![]() | | #1 | ![]() |
| 6 mods and some Kool-Aid ![]() Join Date: Mar 2008 Location: Jax, FL
Rep Power: 28978 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,271
Groans: 856
(Thread Starter) | Not Ranked : 0 score I am hinking of swapping the plugs on both of my cars. I have a CX-7, and Speed 3. Here are the engine mods CX-7: 3" TMIC, CAI, BOV (hybrid mode). 51K miles on it. MS3: 3" TMIC. CAI. BOV (recirc mode), turbo inlet. 37K miles on it. Pending mods include a test pipe. Do you guys thing these mods warrant step colder plus for them? If not, what do you suggest? I do not have a dash hawk, but do have an electronic boost gauge, if that matters. Last edited by Raider; 07-06-2009 at 10:04 AM. |
![]() Join Date: Apr 2009 Location: Bethpage, New York
Rep Power: 4481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,850
Groans: 778
| Not Ranked : 0 score I run my bov VTA and this causes the car to run richer and fauls spark plugs faster then normal... I use denso iridium 2 step colder so that I keep more heat in the bottom block to clean the plugs more efficiently. I havnt had a problem since... one step colder will work fine even with a factory car... |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
| The Following User Says Thank You to JamesDL For This Useful Post: | SpeedSixxx (07-05-2009) |
![]() | | #4 | ![]() |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score you using a dashhawk at all? The plugs are going to help keep knock at bay. Stock vehicles can run 1 step colder and be fine. If your kr isnt high then i would stay with the one step. Ive noticed most go the 2 steps when they raise their boost. |
| The Following User Says Thank You to nyghtryder For This Useful Post: | SpeedSixxx (07-05-2009) |
![]() | | #5 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score I have heard if you are on stock boost to about 18-19 pounds then step one is fine...Anything above that should have step 2 plugs..
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
| The Following User Says Thank You to taf0422 For This Useful Post: | SpeedSixxx (07-05-2009) |
![]() | | #6 | ![]() |
![]() Join Date: Dec 2008 Location: Harrisburg, pa
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score damn i just put one step colder in mine about 3k miles ago. now im getting KR with my mods so i gota buy another set of plugs! FML |
![]() | | #7 | ![]() |
![]() Join Date: Mar 2008 Location: orange county
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,807
Groans: 137
| Not Ranked : 0 score ^^^ have you checked the gap? or tried adjusting the gap?
__________________ 2008 STi Intake Turboback AP |
![]() | | #8 | ![]() |
Groans: 778
| Not Ranked : 0 score just saying....denso iridiums should all be pre gapped and if you check the gap and it is off then go swap em for another set of plugs..cause there is a 50/50 chance you could chip the iridium tip when trying to gap them your selves.... good ruck |
![]() | | #9 | ![]() |
| Not Ranked : 0 score ya i checked my gap out of the box and they were ok. I should check them again but i just talked to palerider about getting some 2 steps and i hope that helps out. plugs are a cheap try to see if they help |
![]() | | #10 | ![]() |
Groans: 137
| Not Ranked : 0 score i had to adjust the gap a little bit. the 2 steps helped a bit with my knock.
![]() | | #11 | ![]() |
| Not Ranked : 0 score thats what im hoping for,fixing the knock. ive always liked NGK plugs but it seems everyone is having good results with the densos so i should just conform |
![]() | | #12 | ![]() |
Groans: 778
| Not Ranked : 0 score |
![]() | | #13 | ![]() |
![]() Join Date: May 2008 Location: NOVA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
Groaned at 47 Times in 40 Posts
| Not Ranked : 0 score IMO ngk is a better plug thats what i have run since the car was new, swapped em out 3 days after i got this this shitbox.
__________________ a built motor is not a built motor without being sleeved |
![]() | | #14 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score 1 step colder...denso itv22 |
![]() | | #15 | ![]() |
Groans: 778
| Not Ranked : 0 score ngk / denso they are both good as long as you buy the iridium and nothing less! |
![]() | | #16 | ![]() |
Groans: 370
| Not Ranked : 0 score I just prefer the densos are they come gapped at .030... vs ..044 or something on the NGKs |
![]() | | #17 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,512
Groans: 157
Ther's a lot of misinformation about heat range on plugs. Here's a good source of accurate data: Tech Info - Spark Plugs Overview If a MS3 owner is concerned about fouling plugs, then going colder is only going to make that condition worse. I run the one step colder NGK Iridium IX. They do have to be regapped from .044 down to .028-.032 - not nearly the difficulty some have suggested, and all new plugs should be checked for gap anyway. Mine are regapped to .030. Hope this is helpful.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. | |
| The Following User Says Thank You to MSMS3 For This Useful Post: | Raider (07-06-2009) |
![]() | | #18 | ![]() |
plug changes are needed less frequently and your not going to foul the plugs out if your running your blow off valve not in recirc lol silliest thing i heard all day.
__________________ a built motor is not a built motor without being sleeved | |
| The Following User Says NO Thank You to fbpem1 For This Un-useful Post: |
![]() | | #19 | ![]() |
Groans: 778
really so are you telling us that running your bov atmospheric does not make you run rich which in turn fauls your plugs faster... ask cpe if they think it is silly... and on top of all that running 1 or 2 steps colder will not make the problem worse it will help if anything even on a stock car bro! do you even know what running a step colder will do? it keeps piston chamber temps from raising into the head and in doing this is helps the "cleaning" process that goes on in your block and so like I said it will help your problem.... and what is long lasting? ...denso's web site recommends changing your plugs more frequently in higher HP applications... | |
| The Following User Says NO Thank You to SpeedSixxx For This Un-useful Post: |
![]() | | #20 | ![]() |
| Not Ranked : 0 score you think the car is loading up more with fuel on a BOV recirc than with WOT on a car w/ a pump in it? thats the silly thing. and those who know me know i don't appreciate CPE's BIASED opinion on just about everything. an IRIDIUM tipped plugged is designed to have a longer service interval than said other plugs and i have said this before fuck denso NGK all the way
![]() | | #21 | ![]() |
| Not Ranked : 0 score you think the car is loading up more with fuel on a BOV recirc than with WOT on a car w/ a pump in it? thats the silly thing. and those who know me know i don't appreciate CPE's BIASED opinion on just about everything an IRIDIUM tipped plugged is designed to have a longer service interval than said other plugs and i have said this before fuck denso NGK all the way
![]() | | #22 | ![]() |
now on a serious note since there isnt alot of choices what would or are you using? | |
![]() | | #23 | ![]() |
| Not Ranked : 0 score possibly if you were more observent you would notice i said i don't like denso's but now let me quote this... "NGK all the way" i have run NGK's in all my cars with nothing but success. i'm on my 3rd set of NGK 6510's now full part number LTR7IX-11 which is 1 step colder than stock. ok thank you.
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
Groans: 856
(Thread Starter) | Not Ranked : 0 score No boost control on either of the vehicles. Want a DH, just money is tight. It is just a thought, as the CX-7's MPG has dropped, even with regular maintenance. So what it looks like, is there are some serious thoughts on what I should do. Either get 1 step, or get regular. EDIT: I do have a boost gauge on the MS3. Boosts to 17lbs, spikes up to 19, if that matters Last edited by Raider; 07-06-2009 at 07:30 AM. |
![]() | | #26 | ![]() |
Groans: 157
I'm with you on the BOV vent to atmosphere being a bad thing. Running rich and with a screwed up AFR mismatch - oxygen the ECU thinks is present got vented to air rather than entering through the intake valves. But, I think you have your info about heat range benefits backward. Please read the link I posted to NGK's site regarding plug heat ranges. If an engine is fouling plugs, it needs HOTTER heat range. A colder range will make the situation worse. It's always a balancing act between detonation (knocking) which can be helped by going with a colder heat range, and fouling, which requires a hotter plug to keep combustion chamber temps up to better burn off the carbon deposits. I have difficulty believing that there are any circumstances with our engines that would justify going two ranges colder. Maybe with a really big Garrett turbo running very high boost and a super lean tune, that might make sense, but then the internals would have to be beefed up a lot too. IMHO, the key to optimizing spark plugs on these engines on stock tune is to adjust heat range so that there is enough heat to keep the tip clean and no more. Keep gap narrow - .028-.032, and if running any kind of tune or higher boost, drop the gap to .026. If you can't keep the tip clean and still have knock, then raise octane to 93. Use octane boost if necessary. Colder plugs do not prevent fouling, they aggravate it.
| The Following User Says Thank You to MSMS3 For This Useful Post: | SpeedSixxx (07-06-2009) |
![]() | | #27 | ![]() |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score Tru Dat MSMS3, running too cold of a plug will foul it. I never heard of anyone recommending 2 step colder plug for these cars with a stock turbo until I seen this thread. |
![]() | | #28 | ![]() |
Groans: 856
(Thread Starter) | Not Ranked : 0 score Ok, so with the mods I have posted in #1, what do you all think I should do? Thread went a bit off topic. |
![]() | | #29 | ![]() |
Groans: 370
I have not ran NGKs before, but I have had zero issues with both the 1 step (ITV22) and 2 step (ITV24) denso plugs...never regapped any of them either | |
| The Following User Says Thank You to aaronc7 For This Useful Post: | SpeedSixxx (07-06-2009) |
![]() | | #30 | ![]() |
Groans: 370
![]() | | #31 | ![]() |
| NEC ![]() Join Date: Mar 2008
Rep Power: 473 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score Stay stock, or go with 1 step colder max. With your mods I wouldn't bother with 1 step colder plugs. I'm running the stock plugs on a SST + fully bolted car... step colder plugs did absolutely nothing for me, didn't help the knock, car felt identical so I said screw it and went back to stock plugs.
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* |
![]() | | #32 | ![]() |
Groans: 370
| Not Ranked : 0 score FYI, cobb examined my stock plugs when all I had was Intake/TBE... they saw signs of boiling on the plugs (at which point step colder would be a good idea). I think 1 step colder is good for any decently modded bolton car or one with raised boost. I don't think you need to switch to step colder right away or anything...car will probably run fine with stock ones. But then it's time to replace those i would look into 1 step colder. |
![]() | | #33 | ![]() |
Groans: 157
| Not Ranked : 0 score With your mods, you'll probably perform best with stock heat range in either the NGK Iridium IX or the Denso iridium. If you are concerned about knock with your mods, try to get 93 octane and you should be fine, even with the test pipe. If you tamper with raising boost (controller, tuner, etc) or get a downpipe, you MUST go one step colder, but not before then, IMHO.
![]() | | #34 | ![]() |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score i think i need new plugs... I gapped mine all fine but I want the ones that are pre gapped.
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
![]() | | #35 | ![]() |
Groans: 856
(Thread Starter) | Not Ranked : 0 score I always run 93, so fuel is not an issue. No boost controlling in my future either. Will seriously consider the step colder. I think I will check the current plugs as it is, or see if I can borrow a local DH to get data logs of how it is running. In fact, I think that is the #1 thing I need to do. |
![]() | | #36 | ![]() |
Groans: 856
(Thread Starter) | Not Ranked : 0 score I will be able to borrow a dash hawk this weekend to get some readings! Yay. |
![]() | | #37 | ![]() |
Groans: 778
thank you for the info =) from what I read on a site about heat ranges and denso...from what I remember a 1 step colder plug will keep the heat from transferring from the tip of the plug in the piston chamber to the top of the plug connected to your ignition coil. in doing this you keep the head from being heat soaked from more heat being transferred from the P chamber to the head and by keeping the heat in you help the cleaning process... now if everyone that is in contact with tuners and such have heard the exact opposite maybe I was a bit too stoned when I read the article but that is what I remembered from the denso heat range chart. it does sound like it would make sense that a 1 step colder plug would keep temps cooler in the process but thats not what I read like I said i shall try and find the article.. thanx for the info tho bro./...I have 2 step colder plugs and I checked em today just to see if I was dead wrong and my plugs are good..but they look brand new and I installed them like 10000 miles ago Last edited by SpeedSixxx; 07-06-2009 at 06:05 PM. | |
![]() | | #38 | ![]() |
Groans: 157
| Not Ranked : 0 score You're welcome. That's why I posted the link direct to NGK's site and their explanation about heat range. It's a good read - all five pages and not just the page I linked to for the illustration. Short summary: If fouling plugs, go hotter. If chasing detonation (knocking) go colder. General advice from experienced racers and engine builders: go one step colder for each 70 hp in gain, or if you are running higher than stock boost or have a downpipe or a leaned out aftermarket tune with increased boost.
![]() | | #39 | ![]() |
![]() Join Date: Jul 2009
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score they make a difference |
![]() | | #40 | ![]() |
Groans: 157
| Spark Plug Question? | QKRTHNU | Mazdaspeed3/6 General Discussion | 2 | 04-13-2009 09:08 AM |
| Analyze this spark plug | aaronc7 | MazdaSpeed 3/6 - Turbo Induction | 24 | 01-03-2009 11:51 AM |
| Spark Plug Gap | khaydin | Cobb Access Port/Maps | 5 | 12-01-2008 10:17 PM |
| Oil in my #4 spark plug thread! | Death-From-A-Mile | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 07-20-2008 02:04 PM |
| Spark plug gap | Jesse MS3GT | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 03-16-2008 04:53 PM |
