Like Tree2Likes
 Old 08-22-2011, 08:51 AM   #81
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
Originally Posted by ganque View Post
Subbed.
I had a Mazda 3 5 door before (with the 2.3 N/A) trust me.. it won't handle the K04...
The CX7 engine DOES fit on the MS3, (only the block/head part).
2.3 NA engine Mounts will never fit on the MS3 mount points....
Sorry but that is a big fucking fail.... I run MS3 mounts no issues. The brackets to the mounts are the issue such as the tranny tripod and the triangle bracket for the Rear mount. The mounts themselves fit just fine No issues with any side or rear mounts, and any tranny mount that does not replace the tripod will work aswell.
Also the stock MZR engine can handle a Ko4 turbo up to around 255-260WHP aftet that things become questionable.
Subbed.
Side not OP be careful if that is a CX-7 turbo the compressor housing are different sizes. Didn't see if you menitoned if your new engine came with one but make sure you verify that it is a mazdaspeed 3 KO4 as the cx-7 KO4 is slightly smaller which can cause lack of power, quicker spool, and possibly rich/lean spots in your tune.
Last edited by pinkcheese; 08-22-2011 at 08:51 AM. Reason: MSF Database - Automerged Doublepost
pinkcheese is offline   Reply With Quote
 Old 08-22-2011, 12:07 PM   #82
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
I believe he used just the block from the cx-7.
I can't see mazda changing the k04 specs for the cx-7. You sure about that?
 Old 08-22-2011, 12:12 PM   #83
pinkcheese's Avatar
Weather you can or can't see it doesnt change the fact that they are. Learned from expierence on this one when my we went to replace a KO4 with one from a CX-7 the compressor housings on the cx-7 are smaller same with the inducer and exducer measurements.
The Following 2 Users Say Thank You to pinkcheese For This Useful Post:
btstarcher (08-22-2011), pzr2874 (08-23-2011)
 Old 08-22-2011, 09:31 PM   #84
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
I re-used my turbo and intercooler.
Tokay444 (08-23-2011)
Motor Mount Inserts vs. Rear Motor Mount Pro's n Con's Dre 2010 MS3 - Engine, Transmission & Driveline 23 05-21-2016 08:47 AM
Motor Is almost out... socks MazdaSpeed 3 - Engine, Transmission & Driveline 37 02-16-2009 09:41 AM
09' MS3 motor vs 08!???? help shamuspeed3 Mazdaspeed3/6 General Discussion 17 10-25-2008 12:06 PM
Page generated in 0.27001 seconds with 22 queries
