-   -   NEED HELP (http://www.mazdaspeedforums.org/forum/f10/need-help-11978/)
speedster 3 09-22-2008 10:02 PM
NEED HELP
Alright im out of ideas, after i installed my cs test pipe i'm getting a very violent/audible vibration under WOT and when i take off from a stop light ( just taking off normally. I can feel the vibration in my shifter, pedals, steering wheel. ive tightened all the bolts on my test pipe. i already have a stiffer motor mount (trz). im out of ideas i need help.
kingpin748 09-22-2008 10:04 PM
Did you take disconnect the battery?
Have you given the ECU time to learn?
The RP will change the sound and feel of the car.
speedster 3 09-22-2008 10:28 PM
i did disconect the battery, but i can feel the actually vibration, as if something was rubbing against a piece of metal, and my transmission/engine is louder.
kingpin748 09-22-2008 10:33 PM
Did you put the springs back on or just bolt it? The first time I turned on mine I was kinda shocked but I also had the DP.
You might also want to check to make sure you hangers a centered properly. I found on of the hangers on the CS TBE stuck out far enough to rattle on another car part until I shifted it.
Drive it around for 20km or so and see what happens. That install does make a big difference.
speedster 3 09-22-2008 10:37 PM
i've give it about 300 miles so far and it just doesnt seem like it can be good for the car, like its metal on metal vibration. i think im just gonna take the test pipe off put the cat back on and see if its still doing it. and then just re mount the test pipe
arkenzo 09-22-2008 10:40 PM
Check the hangers, maybe one is loose or just came out of the rubber hanger mount.
speedster 3 09-22-2008 11:03 PM
ill have it up on a lift tommorow, ill check, what about tranny mounts
Page generated in 0.16126 seconds with 11 queries
