Like Tree54Likes
 Old 03-27-2013, 11:54 AM   #241
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
@sidekick;
FWIW I had oil pooling in all my IC piping when I lost my ringland. Your pics def look like more than typical blow by on a healthy motor.
My saga and pics can be found here
How bad is this-Oil everywhere
Well fuck. At this point, everything points to a cracked or broken ringland. The clutch pedal doesn't fight my foot, although there is a small vibration when pressing on it slightly in gear. I guess it's time to start saving for an engine build... Thanks for the link @Dano;
Edit: @Dano; do you have pictures of your spark plugs?
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
Micha (03-27-2013)
 Old 03-28-2013, 03:39 PM   #242
sidekick's Avatar
Groans: 47
I found this quote from NASIOC in a thread that @Dano; posted:
It's understood that more ignition timing means you start the combustion process earlier than with less timing. Earlier means the rod will be pointed towards the cylinder wall more than more towards the head (verticle). The sooner you start building cylinder pressure the higher the force being applied to the rod with more angle. More angle means it will be pushing the piston harder against the cylinder wall. There are other less thab ideal effects to the crank and the rod itself.
How does this relate to cylinder pressure? More timing means more cylinder pressure for longer. You are exposing the engine to heat for a longer period. More ignition timing means higher in cylinder temps and lower EGTs. Yes lower EGTs mean higher in cylinder temps not the opposite. A high EGT just means you have more burning happening after the exhaust valves open.
So how do we end up at the same power level with less ignition timing as it relates to cylinder pressure? It's simple you burn it faster and therefore you can start the combustion process later. Better rod angle, less force being wasted slamming the piston against the cylinder wall, and you're compressing the combustion process so high cylinder pressures are reached for shorter periods. Pretty common sense stuff right?
There is a place for colder plugs but not as it relates to the original post. My race car puts out over 600 whp and it's run at wide open throttle anywhere from 10 to 20 minutes and I use a 6 range plug with no signs of overheating. Why is this? Water/meth injection slows down the combustion process, the race fuel I use also has a requirement for more timing, so a hotter plug works best.
In my eyes, albeit in a different engine, this is part of our problem. As combustion starts, I believe our pistons are doing exactly what he is talking about. The ringlands are cracking on the exhaust side, which matches up perfectly with his description of what is happening as you increase spark advance. The exhaust side of the piston is being forced against the cylinder wall and the excess pressure and friction causes it to crack.
Is this a viable explanation or am I talking out of my ass?
2006 Mazdaspeed6
The Following 3 Users Say Thank You to sidekick For This Useful Post:
Mauro_Penguin (03-29-2013), SLOWHATCH (03-30-2013), Tokay444 (03-28-2013)
 Old 03-28-2013, 03:52 PM   #243
Ziggo's Avatar
Posts: 3,843   (View Stats)
Side loading goes up as the piston moves down the cylinder. Right at the top there is nearly zero side loading.
Zigatapatalka
Ask Me About My:
Easter Bunny (03-30-2013), phate (03-28-2013)
 Old 03-28-2013, 04:05 PM   #244
sidekick's Avatar
Groans: 47
Zigatapatalka
I understand that, but after the spark plug fires, the piston is moving down... Can you elaborate? Maybe me saying "as combustion starts..." is causing some confusion. I'm not saying this is the ONLY problem, but rather a piece of the puzzle. Many other things that come with over-advanced timing, can also cause problems with ringlands. Like the excessive in cylinder temps and higher pressures for longer periods of time. The OEM pistons were not made with any of these things in mind.
2006 Mazdaspeed6
 Old 03-28-2013, 04:10 PM   #245
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Nice find.
"Exclusivity" - CP-enis
Demodded.
The Seals
sidekick (03-28-2013)
 Old 03-28-2013, 04:17 PM   #246
sidekick's Avatar
Groans: 47
He also talked a little about colder plugs. Maybe there is something there as well. A lot of people here are running colder plugs, but is it REALLY necessary? He claims he is only running step colder plugs on a 600AWHP track car.
2006 Mazdaspeed6
 Old 03-28-2013, 04:21 PM   #247
Pressure against the cylinder wall is unlikely to cause the piston to crack since the force is applied over a relatively large area. The most common way ringlands crack is through detonation. Improper gap will also do it if the ring ends butt against each other but you have to consider expansion rates and if this is the likely culprit.
We know detonation is common on heatsoaked vehicles and it takes out rods. It could be that it takes out ringlands as well over time.
Mauro_Penguin (03-29-2013), phate (03-28-2013), rfinkle2 (04-03-2013)
 Old 03-28-2013, 05:10 PM   #248
sidekick's Avatar
Groans: 47
I completely agree in terms of detonation. That is a well known cause for ringland issues, but that stills begs the question, are we over-advancing timing at any point in the RPM range? I think we should be looking more closely at the RPM range where we are making peak torque, rather than at redline and peak timing values.
2006 Mazdaspeed6
 Old 03-30-2013, 05:04 AM   #249
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
I know some EvoX enthusiasts here in Russia had the same ringland failure issue.. Now they increase the top ring gap slightly and the engine performs very well after that.
Isn't it an option for our engines?
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
The Following 3 Users Say Thank You to paveltol For This Useful Post:
Easter Bunny (03-30-2013), Tokay444 (03-30-2013), Tomas (04-06-2013)
 Old 03-30-2013, 06:20 AM   #250
ciezczak1's Avatar
Posts: 416   (View Stats)
ciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the worldciezczak1 is the leader of the world
Groaned at 4 Times in 2 Posts
Anyone had this problem before? Lol
Sent from my myTouch_4G_Slide using Tapatalk 2
GT3076/ catless dp/ FMIC/ 3.5" CP-E Intake/ 3" Exhaust/autotech internals/ built block/ 3-port/denso itv22/ 6th-port
ciezczak1 is offline   Reply With Quote
The Following 2 Users Say Thank You to ciezczak1 For This Useful Post:
atvfreek (03-30-2013), Dano (03-30-2013)
 Old 03-30-2013, 06:34 AM   #251
Tokay444's Avatar
Groans: 793
That's what Dano plans to do on his virgin motor.
Demodded.
The Seals
Dano (03-30-2013), rfinkle2 (04-03-2013), SLOWHATCH (03-30-2013)
 Old 03-30-2013, 07:22 AM   #252
atvfreek's Avatar
Posts: 7,787   (View Stats)
Is that out of your car? If so what cylinder
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 03-30-2013, 09:12 AM   #253
Posts: 9,484   (View Stats)
do you know how much they are opening up the gap by?
my current plan is to open up the top OEM gap which is .0056-.0094 and take it to .011 or maybe .012.
Leave the 2nd ring gap as is at .013-.017 IF its at the larger end of spec if not I'll open it up as well. got to keep the 2nd ring gap larger than the 1st to prevent ring flutter.
I just want a lil insurance but I think heat management and proper tune is the majority of the issue.
Nliiitend1 (03-31-2013), phate (03-30-2013), rfinkle2 (04-03-2013)
 Old 03-30-2013, 09:19 AM   #254
Micha's Avatar
Posts: 3,436   (View Stats)
Micha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the world
Groans: 261
Groaned at 73 Times in 60 Posts
I have. It happened on my motor on cylinders 1,2 and 3.
I am slow again.
2017 Lightning Blue SuperCab Raptor ordered 1/3/17. Built 2/3/17. Delivered 2/8/17.
I modded it a little.
Micha is offline   Reply With Quote
 Old 03-30-2013, 09:30 AM   #255
Tokay444's Avatar
Groans: 793
Open that top ring to .015"
Demodded.
The Seals
Dano (03-30-2013), Micha (03-30-2013)
 Old 03-30-2013, 09:30 AM   #256
ciezczak1's Avatar
Cylinder 3 held. Only 45psi and I was like fuck it I can't drive it anymore ripped the block apart and found that two days ago lol
The Following 6 Users Say Thank You to ciezczak1 For This Useful Post:
atvfreek (03-30-2013), BlueStreak (03-30-2013), Dano (03-30-2013), Micha (03-30-2013), mzr0818 (03-30-2013), phate (03-30-2013)
 Old 03-30-2013, 09:37 AM   #257
yes I had considered going that big [ getting closer to aftermarket gaps] but that would precipitate the need to open up the 2nd gap as well. I really want to touch as little as possible. IDK
I guess it will depend on how the gaps look when I take it apart and I'll plan to open them up accordingly.
I'll post it up in my new thread when the time comes and get opinions.
The Following 5 Users Say Thank You to Dano For This Useful Post:
cld12pk2go (03-30-2013), Micha (03-30-2013), Nliiitend1 (03-31-2013), phate (03-30-2013), SLOWHATCH (03-30-2013)
 Old 03-30-2013, 10:59 AM   #258
paveltol's Avatar
I'll find this out and will write back here.
The Following 4 Users Say Thank You to paveltol For This Useful Post:
Dano (03-30-2013), Nliiitend1 (03-31-2013), phate (03-30-2013), Tokay444 (03-30-2013)
 Old 04-03-2013, 08:46 AM   #259
paveltol's Avatar
Still waiting for the information from the guys.. They behave like primadonnas, so it will take some time.
Meanwhile, this might be interesting to read: Analyzing a critical engine flaw in the 4b11 by TTP - evolutionm.net
The Following 6 Users Say Thank You to paveltol For This Useful Post:
BlueStreak (04-03-2013), charlesfist (04-03-2013), Dano (04-03-2013), rfinkle2 (04-03-2013), spals (04-03-2013), Tokay444 (04-03-2013)
 Old 04-03-2013, 09:44 AM   #260
looks like their top ring gap is .007 as well as ours and its too tight for the heat generated by more HP. Great information to know. I am thinking of going to .012 for my top ring gap and if the 2nd is already at max spec of .017 it will stay as is. These gaps are subject to change depending on what the gaps in the new motor measure out to as is.
thanks
phate (04-03-2013)
 Old 04-03-2013, 09:49 AM   #261
BlueStreak's Avatar
Posts: 1,467   (View Stats)
Can you give me the following info?
Model/Year:
Mileage:
Compression Results:
Cylinders /w Cracked Ringlands:
Suspected Event Causing Failure and Other Info:
I'll add it to OP for documenting purposes.
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
 Old 04-03-2013, 10:05 AM   #262
ciezczak1's Avatar
Model/Year: mazdaspeed 6
Mileage:91xxx
Compression Results:145 120 45 140
Cylinders /w Cracked Ringlands: cylinder 3
Suspected Event Causing Failure and Other Info: extremely bad gas mileage previous owner took shit care of it.
The Following User Says Thank You to ciezczak1 For This Useful Post:
 Old 04-03-2013, 10:49 AM   #263
So did the failure happen before you bought the vehicle? Was it stock when you got it?
 Old 04-03-2013, 01:53 PM   #264
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
hmm, all of the cylinders have low compression, what can be the cause?
mrQQ is offline   Reply With Quote
 Old 04-03-2013, 03:34 PM   #265
Tokay444's Avatar
Groans: 793
The gauge.
Demodded.
The Seals
Easter Bunny (04-06-2013), himurax13 (04-03-2013), Roddiy (04-03-2013)
 Old 04-03-2013, 08:22 PM   #266
ciezczak1's Avatar
couldn't tell really until 2 weeks after we got it running that the fuel mileage sucked and random knock when partial throttle, so i finally decided to do a compression test and those were the numbers. car had intake and full 3'' exhuast and trans was fucked when we got it
 Old 04-03-2013, 08:40 PM   #267
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
No smoke pouring out the back?
Sent via stocked out for a while ...
Pickles Tune in progress
 Old 04-03-2013, 08:55 PM   #268
ciezczak1's Avatar
When I let the car idle for a bit it starts smoking thought it was the turbo but it seems fine when I took it out
 Old 04-03-2013, 09:04 PM   #269
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Any reason not to run gap less rings?
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
 Old 04-04-2013, 05:58 AM   #270
DSIT995's Avatar
Posts: 1,768   (View Stats)
DSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the worldDSIT995 is the leader of the world
Edited. . Reading fail
sent from my phone usings my fingers
08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock!
99 Miata NB - Stock for now
Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors
DSIT995 is offline   Reply With Quote
 Old 04-04-2013, 10:36 AM   #271
Haha - it happens. I'm just curious as I have experience with them in a NA engine, but not sure of their feasibility in a boosted application. They seem to have a little more tolerance for heat due to the overlapping portions.
 Old 04-06-2013, 09:08 AM   #272
So here is some forensic evidence from my old motor showing what I think was rings butting along with some from another piston that did not appear to butt.
All I have is an iPhone 4 and thus the focal length is just too long to get a great close up pick but here is what I have.
Exhibit A: From broken piston - cyl 3
Top ring side A
Top ring side B
2nd ring side A
2nd ring side B
lost this pic somehow
Exhibit B: From undamaged piston - cyl 1
Top ring side A
Top ring side B
2nd ring side A
2nd ring side B
Exhibit C: Broken piston - cyl 3
this is the exhaust side, rings in original orientation as they were when removed from the motor.
ringland remnant: To me it looks like the carbon has been rubbed off at a 90* angle to the ringland where the ring gap rested.
cylinder 3 piston top
cylinder liner
I thought this was interesting in how my virgin piston rings were lined up. Exhaust side. All were the same with very little overlap between the 1st and 2nd rings.
oil ring gap was on the other side 180 apart from these
The Following 12 Users Say Thank You to Dano For This Useful Post:
06Speed6 (04-06-2013), atvfreek (04-06-2013), BlueStreak (04-06-2013), btstarcher (04-06-2013), cld12pk2go (04-06-2013), Easter Bunny (04-06-2013), Lex (04-06-2013), magicka (04-06-2013), Micha (04-07-2013), mzr0818 (04-06-2013), phate (04-06-2013), Tomas (04-06-2013)
 Old 04-06-2013, 12:34 PM   #273
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
IIRC the manual calls for 90 deg separation between ring gaps.
I stabbed them in a star shape separation (120 degrees) with the top compression ring gaps pointing toward the injectors.
 Old 04-06-2013, 12:37 PM   #274
yeah well the japs that built this motor didn't do that and they left one of the baffles out of the pan. Like Easter Bunny said...this thing was assembled on a Friday afternoon.
06Speed6 (04-06-2013), Easter Bunny (04-06-2013)
 Old 04-06-2013, 12:58 PM   #275
sidekick's Avatar
Groans: 47
You guys may know this already, but piston rings rotate as the piston moves up and down, so the orientation is not how it was from the factory.
@Dano; it's hard to tell from the picture, but is your cylinder wall scored from the broken ringland? Was the block still re-useable?
2006 Mazdaspeed6
 Old 04-06-2013, 01:03 PM   #276
this motor was never run and they were that close was my point.
yes and yes....honed them out with a 500 grit hone.
 Old 04-06-2013, 01:10 PM   #277
sidekick's Avatar
Groans: 47
Oh, I thought these were the rings from your engine with the cracked ringland. Lol. My bad.
How much material did you end up removing from the cylinder wall to make it useable?
2006 Mazdaspeed6
 Old 04-06-2013, 01:13 PM   #278
Dan, the piston that blew could have been letting fuel come into contact with the ring ends after the break thus washing them clean. How do the ring ends look on the other cylinders 2 and 4?
 Old 04-06-2013, 01:15 PM   #279
carbon coated like the ones pictured.
its hard to tell from the pic but that ring looks freshly ground on one side...its that clean and I didn't touch it. The other side is clean on 1/3 of it at an angle as you can see. not sure how to explain that.
 Old 04-06-2013, 01:29 PM   #280
I know it's asking for more work, but can you measure the failed ring end gap? I'd say it's probably safe to even do it in the new motor.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-ringland-failures-140371/
Kolben gebrochen - Motor und Anbauteile - Mazda MPS Community This thread Refback 08-10-2014 09:11 AM
Kolbenschaden - Seite 2 This thread Refback 03-03-2014 12:37 AM
GGREASE'S MS6 Issues after BT install This thread Refback 09-25-2013 03:23 PM
Motor und Anbauteile - [ALLE] Kolben gebrochen This thread Refback 05-14-2013 12:11 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 04-11-2013 12:56 AM
Random MS3 Chat Thread - Page 165 This thread Refback 03-15-2013 12:35 PM
CDFP Pump Failures Dano MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 173 11-10-2015 01:31 PM
Documented failures of updated OEM VVT actuators btstarcher MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-27-2012 05:53 PM
Poll: KMD internals failures NCZ13 Mazdaspeed3/6 General Discussion 56 12-27-2011 09:52 AM
transmission failures on teh ms3 08_ms3_gt MazdaSpeed 3 - Engine, Transmission & Driveline 29 04-16-2010 10:49 PM
Page generated in 0.63561 seconds with 35 queries
