 Old 10-27-2013, 07:39 AM   #1
Rob84's Avatar
Posts: 598   (View Stats)
Rob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the world
Default New plugs
So I put new plugs in my 06 ms6 and now under hard throttle the car stutters. I have them gapped to the specs in my manual but thinking I may pull them and check it again. From what I'm reading when I searched and what I have in my manual are two different gap numbers
Rob84 is offline   Reply With Quote
 Old 10-27-2013, 07:56 AM   #2
jm211's Avatar
Posts: 944   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Groans: 52
What plugs and what gap?
Did you have issues before the plug swap?
Black Mica 2006 Speed6 GT | 62,000 Miles
Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 10-27-2013, 08:22 AM   #3
moomooz12's Avatar
Posts: 378   (View Stats)
moomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the worldmoomooz12 is the leader of the world
Groaned at 7 Times in 6 Posts
The manual specifies what the gap should be for oem heart range spark plugs not for 1-step colder plugs. You should be fine after you re-gap them hopefully.
Autotech HPFP Internals || Corksport TBE || cp-e FMIC || JBR 3.5" WP Intake || JBR TIG & Coolant bypass || JBR EGR delete || JBR OCC || JBR BSD || JBR 88 Trilogy Mounts|| JMF Direct Port Meth Inj IM || Stratified 2-Port EBCS || Turbosmart BOV || NGK colder plugs || Swift springs || JBR RSB
|| Snow Performance//Devils Own WMI
Self Tuned @ 330whp/352wtq 10/19/2013
moomooz12 is offline   Reply With Quote
 Old 10-27-2013, 09:03 AM   #4
Rob84's Avatar
I went back to oreillys and they said that the store I went to gave me the wrong plugs. So I got the ngks. They are a colder plug now gapped to .031. Car runs a ton better now. What they had given me was autolite xt.
How do these plugs look? skeeter149 Mazdaspeed3/6 General Discussion 9 01-17-2009 09:13 PM
1step colder or 2 step colder plugs, need to decide which plugs before tune day(by CHURCH) johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 12-13-2008 04:17 PM
NGK plugs?? dcs191919 MazdaSpeed 3 - Engine, Transmission & Driveline 2 10-15-2008 02:34 PM
Page generated in 0.24379 seconds with 22 queries
