Like Tree54Likes
 Old 04-29-2013, 05:50 PM   #321
breakfasteatre's Avatar
Posts: 308   (View Stats)
breakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the worldbreakfasteatre is the leader of the world
did you check compression before you started tuning with meth/vince?
we never got to the point of tuning for meth. We had some initial maps and then I did the compression test and we stopped there. doh
never have I said I was fully tuned
breakfasteatre is offline   Reply With Quote
 Old 04-29-2013, 09:10 PM   #322
JCMS07's Avatar
Posts: 349   (View Stats)
JCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the worldJCMS07 is the leader of the world
Model/Year: 2007 MS3
Mileage: 128,079
Compression Results: 155-127-45-169
Cylinders /w Cracked Ringlands: 1,2 & 3
Suspected Event Causing Failure, Condition of Affected Cylinder(s) and Other Info: Pushed the car hard at the track and coolant temps would reach 235. Insulator for spark plug in Cylinder #2 cracked during a pass down the 1/4 mile.
Pictures:
Micha likes this.
11.491@115.94 - GTX3076r
JCMS07 is offline   Reply With Quote
The Following 18 Users Say Thank You to JCMS07 For This Useful Post:
86AmishMs3 (04-30-2013), atvfreek (04-30-2013), BlueStreak (04-30-2013), charlesfist (04-30-2013), Dano (04-30-2013), Domino81 (05-01-2013), Easter Bunny (04-30-2013), fredricktsang (04-30-2013), himurax13 (04-29-2013), Lex (04-30-2013), Micha (04-29-2013), mzr0818 (04-30-2013), Nliiitend1 (04-30-2013), phate (04-29-2013), Realgib3 (04-29-2013), RichieRichness (04-30-2013), Tomas (09-08-2013), Ziggo (04-30-2013)
 Old 04-30-2013, 11:24 AM   #323
Mileage: 128,079
Pictures:
Woah, thanks for the pics. That piston looks melted. Looks like it ran too hot/lean. also the pitting on the edge of the crown and down the side looks like some heavy detonation as well.
BlueStreak (04-30-2013), charlesfist (04-30-2013), rfinkle2 (05-01-2013)
 Old 04-30-2013, 06:16 PM   #324
atvfreek's Avatar
Posts: 7,787   (View Stats)
Mileage: 128,079
Pictures:
How was your car running prior to doing a compression test. That motor took a beating.
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following User Says Thank You to atvfreek For This Useful Post:
 Old 04-30-2013, 09:01 PM   #325
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Mileage: 128,079
Pictures:
Wow bro!
Sent from my iPhone using RichieTalk
 Old 04-30-2013, 09:25 PM   #326
JCMS07's Avatar
After the insulator broke on the spark plug for cylinder #2 , I changed out the plug and the car ran fine. It was low on compression at about 130 psi, but still continue to hit the track for months. The car then started to knock almost all the time while cruising then came the misfire on cylinder #3 code. It would then idle rough and foul the spark plug on cylinder 3. Did the compression test and then the rebuild.
The Following 6 Users Say Thank You to JCMS07 For This Useful Post:
atvfreek (05-01-2013), mzr0818 (05-01-2013), rfinkle2 (05-01-2013), SLOWHATCH (05-02-2013), taf0422 (09-08-2013), TiGraySpeed6 (05-01-2013)
 Old 04-30-2013, 09:50 PM   #327
Breaking spark plugs = pretty severe detonation in most cases and the pistons show it too.
 Old 04-30-2013, 10:17 PM   #328
JCMS07's Avatar
I wasn't logging when it happened but suspected it was due to an issue with the meth not spraying. I use to have issues with the check valve sticking often and running lean during WOT.
The Following 3 Users Say Thank You to JCMS07 For This Useful Post:
atvfreek (05-01-2013), rfinkle2 (09-09-2013), TiGraySpeed6 (05-01-2013)
 Old 05-01-2013, 06:50 AM   #329
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
BigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the world
Groans: 56
Groaned at 6 Times in 6 Posts
Jesus you people have the fear of god put in me now. Looks like my BT is on hold until I get a compression tester
2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's
Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals
Winter Beater: 96 GMC K1500 5 speed 4x4
Needed: Driver mod
BigRedSpecial is offline   Reply With Quote
 Old 05-01-2013, 08:03 AM   #330
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
you should have a compression tester regardless. as red blooded north american male, it's an essential tool of life.
mzr0818 likes this.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 10 Users Say Thank You to Tokay444 For This Useful Post:
atvfreek (05-01-2013), BigRedSpecial (05-01-2013), BrianB6 (05-02-2013), Dano (05-01-2013), DSIT995 (07-21-2013), jack_hammer (09-27-2013), magicka (05-01-2013), mzr0818 (05-01-2013), SLOWHATCH (09-08-2013), TiGraySpeed6 (05-01-2013)
 Old 05-01-2013, 08:25 AM   #331
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Meh I prefer whiskey and ignorance.
I hugged rfinkle2
The Following 12 Users Say Thank You to Easter Bunny For This Useful Post:
BigRedSpecial (05-01-2013), cld12pk2go (05-02-2013), jack_hammer (09-27-2013), killer-ms3 (03-24-2014), magicka (05-01-2013), mzr0818 (05-01-2013), SLOWHATCH (09-08-2013), taf0422 (05-01-2013), TiGraySpeed6 (05-01-2013), Todd98SE (05-01-2013), Tokay444 (05-01-2013), Tomas (09-08-2013)
 Old 05-01-2013, 09:22 AM   #332
Groans: 56
I actually have one, but it's an ancient hand held model intended for snowmobiles; for what they cost I might as well get a proper one, especially considering my high levels of fail
Needed: Driver mod
 Old 05-01-2013, 12:07 PM   #333
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
They are as essential as breaker bars, torque wrenches, and condoms.
Pickles Tune in progress
 Old 05-01-2013, 12:15 PM   #334
Groans: 56
Condoms are essential? Damn, I'm doing it wrong
Needed: Driver mod
The Following 3 Users Say Thank You to BigRedSpecial For This Useful Post:
86AmishMs3 (05-01-2013), jack_hammer (09-27-2013), Tomas (09-08-2013)
 Old 05-01-2013, 12:57 PM   #335
Tokay444's Avatar
Groans: 793
what's a condom?
Demodded.
The Seals
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
86AmishMs3 (05-01-2013), rfinkle2 (02-04-2014), SLOWHATCH (09-08-2013), Tomas (09-08-2013)
 Old 05-01-2013, 01:19 PM   #336
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Big building on the beach I think.....
like an apartment but more expensive....
340hp / 371tq
The Following 8 Users Say Thank You to TiGraySpeed6 For This Useful Post:
86AmishMs3 (05-01-2013), BrianB6 (05-02-2013), Easter Bunny (05-02-2013), killer-ms3 (05-01-2013), magicka (05-01-2013), rfinkle2 (05-05-2013), SLOWHATCH (05-02-2013), Tokay444 (05-02-2013)
 Old 07-10-2013, 09:30 PM   #337
DTKII's Avatar
Posts: 247   (View Stats)
DTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the worldDTKII is the leader of the world
Exactly what Lex said, If the TIP is not connected to the VC, the only place for the oil to come from is the turbo itself
I was having problems w oil in my Turbo to my intake manifold so I installed the JBR can VTA which blocks off the manifold and vents the valve cover to atmosphere. Eventually did compression and leak down tests, came to find that I had cracked ring lands in 3 cylinders. My question is if what you stated above is correct after I installed the occ I still saw oil in the manifold and Intercooler after I cleaned it... I know this is prob a stupid question seeing how I know I was getting blow by due to bad ring lands but do you think my turbo seals are bad as well or do you think it's from the ring lands?
Stay away from RD Motorsportz
DTKII is offline   Reply With Quote
 Old 07-10-2013, 09:48 PM   #338
himurax13's Avatar
Groans: 255
I thought if the oil is pooling post turbo it could be the turbo. If it is pooling pre turbo, from the vent cover, it could be the ringlands.
Sent via blown passenger side speakers.
 Old 07-10-2013, 10:24 PM   #339
DTKII's Avatar
It was definitely pooling post Turbo it was in the TMIC, throttle body and intake manifold... I'm wondering bc I would hate to have a bad turbo spewing oil into a freshly built motor. I would also hate to have to drop another 2k on a bigger turbo after already spending 3500 on a built motor....
 Old 07-10-2013, 10:45 PM   #340
himurax13's Avatar
Groans: 255
Well I figure you might as well upgrade when things are getting fixed.
 Old 07-10-2013, 10:55 PM   #341
DTKII's Avatar
If only I had another 2 grand laying around the motor should be done and back in in a couple weeks if everything goes well...
 Old 07-11-2013, 04:42 AM   #342
atvfreek's Avatar
If you already had oil being pushed into the tip and turbo before venting everything Vta, then it takes quite a while to get all the oil out and you may never get it all out without pulling everything apart. So it may have been residual that was pooled in different places.
I literally pulled everything off my car and cleaned it. Even let my intercooler lay on its side for a few hours draining into an oil bucket.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
DTKII (07-11-2013), pwned (07-11-2013)
 Old 07-11-2013, 05:17 AM   #343
DTKII's Avatar
Yeah I hope that's what it was... Since the motor has been out I've cleaned everything. I soaked the Intercooler and intake manifold in mean green, dawn and distilled water for a few hours drained them and let them dry. I bet I dumped a half a quart of oil out of the IM two different times before the motor was taken out. Which I think the leak down test pushed most of that out. The shop I took it to for a leak down was testing it with 75psi and I saw up to a
35% loss in the 3 bad cylinders.
The Following 9 Users Say Thank You to DTKII For This Useful Post:
atvfreek (07-11-2013), BlueStreak (07-16-2013), Boosted Beluga (07-11-2013), btstarcher (07-11-2013), Dano (07-11-2013), Easter Bunny (07-11-2013), Lex (07-11-2013), ms3blackmica (07-11-2013), SLOWHATCH (07-11-2013)
 Old 07-11-2013, 05:12 PM   #344
Attachment 117254
Did all 3 cylinders have broken ringlands? Which 3 were they? Also did the failure happen during a certain event? Like a track day?
 Old 07-11-2013, 05:39 PM   #345
DTKII's Avatar
2,3,&4 were all cracked 4 was the worse which is pictured above. Cylinder 1 held together like a champ there was only a 5% loss during the leak down test on it and it read around 180 on the compression test.
The Following 3 Users Say Thank You to DTKII For This Useful Post:
atvfreek (07-11-2013), SLOWHATCH (07-11-2013), SPEED6 KILLAH (07-17-2013)
 Old 09-08-2013, 09:50 AM   #346
azazelthegreat's Avatar
Posts: 596   (View Stats)
azazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the world
Here we go!
Model/Year: 2008 speed3
Mileage:122k
Compression Results:Cylinder 1,3 and 4 in the 185 range Cylinder 2 has ranged from 30-90
Cylinders /w Cracked Ringlands: 2
Suspected Event Causing Failure, Condition of Affected Cylinder(s) and Other Info: Previous owner pushed the car to hard at the track. or something. idk
Pictures:
azazelthegreat is offline   Reply With Quote
The Following 7 Users Say Thank You to azazelthegreat For This Useful Post:
atvfreek (09-08-2013), daafisch (09-09-2013), DTKII (09-08-2013), Mauro_Penguin (09-10-2013), mzr0818 (09-08-2013), Nliiitend1 (09-10-2013), taf0422 (09-08-2013)
 Old 09-09-2013, 06:09 AM   #347
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
^^ That is my old car so I guess my suspicions from the beginning of this thread were correct.
Tokay444 likes this.
daafisch is offline   Reply With Quote
The Following 4 Users Say Thank You to daafisch For This Useful Post:
atvfreek (09-11-2013), Domino81 (09-09-2013), Nliiitend1 (09-10-2013), Tokay444 (09-09-2013)
 Old 09-09-2013, 08:52 AM   #348
mzr0818's Avatar
mzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the world
Groans: 221
Originally Posted by daafisch View Post
I haven't taken the motor apart (and can't until I find a daily driver) so I can't confirm but I currently have low compression in cyl 2 and blowing oil out of the VC vent. I've been doing time attacks and track days for the past 3 summers. I know at Watkins Glen my coolant reached up into the 230's
LOL back in march
I was ok until 4500 rpm and then Jeff Raped my face
EMWNM 2013
Beating Black women one 5.0 at a time...
2008 mazdaspeed 3 true red
Tuned by Nishan
, 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.
Build in progress. Track whore in the making.
mzr0818 is offline   Reply With Quote
The Following User Says Thank You to mzr0818 For This Useful Post:
 Old 09-25-2013, 07:05 PM   #349
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Here is my shit
06 ms6 85k 15k on the 3071
Compression
1 125
2 80
3 155
4 150
Cyl 1 had a cracked ringland on the exhaust side that was still mostly intact
Cyl 2 ringland was broken on the exhaust side but caused no scoring or marks on the cylinder wall.
I am in the process of replacing the pistons with a used factory set and installing new rings. I found this thread looking for factory end gap specs.
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following 3 Users Say Thank You to Black Metal For This Useful Post:
atvfreek (09-26-2013), Mauro_Penguin (09-26-2013), SPEED6 KILLAH (09-26-2013)
 Old 09-25-2013, 07:15 PM   #350
Tokay444's Avatar
Groans: 793
Then you should open the ring gap a tad.
Demodded.
The Seals
Mauro_Penguin (09-26-2013), mzr0818 (09-26-2013)
 Old 09-25-2013, 07:25 PM   #351
Groans: 78
The new factory 1st rings I bought are sitting at .010-.012 right out of the bag. How important is it that they are all even? I have never been this deep in to an engine before. I was thinking .012 would be okay for the 1st ring and .018 for the 2nd. Any input on the oil ring? I probably over looked it in the thread but it didn't seem to be mentioned.
@Tokay444
- 6MT - Stock -
 Old 09-26-2013, 03:21 AM   #352
Tokay444's Avatar
Groans: 793
I was going to go to .014" and .020" with mine.
Yours seem a lot better than .007" that Mazda specs on the low end.
As far as them all being the same, I would personally set them all the same to appease my own personal idiosyncrasies.
None of it matters if you don't balance the flow in the manifolds though.
Demodded.
The Seals
Easter Bunny (09-26-2013), Mauro_Penguin (09-26-2013), mzr0818 (09-26-2013)
 Old 09-26-2013, 03:53 AM   #353
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
Guess it's time for a compression tester
Sent from my phone whilst bojanglen.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
The Following User Says Thank You to Goodrich27 For This Useful Post:
 Old 09-26-2013, 01:12 PM   #354
Groans: 78
I'm sure my hone job opened up the cylinder walls a tad.
- 6MT - Stock -
 Old 09-27-2013, 08:25 AM   #355
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Originally Posted by azazelthegreat View Post
Here we go!
Mileage:122k
Pictures:
and that, kids, is why you need to thoroughly inspect a used "sport" or "performance" car before purchase.
it's fun to do bad things
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
azazelthegreat (09-27-2013), Mauro_Penguin (09-27-2013)
 Old 09-27-2013, 08:29 AM   #356
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Originally Posted by Black Metal View Post
Here is my shit
It looks as if you started melting the piston as well.
 Old 10-08-2013, 09:58 AM   #357
slw97's Avatar
Posts: 147   (View Stats)
slw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond repute
This is my friend Jamar's @GGrease; MS6 that we have been tearing down
Model/Year: 2006 MS6
Mileage: 105,000
Compression Results: 120,120,609w/oil added),120
Cylinders /w Cracked Ringlands: Cyl 3
High BAT's and coolant temps from running at the midnight drags.
Thought that the K04 was toast since it was smoking so bad so we swapped a GTX2867 and the smoking continued... the GTX only has maybe 20 miles on it.
Here are some pictures of the piston and cylinder bore. Hoping that we can save the bore with some honing.
Originally Posted by Ckmazdaspeed3 View Post
I don't know about you, but most of my races are impromptu. I'm not like, "hey dude, pull over so I can switch to my super special meth map" lol.
Originally Posted by TRex
"i don't care if it is a soccer mom in a mini van, if that whore launches on me im going at it like i'm racing a supra....just so i can bask in the sweet sweet tears of their defeat.
couple things to say...... first off the immaturity to be driving at those......ahhhhh shut up woman!!!!
2013 CWP MS3- CS 3" SRI, CS Catted DP, CS 80 Duro Race RMM, GFB BPV, CS STS, AutoTech FP Internals, CS FMIC piping w/TR-6 Core, Res Delete
304 Whp 371 Wtq DYNOJET 3 Gal E85
Purple Drank Tuned
2007 Ms3- Mazda speed CAI, gutted 2nd CAT, AccessPORT (SnailTooned), CorkSport RMM Inserts, flat black gen 1 wheels. 298 WHP 320 WTQ Sold but not forgotten
slw97 is offline   Reply With Quote
The Following User Says Thank You to slw97 For This Useful Post:
Lex (10-08-2013)
 Old 10-08-2013, 10:34 AM   #358
What were the modifications installed and tune?
 Old 10-09-2013, 05:17 PM   #359
RogerH's Avatar
Posts: 68   (View Stats)
RogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond repute
Groaned at 3 Times in 1 Post
Here is my piston. Here are the details:
2006 MS6
123,300 miles
Cylinder#4
No Compression test, the motor dropped a cylinder while wide open in 6th gear. I was running a stage 2 ots cobb map. my car is catless, cs dp, aem cai,cs tip, cpe single 3" exhaust, cs tmic. I should never have driven my car that hard on an ots map being catless. This happened a couple months ago. now I have k1 rods, and cpe stg 2 pistons. there was a dent deep enough in the #4 sleeve that it had to be replaced.
RogerH is offline   Reply With Quote
 Old 10-09-2013, 05:33 PM   #360
^ That is melted - clearly way too much heat in that motor or a failed injector.
Mauro_Penguin (10-10-2013)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/mzr-disi-ringland-failures-140371/
Kolben gebrochen - Motor und Anbauteile - Mazda MPS Community This thread Refback 08-10-2014 09:11 AM
Kolbenschaden - Seite 2 This thread Refback 03-03-2014 12:37 AM
GGREASE'S MS6 Issues after BT install This thread Refback 09-25-2013 03:23 PM
Motor und Anbauteile - [ALLE] Kolben gebrochen This thread Refback 05-14-2013 12:11 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 04-11-2013 12:56 AM
Random MS3 Chat Thread - Page 165 This thread Refback 03-15-2013 12:35 PM
CDFP Pump Failures Dano MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 173 11-10-2015 01:31 PM
Documented failures of updated OEM VVT actuators btstarcher MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-27-2012 05:53 PM
Poll: KMD internals failures NCZ13 Mazdaspeed3/6 General Discussion 56 12-27-2011 09:52 AM
transmission failures on teh ms3 08_ms3_gt MazdaSpeed 3 - Engine, Transmission & Driveline 29 04-16-2010 10:49 PM
Page generated in 0.67132 seconds with 40 queries
