Like Tree54Likes
 Old 03-15-2013, 03:15 PM   #121
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Celestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the world
Groaned at 55 Times in 26 Posts
You did blow unless you call broken ringlands fine. Not saying your tunes were "unsafe" but you ran the OEM motor into an area where it failed. The question is - what is the common denominator?
I'm sorry but I've been through 3 motors on my 6 only one of them was blown. Blown means I can't get to work the next day. If I can get to work the motor is not blown it's just damaged. I've had the last engine consume 1L of oil for very 200km, it wasn't blown it sure was damaged though. Yet I still got to work so it is what it is, car drove fine with little issues otherwise. It was a true Mazda engine, soul of a rotary.
Vince's car with the cracked ringland made ~340whp on the dyno. I'd hardly call that blown.
What would be an example of a safe tune?
-lower boost
-lower timing
-more fuel
Is there more to it than that.
From what I have gathered working on both motors post disassembly they seemed to have suffered heat issues. Of course the exhaust side will be the one that's damaged that's the side with more heat. Hence why the oil coolers are on that side. We can argue all the small stuff but in the end the motor forged, stock, Ferrari will wear out. The key here is wear out and not blow up (re blown).
If we can run the motor to the point where the ring lands don't crack and the motor wears out I would consider that acceptable. Anyone who believes otherwise is living in a fantasy dream land.
Celestspeed3 is offline   Reply With Quote
The Following 4 Users Say Thank You to Celestspeed3 For This Useful Post:
atvfreek (03-15-2013), BlueStreak (03-15-2013), cocoanton (04-15-2013), Fobio (03-15-2013)
 Old 03-15-2013, 03:25 PM   #122
Now on to the solution:
I am more then open to opening up the ring gaps to see if that makes a difference.
There are other solutions as well.
As @Tomas; posted you can add race fuel which will decrease combustion temps and provide knock resistance so you are walking around the issue.
The Following User Says Thank You to Celestspeed3 For This Useful Post:
Tomas (03-20-2013)
 Old 03-15-2013, 03:27 PM   #123
warlord's Avatar
Posts: 756   (View Stats)
warlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the world
Groaned at 60 Times in 18 Posts
Noob here but I've never seen a thread or a post here about using the ignition per cylinder comp table in ATR. Since there are four cyl but only one knock sensor i don't know how you would isolate which cyl is knocking but maybe running x% less timing in cyl 3 on a consistent basis would curb some of the failure in that lean running failure prone cyl #3 .
2018 Audi S6 Prestige. APR Tuned 575 AWHP (current)
2017 Audi A4 APR tuned 315 AWHP (sold)
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following User Says Thank You to warlord For This Useful Post:
Tokay444 (03-15-2013)
 Old 03-15-2013, 03:43 PM   #124
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
Originally Posted by warlord View Post
Noob here but I've never seen a thread or a post here about using the ignition per cylinder comp table in ATR. Since there are four cyl but only one knock sensor i don't know how you would isolate which cyl is knocking but maybe running x% less timing in cyl on a consistent basis would curb some of the failure in that lean running failure prone cyl #3 .
If we are not able to address the situation from a general, high-level perspective that everyone can use, based on the forum wide discussions on this thread, then, from my personal perspective, we will have to start looking into the effects of tuning individual cylinders.
-- Mario Andretti --
The Following 2 Users Say Thank You to Fobio For This Useful Post:
Celestspeed3 (03-15-2013), warlord (03-15-2013)
 Old 03-15-2013, 03:43 PM   #125
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
I just added quite a bit to my last post. If we can run an 11:1AFR and make the same power we did at 12:1, IMO, there is no reason to even bother running 12:1. It just puts you closer to the edge of detonation, for no good reason.
@David@COBB; is there anyway you can allow us to log the calculated Cat Temp. that the aeroforce and dashhawk can read? We know the PID is there, but there is no way to log it. I know it is only a calculated value, but that still gives us a better idea of EGTs than nothing at all.
On my current tune, a 2nd-4th gear pull left the Cat Temp B1S1 PID at a little over 1400°.
2006 Mazdaspeed6
The Following 2 Users Say Thank You to sidekick For This Useful Post:
Celestspeed3 (03-15-2013), Fobio (03-15-2013)
 Old 03-15-2013, 03:46 PM   #126
BlueStreak's Avatar
Posts: 1,467   (View Stats)
At the end of the day, we are asking our cars to do things they were never designed to do. Things will get damaged/broken/worn/whatever. Let's not get stuck in the weeds nit picking on shit that doesn't get us where want to go. Moar fast.
'07 CWP MS3
Forged.
The Following 14 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (03-15-2013), Celestspeed3 (03-15-2013), cymen (03-15-2013), Dano (03-15-2013), Easter Bunny (03-18-2013), Fobio (03-15-2013), phate (03-15-2013), rfinkle2 (03-15-2013), SLOWHATCH (03-16-2013), snailD (05-11-2013), Standsideways (03-15-2013), TiGraySpeed6 (03-15-2013), Tokay444 (03-15-2013), uncorked11 (03-27-2013)
 Old 03-15-2013, 03:48 PM   #127
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I've played with fueling on the dyno, and so has Dustin. These engines just don't seem to care and make the same power once you rework timing a bit. I didn't believe it until I did it lol.
sidekick likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 13 Users Say Thank You to phate For This Useful Post:
BlueStreak (03-15-2013), Celestspeed3 (03-15-2013), Dano (03-15-2013), Easter Bunny (03-18-2013), Fobio (03-15-2013), Mattcinnc1 (06-07-2013), rfinkle2 (03-15-2013), sidekick (03-15-2013), SLOWHATCH (03-16-2013), snailD (05-11-2013), TiGraySpeed6 (03-15-2013), Tokay444 (03-15-2013), torquemaniac (02-09-2016)
 Old 03-15-2013, 03:50 PM   #128
sidekick's Avatar
Groans: 47
Since you actually tested this yourself, I'm curious, what do you target for your AFRs?
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
phate (03-15-2013)
 Old 03-15-2013, 03:52 PM   #129
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
I was thinking about some possibilities that might be exacerbating the wall wetting if that is in fact what is going on.
I know that many of the cars that I've worked on, and in my own car, the afr's get silly rich when injecting meth and closing the throttle plate.
Do you guys think that could be a part of, or contribute to the issue?
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
BlueStreak (03-15-2013), Celestspeed3 (03-15-2013), Fobio (03-15-2013), phate (03-15-2013), SLOWHATCH (03-16-2013)
 Old 03-15-2013, 03:52 PM   #130
Eth Fiend
phate's Avatar
11.5 is my starting point, and I will go richer from there depending on what is needed and what the intended use is.
-06 MS6
The Following 9 Users Say Thank You to phate For This Useful Post:
BlueStreak (03-15-2013), Fobio (03-15-2013), rfinkle2 (03-15-2013), sidekick (03-15-2013), snailD (05-11-2013), Standsideways (03-15-2013), TiGraySpeed6 (03-15-2013), Tokay444 (03-15-2013), torquemaniac (02-09-2016)
 Old 03-15-2013, 05:16 PM   #131
Driver
Fobio's Avatar
Groans: 44
Anyway, @Lex needs to get back in here and talk about the issues at hand, rather than succumbing to influences that detract us from building fast cars and actually driving them.
The car does all kinds of stuff when it's hot...including dumping fuel. Prior to going BT, I suffered from the smoking turbo after my first track day...it was sitting there just idling when it started smoking. I completely wrote off the situation as a lot of ppl were experiencing this. We all went head first into understanding fuel dilution, based on the fuel washing down the cyl walls. Everyone got a bnoon bolt...we upped idle...got occ's...etc.
Once I got an occ installed, I noticed that fuel dilution was a really serious issue for me. My occ smelled like gas, the engine oil smelled strongly of gas...furthermore, I'd typically have more liquid [gas + oil] when I checked oil level near a change than immediately after change. So unlike most guys who began losing oil due to low compression, I was actually getting mad wash down. Did the issue start then? idk...could be...
In short: Yes, I think it may be a contributing factor.
The Following 4 Users Say Thank You to Fobio For This Useful Post:
atvfreek (03-15-2013), rfinkle2 (03-15-2013), sidekick (03-15-2013), Standsideways (03-15-2013)
 Old 03-15-2013, 05:44 PM   #132
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
How dare you accuse my Rob of instigating you Putz.
The car dumps fuel when hot? I think you need to go back to doing what you do best.
The Following 5 Users Say Thank You to Tomas For This Useful Post:
Fobio (03-15-2013), rfinkle2 (03-15-2013), sidekick (03-15-2013), Tokay444 (03-15-2013), uncorked11 (03-27-2013)
 Old 03-15-2013, 05:51 PM   #133
Driver
Fobio's Avatar
Groans: 44
I think you and Rob know I wasn't referring to him. And since I think you're trying to be funny to lighten up the mood, I thanked you post.
When the car is hot, and when it knocks, it richens AFR's...it doesn't matter whether you're knocking 2 - 3 counts or maxed 5.9...you car will richen up. But I think you know that already...
 Old 03-15-2013, 05:58 PM   #134
sidekick's Avatar
Groans: 47
So, what about tightening up the piston to wall clearances? This would create a better ring seal correct? I suppose we will just end up back where we started though, because the piston may expand too much and actually seize in the bore. It's almost like anything we try is just going to create a new problem.
Edit: I have a better idea... Let's scrap the DISI and swap in LS1s.
2006 Mazdaspeed6
 Old 03-15-2013, 05:58 PM   #135
Bob Ross Fanclub
Tomas's Avatar
Knock is not the same as hot.
And it will only dump fuel when knocking if the table says it should irrespective of temperature. Which I am sure you know.
Standsideways (03-15-2013), Tokay444 (03-15-2013)
 Old 03-15-2013, 06:08 PM   #136
Driver
Fobio's Avatar
Groans: 44
Sure...and I'm sure you and I agree it's better that it dumps fuel when it's hot and knocking, rather than lean out those "knocking" tables too just to be hardcore?
Tomas...we're car guys who go to the track and we want to help other enjoy their cars. I respect you for that. and that's all that matters...
The Following 3 Users Say Thank You to Fobio For This Useful Post:
Celestspeed3 (03-15-2013), sidekick (03-15-2013), SLOWHATCH (07-31-2013)
 Old 03-15-2013, 06:43 PM   #137
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I have 196569kms stock motor on what @BlueStreak; and @flobio; say is an "aggressive"
tune. I'm almost never NOT WOT. I see coolant temps in the 21X-22X regions even in the winter, and I did a compression test yesterday. 180+/-2 on all 4.
I don't spray meth.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 03-15-2013, 06:44 PM   #138
BlueStreak's Avatar
I did? :s
'07 CWP MS3
Forged.
 Old 03-15-2013, 06:50 PM   #139
Tokay444's Avatar
Groans: 793
Yes. At copa cabana.
Demodded.
The Seals
 Old 03-15-2013, 06:51 PM   #140
rfinkle2's Avatar
Groans: 298
If I agree to be the closest to retarded on the IQ scale, can we attack this ring land issue?
I hereby declare I am closest to retarded and really have very little business adding my 2 cents in an engineering type thread. There!
Now... can we include everyone?
The Following 8 Users Say Thank You to rfinkle2 For This Useful Post:
aggierandy (03-17-2013), BlueStreak (03-15-2013), breakfasteatre (03-17-2013), Fobio (03-15-2013), mzr0818 (03-16-2013), sidekick (03-16-2013), snailD (05-11-2013), Tokay444 (03-15-2013)
 Old 03-15-2013, 06:53 PM   #141
Tokay444's Avatar
Groans: 793
I will not sign off on that statement.
Demodded.
The Seals
BlueStreak (03-15-2013), rfinkle2 (03-15-2013), SLOWHATCH (07-31-2013)
 Old 03-15-2013, 06:56 PM   #142
Domino81's Avatar
Posts: 5,081   (View Stats)
I might be able to one up you, Rob, and claim full-retard on this. Until last week I had no idea ring lands even existed. I just saw a piston.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
The Following 10 Users Say Thank You to Domino81 For This Useful Post:
atvfreek (03-15-2013), BlueStreak (03-15-2013), duappleganger (03-20-2013), Fobio (03-15-2013), phate (03-15-2013), rfinkle2 (03-15-2013), SLOWHATCH (07-31-2013), snailD (05-11-2013), Tokay444 (03-15-2013), Tomas (03-15-2013)
 Old 03-15-2013, 06:56 PM   #143
Driver
Fobio's Avatar
Groans: 44
Rob...I like talking cars with you.
and I used a homosexual emoticon...so can I fit in now?
can we haz car talk prease? is that better english for you motherfuckers?
 Old 03-15-2013, 06:56 PM   #144
BlueStreak's Avatar
TBH. I don't recall saying that but at the same time, I do recall thinking that at one point so I won't debate that.
At the same time, I managed to make 400/400 on pump gas (with winter win) so who knows if mine was aggressive. The car hates that tune now in this warmer weather.
I think we're deviating here tho.
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
 Old 03-15-2013, 07:04 PM   #145
Tokay444's Avatar
Groans: 793
Fair enough.
I don't think anyone will ever see 200kms on a built motor before it's "worn out", but mine has neither blow, worn out, or cracked a ring land.
I think, so far anyway, the port meth is a common denominator.
It may not be a root cause, but it has a theme so far. @phate; did the car you showed pics of run port meth?
Demodded.
The Seals
 Old 03-15-2013, 07:17 PM   #146
We need to get more data but I doubt only cars with wmi broke ringlands.
About running richer when hot, the ecu richens the mixture when bats exceed 130.
Cooling via fuel is very effective in this motor and other DI applications.
Aside from the banter we really need more data. When I looked into broken rods we had many data points for analysis. 5 failures is not enough to draw conclusions other than generic ones and we can't even see the data that is trapped in this thread. We should have a separate data and discussion thread.
The Following 8 Users Say Thank You to Lex For This Useful Post:
atvfreek (03-15-2013), BlueStreak (03-15-2013), Fobio (03-15-2013), Mauro_Penguin (03-22-2013), Nliiitend1 (03-16-2013), rfinkle2 (03-15-2013), Standsideways (03-15-2013), Tokay444 (03-15-2013)
 Old 03-15-2013, 07:20 PM   #147
rfinkle2's Avatar
Groans: 298
I know you run WMI Lex and was wondering if you see that same phenomenon of going extremely rich between shifts?
I probably am giving an impression I am opposed to WMI, but I have a kit on my car and still plan on running it.
 Old 03-15-2013, 07:59 PM   #148
BlueStreak's Avatar
Agreed. I figured this thread would be like the other database threads. It then snowballed into good discussion and other stuff.
Start up a thread, Lex. Maybe a mod can move the good points over and this one can be distilled into strictly a database /w photos and supporting info.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
Fobio (03-15-2013), Standsideways (03-15-2013)
 Old 03-15-2013, 07:59 PM   #149
Domino81's Avatar
There's now no doubt to me you're Canadian because you referred to what I call a miserable Friday in March (36 with flurries all day) as "warmer weather".
Fuck you, Dave. lol I look forward to finally driving my car in August when its warm enough to take it out of my garage.
The Following 4 Users Say Thank You to Domino81 For This Useful Post:
BlueStreak (03-15-2013), Fobio (03-15-2013), rfinkle2 (03-16-2013), Standsideways (03-15-2013)
 Old 03-15-2013, 08:13 PM   #150
BlueStreak's Avatar
Haha. Didn't even realize but its true. It is warmer out but lots of days are still below freezing.
'07 CWP MS3
Forged.
 Old 03-15-2013, 08:32 PM   #151
Let's look at it another way.
A stock motor and stock tune is designed to "save" itself at all costs. One could conclude that a stock motor with a stock tune may never have anything wrong with it provided maintenance is done.
When we start modifying things become a whole new ball game.
I want to say this, not even i-Moto has done a road course with a BT car. I know 3 Canadian locals that have. I'm sure their aren't too many people here either with a BT that do time attack. So if the problem may be entirely ours and caused directly by us.
I don't want to hear this person knows that and this person knows this. I'm getting really tired of this shit. I just want to drive my car without having to do three motor swaps like my last car. Its the internet we are all a bunch of lazy assholes with no money trying to make our slow cars fast. Face it if we could afford it we would all have Porsche GT2's or something a little more "fun" where most if not all of the BS little issues are dealt with by a team of professional engineers.
Now I don't know much about tuning, I know how things work mechanically. I know this, heat wrecks stuff. If too much combustion chamber heat is causing the cracked ring lands, too much fuel is washing down the wall causing more friction (heat) to crack the ring lands, or its detonation it is the same issue. Too much heat or heat where it shouldn't be.
Let me say this again, I don't know much about tuning. Have said that, will the difference in tuning strategy make a difference? If my tuner does high boost low timing, or low boost and high timing, richer, leaner does that affect my output and longevity? Is one more prone to detonation, given the fact that they produce the same torque and power?
At the end of the day I'm here to learn. I could care less if this ring land thing gets solved or not. I have my solution, a forged engine sitting at home collecting dust because I KNOW I WILL BREAK the stock motor sooner or later.
Lex you want more data tell me what you need and I will do it. If the motor gets damaged cares I have the other one. We might as well learn something useful in the process.
and now back to my ice cream and porn . .
breakfasteatre (03-17-2013), Fobio (03-15-2013), SLOWHATCH (07-31-2013), Standsideways (03-15-2013)
 Old 03-15-2013, 08:51 PM   #152
Ziggo's Avatar
Posts: 3,843   (View Stats)
The data is going to be discussed wherever it is. We can't sit down in a meeting room hand hash it out, all we have are threads. If the @BlueStreak; could just try to keep up and update the OP with information as it is presented we can have the data easily accessible.
Staff members can copy the info from the post to the OP ourselves provided bluestreak doesn't care.
No reason for people to get defensive. This is MSF we are interested in the answers, only time people get ridden is if they refuse to look at the evidence presented and don't contribute. If people start taking pot shots they get bounced, let the data do the talking, and we don't have enough data to point at any one thing yet. The best we can do now is come up with ideas for possible causes and look for evidence that supports the cause.
My .02, this is not something that will be avoided like bent rods. torque limiting tunes allow us to make more power while avoiding bent rods but at the end of the day, making power makes heat, and keeping the oil and coolant temperatures under control and richening up AFRs will only do so much. I think that best case we can come up with guidelines that point to a safe zone, but I don't think there is a secret that will allow this limit to be exceeded that doesn't involve changing the hardware in some way (ring gap, piston shape/material etc....) Aggressive use of the ignition BAT vs ECT tables will probably keep you safer, but will cut power in the process.
TiGraySpeed6 and Celestspeed3 like this.
Ask Me About My:
The Following 11 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (03-15-2013), BlueStreak (03-15-2013), Celestspeed3 (03-15-2013), DSIT995 (03-16-2013), Fobio (03-15-2013), Nliiitend1 (03-16-2013), phate (03-15-2013), rfinkle2 (03-16-2013), Standsideways (03-15-2013), TiGraySpeed6 (03-16-2013), Tokay444 (03-16-2013)
 Old 03-15-2013, 09:01 PM   #153
BlueStreak's Avatar
I'll update OP tomorrow /w current info and links.
Off to bed now. Early start tomorrow.
'07 CWP MS3
Forged.
The Following 6 Users Say Thank You to BlueStreak For This Useful Post:
Celestspeed3 (03-15-2013), Dano (03-16-2013), Fobio (03-15-2013), Lex (03-16-2013), rfinkle2 (03-16-2013), Ziggo (03-15-2013)
 Old 03-15-2013, 09:05 PM   #154
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
Subbing and plan on keeping an eye on my compression from now on.
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 03-15-2013, 09:12 PM   #155
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Groaned at 4 Times in 2 Posts
did you guy's check if the one with ringland failure still have the egr system ?
Because the egr system is for Nox, but by reducing Nox it also reduce combustion temp by adding inert gas in the combustion chamber.
If you remove the egr systeme, you also remove the safety it also provide.
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline   Reply With Quote
The Following 4 Users Say Thank You to mrdouble99 For This Useful Post:
atvfreek (03-15-2013), Fobio (03-15-2013), rfinkle2 (03-16-2013), Tokay444 (03-16-2013)
 Old 03-15-2013, 09:22 PM   #156
Driver
Fobio's Avatar
Groans: 44
My EGR was deleted.
I was talking to the local guys about this today on Whatsapp. It'd be nice if we can quantify it, and apparently you can, as @Celestspeed3 showed my a graph that *I THINK* shows the relationship of EGR duty cycle and heat...then again, I was also reminded that the EGR is closed during open loop operation anyway.
Which I guess is why I always tell the local guys to drive the car hard and rev it out a bit every once in awhile, even if they are not aggressive drivers...Italian tune up, they call it...
The Following User Says Thank You to Fobio For This Useful Post:
 Old 03-16-2013, 12:24 AM   #157
EGR valve is only open during cruise conditions. Not at idle and not at WOT.
@Ziggo; we did not sidestep the rod issue, we just found out that detonation killed rods and found ways to mitigate this. It's not just the "torque limiting" it's the dangerous cylinder pressures that were eliminated. This can be a similar situation. We just need to see an emerging pattern. So far temperatures seem to be a common variable and I am sure that in some cases detonation is also one.
@rfinkle2; I do notice a rich cell between shifts but this is similar for both cars using and not using WMI.
 Old 03-16-2013, 05:56 AM   #158
rfinkle2's Avatar
Groans: 298
That is a bit of tricky question but I'll take a shot @ it. The short answer is, if you want to increase the reliability of your map, you will probably have to do so @ the expense of power.
e.g. if you increase the boost, you will have to back out some timing, if you decrease boost, you will have less chance of detonating, but can probably add some timing back in (will probably have to do so to maintain the original power level).
If you increase the fuel and run a lower afr, you will cost yourself some power (especially on pump gas) and my opinion is that this car is sensitive to being too rich... and sometimes rich knock can be induced.
So, longevity can probably be increased by a margin that I'm not sure anyone knows, and probably by a power level that you might not be completely satisfied or as competitive with.
I hate cliches but a fitting one in this instance is "pay to play".
I notice a much more pronounced rich condition after throttle close using meth injection, especially if it is after a shift, but the next gear is not engaged quicky (i.e. logging situations).
Celestspeed3 likes this.
Last edited by rfinkle2; 03-16-2013 at 05:57 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Celestspeed3 (03-16-2013), SLOWHATCH (03-16-2013), TiGraySpeed6 (03-16-2013)
 Old 03-16-2013, 06:08 AM   #159
Ziggo's Avatar
The point is, we were able to tune around a hardware limitation and continue to increase the ability to make power/go faster. At one point rods were bending at frequently at 300whp. Now cld12pk is running 500whp+ on the stock rods, and there are a bunch of us running around the 400whp level with the rods still in the block, which is what seems to be precipitating this new failure mode. I don't think this is going to be avoided in a similar fashion allowing the power to continue to increase without changing something internally.
Ask Me About My:
The Following 7 Users Say Thank You to Ziggo For This Useful Post:
BlueStreak (03-16-2013), Celestspeed3 (03-16-2013), cld12pk2go (03-17-2013), Dano (03-16-2013), Fobio (03-16-2013), mzr0818 (03-16-2013), rfinkle2 (03-16-2013)
 Old 03-16-2013, 08:39 AM   #160
Well it sounds like you have a good idea for the root cause. I know I personally can't say I do based on the few pieces of evidence provided.
I don't think only 400+whp cars broke ringlands if we are to believe at least some of the other low compression K04 cases suffered this fate. On top of this not all high hp cars broke ringlands. There is always something that can be done to mitigate failure if we understand that root cause of that failure. Whether it's cooling, capping power output, or gapping rings but it's too early to tell. Let more data come forward.
Celestspeed3 (03-16-2013), Dano (03-16-2013), Fobio (03-16-2013), mzr0818 (03-16-2013), Tokay444 (03-16-2013)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-ringland-failures-140371/
Kolben gebrochen - Motor und Anbauteile - Mazda MPS Community This thread Refback 08-10-2014 09:11 AM
Kolbenschaden - Seite 2 This thread Refback 03-03-2014 12:37 AM
GGREASE'S MS6 Issues after BT install This thread Refback 09-25-2013 03:23 PM
Motor und Anbauteile - [ALLE] Kolben gebrochen This thread Refback 05-14-2013 12:11 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 04-11-2013 12:56 AM
Random MS3 Chat Thread - Page 165 This thread Refback 03-15-2013 12:35 PM
CDFP Pump Failures Dano MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 173 11-10-2015 01:31 PM
Documented failures of updated OEM VVT actuators btstarcher MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-27-2012 05:53 PM
Poll: KMD internals failures NCZ13 Mazdaspeed3/6 General Discussion 56 12-27-2011 09:52 AM
transmission failures on teh ms3 08_ms3_gt MazdaSpeed 3 - Engine, Transmission & Driveline 29 04-16-2010 10:49 PM
Page generated in 0.71933 seconds with 34 queries
