Like Tree54Likes
 Old 03-16-2013, 08:56 AM   #161
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I don't think it's necessarily power related.
Kmac made 600whp on stock block. No chucked rod. No broken ring lands. LOTS of meth (while that doesn't eliminate meth as a factor, it does put one check in the no column), and just generally driving the car as hard as situationally possible. But he's just one case I suppose.
"Exclusivity" - CP-enis
Demodded.
The Seals
SLOWHATCH (03-17-2013)
 Old 03-16-2013, 09:57 AM   #162
Posts: 9,484   (View Stats)
The point is, we were able to tune around a hardware limitation and continue to increase the ability to make power/go faster. At one point rods were bending at frequently at 300whp. Now cld12pk is running 500whp+ on the stock rods, and there are a bunch of us running around the 400whp level with the rods still in the block, which is what seems to be precipitating this new failure mode. I don't think this is going to be avoided in a similar fashion allowing the power to continue to increase without changing something internally.
Well it sounds like you have a good idea for the root cause. I know I personally can't say I do based on the few pieces of evidence provided.
I don't think only 400+whp cars broke ringlands if we are to believe at least some of the other low compression K04 cases suffered this fate. On top of this not all high hp cars broke ringlands. There is always something that can be done to mitigate failure if we understand that root cause of that failure. Whether it's cooling, capping power output, or gapping rings but it's too early to tell. Let more data come forward.
I don't think the ringland failures are directly HP related either although more HP gens more heat. If a guy at 325WHP runs his car hot enough, long enough the ring land will likely break whether due to heat fatigue, ring butting, deto or all of the above. With the progress in eliminating rod failure we are now able to keep the same motor at a higher HP level for longer. This enhances the chance of other failure modes to crop up as we are now seeing.
What I think we want to do is push that time window out by cooling the motor off not decreasing power. That would be step 1 in my book. The next step for guys wanting to stay in an OEM configuration yet optimize it might need to alter the ring gaps to attain more headroom with ring butting. Could be the rings are not doing this in every instance of a failure but it is one thing to eliminate.
long term data my indeed show the gen2 piston design as already addressed this entire subject...lol
@Lex; do you, or anyone, have any data on a gen2 piston with the oil residue/burning on the exhaust side?? didn't ckmazdaspeed3 send you his PU pistons after he threw his rod?
atvfreek (03-20-2013), BlueStreak (03-16-2013), Tokay444 (03-16-2013)
 Old 03-16-2013, 10:47 AM   #163
The one gen2 piston I have is a lot cleaner. However, through the many gen1 pistons I've seen, the buildup of oil residue and staining happens as mileage increases. So the gen2 probably just has fewer miles compared to the gen1. Gen 1 is on the left, gen2 on the right.
The Following 6 Users Say Thank You to Lex For This Useful Post:
802MS3 (03-16-2013), Dano (03-17-2013), mituc (03-16-2013), SLOWHATCH (07-31-2013), snailD (05-11-2013), Tokay444 (03-16-2013)
 Old 03-17-2013, 11:49 AM   #164
yes more mileage and data needed on the PU pistons.
 Old 03-17-2013, 06:55 PM   #165
BlueStreak's Avatar
Posts: 1,467   (View Stats)
OP updated. Some info paraphrased to keep it short.
@taf0422;. Any news?
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
phate (03-17-2013), Ziggo (03-17-2013)
 Old 03-17-2013, 07:04 PM   #166
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
its a ton of labour hours even if I have guys helping me, and I wouldnt want to pull anyone away from the fun during the dyno runs, but would it be worthwhile to this discussion if we pulled my head and pulled the rods and pistons in april? If so, ill grab the one time use parts so we can put it back together.
For reference: I have a poo, now with 38k kms (23k miles) with low compression in cylinder 4. Me and my nader brothers did a leak down test, 20% past the rings.
Ran 4 time attack events, saw oil temps hit 260 after about 5 laps, did 5-15 laps at 260.
Off the shelf stage 2 map + maf cal. Dynoed at 270/310 ish
one event I blew couplers off multiple times due to faulty hose clamp
breakfasteatre is offline   Reply With Quote
The Following User Says Thank You to breakfasteatre For This Useful Post:
Celestspeed3 (03-17-2013)
 Old 03-17-2013, 07:45 PM   #167
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I wish. I'm still waiting to hear from Pablo. I will try to find out from him tomorrow. I will let you guys know tomorrow night if I get anything. I'm just as curious as you guys are.
@SPEED6 KILLAH;
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 2 Users Say Thank You to taf0422 For This Useful Post:
BlueStreak (03-17-2013), mzr0818 (03-17-2013)
 Old 03-17-2013, 08:06 PM   #168
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Great thread...
Anyone have a compression tester recommendation (and a good procedure)? I should probably check mine...
 Old 03-17-2013, 08:17 PM   #169
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Great thread...
I bought the basic one from autozone. I forget how much, it was an impulse buy. Think around $30. Seems fine, produces consistent results.
As for the procedure, get car up to temp. Pull one spark plug at a time, attatch comp tester, pin accel pedal while cranking a few seconds, read pressure ASAP. Repeat for each cylinder.
'08 CWP MS3 w/ T3 3071r
 Old 03-17-2013, 08:26 PM   #170
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Todd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the worldTodd98SE is the leader of the world
Great thread...
OTC makes good testers. Bought mine on Amazon.
I pull all the plugs and crank for 10 revolutions on a warmed up motor.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following 4 Users Say Thank You to Todd98SE For This Useful Post:
daafisch (03-18-2013), Micha (03-18-2013), Nliiitend1 (03-17-2013), rfinkle2 (03-18-2013)
 Old 03-17-2013, 08:30 PM   #171
Pull all plugs so the starter has an easier time turning the motor over.
BlueStreak (03-18-2013), daafisch (03-18-2013), Micha (03-18-2013), Nliiitend1 (03-17-2013), superskaterxes (03-18-2013), Todd98SE (03-17-2013)
 Old 03-18-2013, 01:05 PM   #172
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
I have a question for the people who had Ringland Failures how much boost are you guys running and what was you coolant temp at?
SPEED6 KILLAH is offline   Reply With Quote
The Following 3 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
atvfreek (03-18-2013), Easter Bunny (03-19-2013), rfinkle2 (03-18-2013)
 Old 03-18-2013, 01:09 PM   #173
BlueStreak's Avatar
At the time, mine was 20-21 PSI on a GT3071. Coolant temps were in the 230F range coming off the road course on a 35*C day.
'07 CWP MS3
Forged.
The Following 6 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (03-18-2013), Dano (03-18-2013), Easter Bunny (03-19-2013), phate (03-18-2013), rfinkle2 (03-18-2013), superskaterxes (03-18-2013)
 Old 03-18-2013, 01:22 PM   #174
mzr0818's Avatar
mzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the world
Groans: 221
Mine was 22psi/ coolant temps 225 range after coming off the track 60degree day
I was ok until 4500 rpm and then Jeff Raped my face
EMWNM 2013
Beating Black women one 5.0 at a time...
2008 mazdaspeed 3 true red
Tuned by Nishan
, 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.
Build in progress. Track whore in the making.
mzr0818 is offline   Reply With Quote
The Following User Says Thank You to mzr0818 For This Useful Post:
 Old 03-18-2013, 01:23 PM   #175
I had just moved up from a 21-22PSI tune to a 26 PSI tune. The timeframe was around August last year and AMB temps were ~100*f. I don't know exactly when mine went nor the exact ECT but I routinely saw 217-220* last summer. My tstat must be broken b/c I see 217 now after a 10-15 minute drive around the city. AMP temps in the 40*f
 Old 03-18-2013, 01:24 PM   #176
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Just did the same thing with the same tester this weekend. $60.00 for what seems to be a really good piece of equipment.
http://www.amazon.com/gp/product/B004K2FSXI/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1http://www.amazon.com/gp/product/B004K2FSXI/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I cranked mine 10x's as well.
I was within 5 psi on all cilynders, all just above 180 psi.
Great thread...
Just for people who pass through the thread:
1) warm engine to operating temp
2) Pull relay labeled circuit
3) pull all 4 plugs
4) insert compression tester
5) optional : hold gas pedal to floor while testing
6) Crank all cylinders between 5-10 times each
7) AFAIK, you want all 4 cilynders to be within roughly 5% of eachother, in our case, somewhere in the neighborhood of 180-185psi.
The Following 12 Users Say Thank You to rfinkle2 For This Useful Post:
alphasaur (03-18-2013), atvfreek (03-20-2013), BlueStreak (03-18-2013), charlesfist (03-20-2013), cld12pk2go (03-18-2013), IMASA (03-18-2013), magicka (03-18-2013), phate (03-18-2013), SPEED6 KILLAH (03-18-2013), TiGraySpeed6 (03-18-2013), Todd98SE (03-18-2013), Tokay444 (03-19-2013)
 Old 03-18-2013, 08:04 PM   #177
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
Celestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the world
Groaned at 55 Times in 26 Posts
If you pull all the plugs and do the test sometimes the values come out lower. I've had this happen with my leakdown tester. I'm not sure why, just something I've noticed. So I just pull one plug at a time now.
Celestspeed3 is offline   Reply With Quote
 Old 03-19-2013, 05:29 AM   #178
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
I have never done it without pulling all of the plugs.
Sent via smokey turbo.
Pickles Tune in progress
The Following 3 Users Say Thank You to himurax13 For This Useful Post:
Celestspeed3 (03-19-2013), rfinkle2 (03-20-2013), taf0422 (03-19-2013)
 Old 03-19-2013, 05:39 AM   #179
Just something I've noticed with my leakdown tester.
When I did @breakfasteatre; motor I pulled all the plugs and the I didn't get proper values.
 Old 03-19-2013, 06:10 AM   #180
himurax13's Avatar
Groans: 255
Are you talking about doing a compression test or a leakdown test? In either case, you should pull all of the plugs. Maybe you need a new guage. My POS harbor freight setup reads 10 psi lower than other guages.
The Following 4 Users Say Thank You to himurax13 For This Useful Post:
Celestspeed3 (03-19-2013), Micha (03-20-2013), rfinkle2 (03-20-2013), TiGraySpeed6 (03-19-2013)
 Old 03-20-2013, 09:17 AM   #181
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
is it possible to diagnose ring/ringlands without pulling motor apart? something like like a camera or something?
mrQQ is offline   Reply With Quote
 Old 03-20-2013, 09:23 AM   #182
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world2.0t03speed is the leader of the world
Default Re: MZR DISI Ringland Failures
You can't. look at the pictures they crack on the sides of the pistons in between the rings. Compression/leakdown test is your best chance of diagnosis.
Edit: also have you ever seen a piston with rings seated in a bore? You can't really see the top ring at all.
heres a picture i borrowed from another thread. now imagine looking in there with a tiny camera trying to diagnose a cracked ringland with everything black and covered in carbon.
2.0t03speed is offline   Reply With Quote
The Following 6 Users Say Thank You to 2.0t03speed For This Useful Post:
BlueStreak (03-20-2013), Celestspeed3 (03-20-2013), charlesfist (03-20-2013), Easter Bunny (03-25-2013), phate (03-20-2013), Tokay444 (03-20-2013)
 Old 03-20-2013, 09:27 AM   #183
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
A leakdown test will tell you what you need.
-06 MS6
-Corn fed 07 MS3 - Sold
2.0t03speed (03-20-2013), BlueStreak (03-20-2013), Celestspeed3 (03-20-2013), charlesfist (03-20-2013), Dano (03-20-2013), rfinkle2 (03-20-2013), Tokay444 (03-20-2013)
 Old 03-20-2013, 10:03 AM   #184
Tokay444's Avatar
Groans: 793
I just did a leak down.
It told me I need peepee touch.
Demodded.
The Seals
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
Easter Bunny (03-25-2013), Micha (06-09-2013), rfinkle2 (03-20-2013), silvapain (03-27-2013)
 Old 03-20-2013, 10:18 AM   #185
A high leakdown percentage 15-20%+ tells you the motor needs something done internally and needs to come apart anyways.
2.0t03speed (03-20-2013), atvfreek (03-20-2013), BlueStreak (03-20-2013), Celestspeed3 (03-20-2013), charlesfist (03-20-2013), Easter Bunny (03-25-2013)
 Old 03-20-2013, 10:48 AM   #186
mrQQ's Avatar
got it.
edit: is high leak a definite for a crack? can it, in theory, be anything else (if it's leaking past the cylinder, not the valves)?
 Old 03-20-2013, 10:50 AM   #187
Tokay444's Avatar
Groans: 793
My leakdown tester has 40% at the far end of the "low" scale.
Demodded.
The Seals
 Old 03-20-2013, 10:52 AM   #188
atvfreek's Avatar
Posts: 7,787   (View Stats)
got it.
When you have high percentage of leak down, you have to listen for the air, if you hear it out the intake, it would be intake valves, exhaust-exhaust valve, out the oil fill cap then rings/ring land etc.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 8 Users Say Thank You to atvfreek For This Useful Post:
2.0t03speed (03-20-2013), Amnesiac (03-20-2013), BlueStreak (03-20-2013), charlesfist (03-20-2013), Dano (03-20-2013), Easter Bunny (03-25-2013), Lex (03-20-2013), snailD (05-11-2013)
 Old 03-20-2013, 10:56 AM   #189
Tokay444's Avatar
Groans: 793
Demodded.
The Seals
 Old 03-20-2013, 11:13 AM   #190
but that's for normal cars not racecars...racecar rebuild occurs around 20%
The Following 10 Users Say Thank You to Dano For This Useful Post:
atvfreek (03-20-2013), BlueStreak (03-20-2013), Celestspeed3 (03-20-2013), charlesfist (03-20-2013), Easter Bunny (03-25-2013), Micha (06-09-2013), silvapain (03-27-2013), taf0422 (03-20-2013), TiGraySpeed6 (03-20-2013), Tokay444 (03-20-2013)
 Old 03-20-2013, 11:21 AM   #191
atvfreek's Avatar
I've never seen a spec for 40% leakdown. Is that from the 80's? lol
20% leakdown is the max spec I have always seen.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
2.0t03speed (03-20-2013), BlueStreak (03-20-2013), Micha (06-09-2013), taf0422 (03-20-2013), Tokay444 (03-20-2013)
 Old 03-20-2013, 12:44 PM   #192
Tokay444's Avatar
Groans: 793
Fuck!
That was my anal seepage gauge.
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
Dano (03-20-2013), Domino81 (03-20-2013), Easter Bunny (03-25-2013), Micha (06-09-2013), silvapain (03-27-2013)
 Old 03-20-2013, 01:30 PM   #193
haha well there's the answer then.
If you are leaking 40% its time for surgery.
atvfreek (03-20-2013), Easter Bunny (03-25-2013)
 Old 03-20-2013, 01:40 PM   #194
mrQQ's Avatar
yes, but does it have to be a crack? can it be something else?
 Old 03-20-2013, 01:43 PM   #195
It depends where the air is coming from. It could be cracked ringlands,valve seals,blown rings, etc.
The Following User Says Thank You to 2.0t03speed For This Useful Post:
 Old 03-20-2013, 01:53 PM   #196
rfinkle2's Avatar
Groans: 298
If the injector seals are leaking, could you get a shit compression / leakdown reading as well?
 Old 03-20-2013, 02:05 PM   #197
That's a good question. I guess it is possible, but iirc @Rokusek; did a comp test a few hundred miles into his built motor and compression was the same across the board. At the time we didn't know it but he had 2 blown injector seals.
Rokusek (03-21-2013)
 Old 03-20-2013, 02:31 PM   #198
atvfreek's Avatar
Yes it can be something else, that's why I through in the etc. lol... Really the leakdown is confirming there is something wrong internally and it gives you an idea of where to look... Basically high percentage of leakdown means you need to open her up and see what has failed.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following User Says Thank You to atvfreek For This Useful Post:
 Old 03-20-2013, 02:37 PM   #199
atvfreek's Avatar
Unless the injector seal is totally fucked, the leakdown will likely be pretty minimal. Say 3 cylinders have 180psi for compression, then the 4th has 165psi, that is only about 8-9% difference between cylinders, so leakdown may only be 5-10% more than the others. One thing that will throw it off, is the compressor won't be able to put 180psi in the combustion chamber so the difference in leakdown may be even less.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
rfinkle2 (03-20-2013), taf0422 (03-20-2013), TiGraySpeed6 (03-20-2013)
 Old 03-20-2013, 04:29 PM   #200
taf0422's Avatar
Groans: 192
Default MZR DISI Ringland Failures
Still waiting for a diagnosis from pablo guys. Was supposed to get some pictures yesterday of her but nothing yet so as soon as I get some goodies of the possible failure I will update!!
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 3 Users Say Thank You to taf0422 For This Useful Post:
BlueStreak (03-20-2013), Dano (03-20-2013), rfinkle2 (03-20-2013)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-ringland-failures-140371/
Kolben gebrochen - Motor und Anbauteile - Mazda MPS Community This thread Refback 08-10-2014 09:11 AM
Kolbenschaden - Seite 2 This thread Refback 03-03-2014 12:37 AM
GGREASE'S MS6 Issues after BT install This thread Refback 09-25-2013 03:23 PM
Motor und Anbauteile - [ALLE] Kolben gebrochen This thread Refback 05-14-2013 12:11 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 04-11-2013 12:56 AM
Random MS3 Chat Thread - Page 165 This thread Refback 03-15-2013 12:35 PM
CDFP Pump Failures Dano MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 173 11-10-2015 01:31 PM
Documented failures of updated OEM VVT actuators btstarcher MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-27-2012 05:53 PM
Poll: KMD internals failures NCZ13 Mazdaspeed3/6 General Discussion 56 12-27-2011 09:52 AM
transmission failures on teh ms3 08_ms3_gt MazdaSpeed 3 - Engine, Transmission & Driveline 29 04-16-2010 10:49 PM
Page generated in 0.62739 seconds with 38 queries
