problem with the rings sealing and allowing oil into the combustion chamber. There is some oil in the intercooler and the TB coupler, but not much, just a coating. Here are my plugs: http://farm9.staticflickr.com/8097/8...39de0885_b.jpg http://farm9.staticflickr.com/8514/8...edab213b_b.jpg http://farm9.staticflickr.com/8097/8...b001a546_b.jpg http://farm9.staticflickr.com/8245/8...eabc4588_z.jpg |
#3 ftl |
What are you coolant temps are at? |
No occ. Coolant temps stay in the lower 190s. |
OCC is great for cleaning up the intake tract when the engine is in good shape but if your compression is down and causing a lot of blowby it's a band-aid. |
@sidekick; FWIW I had oil pooling in all my IC piping when I lost my ringland. Your pics def look like more than typical blow by on a healthy motor. My saga and pics can be found here http://www.mazdaspeedforums.org/foru...ml#post1642342 |
| All times are GMT -7. The time now is 06:58 AM. |
