![]() | | #41 | ![]() |
![]() Join Date: Jul 2010 Location: Rochester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,462
Groans: 64
| Not Ranked : 0 score
__________________ Cp-e HPFP : JBR 80duro RMM : JBR Special Edition Heavy Shift Knob : JBR EGR Delete : Matt Damond OCC kit : Cobb AP : Cobb DP : Cobb BPV XLE : ETS TMIC : CP-e SRI : Cp-e TIP : Magnaflow CBE : Aeroforce Interceptor Dual Gauge : Blockhead vent pod :PERM Tuned : H&R Springs : TSW Nurburgring 18x8.5 w/ 235/45 Hankook Ventus V12 Evo : DDM 6000k Lows : DDM 3000k Fogs : Corksport LED light kit : 3M 35% color stable tint |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,066
Groans: 82
| The Following User Says Thank You to Fatguy729 For This Useful Post: | dougefresh_ (06-09-2011) |
![]() | | #43 | ![]() |
![]() Join Date: May 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 417
| Not Ranked : 0 score wow. This thread went to shit. Take your time, think about what you're doing, and think about it again. Those are some things you must do when doing an install on your car. and FYI, that bolt you broke off is into your turbo, not the manifold. |
![]() | | #44 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
| Not Ranked : 0 score I wish I had a impact gun for when i installed my DP ![]() My biggest issue was finding that magic combination of extentions and universal with the socket on one bolt best thing though is your finished Congrats!
__________________ COBB AP | COBB SF | COBB TIH |HKS SSQV RECIRC | Autotech HPFP Internals | TURBO XS DOWN PIPE | TURBO XS RACE PIPE | HKS HI-POWER CATBACK EXHAUST | DENSO ITV-22 PLUGS | CXRacing FMIC | SURE 90D RMM | MATT DAMOND OCC KIT | JBR ADJ SHIFT PLATE + HEAVY SHIFT KNOB [SIGPIC][/SIGPIC] |
![]() | | #45 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score I will offer some knowledge instead of fail real quick... After cursing at the bottom 2 OEM nuts for the dp, I discovered some pb blaster and the locking nuts that came with the cnt dp are the best combo. I was able to hand tighten the new, not rusted nuts on ALMOST all the way by hand, and it took me maybe 10 1/8th turns to put 40-50 pounds torque with the stubby! |
| The Following 3 Users Say Thank You to Fatguy729 For This Useful Post: |
![]() | | #46 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
I assume you have an OCC? Before you do this, you could do what Skates did... He just drilled out the tiny 1/8" holes in his valve cover baffle, and runs a filter on it vta and has NP. Everyone that goes BT has this issue, and since you're pushing 21 psi, you may need to check it out as well. I'd buy an OEM dipstick and see if it holds okay. If it pops out after 1 run, address it w/ one of the two methods. Here is a pic of the holes Skates drilled (free to do... I would do this, but I work in my car outside w/ shit blowing around and trees and don't want to risk getting something in there: ![]() He drilled those 6 holes out larger and he's fine.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
![]() | | #47 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score I do not have an occ. I was hoping my fp would hold up so I could get the Matt Damond kit next week, but I'll have to order internals asap. If they're in stock. Only thing I don't understand is why I'm hitting good afr with no knock with 1300 psi? I was wondering if this had something to do with the new ap update that states it fixed a fuel pressure issue? However, if I have the issue with the new dipstick, I may see if this vacuum cap holds, and just keep the dipstick in my hatch. I used a 3/8"cap, it was noticeably too small, but it was easily worked on and held fine during 2 WOT runs. It didn't even back off slightly. |
![]() | | #48 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score So WTF? 3 logs from today... I haven't done a MAF cal yet.... Calculated load is lower, only 1 log shows low DIFP, BUT still no KR, AFR is fine, WGDC is great... this doesn't make sense to me unless the new Cobb update shows drastically different DIFP numbers that are different from the previously known standard. BTW, I am killing myself listening for an exhaust leak.... How the fuck do you determine exhaust leak sound from turbo sounds? |
![]() | | #49 | ![]() |
![]() Join Date: Jan 2011 Location: Vero Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 152
Groaned at 50 Times in 30 Posts
| Not Ranked : 0 score interesting. i think im going to aim for a tune under 20psi. lol
__________________ '12 Ford Focus SEL |
![]() | | #50 | ![]() |
| Not Ranked : 0 score Use the paper trick. take a piece of paper and hold it against every exhaust joint. If the paper flaps around, you have an exhaust leak there.
__________________ |
![]() | | #51 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score Well, I'm gonna search, but how hard is it to get the turbo off... Compared to, lets say a dp install LOL? I need to get that bolt out and retap that hole |
![]() | | #52 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Groans: 52
the nuts for sure have to be replaced they get completely mangled during removal | |
![]() | | #53 | ![]() |
Groans: 82
I'm simply wondering if anyone has taken their turbo off, and how much of a PITA that is gonna be! I'm reading people's BT builds, but most don't mention taking the stocker off! | |
![]() | | #54 | ![]() |
| Not Ranked : 0 score You start with removing the DP, then additionally disconnect the WGA, coolant, and oil lines along with the TIP. Then it's four studs just like the DP ones. Tapayommoma
| The Following User Says Thank You to silvapain For This Useful Post: | Fatguy729 (06-15-2011) |
![]() | | #55 | ![]() |
Groans: 52
IMO taking off downpipe is worse then turbo removal except the oil feed line i HATE connecting that ... | |
| The Following User Says Thank You to Nitr0EngiE For This Useful Post: | Fatguy729 (06-15-2011) |
![]() | | #56 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score This is quoting the manual, and makes 0 sense to me... It doesn't mention anything about the exhause mani or WGA. It sounds like the stock turbo can come out from the bottom? Turbocharger Removal Note 1. Remove the TWC. (See 01-15B-2 EXHAUST SYSTEM REMOVALIINSTALLATION[L3 WITH TC].) 2. Disconnect the rear H02S 3. Remove the insulator (Exhaust manifold upper side). (See 01-15B-2 EXHAUST SYSTEM REMOVALI INSTALLATION[L3 WITH TC].) 4. Set the generator duct out of the way. (See 01-17B-6 GEf\IERATOR REMOVALIINSTALLATION[L3 WITH TC).) 5. Remove the insulator (Exhaust manifold lower side). (See 01-15B-2 EXHAUST SYSTEM REMOVAL/ INSTALLATIOI\J[L3 WITH TC).) 6. Remove the insulator (WU-TWC top side). (See 01-15B-2 EXHAUST SYSTEM REMOVALIINSTALLATION[L3 WITH TC).) 7. Remove the front H02S. (See 01-15B-2 EXHAUST SYSTEM REMOVALIINSTALLATION[L3 WITH TC).) 8. Remove the WU-TWC. (See 01-15B-2 EXHAUST SYSTEM REMOVALIINSTALLATION[L3 WITH TC).) 9. Remove the oil pipe and water pipe. 1O. Remove the turbocharger. Turbocharger Installation Note 1. Install the turbocharger. Tightening torque 38-51 N·m {3.9-5.2 kgf.m, 29-37 ft·lbf} 2. Install the WU-TWC. (See 01-15B-2 EXHAUST SYSTEM REMOVAUINSTALLATION[L3 WITH TC].) 3. Install the front H02S. (See 01-15B-2 EXHAUST SYSTEM REI\I10VAL/II\lSTALLATION[L3 WITH TC].) 4. Tight the water pipe installation bolt while the stopper of the water pipe is faced to the tu rbocharger. 5. Install the water pipes and, insert the water hose until it reaches the stopper. Edit: I'm guessing that's why the say to remove the guard on the alternator? BTW..... TWC=DP HO2S= O2 sensors generator duct=alternator bracket Edit AGAIN: Nevermind, figured it out!!! Last edited by Fatguy729; 06-15-2011 at 03:15 PM. |
![]() | | #57 | ![]() |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score Fatguy, fuck that dude. Taking the turbo off is miserable! Assuming that there is room (I'm not in front of my DP, but I think that there should bs room), go to sears and pick up a stud remover ratchet attachment for like $25. It is 2 cylinders that press together as you turn the wrench. You absolutely can get the stud out if you can get this bitch in there... Work fast (not that it is easy to move a hot DP) and get to the bitch why'll everything is still hot, and it will bs easier. I'm on my phone, so I'm not gonna post a link, but I have a pic of the stud remover on one of the last pages of "cpe side mounts released" thread. |
![]() | | #58 | ![]() |
Groans: 134
| Not Ranked : 0 score Custom Performance Engineering™ Side Mounts are RELEASED Check out the last post... This thing is great if u can get it in there! |
![]() | | #59 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score I really don't think there will be room... I'm on my phone too. I'll check out the link later |
![]() | | #60 | ![]() |
Groans: 134
| Not Ranked : 0 score Ok, so I just checked out your pictures, and it looks like the one giving you problems is the upper rear. If that is the case, assuming the ex mani is not in the way, the stud remover should work. |
![]() | | #61 | ![]() |
Groans: 52
| Not Ranked : 0 score to remove manifold you gotta remove the supports for turbo to move it down low enough to clear the studs on the turbo turbine inlet. which you will have to unhook the oil return to lower it if you do this you will have direct access to entire side of turbo and you can leave all coolant lines and oil feed connected then temporarily put the two bolts that hold turbo on bracket to the engine back to support thr turbo while you wrench it, and this requires 2 people btw, to move turbo and position it while you unhook it. and someone above to pull mani off. |
![]() | | #62 | ![]() |
Groans: 82
(Thread Starter) | Not Ranked : 0 score ugh, FML. |
![]() | | #63 | ![]() |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
Groans: 52
Groaned at 54 Times in 39 Posts
| Not Ranked : 0 score Looked at your logs...tune down the boost and you might be fine without a fuel pump or internals your hitting 19-20psi and your FP is lower than it should be tune down to 17-18 and do a log and see how its holding. I was lucky with the bolts on my downpipe I didn't even need PB Blaster, just some good ole' redneck strength and a wrench.
__________________ 2009 CWP Speed3 |
![]() | | #64 | ![]() |
Groans: 82
This has just altogether sucked balls, and I'm afraid to drive my car at WOT. Even when I get my internals, I think the stupid DP is leaking, so I need to fix it.... WHich seems as if it will suck even bigger balls! | |
| tip install | myslow1 | 2010 MS3 - Turbo Induction | 11 | 02-08-2011 10:20 PM |
| LOC, Amp, Sub Install | ChimmyChong | 2010 MS3 - Car Audio & Electronics | 8 | 07-20-2010 08:15 AM |
| What if or What would it take to install.... | manofhonor24 | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 06-30-2010 04:34 PM |
| CP-E CAI Install | PiKA West | 2010 MS3 - How-To's | 21 | 02-17-2010 08:53 PM |
