![]() | | #281 | ![]() |
| Not Ranked : 0 score
![]() | | #282 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
Regular 1st ring, gapless 2nd ring, regular oil control ring pack. Its crossed my mind a few times already.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Dano (04-07-2013) |
![]() | | #283 | ![]() |
| Not Ranked : 0 score hum...I would think you want a gapless 1st ring so it can prevent the majority of combustion gasses from getting past and then run a regular second ring so if they do it will allow them to escape and prevent ring flutter. I would think a better seal on the 2nd ring than the first is no bueno. I briefly read Total Seal's page on their rings but that was my take on it. TechPage I wonder if @SPEED6 KILLAH; has any experience/thoughts on these type of rings? or anyone else for that matter.
![]() | | #284 | ![]() |
I can send you the ring in question along with some others...you just have to see how clean the one side is. I'm telling you it looks polished ![]() although I suppose it could have bee polished after the failure with all the moving parts in that area with the land broken. chicken <> egg lol
![]() | | #285 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | rfinkle2 (04-29-2013) |
![]() | | #286 | ![]() |
![]() ![]() Join Date: Apr 2011 Location: Winston-Salem, NC
Rep Power: 3104 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,046
Groans: 221
__________________ EMWNM 2013 Beating Black women one 5.0 at a time... ![]() 2008 mazdaspeed 3 true red Tuned by Nishan , 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.![]() Build in progress. Track whore in the making. |
![]() | | #287 | ![]() |
![]() Join Date: Sep 2011 Location: virginia, portsmouth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 164
__________________ 2008 MS3 gt mica black EL NATOR DE Virginia/Florida Update: getting that Purple drank in my tank. build block, pnp everything, tr825 core, meth and lots of it. 554whp/546wtq @ 30psi. another build? maybe soon.. b/c race cars need more attention than women. . ![]() ![]() adlpb: ~Fast cars are for straight lines. Corners are for fast drivers.~ #CATBACKEXHAUST | |
| The Following User Says Thank You to tastysi2004 For This Useful Post: | mzr0818 (04-15-2013) |
![]() | | #288 | ![]() |
![]() Join Date: May 2011 Location: Virginia Beach, Virginia
Rep Power: 3957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,694
| Not Ranked : 0 score DAMNIT!!! I didnt want to be brought in here, i just wanted to lurk and read as much as possible lol To late now... Idk how soon thats going to be it all depends on Mauro and how long he can be down for, and getting the block to the shop ASAP! It can be ripped apart in a day easy, but the down time is what he doesnt want so we will have to buy what i know he i will need for now, then once we pull the motor and get the block to the shop then we will know more. Ok so @tastysi2004; had been having some issues with smoking, at first we thought it was the turbo, I told him to put an OCC on the car and that would help fix the smoking problem. He put the OCC on and all the white smoke went away. (He already had the Bnoon Bolt) Well that allowed us to see the Black smoke that was being masked by the white, as well as the smell. Absolutely horrid burnt oil smell. When he let off after a hard WOT pull the car would just pour black smoke out the back for a good while. He was having power loss down low. I told him several times we needed to do a compression check and see what the hell is going on with his car. Because something was obviously wrong with it. So Sunday morning in MD for MNM, we did a warm compression check and found 160/160/160/130 (1,2,3,4). #4 's plug was a oily. and he has some serious knocking coming from right in between #3 and #4 . (used the screw driver method to hear for knocking) Also checked plug gap @mzr0818; do you remember what that was?) dont remember as i was more concerned with the compression test. So he drove back to VA Beach from Bethesda MD and said the car was great the entire drive back to hampton roads but right as he was getting home, the car started Knocking hardcore. (what ever hardcore is idk). As soon as we can get into it and tear it down I will be sure to get some good detailed pics to post up here. /end failure report
__________________ I'm not back... But help me find SOMETHING Daily: Evelyn (Eve), 04 4Motion 6Speed VW Passat W8 Sold to @yourstruly; : Isabella (Izzy), 06 MS6 GT with Navigation #1271 Sold to @downmented; : Audrey, 95 Miata Totaled: Vivian (Viv), 07 MS3 bolted and built, brutally murdered by a texting driver ![]() | |
| The Following 5 Users Say Thank You to Rokusek For This Useful Post: | BlueStreak (04-16-2013), breakfasteatre (04-16-2013), mzr0818 (04-15-2013), Nliiitend1 (04-17-2013), wolly6973 (04-15-2013) |
![]() | | #289 | ![]() |
Groans: 221
Yes. .030, .030, .031, .030 1-4 Just a thought I was showing crazy ass knock on the AP when mine was cracked. Did he moniter any??? Also I called that shit... EDIT #2 This is the thread all the cool kids are on...
__________________ EMWNM 2013 Beating Black women one 5.0 at a time... ![]() 2008 mazdaspeed 3 true red Tuned by Nishan , 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.![]() Build in progress. Track whore in the making. | |
| The Following 3 Users Say Thank You to mzr0818 For This Useful Post: |
![]() | | #290 | ![]() |
| Not Ranked : 0 score My knock was ranging from 3 to 8.1 right before I pulled into my place. After letting my car cool down I had to go make an errand and she knocked 2.5 at most.
![]() | | #291 | ![]() |
There was no knocking nearly the entire ride home?
![]() | | #292 | ![]() |
Groans: 221
| Yup thought so. Mine was in the 8.blaa blaa at times the day before I parked her.
| The Following 2 Users Say Thank You to mzr0818 For This Useful Post: | Nliiitend1 (04-17-2013), Rokusek (04-15-2013) |
![]() | | #293 | ![]() |
| Not Ranked : 0 score I saw knock at 2.5-3.0 levels on bumpy roads only. Aside from that, no knock until I got home. I kept a close eye on knock the entire ride home. Haven't started her today. I want to check for some metal shavings in the oil pan. update.. motor: 98,xxx miles compression 165, 160, 170, 131 sludge like a mofo in the motor knock was usually 8.1 everytime i drove her. after i found that certain ticking noise. piston #4 had a cracked ringland. about 2 inches of it.
__________________ 2008 MS3 gt mica black EL NATOR DE Virginia/Florida Update: getting that Purple drank in my tank. build block, pnp everything, tr825 core, meth and lots of it. 554whp/546wtq @ 30psi. another build? maybe soon.. b/c race cars need more attention than women. . ![]() ![]() adlpb: ~Fast cars are for straight lines. Corners are for fast drivers.~ #CATBACKEXHAUST Last edited by tastysi2004; 09-08-2013 at 10:52 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to tastysi2004 For This Useful Post: | Rokusek (04-15-2013) |
![]() | | #294 | ![]() |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Groaned at 23 Times in 2 Posts
| Not Ranked : 0 score Finally I have received the ring gap info from EvoX builders here. They do it this way: 1st: 0.45mm 2nd: 0.45mm Oil: 0.5mm These figures seem to be close to oem DISI specs...don't they?
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. |
| The Following 5 Users Say Thank You to paveltol For This Useful Post: | 802MS3 (04-16-2013), 86AmishMs3 (04-20-2013), mituc (04-16-2013), rfinkle2 (04-29-2013), Tomas (04-29-2013) |
![]() | | #295 | ![]() |
OEM spec ![]() I just recently completed the assembly of my virgin motor with Gen2 pistons I opened up the OEM gaps as follows. 1st: .35mm - .014in 2nd: .48mm - .019in Interested to see if your guys have trouble running the same gap in the 1st and 2nd ring. any gasses that escape the 1st ring may get trapped and cause the rings to flutter. At least that't the reason the 2nd ring is always speced larger than the 1st.
| The Following 5 Users Say Thank You to Dano For This Useful Post: | 86AmishMs3 (04-20-2013), breakfasteatre (04-16-2013), charlesfist (04-29-2013), Nliiitend1 (04-17-2013), Tomas (04-28-2013) |
![]() | | #296 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score Just got word on my pistons. I will update when I get more. Year/model: 2007 MS3 Mileage: Exactly 95,000 miles Compression: 180-180-180-90 Cylinder with cracked piston: Cracked ring cylinder 4 Suspect event : old age and motor being pushed. Cylinder 4 misfire. Car almost overheated over the summer due to thermostat. HT65 turbo installed at 30,000 miles with 390tq. BNR installed at 88,000 miles with 390-400tq. So 65k miles at 390-400TQ. Spraying meth for most of the engines life as well. ImageUploadedByTapatalk1366373839.801836.jpg ImageUploadedByTapatalk1366373850.312258.jpg
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 Last edited by taf0422; 04-19-2013 at 06:32 AM. |
| The Following 13 Users Say Thank You to taf0422 For This Useful Post: | 86AmishMs3 (04-20-2013), atvfreek (04-20-2013), BlueStreak (04-19-2013), charlesfist (04-29-2013), Lex (04-25-2013), Micha (04-28-2013), mzr0818 (04-22-2013), Nliiitend1 (04-19-2013), SPEED6 KILLAH (04-19-2013), superskaterxes (04-19-2013), Tokay444 (04-19-2013), Tomas (04-28-2013), Ziggo (04-19-2013) |
![]() | | #297 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
(Thread Starter) | Not Ranked : 0 score Thanks, taf. I'll update OP when I get back to my desktop. Sent from my iPhone using Tapatalk
__________________ '07 CWP MS3 Forged. |
| The Following 4 Users Say Thank You to BlueStreak For This Useful Post: |
![]() | | #298 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score I hate reading these threads...knowing that my engine is destined for fail. "Every engine dies, not every engine really lives." William Wallace
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following 8 Users Say Thank You to 86AmishMs3 For This Useful Post: | BlueStreak (04-20-2013), cld12pk2go (04-26-2013), Dano (04-20-2013), Micha (04-28-2013), rfinkle2 (04-20-2013), TiGraySpeed6 (04-26-2013), Todd98SE (04-20-2013), Tomas (04-28-2013) |
![]() | | #299 | ![]() |
![]() Join Date: Aug 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score Ok so, is everyone at risk for this? Or only big power guys, guys who do track time, really high mileage guys, guys running assloads of timing with Meth/E? I'm lightly bolted but have been running 2 gals of E85 and about 4-5 degrees more wot timing than the last OTS maps (before the new pure boost 2.31's). Never tracked, but definitely beat on it in the heat when I was tweaking my tune and logging for summer temps. Saw BATs hit 170F on the stock TMIC. ECTs got to 190s. For its worth, I NEVER have had to add any oil between 5000 mile changes. I fill to H, and check before I change it and it's still at H. mileage is 47,000 on an '07. Only smoking I ever see is when I go WOT after cruising for a while, I'll get some black smoke, but only the first time and then it will only happen again after at least another 10-15 mins of cruising. But it's done that forever. From reading (most of) this thread, my impression is that mildly modded, street-driven-only cars with a moderate tune don't need to worry, but I want to make sure that running E and the additional timing isn't an issue...
__________________ '07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune. Last edited by bast525; 04-25-2013 at 11:54 PM. |
![]() | | #300 | ![]() |
@taf0422; did you start noticing the misfire and symptoms after a particularly hard run or hot event?
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #301 | ![]() |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() | |
![]() | | #302 | ![]() |
![]() Join Date: Jan 2011 Location: Toronto, Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
| Not Ranked : 0 score Driving home, thinking about my car, getting fucking pissed off. compression is down to 150 now in cylinder 4. I was running a god damned OTS stage 2 map, 4 time attack events last year. Im at 45k kms now, was at 31k when i found low comp after the summer. motherfuck. ok here are the variables. penz plat 5w30 was running oil temps of 260F, would run ~5 laps at that temp and then come off. One day i had couplings blow off multiple times i did an oil analysis after the last track day, low shear, plenty of additive left, only thing they made note of was high silicon content. (silicon in the piston alloy?) i think there was 5k kms on that oil, but at least 2 time attack events on the oil what is making me mad is all the dudes running on the track with stock internals and having no problems. What has happened thats any different? in regards to oil temps, @super_pablo_; is running in god damned arizona. What are your temps?
__________________ |
| The Following User Says Thank You to breakfasteatre For This Useful Post: | BlueStreak (04-29-2013) |
![]() | | #303 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
| Not Ranked : 0 score Wonder if extreme ambient temperature differentials have any issue here? Is there any coloration of ringland failures and climate? Just a crazy idea that popped into my bald bean?
__________________ Nator is what it does. |
![]() | | #304 | ![]() |
Groans: 192
| Not Ranked : 0 score A little more part throttle knock on the highway and some smoke from the tailpipe every now and then. Did a quick WOT merging into traffic and the check engine light came on with a misfire when I got to the next light.
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
![]() | | #305 | ![]() |
![]() Join Date: Nov 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,528
Ive seen water temps around 230-240, and I have an oil pressure gauge that see drop pretty fucking low when I come off the track... but other than that, I cant help. | |
![]() | | #306 | ![]() |
Groans: 793
i don't think i've seen any ots maps that support meth injection though... ...and i thought you WERE tuning with vince...
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
![]() | | #307 | ![]() |
__________________ | |
![]() | | #308 | ![]() |
| Not Ranked : 0 score I don't think oil viscosity will have anything to do with it with one exception, but the thought of a 30w oil at 260* oil temperature makes my asshole pucker up. The one exception would be, lower weight oil means less pressure, particularly when hot, which could conceivably mean less flow thru the squirters and less cooling of the piston. Zigatapatalka
| The Following 9 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (04-29-2013), BlueStreak (04-29-2013), breakfasteatre (04-29-2013), charlesfist (04-29-2013), Dano (04-29-2013), Easter Bunny (04-29-2013), phate (04-29-2013), rfinkle2 (04-29-2013), Tokay444 (04-29-2013) |
![]() | | #309 | ![]() |
Groans: 793
![]() | | #310 | ![]() |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score Late to this party, as I am usually. I had cracked ringlands in cyl#3. I was cruising down the TP at 75ish, got off, coasted to a light, and she died. Babied it back to Pablo and that was it. Mods were, I, TIP, DP, HPFP, no tune. I do not have any other particulars.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! Last edited by predapio; 04-29-2013 at 11:03 AM. |
| The Following 4 Users Say Thank You to predapio For This Useful Post: |
![]() | | #311 | ![]() |
![]() Join Date: Apr 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score wonderful - just another thing i have to worry about with this damn car |
| The Following User Says Thank You to drillbitmoore For This Useful Post: | makjur (04-29-2013) |
![]() | | #312 | ![]() |
| Not Ranked : 0 score You can probably add the modifications, tune, etc.
| The Following User Says Thank You to Lex For This Useful Post: | predapio (04-29-2013) |
![]() | | #313 | ![]() |
| Not Ranked : 0 score The pitting on the sideskirts of some of these pistons look like detonation marks. Long scratches or scoring are normal on the sideskirts but pitting is a little strange.
| The Following 5 Users Say Thank You to Lex For This Useful Post: | BlueStreak (04-29-2013), cld12pk2go (04-29-2013), DSIT995 (07-21-2013), rfinkle2 (04-29-2013), Tomas (04-29-2013) |
![]() | | #314 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score HOW IN THE FUCK DOES IT DETO DOWN THERE!!!!!????? I know it _looks_ bizarro, butt, damn.....
__________________ ![]() "I only do what the voices in my wife’s head tell her to tell me to do" |
![]() | | #315 | ![]() |
| Not Ranked : 0 score after the ringland breaks would be my guess.
![]() | | #316 | ![]() |
Groans: 338
Also it is possible I think @Lex; mentioned this too that maybe it's fuel passing the first ring and then through pressure spikes through the fluid that is helping to break the ringland. (think liquid in a beer bottle and hitting the top and then the bottom falls off) Edit: I'm retarded.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 04-29-2013 at 03:50 PM. | |
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | rfinkle2 (04-29-2013) |
![]() | | #317 | ![]() |
| Not Ranked : 0 score This is a head scratcher since I've seen that pitting now on several of these broken ringland pistons.
| The Following User Says Thank You to Lex For This Useful Post: | atvfreek (04-29-2013) |
![]() | | #318 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following 5 Users Say Thank You to atvfreek For This Useful Post: | BlueStreak (04-29-2013), Lex (04-29-2013), mzr0818 (04-29-2013), rfinkle2 (04-29-2013), snailD (05-11-2013) |
![]() | | #319 | ![]() |
Groans: 793
| Not Ranked : 0 score So far I don't think any pu's have confirmed. Breakasteatre is at the speculation stage of problem solving.
![]() | | #320 | ![]() |
If broken gen2 pistons start to show up soon, that means it's a power/heat related failure of the OEM part since a good number of people are pushing the motors now versus 3 years ago. If it's a fatigue issue or a gen1 design issue, we won't see gen2 failures until later and perhaps not as frequently.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-ringland-failures-140371/ | ||||
| Kolben gebrochen - Motor und Anbauteile - Mazda MPS Community | This thread | Refback | 08-10-2014 09:11 AM | |
| Kolbenschaden - Seite 2 | This thread | Refback | 03-03-2014 12:37 AM | |
| GGREASE'S MS6 Issues after BT install | This thread | Refback | 09-25-2013 03:23 PM | |
| Motor und Anbauteile - [ALLE] Kolben gebrochen | This thread | Refback | 05-14-2013 12:11 AM | |
| VersaTuner: ????????, ??????????, ????? ?????? | This thread | Refback | 04-11-2013 12:56 AM | |
| Random MS3 Chat Thread - Page 165 | This thread | Refback | 03-15-2013 12:35 PM | |
| CDFP Pump Failures | Dano | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 173 | 11-10-2015 01:31 PM |
| Documented failures of updated OEM VVT actuators | btstarcher | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 11-27-2012 05:53 PM |
| Poll: KMD internals failures | NCZ13 | Mazdaspeed3/6 General Discussion | 56 | 12-27-2011 09:52 AM |
| transmission failures on teh ms3 | 08_ms3_gt | MazdaSpeed 3 - Engine, Transmission & Driveline | 29 | 04-16-2010 10:49 PM |
