well i got my car back and to me it just seems like it has better power throughout the whole power band now. that might also be because my rental was a mazda 6i, but i'll report back more info later on after i do some logs and what not. |
see for yourself.... my knock retard was below 2.0 last week. now it is going up into the 3's-4's again. i think the knock sensors are just too damn sensitive http://i101.photobucket.com/albums/m...-boost/new.jpg |
So the solenoid can be replaced/updated? How do you know if you have an old version? I just signed up to buy Mrlilguy's CDFP; how will I know he didn't use an older version fuel pump and whether I have a fast responding solenoid...? How much was the replacement solenoid? |
jon (mrlilguy) is who informed me that all i needed was a solenoid. if you read the actual TSB it tells you how to decode some numbers on the pump. this will tell you the manufacured date. if it is after may 26th 07 the pump has the new solenoid, if not, that is when you may need the TSB actions done. Jon is replacing solenoids as needed as he rebuilds the pumps. everything that ships from him should need nothing done. |
so is he replacing selanoids he already sent out? How do we get this selanoid? |
So how do we get the solenoid +1! |
1 Attachment(s) here is my log after the tsb upgraded pump, didn't do much for my fuel pressure drop. think i'll have to get an mrlilguy pump. this is 3rd gear at 17psi and tuned, not perfect yet still adjusting my tune. |
Haltech whats with the PM spam? "James" is preeching or something to me. Anyone else get that? I have the pump and flash now and the car runs the same as with just the flash. I can't distinguish any differance in the AFR's. I have a pump on order anyway, but I wanted to get all the backround stuff done. Mods never fix a mechanical problem ya'know. |
Please fwd me a copy of what you are receiving so i can handle it. |
Can we buy the solenoids from the dealer? Who can answer this? |
1 Attachment(s) well i like doing logs so i did another one this morning in 3rd gear. temp was around 59, colder than when i did the one yesterday. i didn't seem to get any severe drops in fuel pressure. i am still order the upgraded fuel pump though, i'll probably need it when i add my downpipe this weekend. the one thing i did last night was clean my maf sensor and recharge my air filter. |
I just got two reflashes. Dealer made me get the emissions recall flash and they also say they did the fuel pump TSB. Odd thing is they did both flashes in under an hour :dunno: I know the ecu/pcm needs to learn but so far the car runs worse, I have worse hesitation now than I did before. The dealer did not give me a work receipt stating "well send one in the mail to you". But the service manager did say if my car keeps acting up to bring it in for the fuel pump. What PID are you guys using to see your fuel pressures??? Is it a standard or mazda specific pid? |
its under the main fuel menu, not the mazda one. i believe its called fuel pressure direct injection. |
^ Thanks ill do some datalogs and see if my fuel pressure is fubar... |
take a look here is before the solenoid swap. look how low the pressure dips once i rolled on the throttle. http://i101.photobucket.com/albums/m...t/4thagain.jpg ok now this is with the new solenoid. notice the pressure does not drop and even the peak pressure is way higher. http://i101.photobucket.com/albums/m...-boost/new.jpg |
WOW!!!!:shocked: Looks promising!!!! Look at that fuel pressure curve...its almost flatline!!!! AWESOME!!!! :top: I can't wait!!!! |
but that knock chart is kind of scary the way it keeps increasing. |
1 Attachment(s) well the tsb proved to be useless and i can't wait to get my mrlilguy pump. it was 45 degrees this morning and with my tune which is very conservative, only add 5 for fuel in from 3k-4k and i hit fuel cut this morning. boost is set at 17psi and i start pulling fuel around 4100 rpm. here is the log, the fuel cut can be seen where the afr spikes up. if it wasn't for the fuel cut it looks like i would have had good afr's all the way through. |
What gear are you doing these pulls in? |
Have an enjoyable day.... the pump will work for this at least. |
i do them in 3rd gear. unless i go on the highway its just to hard to do 4th or higher, go way to fast to quickly. |
How much is the new solenoid? And do you need the TSB reflash to make it work properly? |
why bother with a new solenoid its not going to do anything for you, it didn't for me. |
because Tru has gotten good results with the reflash and upgraded solenoid on his lilGuy cdfp. W/out the solenoid, and just the reflash with his current setup Tru was experiencing cut again until the solenoid was installed. At least that is how I understand it. |
well i am experiencing fuel cut with the new solenoid and reflash although i don't have the new lilguy pump yet. |
that thing is better then afgani H ...... |
what the fuel pump? |
well i can't wait to get mine. i'll have just about all the bolt ons you can have minus a bigger turbo and exhaust manifold. |
TRU-BOOST, Any chance you could list the part # of the new solenoid? |
Well thats the thing. If I could get the solenoid for cheap, and didn't have to go to the dealer, I'd much rather do that. I hate taking my car to the dealer, I'm terrified they're going to dent, scrape, break something. Rather pay 50-100 bucks and not have to deal. |
any update on the price of the solenoid? |
any update on the solenoid part #? |
| All times are GMT -7. The time now is 06:38 AM. |
