-   -   next mod? (http://www.mazdaspeedforums.org/forum/f10/next-mod-185101/)
AZST 03-03-2015 07:37 AM
next mod?
So i'm torn right now on whats next for the Speed3. I have an sri, tip, and catback, and right now my pump is holding about 1750/1800 consistently at WOT. I'm stuck between getting an AP from freektune or stratified with an OTS+ style map, or spending that money on a test pipe, fuel pump internals, and a STS. My question is: is the AP worth getting right now when I could only run an ots stage 1 or 1+ tune? Or is the test pipe and pump worth getting first, and waiting on the tune for a bit
edit: Considered full downpipe but I don't have the $$ right now
CWP_MS3 03-03-2015 07:39 AM
Internals and AP, then continue modding. Do a custom tune last, so you don't need to retune.
Mike@Stratified 03-03-2015 07:59 AM
Blog : The modification path in a MazdaSpeed/MPS vehicle : Stratified Automotive Controls
Vansquish 03-03-2015 08:04 AM
HPFP Internals + AP are the next step. I wouldn't do anything else. Furthermore, if you don't have the money for an Ebay downpipe, you should probably not be modding your car. Everything you do to the engine is likely to sacrifice some motor longevity.
AZST 03-03-2015 08:16 AM
I wasn't considering an ebay downpipe as a legit option for a downpipe to be honest. Am I stupid for not looking at ebay parts?
HawkeyeGeoff 03-03-2015 08:18 AM
Def +1 on the pump internals as a necessity. Don't be an idiot.
AZST 03-03-2015 08:20 AM
Only reason internals arent at the top of my list is that they haven't dipped into danger yet. But i guess it's a "they'll work great till they don't" type of thing. Thanks guys.
CWP_MS3 03-03-2015 09:03 AM
Doesn't matter. They're justa precaution. You're at the point where you need to decide if you're jumping in or staying out of the water. Ain't no dipping toes and shit.
It sucks to spend that much money on shit that doesn't directly make you more power, but it is what it is.
Vansquish 03-03-2015 10:52 AM
As far as a downpipe, yes.
anavrinIV 03-03-2015 11:22 AM
I disagree only on the basis the that ebay downpipes I've personally seen and/or installed fit terribly. The one I installed required forceful removal of the hangers and clamps to meet it up with the cat back, and I know @Travisms3; has fitment issues with is so much that it pulls the exhaust tip well into the bumper.
As a pipe it works out fine, but fitment is complete crap and I wouldn't run it. A catless CNT is only a couple hundred bucks, go that route if any.
Vansquish 03-03-2015 11:30 AM
I have an Ebay DP (M2 brand) that cost me a little over $100USD, and it works perfectly with zero modifications except for a more robust v-band clamp.
YMMV, of course.
ASHMS3 03-03-2015 11:33 AM
The latest batch of M2/Manzo for MS3's seem to have some fitment issues. Mine was a little short too, I had to get a little creative with a stock donut gasket and stock hardware to get it to mate up to the stock catback. Just pulling catback forward made it hit the underbody.
CWP_MS3 03-03-2015 11:36 AM
Truff. I had fitment issues. It pulled my whole exhaust forward because it was short, which makes it *almost rub*. The hangers do not line up, and I had to cut them off because they were knocking on the body hangers. And the lifted 02 bung is too high, and gives me a check engine light for a rear 02.
With that said, for $150 bucks I'd probably do it again. If I cared a little more, I'd go CNT as suggested.
I haven't heard of any issues for the MS6. I've seen a ton for the MS3.
AZST 03-04-2015 07:41 AM
Gotta go catted; ran catless on previous car and I didn't dig my bumper to bumper traffic custom fit gas chamber.
CWP_MS3 03-04-2015 07:44 AM
Then if CNT is available now, I'd go with that. Check with them before you order it though. When I wanted them it seemed common for them to be backordered.
ASHMS3 03-04-2015 07:45 AM
They are still backorder pretty much all the time, call them and see what the lead time to fill the order is.
AZST 03-04-2015 07:48 AM
Yeah I just checked it out and it's backordered. Gonna call tonight and see what the fill time is.
sporkbomb 03-04-2015 08:41 AM
Good luck w/ your progress man, but I am confused why you are still searching for a downpipe. You are only doing it for shits and giggles, correct?
You should take to heart @Mike@Stratified;'s input on post #3. That there is some damn good reading.
I heard there is also the Donation Mod. I've heard that you don't even need CDFP internals before going w/ that mod.
AZST 03-05-2015 01:27 PM
Yeah just for shits and giggles, and future planning. Internals and AP first
sporkbomb 03-05-2015 01:59 PM
Good plan ... golf clap.
MD1032 03-05-2015 05:04 PM
The thing new people continually fail to understand is that coming from stock, you need more air flow to make more power, and that means you need more fuel. I bet with the stock intake and a good tune, you could actually outrun what the stock HPFP can do. That right there should tell you that a custom tune/AP, and internals are the most important mods for your vehicle.
More power isn't going to just magically appear if you add more flow mods...all those mods will do is give you more headroom that you aren't using because you don't have internals yet.
jack_hammer 03-05-2015 05:23 PM
How do you know your fuel pressure without an ap?
AZST 03-06-2015 02:03 PM
Honestly been using the Torque app.
Thepedigree13 03-07-2015 03:21 AM
Although getting the AP and internals does not give you the instant gratification that flow mods do, it is pretty liberating. You will have fun messing with AP, logging, monitoring, etc. Then you are free to add pretty much any of the basic shit and prepare for a tune.
I have just reached the point where I am preparing for a tune, changing plugs and fixing a small exhaust leak. I will tell you, I am more anxious and excited to get a tune than I was for any of the other mods.
I followed what these guys suggest as a mod path and have not had any major issues.
Have fun with it and be patient.
jack_hammer 03-07-2015 08:23 AM
I figured. You can't use that to reliably tell you the fuel pressure at WOT. The ap can. There are a couple other options too. But ap is the most common
AZST 03-09-2015 12:07 PM
Originally Posted by jack_hammer (Post 2827725)
I figured. You can use that to reliably tell you the fuel pressure at WOT. The ap can. There are a couple other options too. But ap is the most common
Can or can't? contextually Can't makes more sense, but do you mean the torque app is reliable or is not?
jack_hammer 03-09-2015 06:47 PM
Fixed. You cannot reliably use it because the refresh rate is too slow. At least that's the accepted line by those who keep up with that kind of stuff. (That doesn't include me. I've never tried it.)
MD1032 03-09-2015 07:20 PM
Torque reads the same fuel pressure the AP does (on the high pressure side). You just need to make sure that you have no other live displays open and only log fuel pressure and RPM (basically the bare minimum in my opinion), so that no other PID's are being polled. In theory, even the cheap ELM327 OBD adapters should be capable of like 20 points per second. In practice, this is never achieved, but you will get enough to be able to see significant low pressure events.
I was able to use Torque to determine that my fuel pressure was indeed dipping on my completely stock 2012 Pu, on the stock tune. I attached an example that I captured using torque and my ELM327 adapter. This is actually what first led me to buy an AP. Don't discount Torque, it's a very powerful diagnostic tool for how little it costs.
AZST 03-10-2015 08:55 AM
I was making the mistake of polling quite a few PIDs, and as i look through the logs I am noticing only about 7 or 8 points per second, yet the general curve of the points doesn't seem to indicate low pressure. But, all of this aside, internals are a def need.
Page generated in 0.19919 seconds with 11 queries
