Need help. Strange noise on acceleration. For the last few weeks I have noticed a weird metallic slapping/creaking noise when I start the car. Never lasted more than it took to crank the car. Today while driving I heard the noise right after a shift during acceleration coming from the upper left side of the clutch peddle but inside the actual engine bay. It continued to get worse. Called off school and limped home. I almost felt as if something was loose. Figured out that you could get the noise to reproduce loudly by turning off the car and cranking it. Had wife crank car and it sounded like the chatter noise was coming from around or under the battery (transmission mount). I also noticed that the right side of the engine seemed to shake much worse than the left. Does this seem consistent with a transmission mount failure? If not what else should I look for. Luckily my wife is going out of town on business for a week so I have a car and time to figure this out. |
That could be the trans mount. Just pull the battery box and take a look. It could be the bolt coming loose, so make sure you check that. Check for tears in the rubber pieces. |
Well looks like I may have found the problem.... What do you guys think? Time for a TRZ Transmission mount? http://i1219.photobucket.com/albums/...615_101754.jpg http://i1219.photobucket.com/albums/...turner4/TM.jpg |
I'm no expert, but that don't look so good. |
I'm pretty sure those gaps are supposed to be there. It's been a long time since I messed with the stock piece. This is how mine looked when it really failed: http://i64.photobucket.com/albums/h1...3/DSCN2291.jpg http://i64.photobucket.com/albums/h1...3/DSCN2290.jpg http://i64.photobucket.com/albums/h1...3/DSCN2289.jpg And the bolt was bent: http://i64.photobucket.com/albums/h1...3/DSCN2285.jpg Which ruined the threads in the mount: http://i64.photobucket.com/albums/h1...3/DSCN2288.jpg |
Looks fine, but you have to pull it to really tell. Could be cracked underneath. Have you pulled the rear mount? Pull that first. Take it out, check for tears. Look at passenger mount, pretty easy to see too. |
Hmmm ok. Well a replacement mount is already on its way. What else could it be if it turns out to not be the mount? I will try to describe the symptoms better. - Thunking/bang noise. - Coming from upper left side of driver foot well or under battery area if looking from under the hood. - Happens immediately after a shift as transmission is engaged or when in higher rpms and punch it. - Also happens when you crank the car to start it but more intermittent then. Sounds like something is "banging" around in the engine bay. - Car shifts smooth. - Clutch holds fine. - Sound not coming from inside engine. Any more ideas? Quote:
Did you try tightening the bolt? |
OK, you have a CPE RMM. Did you take it out and look at it? It can look pretty installed, but take it out, might be torn. and do NOT tighten, toque, etc the Transmisison mount bolt. It is set to go to a set point, and if you tighten it, the thing can back out and snap. Well known back in the day of that happening. The threadlock gets broken, so nothing to keep it in. I coated my TMM bolt in red loctite when I installed the TRZ mount. So year, take out the rmm first, check for cracks. |
Well fuck. There is a leak on the drivers side where the axle enters the transmission housing... Could this be related to the noise? Its seems to be leaking pretty good. Any advice. I really know very little about transmissions. The RMM looked good BTW. Ok did some research and the axle seal seems shot. Shouldn't be related to the noise. |
Ok TRZ mount went in. Sound seems to be gone. Seems is the key word. The transmission is LOUD now and vibrates. In all honesty it sounds like a milder version of a fully race prepped rx8 I drove a while ago. At certain RPMs the whine is loud. I like the noise though. Besides that the car shifts so damn smooth now. I can't imagine ever grinding 3rd again. Just smooth. Tried out some no lift shifting and there was no engine thrash just acceleration. Well worth the money. Forgot to put some loctite on the bolt so when I get a chance I will pull it back out and put some on. Great mod! |
I get a clink on take off or weight transfer and am sure it must be this...now I can't decide to buy one now or wait to see what new ones come out. |
OP,Get loctite in that bolt ASAP! And if you are hearing things, start looking at the mounts.:booty: |
The CPE RMM is fine. Didn't check the passenger mount as the engine lash and noise was from the left side but I suppose I should check it since I have had problems with two mounts. |
What ^ said. I have the TRZ, and it makes the car sound like a WRC car. Buddy who is nearly fully bolted seems silent compared to mine. But I sure do love knowing the engine is not falling out and into the radiator. |
The play in the trans mount probably let the motor/tranny move around too much and tore the axle seal. you need to get that looked at...you don't want to run the tranny out of fluid. |
maybe AutoZone/Advanced/Napa has large sockets you can rent? |
I am putting the trz in tonight whooohooo! My trans feels like it's going to fall the fuck out it needs this so bad. What are my chances of reusing the bolt? |
I have read for the last 5 years, it is a 1 use bolt. But many have reused no problem. Coat the bitch in red loctite. I coated every inch of thread to the point it was dripping, and I also put some on the threading before putting it in. I did not want it to back out. |
Will do. I just hope its not snapped in half or something. I need someone to yell and make me go check it right now. |
9YA021437A is the part # if you want to get a new one from onlinemazdaparts.com If it snapped ,the motor is resting on the radiator and axles are popping off. |
4 Attachment(s) The new mount is amazing and it fixed my engine flapping around! Shifts and driving in general feel so much better. The car sounds awesome, and my butt dyno readings are off the charts!! My clicking on weight transfer however, is not fixed which points me to the axles I guess? The sound is more audible now. So far I give this TRZ mount 5 stars though. Install was straightforward, but I filled it with fail. All the bolts on the tripod were a bitch to get off, but we used a headless lacrosse stick for leverage on the wrench. I also made the stupid mistake of installing the trz without the tripod first...so cleaning the red loctite off the bolt that was already setting was a pain in the ass. And it was a bitch getting it in the second time, almost thought we stripped the threads. The funny part was this piece fell out on the road at 80mph on the test drive, I thought I hit a squirell something. WTF is it? haha. I turned around and found it in the middle of the road. Also here is a pic of my yummy oem mount. |
Oh yeah, mystery weight thing. I goes onto the back of the mount. Keeps the car from time travel. Watch out for 88 mph. And Parkinson's. |
This was a very interesting read, glad you found the issue dsm. |
http://images.sodahead.com/profiles/...622281723.jpeg |
Go fuck yourself shit head..not interesred :neener: |
Do you realize you just gave someone advice who was having issues with their car 2 years ago? Noobs gonna newb I guess |
Simply forgot to look at the date.while excited to share since just when through something similar..anyway you dont hv a chance to fuck someone online. Come here and say it in person to me. And. I will cut you f**** tongue off. Im done with you. . bully. Shit |
Oh by the way. Its two years ago indeed..you looked at this post today. Do you realized it was two yrs ago? Then y the fuck are you in the post today? Infos could be old. And can be new again for someone just has experienced the problem today! |
Oh dear Sent from your mums phone |
I can not continue with you because I refuse to try to understand the incomprehensible shit that is spewing from your keyboard. Learn English dick breath. |
Sent from my iBro 5 using tapatalk, Bro! |
| All times are GMT -7. The time now is 06:44 AM. |
