Edit: @Dano; do you have pictures of your spark plugs? |
I found this quote from NASIOC in a thread that @Dano; posted: Quote:
Is this a viable explanation or am I talking out of my ass? |
Side loading goes up as the piston moves down the cylinder. Right at the top there is nearly zero side loading. Zigatapatalka |
Nice find. |
He also talked a little about colder plugs. Maybe there is something there as well. A lot of people here are running colder plugs, but is it REALLY necessary? He claims he is only running step colder plugs on a 600AWHP track car. |
We know detonation is common on heatsoaked vehicles and it takes out rods. It could be that it takes out ringlands as well over time. |
I know some EvoX enthusiasts here in Russia had the same ringland failure issue.. Now they increase the top ring gap slightly and the engine performs very well after that. Isn't it an option for our engines? |
http://img.tapatalk.com/d/13/03/30/daqemuhu.jpg Anyone had this problem before? Lol Sent from my myTouch_4G_Slide using Tapatalk 2 |
Sent from your couch |
Leave the 2nd ring gap as is at .013-.017 IF its at the larger end of spec if not I'll open it up as well. got to keep the 2nd ring gap larger than the 1st to prevent ring flutter. I just want a lil insurance but I think heat management and proper tune is the majority of the issue. |
Open that top ring to .015" |
Cylinder 3 held. Only 45psi and I was like fuck it I can't drive it anymore ripped the block apart and found that two days ago lol Sent from my myTouch_4G_Slide using Tapatalk 2 |
I guess it will depend on how the gaps look when I take it apart and I'll plan to open them up accordingly. I'll post it up in my new thread when the time comes and get opinions. |
Still waiting for the information from the guys.. They behave like primadonnas, so it will take some time. Meanwhile, this might be interesting to read: Analyzing a critical engine flaw in the 4b11 by TTP - evolutionm.net |
thanks |
Model/Year: Mileage: Compression Results: Cylinders /w Cracked Ringlands: Suspected Event Causing Failure and Other Info: I'll add it to OP for documenting purposes. |
hmm, all of the cylinders have low compression, what can be the cause? |
The gauge. |
No smoke pouring out the back? Sent via stocked out for a while ... |
When I let the car idle for a bit it starts smoking thought it was the turbo but it seems fine when I took it out Sent from my myTouch_4G_Slide using Tapatalk 2 |
sent from my phone usings my fingers |
Haha - it happens. I'm just curious as I have experience with them in a NA engine, but not sure of their feasibility in a boosted application. They seem to have a little more tolerance for heat due to the overlapping portions. |
So here is some forensic evidence from my old motor showing what I think was rings butting along with some from another piston that did not appear to butt. All I have is an iPhone 4 and thus the focal length is just too long to get a great close up pick but here is what I have. Exhibit A: From broken piston - cyl 3 Top ring side A http://mail.netsecurenow.com/img/ringland/1a.jpg Top ring side B http://mail.netsecurenow.com/img/ringland/1b.jpg 2nd ring side A http://mail.netsecurenow.com/img/ringland/2a.jpg 2nd ring side B lost this pic somehow Exhibit B: From undamaged piston - cyl 1 Top ring side A http://mail.netsecurenow.com/img/ringland/3a.jpg Top ring side B http://mail.netsecurenow.com/img/ringland/3b.jpg 2nd ring side A http://mail.netsecurenow.com/img/ringland/4a.jpg 2nd ring side B http://mail.netsecurenow.com/img/ringland/4b.jpg Exhibit C: Broken piston - cyl 3 this is the exhaust side, rings in original orientation as they were when removed from the motor. http://mail.netsecurenow.com/img/bui...wn/piston1.jpg ringland remnant: To me it looks like the carbon has been rubbed off at a 90* angle to the ringland where the ring gap rested. http://mail.netsecurenow.com/img/bui...wn/piston4.jpg cylinder 3 piston top http://mail.netsecurenow.com/img/bui...wn/piston3.jpg cylinder liner http://mail.netsecurenow.com/img/bui.../cylinder3.jpg I thought this was interesting in how my virgin piston rings were lined up. Exhaust side. All were the same with very little overlap between the 1st and 2nd rings. oil ring gap was on the other side 180 apart from these http://mail.netsecurenow.com/img/ringland/newpiston.jpg |
IIRC the manual calls for 90 deg separation between ring gaps. I stabbed them in a star shape separation (120 degrees) with the top compression ring gaps pointing toward the injectors. |
yeah well the japs that built this motor didn't do that and they left one of the baffles out of the pan. Like Easter Bunny said...this thing was assembled on a Friday afternoon. |
You guys may know this already, but piston rings rotate as the piston moves up and down, so the orientation is not how it was from the factory. @Dano; it's hard to tell from the picture, but is your cylinder wall scored from the broken ringland? Was the block still re-useable? |
this motor was never run and they were that close was my point. yes and yes....honed them out with a 500 grit hone. |
How much material did you end up removing from the cylinder wall to make it useable? |
Dan, the piston that blew could have been letting fuel come into contact with the ring ends after the break thus washing them clean. How do the ring ends look on the other cylinders 2 and 4? |
carbon coated like the ones pictured. its hard to tell from the pic but that ring looks freshly ground on one side...its that clean and I didn't touch it. The other side is clean on 1/3 of it at an angle as you can see. not sure how to explain that. |
| All times are GMT -7. The time now is 06:58 AM. |
