-   -   New CDFP TSB (http://www.mazdaspeedforums.org/forum/f10/new-camshaft-driven-fuel-pump-tsb-2819/)
dadasracecar 04-08-2008 06:51 AM
New CDFP TSB
New TSB for the high pressure fuel pump...
Attachment 150
Hey Laloosh, remember when I posted that I thought there was something wrong with your stock fuel system???
phailerider 04-08-2008 07:07 AM
omg... what the hell does this mean for me? They are talking about a PCM update. I assume it wouldnt be a bad idea for me to get that... is there a possibility that the upgrades are also somehow affected? Jordan felt that my car was still running out of fuel even with the upgrade....hmmm
Dada.... what you gonna do?
ikillforfunok 04-08-2008 07:13 AM
Noice! Where can I go to view all the TSB's that have been released for the speed3?
Laloosh 04-08-2008 07:21 AM
lol this is great, i guess this officially confirms the fuel problem was not in my head. If theres a TSB out for a fuel pump that means tons of people are having issues with it, not just a select few. Thx for owning your company even more:hail:
dadasracecar 04-08-2008 07:32 AM
My fuel pressure stays above 1800 at WOT through the gears so I'm not interested in it. Now, that said, if other software changes include getting rid of fuel cut(s), etc. then I'd want the reflash. Basically my car is fine as is so I'll wait to see if more information comes out or reviews from people who have the TSB performed. There is no chance that they are getting my cp-e pump.
dadasracecar 04-08-2008 07:40 AM
I told you from the beginning that I thought there was something wrong with your fuel system. You said, "My fuel system was fine. Many ms3's are experiencing the same exact problems i was, they just dont own a standback to datalog it."
I've shown the logs to Jordan and told him the same thing long ago. Like I said to you earlier, I never really understood the original beef btw you and cp-e to begin with. I did acknowledge your fuel problem back then.
Laloosh 04-08-2008 07:43 AM
the orginal beef with them was them denying my problem. Ive sent them the logs and got emails back that theres nothing wrong with my fuel system....
one of two things happened.
1. They didnt even look at the logs and just brushed it off cause no1 else was having a problem
2. They're dumber than we all think
Im voting for 1
btw you have seen the logs i sent them and you saw the problem, i saw the problem, but they didnt? cmon now
dadasracecar 04-08-2008 08:08 AM
Like I said man, I never understood the beef. I saw your logs. I still have them. I told you I thought your original fuel system was fucked. You disagreed with me on that. You brought up cp-e, not me with your "owning your company" comment.
phailerider 04-08-2008 08:09 AM
well i think its a given theyre not gonna get our upgrades... but what are the chances that the problem isnt to do with the internals?
maybe its something to do with the core housing.... then the question remains if I should switch cores just to be on the safe side. Im scheduled for more tuning and dynop time today... I'll log the fp and see whats happening.
complications complications.... maybe my power issues are to do with this. Ive always thought I didnt make what I was supposed to. Today will be telling.
Laloosh 04-08-2008 08:19 AM
my car has no fuel pressure problems after the pump so in my case it wasnt pcm related.
Laloosh 04-08-2008 08:21 AM
yes i did disagree with you on that and i still do. THe stock pump was running out of fuel. The injectors were opening and the pressure was dropping, reporgraming the computer is not going to chance what the hardware can physically flow unless they lean the car out and request less fuel
phailerider 04-08-2008 08:25 AM
we need to figure out what the new program is.... and now.
Crossbow 04-08-2008 08:32 AM
The problem with Mazda reflashes...is they tend to do more harm then good. Mazda tends to fix problems by reducing power and performance, not increasing it.
Good example is the MSP10 recall. It lowered the redline on the Mazda6. And dealers/service managers, even actual mazda employees can't tell you what the flash is going to do. You've either got to hack it (which only a few people are doing), or talk to the engineers in japan.
Laloosh 04-08-2008 08:44 AM
all these problems occur when its cold, so whoever is doing reflashes better log what ecu does in cold temps. Its deeper than just timing and a/f ratio. Cobb stated the throttle closing triggers a bunch of other parameters to change.
Btw randy, lol i shit like 3 times today already. THis better work lol
dadasracecar 04-08-2008 08:55 AM
It's not just a pcm reflash. The older pumps are being replaced. All MS6s and some MS3s and CX7s will get new pumps if they've had issues. I wondering about the differences in the pumps.
Loosh, you and I agree. Your pump was not supplying enough fuel. That's why this new pump would apply to you. Presumably the reflash adjusts the spill valve PID loop to deal with larger pump internals.
redrocketz 04-08-2008 09:40 AM
hah this is what VW did about 4-5 months ago. they have updated pumps now.
Laloosh 04-08-2008 09:51 AM
so cars after 11/2007 build date will no longer be running out o fuel?
Bravnik 04-08-2008 10:29 AM
I'm going to call my Mazda Dealer today and schedule the replacement. The CDFP is an updated spec one, so I have hopes it's capable of pushing out more fuel.
phailerider 04-08-2008 10:33 AM
good luck finding one.... thanks to all the cdfp suppliers in the aftermarket.
redrocketz 04-08-2008 11:39 AM
they aren't hard to get they have quite a few sitting on the shelf for us.
I just talked to my cousin he had both of his pumps replaced on his car already said it made a world of difference in the cold weather.
Haltech 04-08-2008 12:06 PM
Interesting... i still think there was bad programming in cold weather mode like ive been saying for the last 5 months. I think the probably upgraded a spring in the pump and changed the parameters in the ecu for temps below 45F
redrocketz 04-08-2008 01:05 PM
yeah but my cousin has an RS4 and was having cold weather issues also then Audi replaced both of his pumps (one per side) and now it runs great.
Averia 04-08-2008 01:20 PM
Rosetta Stone Japanese is looking real good right now. I keep looking at my phone like I'm gonna call...Please stop me!!!
Haltech 04-08-2008 01:41 PM
ive got the rosetta stone master DVD with EVERY language if you need it :)
Averia 04-08-2008 02:11 PM
Cool. I'm game for that -- just need to drive to HB sometime. Nice dog btw I had an Airdale when I was I kid.
thejake 04-08-2008 02:29 PM
So, what would be the recommended approach in getting a new pump under warranty?
I have experienced fuel cut and power loss during WOT in 4th and 5th. It happens more often when the temperature is colder and when I have people in the car. The thing is, I can't reliably reproduce the problem and I fear the symptoms will go away completely as the temps rise.
Any thoughts on how I get a new pump before next winter?
Jesse MS3GT 04-08-2008 04:07 PM
What this TSB states is exactly what happened to me July of last year. I even had my car towed to the dealer. They claimed I had no code or CEL, also said my traction control light wasnt on. basically somehow from the tow ride to the dealership my car stopped running rough and stopped accelerating sluggishly and fixed itself. All they did was give me my car back after doing the mount recall and sent me on my way...
Added to TSB/Recall sticky!
driver311 04-08-2008 08:38 PM
word
phailerider 04-08-2008 09:27 PM
Can someone please confirm if we can get the pcm flash if our warranty is shot to shit? How does warranty/modding affect a tsb?
mrlilguy157 04-08-2008 10:40 PM
the internals are the same (I have seen old pumps and new pumps), instead, it is the 'spill-over solenoid' on the top of the pump (the electrical connector goes to it). That is what regulates pressure with the pump and to the hard fuel line, further going to the injectors. A pin moves up and down pushing on a cap and spring assembly (itty-bitty, maybe 1/4" big), to regulate flow of gasoline to the pressurization chamber.
The reaction time of that solenoid (what the PDF directly talks about!) is prolonged due to the need of a larger current to run different variations of solenoids, or the 'slow response'. They arent talking about the response of the piston/bore assembly - that will always be the same - the cam is always spinning!
I hope this makes good sense to you guys. The ECU reflash will most likely raise the goal AFR of the car and ECU, which would allow higher pressures in the fuel rail, always, due to less fuel escaping the rail through the injectors and into each cylinder.
no concerns over here.
mrlilguy157 04-08-2008 10:42 PM
I stole this chart from a guy off of mazda6club...
http://www.mrlilguyCDFPs.com/random/pumpspecs.pdf
this chart shows that a fuel pressure somewhere under 1500psi within the rail will induce a fuel cut (one would like to believe)
thejake 04-08-2008 11:10 PM
Perfect, thanks!
:beerchug:
Munnugles 04-09-2008 01:30 AM
hey... dont mean to kinda hi-jack the thread... but were do u find these tsb's. i was looking at mazdas website at the owners part, and it says that there are no recalls for my car. but when i looked at the cdfp recall that was posted here its in my vin number range.
thanks in advance
Crossbow 04-09-2008 06:30 AM
You can sometimes find TSB's at finishlineperformance.com.
Recalls are the only thing that owners are notified of.
TSB's (Technical Service Bulletin) are for common problems that show up at dealerships, that mazda is providing an easy explanation fix for. These generally include an updated part, or a reflash. Though these are internal, it's generally easy for someone to find most of them online. (Usually pdf's mailed to the dealer)
MRI's (Mazda Repair Information) is an internal only (through esi.mazdausa.com) memo to service managers about certain problems that are reoccurring, and how to identify, diagnose, and fix them. I've only ever seen these on the dealer site itself.
You can pay for this level access at...
Mazda Technical Information
Or find a really nice service manager...
Jesse MS3GT 04-09-2008 06:41 AM
So are you saying having the dealership perform this TSB would be pointless? Or just stating its not as good as one of your pumps(which is a no brainer lol).
phailerider 04-09-2008 06:51 AM
What are you basing this speculation on Jon.... the VW flashs or fixes?
phailerider 04-09-2008 08:14 PM
How in the HELL did this thread not get posted in today?
This the biggest news weve had from mazda since we bought the car people. Am I mistaken or is everybody waiting for baited breath for two things?
#1 More fuel.... anyway we can get it in additon to the obvious internal kits that Jon sells. We'll bore out this thingermajig, and ad this or that... and mazda has a "fix" that may increase a little flow, and reaction time.
That could mean a fix for our lean humps down low on modded cars... maybe. We all have seen commanded a/f drop like a rock in the datalogs as our real a/f waits. The solenoid may have something to this. Might be worth a little discussion people.
#2 Power.....Everybody is all on Cobb and Paisinis dick about a "flash" for power to lean the car out. Jons speculation and it makes sense is that if they flash it for LESS fuel in the commanded a/f and increase the reaction time.. it will solve what the tsb is for.
It was for "lack of power". lack of damn power people...mazda just announced a flash to solve "lack of power". Can we discuss this a little further for us modded guys?
I think Im gonna get the damn thing done.
Crossbow 04-09-2008 08:33 PM
I'm just wary. Mazda doesn't do anything to aid power. They do things to patch a problem in the fastest and cheapest way possible. If they can resolve an issue by cutting back on a vehicles power, they will (and have).
People have lost power on the 6club forums from certain flashes. A bunch of owners have cold running issues, they adjust the fuel curve for everyone, and bam...unhappy owners. A bunch of cars have emission issues, Mazda adjusts timing, fuel cutoff, and redline points. (MSP10 recall). How'd you like your fuel cut to go from 7k rpm to 6500 after a simple dealer visit?
I'd be very wary until someone could figure out EXACTLY what the reflash is doing. I wish I still Mazda insiders. We could get a look at what changes were happening....basically we need guinea pigs with loggers!
I don't mean to sound all negative...I've just had bad experiences with Mazda fixes in the past! I'll see about getting this flash though after datalogging for a bit, my dashhawk should arrive tommorow or friday!
phailerider 04-09-2008 08:47 PM
I understand being wary...
But youd have to be plum crazy to solve a tsb for "lack of power" on some ms3's by reflashing the car to make it "slower". Assumably it would HAVE to be a mod to INCREASE power if the tsb is lack of power.
Volswagens and Audis have had similar "fixes" and the general responses have been that they need to be done.
Im am going to watch this closely. Its very important that we get to the bottom of this. Enganear, locally... has a stock MS3. Im gonna try to convince him to get it done so we can datalog the shit out of his car before and after the flash... It would be VERY interesting to see what shows up.
Crossbow 04-09-2008 08:57 PM
One other thing to mention. Make sure to ensure that the dealer knows about the TSB, and has their IDS updated to the proper version. Some dealerships aren't aware of these updates, and just dropping your car off doesn't ensure that you'll get the update. (Some dealerships only update their IDS at the beginning or end of the month, because Mazda doesn't pay labor time for IDS updates, or at least used to not...so there is no incentive to stay updated.)
thejake 04-09-2008 09:18 PM
Having an '06 build date, my number one concern is not the ECU flash but the fuel pump update. Long term, any negative changes introduced via the ECU flash should be addressable by the AccessPort
My question is this: Does every old fuel pump have issues, or does this only effect some?
mrlilguy157 04-09-2008 09:26 PM
seems as if most likely it is *some*, but I don't know.
I've got a new build date parts pump sitting here. I'm mailing the late model solenoid to Randy.
The comment about leaning out the car would solve all of the possible complaints people could be referring to;
1) Lack of power = "leaner is meaner", even if it bumps the AFR from 11.5 to 12.
2) Hesitation = less pressure would escape through the injectors because less fuel would spray into the cylinders, therefore there wouldnt be as dramatic of a pressure drop
3) Fuel cut = less pressure would escape through the injectors because less fuel would spray into the cylinders, therefore there wouldnt be as dramatic of a pressure drop. Pressure stays up above the 1500psi range in the lower half of gears = less chance of fuel cut.
Sounds logical to me.... I don't work for corporate. I'm thinking about advantages to us, not cost and political sides of a massive company.
enganear 04-09-2008 09:29 PM
+1 :saroll:
-enganear
phailerider 04-09-2008 09:34 PM
Originally Posted by enganear (Post 16103)
+1 :saroll:
-enganear
woohoo enganear!!!!!
btw... where in the world are you!!!
phailerider 04-09-2008 09:36 PM
If the solenoid helps with the lean hump, and enganear sees some improvement... Im gonna be VERY excited about this. I would LOVE higher a/fs but im worried about tuning them in and what it would do to that lean hump in the process. Its why we have remained so cautious with the standback.
Zach said they pulled fuel like crazy all over the place with the Xede on Jasons car.. that 329/394 on his ms6 was with an a/f running around 12.5-13.5 all the way through. And lean as SHIT down low.... i just dont have the balls for it yet.
enganear 04-09-2008 09:43 PM
Currently in Monterrey, Mexico.....:sombrero::sombrero::sombrero:
-enganear
phailerider 04-09-2008 09:49 PM
-enganear
how much work and how much play when you travel? youre all over the place!! You always go with folks or always by yourself?
TotallyNotAmused 04-10-2008 09:17 AM
Seeing as I picked up the car in August, I'm gonna go ahead and say that yeah, I have a pre November build date. Jon, since I have one of your upgraded pumps, I don't need to worry about this, do I? I don't want to bring it in and get this done and loose the upgrade I got from you.
shucky 04-10-2008 11:50 AM
so anyone done the TSB yet?
CraigHJr 04-10-2008 12:33 PM
HAHAHAHAHA this is amazing I have all of the symptoms! Guess my standback wasn't causing my persistant intermitant 2177/2187 codes.
dadasracecar 04-10-2008 12:49 PM
thank you.
Crossbow 04-10-2008 12:52 PM
I tried to get the TSB today. Dealership had no idea it was even out. I'll try another dealer this weekend.
CraigHJr 04-10-2008 01:24 PM
I'm bring the tsb with me, my pro date older, my vin is older, the symptoms are there and documented on previous visits. I am happy today now.
Laloosh 04-10-2008 01:36 PM
Originally Posted by dadasracecar (Post 16416)
thank you.
funny how he didnt have those issiues prior to the standback:spank:
bova 04-10-2008 01:38 PM
i am going to have to say it has to do with the way the standback controls boost.
CraigHJr 04-10-2008 01:46 PM
Well I have been very quick to jump around between setups so this may or may not help, but I'm excited to go get it done anyway.
dadasracecar 04-10-2008 02:53 PM
You don't give up do you? Mazda comes out with a TSB that addresses exactly what his symptoms are. He suggests, after seeing the TSB, that his problem might not have been the standback, yet you somehow know it was. Meanwhile palerider is tuning the shit out of his car and making the most hp of any nonmeth speed3 out there using the standback with no issues.
Whatever dude. :twak:
Laloosh 04-10-2008 02:57 PM
yourself and cpe can go hug now.....truth is i will always hate them and their stealing ways. So no i wont give up, either way they will be out of money soon. Many of us know the truth behind them.
Palerider is tunning the shit out of his car? Last i checked he isnt making the power he is suppose to or trapping where he is suppose 2. So yea LOL to that.
redrocketz 04-10-2008 03:11 PM
in all honesty he should be putting more to the ground than our speed6 but eh isn't now why that is is beyond me.
Crossbow 04-10-2008 04:55 PM
Everybody would be so friendly and happy in person. Damn you forums! Damn you internet!!! Why must you allow ego's and miscommunication to clash so easily!
On another note, FedEx decided I lived in a different city then the package was addressed to, and failed to deliver my dashhawk today. Sigh.
phailerider 04-10-2008 08:39 PM
what power am I supposed to make Chris? I wasnt making the power I was supposed to the minute I started posting dynos around here. I should dyno in Cali or NY.
There are obvious issues still needing to be worked out on my car.
1...Intercooler is maxed.... rated 350whp. My setup fell behind the minute it went on..I got alot more power with a little ice on the stocker...lol
2...Ive got potentially a shitty intake setup... and maf issues because of it.
3...Ive got a dyno around the corner I could make 20whp more on.... and will Monday to shut everybody up.
4...Ive got a/fs in the 10s all through my power band..... I could lean the fuck out of it some more...
5...I could easily add another degree of timing.
6...I could take my highflow cat off.
In other words... you want 375. I could give it too you easy. Im probably at 340-345 just on changing dynos alone. I guess all the other speeds that have dynoed at Marks have "power issues" as well. Dereks car made 242/265 with a ms cai/ racepipe. Stock it would have been about 215whp / 230trq. Is his setup "having issues" with a mscai and racepipe?!?! or could the dyno be affecting him as well?
And last.... there is NO FUCKING WAY you can say that my car doesnt trap what its supposed too. I drive like shit. Ive only made three passes. I cant make myself rape the car yet. It is SO FUCKING VIOLENT when I get on it in 1-2-3 that Im still afraid Im going to break something. Ive only run the 1/8th and have of those runs are on and off throttle... 2 of the 3 I was so fucked in the head i forgot to turn dcs off..
You should be laughing at that... not telling me my car is slow. Even as big a joke as that is I trapped what Driver did on his 12.7 run...in the 1/8th anyway. I would have been walking the fuck all over him the back half.... where i know how to drive...lol
I will not make the torque numbers that you guys did... that is a given. I should make about 30-35 more hp because of drivetrain loss. Hell you guys tuned for a 12.5-13.5 on the dyno... who knows what timing and shit you added... and your 329 hp number was highly controversial becuase of the track times the car made.
My car is a cautious work in progress.... and I probably share too many details with you guys. Do not use my vehicle to trash the standback. It pisses me off. Mark riley is aware of the controversy about it and thinks i should quit posting online... too much bullshit. He likes what its capable off, and doesnt see what the big deal is. It pisses him off that bullshit like this can destroy decent companys.
I should be like Whoosh and hold out until I get the kinks worked out and then try 3-4 dynos until I get one I like..... then maybe 100 passes at the track until I know what Im doing. Then post a track number.
Jesus guys... My car is a beast... come trade cars with me for a weekend and then tell me theres something fucked up.
enganear 04-10-2008 09:12 PM
Usually alone, very little play. I just found out this morning I have to go to Shanghai next week, so I will miss your dyno event on Monday. :17:
I do like riding the maglev train from the Shanghai airport, 267MPH, 20' off the ground is cool.
-enganear
Laloosh 04-10-2008 09:19 PM
you trapped what driver and i did in the 1/8th, however i walked drivers car in the back half as well. I understand you were haveing traction issues an are still new to the whole track thing but its not really that hard to get a mph out of car as apposed to et. Do a 1/4 on run on the dh....for reference mine reads 116ish......The more i look at it the more i feel that something is up with this car. What was your dyno before the BT? 270ish it think?
So you gained 50whp from a BT and manifold upgrade and almost no torque? Doesnt sound like everything is clicking there to me.
btw me and randy are not arguing lol....we chat ont he phone weekly about various things from nutrition to cars. We just dont agree on cpe lol
phailerider 04-10-2008 09:47 PM
Chris... I'll do the dashhawk runs. In the 1/8th for a rookie driver whose afraid to "get into it"... 86 is flying!! I cant stress enough... I dont launch this car ever on the street. i VERY rarely ever floor 2nd and NEVER 1st. Now even third scares me when Im in boost and shift into it. My ONE 1/8th freaked me out terribly.
Before the turbo... Derek trapped higher than my car..lol I made two runs and trapped 81... he trapped over 82... at 242/265 on Marks dyno. I KNOW I pulled the fuck on him in street rolls but i couldnt trap higher...lol Im determined to try and break my car the next time I go to the track... if it breaks i'll fix it..
As far as the 50 hp from the bt...
Yeah we slapped it on ...maxed out the MAF and the IC ... and "only" made 323-269..... 54 hp.
Big deal.... add a 3" MAF and a decent IC Id probably pick up an easy... 20-25 more.
Different dyno... 15-20 more
Pull more fuel like they did with the Xede PG car and timing.... 10-15 more
make more than two pulls with all that Im looking at 370 easy.... and maybe a blown engine too.
redrocketz 04-10-2008 10:18 PM
hey our trap and ET at the strip is what it is there was decent tire spin and apparently a shot clutch from SPEC. we showed video of the run people didn't want to believe it that's their problem the car is what it is and that isn't a drag car. On the highway the bitch pulls really damn hard. This season we will have DR's manifold fuel system and cams so watch out.
I'm sure Randys car pulls like a raped ape on Sunday. There are soo many variables in Drag times you can't just say the car makes this power and weighs this much so it must trap this speed if it were that simple than RX8's should be able to pull away from my truck but they don't we are bumper to bumper. I have had customers tell me that I drive the shit out of their cars better than they can. The driver mod is a big one.
phailerider 04-10-2008 10:19 PM
+1
makes for a good website....and be careful about knocking my car too bad. If Anthony doesnt get his ass out here in the next couple months Im gonna recruit your ass to come drive this thing. His ticket is already paid for.
I didnt build it for nothing. I want to see what it WILL do!!!
Even if I get decent... i'll leave too much out there.
And as far as cpe goes... Im over what they did to you. I think they know what that cost them and in the scheme of things they paid too much. They have a decent product that gets WAY to much gripe.
I was at the shop today when a dude called in, left a message, and wanted mark to hook up his new water/meth kit and a greddy Emanage to his speed3....I was so in shock we just laughed and laughed. WTF!!!
He was gonna spend money to blow his shit up and for a couple hundred more he could get boost control, "some" fuel control, a little timing, a secondary system for his water/meth, a map clamp, shittons of datalogging, tech support out the wazzoo, etc, etc....
the product is a good value when guys are trying to tune a ms3 with emanage, for crying out loud.... how hilarious is that
phailerider 04-10-2008 10:22 PM
zach... thats all you had to say.
I think your numbers are dead on, compared to mine... I think a bigger ic and leaning it out to where you guys had it will give me the 360 everybody wants to see before they let this thing lie and then give me shit about "track times"
Thats why im gonna bring driver out here. I want to REALLY know where i stand.
NYpest 04-11-2008 04:21 AM
um cdfp tsb ??
mtlms3 04-11-2008 06:29 AM
Originally Posted by NYpest (Post 16668)
um cdfp tsb ??
LMFAO! I forgot what I was reading about :slap:
phailerider 04-11-2008 06:40 AM
well.... a discussion about the fuel pumps is bound to get back to the cpe issue. this whole board to some extent is founded on an argument that was had over..
fuel pumps.
My power issues are inherently involved with that discussion because my car is constantly brought up as an example on both sides.... remarkably!!! Its apparently PROOF that there is something wrong or PROOF that there is nothing wrong.
funny kind of.
I would like to see the discussion eventually get back on track regarding whether we should get work done at the dealer. I would love to have more fuel and be leaner in certain places. The fear is that once you have the flash.... YOU CAN NEVER GO BACK!!!!!
NYpest 04-11-2008 06:48 AM
Hmmmmm "what if"(and a big if) you picked up a AP(if it is out as soon as ppl think) DL the stock ROM before the flash then before you upload the Stage map go to Mazda and and see what the update is all about. This way you may be able to end up going back to your before FP/flash ROM... Course this only works 4 ppl who will buy the AP.
phailerider 04-11-2008 06:53 AM
Originally Posted by NYpest (Post 16694)
Hmmmmm "what if"(and a big if) you picked up a AP(if it is out as soon as ppl think) DL the stock ROM before the flash then before you upload the Stage map go to Mazda and and see what the update is all about ?
that is a mighty fine idea!!!! i was going to get that cobb ap anyway...lol Didnt know what the hell I was going to do with it.... but I was going to get it.
I wouldnt be surprised if the cobb reflash is in the same ballpark as the mazda tune anyway... assuming the mazda tune pulls a little fuel. Difference is we'll all know more about the reflash than the mazda flash.... no telling what gets changed on the mazda flash.
mtlms3 04-11-2008 07:10 AM
Well, my reflash is set for Monday . . . I can't stand the issues I have been having (the issues described in the TSB) and if the reflash fixes them, I'll be happy.
The week after, I will bve heading to the dyno to do a baseline with stock BPV and one with the Synapse . . . but that is for another thread . . .
As for the CPE thing, I guess I joined the game a little late and have no idea what this issue is . . . so I'll just sit back, grab a bag of chips and a beer and enjoy the show :alcoholic:
NYpest 04-11-2008 07:22 AM
you mean SOAP
mazdamn02 04-11-2008 02:26 PM
My dealership wouldn't schedule an appointment for it because they don't have any pumps, lol.
redrocketz 04-11-2008 03:27 PM
hah we bought them all.
Jesse MS3GT 04-11-2008 04:06 PM
Well that means im SOL too. You go to Morries or Luther?
Haltech 04-11-2008 06:41 PM
Look Randy, no one is saying your car isn't a monster. We know it is, just your dyno numbers are so low for the size turbo and tuning solution you're running bro.Maybe it is the dyno, but the car should be seeing bigger numbers than that. We also know you aren't a drag racer by nature and that is fine with me. Everyone is on the fence which direction they are going to take with their cars pending outcome of yours, Ant's and Whoosh's.
So you're going to allow Mike Riley to dictate what you do and don't do? That's about the lamest thing Ive ever heard you say. If Mike Riley has so information to give us on this wonderful product, tell his ass to come over here and post about it. Until than, its going to be the same ole, same ole.
People are going to be a cheerleader for some one, depending on what they get kicked down to them for free. The difference is, how much of a slut or whore do you plan on being? Being the biggest slut/whore only gives you a bad rep in the end. Independence is where you should be and no one should dictate what you decide to do. Alienation only hurts you in the end.
phailerider 04-11-2008 07:28 PM
Well let em draw their own conclusions then. FWIW.... i wasnt aware anybody else had put a fucking gt30 on an ms3 other than ATP.... whose selling them and posting dyno graphs that are as atypical as hell. ATP puts up some dyno that nobody can fucking read, with no torque, and fuel cut half way through the run.... and then "thats what a goddam gt30 is supposed to make"
I could tweak it or spend another 5000 grand experimenting with just the right maf and ic.... try out 4-5 dynos... tune it some more and make your number.... But instead Im driving the fastest ms3 in the country and approaching 1000 miles on the turbo....and DOING IT SAFELY!!!!!!!! None of the local guys are talking about how terrible its all going here. Their datalogging with me trying to wipe shiteating grins off their faces.
If an easy 375 is possible by slapping a big turbo on a ms3, with a ecu weve never seen before.... then somebody else needs to fucking do it. You talk about whores.... this whole community is drinking the Cobb and PTP jones juice all the while they havent fucking done a goddam thing yet. if it was "so easy"... I wouldnt be the only one doing this.... the cars have been around for 18 months for crying out loud. its a joke that my first modding project ever like this...that I am where i am.
So now im a slut/whore? wow...
And lets see.... instead of listening to mark riley I should listen to a bunch of guys running their mouths on the internet?!?!
The motherfucker tunes 600-1000 whp four cylinders for a living. Hes been doing it for decades. He works on my car when guys arent flying his ass to all parts of the country cause their car is "stuck" at 680 whp and the setup should be netting more.... recently a flight to hawaii for a week netted him an 800whp srt.
Yeah im on his dick.... HARD!!! my project is a simple bolton... piggyback ecu tune with a "little" turbo plopped on. hes not all that impressed with the difficulty. Hes a little interested because hes bored with big power srts, dsms, hondas, and all the other shit he sees all day long. oh yeah... hes also intersted because of "me". Im a very atypical car guy and quite frankly Im probably a bit of fresh air around there to all the other fucking know-it-alls he has to deal with... and then their cars break... and he has to fucking spent a shitton of time trying to figure out what the hell is wrong, how to fix it, and keep it from happening again.. he likes me because for our "little" project so far.. im a curious team player. and one hell of a personality around the shop. Lets just say that evrybody there is talking their pills now... and a few of their health problems are getting better..lol
Yeah...i should listen to a bunch of dudes who cant agree half the time anyway. i love all you guys but its not like COMBINED you have the knowledge if got right up the street. yeah he does things his way and gets pissed when you suggest other shit.... you know why..
I stand there and watch while amateurs tow their shit in so he can fix their fuckups..... ALL DAY LONG!!!!! every week.... My jobs get interrupted by guys all over the country calling in asking him what the fuck their doing wrong... I see him talk with Corky Bell on a first name basis.
jesus kevin... damn straight im a slut. duh. Ive got a little turbo, smaller than a fucking 50 trim on my car... im new to modding and the guys three blocks away.
My build is peanuts to him.
Im gonna chill with the public updates... im tired of defending myself like this. I come here with pride and looking for advice and i get this crap. I'll start posting about my wheels and shit.
Haltech 04-11-2008 07:50 PM
No one does as far as i know, have a Gt30 on an MS3. ATP isnt voted high on my book with their hack of a turbo kit.
I could tweak it or spend another 5000 grand experimenting with just the right maf and ic.... try out 4-5 dynos... tune it some more and make your number.... But instead Im driving the fastest ms3 in the country and approaching 1000 miles on the turbo.. None of the local guys are talking about how terrible its all going here. Their datalogging with me trying to wipe shiteating grins off their faces.
Why would you need to spend $5K on an intercooler and maf? At this point, if a true tuning solution was available, you could tune around the stock MAF until something larger was created. This is where interceptors "lack" tuning ability. And, who the fuck said anyone was talking about how terrible your project is going? I think you are being a wee bit sensitive all of a sudden.
People are working on doing that right now Randy. A larger turbo should easily take someone to 375 without a blink. Do the math on the PSI vs the CFM of the bigger turbo's. People do this all day long with Nissan's, Suburu's and SRts. The joke is the tuning solution, not the parts. Ill give you an example:
1992, Vortech releasing a 8 psi supercharger kit for the 5.0 302. People are basically seeing 260's to the 270 hp range with it. 1994 a real tuning solution pops up from Autologic and the same fuckin car makes 355hp to the wheels. Luck? Not at all. Before the autologic, came the Crane Interceptor. People still couldnt pull 300 to the wheels with it.
Again, you read to far into this and are wayyyyy to sensitive all of a sudden. I dont care if that motherfucker tunes 1000 hps cars all day long. I know MANY tuners in the ford world that tune 1500hp cars. Whats the point of the discussion? The point is this, he cant tune his ass out of the Mazda ECU with the solution you gave him. Stop kidding yourself Randy. The car has MORE power trapped in it, but he cant tap it until he has a real solution to work with. Do you think he is going to say what a piece of shit your setup is with ALL the fucking money you have spent with him? Cmon, thats common sense in the business world. Stupid i am not, so lend me credit here.
If you aren't on his dick, why listen to him telling you to stop posting on forums than? He should be taking his mad ass tuning skills and providing a solution. Instead, i see him expecting praise all across the country instead of using his "knowledge" to fix the tuning problem with this car.. There are people who can tune via software and their are tuners. Do you know the difference?
Are you trying to cut off your legs & arms, all in one shot? If you look around, this board isnt comprised of a bunch of stupid fucking people. We all come from different platforms and have owned some really fast cars. There is a ton of knowledge sitting here and you have decided, based on your software tuner, what you will and wont do. Call me stupid, but im not a fucking puppet for anyone. If we all agreed on everything, would do we even need discussion forums?
I dont know one kickass tuner that takes calls while tuning. Perhaps, he needs some employees to take the phone call strain off. If im strapped to a dyno, you bet your ass my car will be tuned with complete focus on my car. That IS what you're paying for. I could careless he is talks to Corky Bell on a first name basis. If anything, him and corky should be working on a tuning solution for ALL platforms.
No, you're becoming a puppet all of a sudden for the wrong reasons. " Ill do what Mike tells me to do."
Go ahead, alienate yourself. See what that does to the respect level you have developed, but more importantly, the relationships you have developed with people here. This happen EVERY fucking day on every platform forum in the country. The game never changes, only the screen names and the type of car associated with it.
You will look back on this in one year and laugh. Or, maybe you wont. Depends if you continue to be a puppet for someones excuse of not tuning with a viable solution dude.
Been there, Done That & wrote the fuckin book.
phailerider 04-11-2008 08:19 PM
All right..I dont disagree with much of what you said.
and a small point... Mark doesnt take time out when hes tuning my car.. the girl answers the phone and in between pulls may tell himwhose on the phone....lol There are only like 2-3 times hes ever excused himself and the car needed to cool down all those times anyway.
I have made all my installs there... well over a hundred dyno pulls... multiple tuning/ tweaking sessions.... hours of phone conversations on my behalf... and my total bill so far there is a little over $4000 and that includes my tips and free vitamins and health advice I give them.
My turbo/manifold/inlet and custom intake install, with V2 in and out with 30-40 dyno pulls, and tune, a full day on the dyno... cost 1100 bucks. Their three blocks away, its a hangout for me now many days. Im committed there.
Ive got the fastest ms3 on the boards, and I havent broken anything. ive had my pump on multiple times... leaking gas into my engine with no ecu control... problems here and problems there... nothing has broken except my wideband.
One of the guys who works there just got out of the hospital battling thyroid cancer.. they are as much a part of all of this as you guys are. i reiterate... im committed there. take it or leave it.
You got to remember I was a complete noob to this scene a year ago. I wouldnt be where i am now without them.... not close. And BIG POINT... if this is all for fun.. the relationships ive got there make it better.. not worse. Being apart of that, DCR, all the rest.... as a beginner... has improved the experience.
As far as alienating everybody and being too sensitive.... hogwash. you read to much into where the aggravation was coming from. I get tired of all the bellyaching about how terrible all the options are...this and that.... I say..
just fucking do it.
When better options are available to unleash this car... and 500 guys are running the shit. I'll look back, and I promise you.... I'll have had the best experience of them all. Im not restrained financially and i think a lot of guys around here will tell you I have a good heart. I try...
Its just frustrating to be taking the very best RIGHT NOW... getting the results Im getting and then be told constantly how "disappointing" it is. Youre right Im dedicated to the community... and ive poured tons of money into this project. Im just getting started Kevin... I'll have everything on here as soon as it comes out.
as far as the 5000 for an ic and intake swap.... you missed the point. I'm going to swap... Ive been in touch with people and places that will be doing things above and beyond whats available now. Im unimpressed with whats currently available, and Im not going to keep modding the mods with flawed shit. Strangely Im passed the bolton stage to a degree.
Im tired of waiting for "the neverending promises... the "update" threads". they are a joke. my car is real, its fast, and its going to break ground all the way along.
BTW... Of course Im going to keep the updates coming. I was being facetious. I am also going to speak my mind. I may not have been around the modding world all my life, but im a pretty astute guy i think and there isnt anything my little hobby has presented that we havent overcome yet. Ive just been more frustrated by the reactions, than with the actual car.
Youd be too.
Haltech 04-11-2008 08:29 PM
I understand Randy and the best way to deal with this is to throw your success with your car, in their faces. People are going to talk shit. However, the reason they are doing that is to see how far that can make you go and see the results. Poeple have faith in you Randy and appreciate everything you have done, me included, fucker:squintfinger:
I was replying to your rant... you should know better :nutkick:
phailerider 04-11-2008 08:38 PM
my posts in this thread have been pretty goddam long...lol
Well at least nobody can accuse me of being a post whore.. ricer version of Hemingway maybe... but no post whore...lol
Haltech 04-11-2008 09:25 PM
No shit, considering i have 10X the posts as you!
phailerider 04-11-2008 09:33 PM
Well thats because you are the "real" admin.... and I am the "pretend" one. Im less committed.:)
Haltech 04-11-2008 11:20 PM
Keep us the way you been posting and its going to commit you to an institution!
Laloosh 04-12-2008 12:04 AM
i dont even know who this mark guy is, but umm the tuning solution you are using is not hard to use, and i have read nothinb but 'multiple phone calls to cpe' to try to figure shit out. Pardon my lil rant BUT THERES NOTHING TO FIGURE OUT, its fucken timing and fuel, your daughter could do that shit in 10 min on the street. Don't fall for the trap that he's 'tuning' your car, cause hes not doing anythign special that you or anybody on this site can't do. I dont know why but everybody makes tunning be diffricult....and its one of the easiest things you can do.
As for my opinion on the car....I still think something is wrong lol. How does a ms6 make more power and a shit load more torque is beyond me, than again they only trapped 106 so its probably a bullshit dyno. But wait i 4got, trap speeds don't mean anythign to people on here lol.
You want to tune your car? Go to the track on a empty night. The best 20 dollar tune you will ever get.
phailerider 04-12-2008 06:42 AM
Originally Posted by Laloosh (Post 17073)
i dont even know who this mark guy is, but umm the tuning solution you are using is not hard to use, and i have read nothinb but 'multiple phone calls to cpe' to try to figure shit out. Pardon my lil rant BUT THERES NOTHING TO FIGURE OUT, its fucken timing and fuel, your daughter could do that shit in 10 min on the street. Don't fall for the trap that he's 'tuning' your car, cause hes not doing anythign special that you or anybody on this site can't do. I dont know why but everybody makes tunning be diffricult....and its one of the easiest things you can do..
the calls were essentially discussing why things are responding the way they are.. why the lean hump... secondary fuel... the maxed maf.... the coldweather fuel cut fix.... where do we clamp the map.... datalogging...what were seeing. The reflash and "other" things Im not going to discuss just yet.
he doesnt always take my word for things.... And remember... hes learning our car first hand... he doesnt spend hours on the forums wading through all the bullshit. He draws his own conclusions. he'll see things on the datalogs and then he'll call and discuss it.
he knows my goal is to build the biggest, baddest ms3.... he is intent on discussing where we are going next with the tools we have now. And also hoping to get work done by them for us.
All that ...eh.... 6-8 phone calls 10-20 minutes(some they were calling in)... one lasted over an hour but it was on the the vacuum hose shit and then a ton of other stuff about whats going to be available soon. remember.. CPE is just as interested as to how things are going down here as well.
Yeah... something is wrong....lol Im not going to keep fucking repeating where more power is. I'll keep you updated as I fix the small issues..
And until somebody catchs up... the 335-345 THAT IVE GOT RIGHT NOW(at least).... will have to do. Im done posting my dynos from Marks. I'll use it as MY baselines but since its low, I'll use the other dyno for all you guys. The fact that it reads 20 higher, and is newer seems to be more exciting for everybody...oooh, aaahhhh. It doesnt matter Ive shown it on graphs before. You guys are going to have to see it EVERY GODDAM time to believe it....lol
redrocketz 04-12-2008 12:34 PM
you can call BS all day long but truth of the matter is those are REAL numbers and those are real times take it as it is. there are waay too many variables at the track and like I've said before it's AWD they dont pull as much at the top end period get over it.
Laloosh 04-12-2008 12:43 PM
if a dyno number makes you happy then knock yourself out.
btw, 330whp is 330whp weather it be awd or fwd or rwd, awd does not pull any more or less....so lets get that out of the way
digitaljedi 04-12-2008 12:54 PM
Wasn't paleriders dyno done on a mustang dyno? Those things murder you for power.
digitaljedi 04-12-2008 12:56 PM
loosh is right, total b.s., 330whp is 330whp, the weight of awd and fwd is obviously different, but power is power, doesn't matter what drivetrain it is.
That's like asking whats will fall faster, 1,000 lbs. of feathers or 1,000 lbs. iron. Same shit.
phailerider 04-12-2008 02:02 PM
It depends on if the iron was in the shape of a parachute.
det_ms3 04-14-2008 08:43 AM
i got it done and there is definitely more more to it now. you can feel it in through 3-4 especially 4th. not to mention i did 1-2 pulls and it hit redline without falling off or at least felt like it. its almost 11 here so i can't really go do any runs to see where its at after that like 3-4-5 but i can definitely feel the difference.
CraigHJr 04-14-2008 09:08 AM
Mazda blew mine off, they said the problem was the purge valve and the one way valve. I am sure my car will pop a celo in another day or two anyway so maybe then they will fix it right.
det_ms3 04-14-2008 09:26 AM
my dealership wasnt going to do it saying there wasn't anything on vin to make them perform the reflash. i went home got the TSB pdf and showed them they pulled it up and took care it. i also got an oil change a bath for the car. all in all its a good day. my is clean and it runs better.
BlackMS3 04-14-2008 09:27 AM
Track numbers are a valid measuring tool either.... There are a ton of variables, including temp, altitude, track conditions, tires, driver, etc, etc...
BlackMS3 04-14-2008 09:29 AM
I hate it when the dealer washes my car!!! I swear they use a dirty rag to wipe it down!!!
I tell them to leave it alone now.... "just do the maintenance, because you suck at washing a car!" They got the point.
TurboWagon 04-14-2008 09:31 AM
Wish my dealer would actually DO the TSB. I guarantee if I leave the car for them to "recreate" the symptoms, they wont find them. My car is affected by the PCM flash but they basically said, "If it ain't broke, don't fix it"
clos561 04-14-2008 09:40 AM
so what is the flash doing to the cars? flash/fix...i read the thread but didnt see anything abotu someosn results after they had the work done.
Page generated in 0.27865 seconds with 11 queries
