![]() | | #1 | ![]() |
![]() Join Date: Nov 2010 Location: Albuquerque NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 358
(Thread Starter) | Not Ranked : 0 score Other mods include; ATP HPFP, Cobb SRI+TIP, CX FMIC (Everything was running fine with these mods which is before what I installed today). To me it sounds like a fueling problem but not quite sure. When I give it gas, there's a weird metal clinging sound that seems to come from the turbo/DP area which I was unable to isolate. No codes!!! Ill see if I can upload a video. You tube video of knock: http://www.youtube.com/watch?v=jGo04...ature=youtu.be
__________________ [SIGPIC][/SIGPIC] "That Other's May Live" SELF TUNED 380WHP/372WTQ Dyno Jet @SL E85 mix ENGINE GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV SUSPENSION CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS OTHER SHIT JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS Last edited by Jansi; 07-16-2013 at 08:06 PM. Reason: no downloading req for vid |
(Thread Starter) | Not Ranked : 0 score Attached are some videos of the car with the issue during the idle. Hopefully they work.
__________________ [SIGPIC][/SIGPIC] "That Other's May Live" SELF TUNED 380WHP/372WTQ Dyno Jet @SL E85 mix ENGINE GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV SUSPENSION CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS OTHER SHIT JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS Last edited by Jansi; 07-16-2013 at 07:58 PM. |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
| Not Ranked : 0 score @ms6mil; Rob, any insight? And no worries we will catch you at the next meet! Hope you get your problem fixed!
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() |
![]() | | #4 | ![]() |
![]() Join Date: Jan 2012 Location: Pensacola, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score I'm away from a pc right now so I can't look at your logs, but it sounds like an exhaust leak. Check your manifold and downpipe. Look for any signs of carbon where it shouldn't be. Chances are, you are dumping a ton a fuel. tapawhat
__________________ HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust Beachshoer Intake Manifold P/P /w VTCS Delete Sure Shortcut | Sure Anchors | Sure 1/8 TIG Cobb AP | Cobb FMIC | Cobb Sport Springs ATP GT3071R /w Stratified Boost Dial Stratified Automotive Guardian Angel Go Fast Bits Respons (100% VTA) Autotech Internals I tune myself, bitches |
![]() | | #5 | ![]() |
(Thread Starter) | Not Ranked : 0 score I thought the same thing but on that log (stage_1), the LTFT are -4.84 and when the stutter occurs the AFR's shoot up to 15.27. Wouldn't this indicate a really lean condition?
__________________ [SIGPIC][/SIGPIC] "That Other's May Live" SELF TUNED 380WHP/372WTQ Dyno Jet @SL E85 mix ENGINE GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV SUSPENSION CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS OTHER SHIT JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS |
![]() | | #6 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score sounds like an intake leak hows your afr, then go look at your trims if its adding fuel that's it it will correct for a small leak but will run wackey gl
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well its reducing fuel. Im pulling all pre turbo and changing the dp gasket to see if that helps. Like i said before, theres a weird sound coming from Turbo/dp area. Almost like something is in the turbo, I just inspected it and found nothing. Im hoping its a shitty gasket Sent from Tapatalk
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here's the link to youtube of the knock from the valve cover for those who dont want to download the file. Someone please give me an idea of what it could be. The motor only has 46K on the clock so I really doubt some bad lifters..... ? Engine knock 08 MS3 - YouTube Knock most notable 5-17 sec's, as well as a rattling when accelerating.
![]() | | #9 | ![]() |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score I only heard a click right at 5 second and one at 14. At acceleration I only hear throttle tip in rattle from HPFP. (few threads on that here) Is that the sound you speak of? On the other vid I definitely hear the popping sound from the exhaust. Have you tried uninstalling recent mods and making sure nothing got stuck inside the DP area? eBay DP's are usually okay but there are a few bad ones out there. How far are you from Columbus or ATL? Are you driving your car at all? Could you make it down so we can help figure it out?
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 ![]() EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
![]() | | #10 | ![]() |
Groans: 40
| Not Ranked : 0 score my exhaust broke off and didn't run bad.......
![]() | | #11 | ![]() |
Im roughly 4hours south of ATL.
__________________ [SIGPIC][/SIGPIC] "That Other's May Live" SELF TUNED 380WHP/372WTQ Dyno Jet @SL E85 mix ENGINE GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV SUSPENSION CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS OTHER SHIT JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS | |
![]() | | #12 | ![]() |
![]() Join Date: Sep 2008 Location: Clayton, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 33
Groaned at 7 Times in 6 Posts
| Not Ranked : 0 score Did you put a screwdriver on the valve cover to be sure that's where the noise is coming from?
__________________ 2008 CBM MS3 CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune |
| The Following User Says Thank You to soul.survivor For This Useful Post: | ms3rick (07-17-2013) |
![]() | | #13 | ![]() |
(Thread Starter) | Not Ranked : 0 score I did, the knocking is coming from the #4 area which is the closest to the pump. This is why I took the pump out. Mind you it was runing perfectly fine before install of exhaust mani and DP.
![]() | | #14 | ![]() |
Groans: 307
| Not Ranked : 0 score I hope you were talking about the HPFP rattle. tip in rattle is common fuel pump rattle Let the GA section guys know if know if you need a hand this weekend.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 ![]() EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() Last edited by ms6mil; 07-17-2013 at 10:20 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #15 | ![]() |
![]() | | #16 | ![]() |
Groans: 307
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 ![]() EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | |
![]() | | #17 | ![]() |
(Thread Starter) | Not Ranked : 0 score Im sending you a pm
![]() | | #18 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok so far I've narrowed it down to the turbo. I was talking to @ms6mil and we talked how the ebay DP bel mouth might be a tad bit small to where it causing the internal waste gate flapper to not properly open and close. I will confrim this once I remove the DP and inspect the components for any abnormal scratching/wear the next hour or so Sent from Tapatalk
![]() | | #19 | ![]() |
| The Following User Says Thank You to Jansi For This Useful Post: | Hush (07-20-2013) |
![]() | | #20 | ![]() |
![]() Join Date: Mar 2012 Location: Grayson, Ga
Rep Power: 751 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,729
| Not Ranked : 0 score Damn that's crazy. Tapatalked
__________________ ![]() |
