  • 1 Post By jmettee
 Old 10-11-2017, 01:43 PM   #1
dandydaniel's Avatar
Posts: 47   (View Stats)
dandydaniel is on a distinguished road
Default noise coming from engine bay please help
as the title says, just wanted someones help in diagnosing what this noise could be. i just started hearing it about a week ago and ever since then, it's been there. The noise begins the moment the engine is just about warming up and then from there, just stays consistent regardless of RPM/stopped/going what not. There haven't been any differences in performance or idle or start up or anything which is why I haven't ran off to the mechanic yet.
anywho, its a 09 ms3 with 49k miles on the odo.
https://www.youtube.com/watch?v=JPPkMlgjJgQ
hopefully someone can help me and figure this noise out quick!
thanks in advance yall.
09 ms3 . hks cbe+testpipe . cpe sri+tip . jbr sts+ssp . jbr rear sway . trz rmm . roadmagnets
dandydaniel is offline   Reply With Quote
 Old 10-11-2017, 03:25 PM   #2
danb's Avatar
Posts: 85   (View Stats)
danb is just really nicedanb is just really nicedanb is just really nicedanb is just really nice
water pump going?
2004 mzd3 173k, winter monster. injen black cai, twm short shifter, mazdaspeed Accessory exhaust, Tri point engineering rear sway bar. the usual rust...
2011 mzd6 58k. wifes ride
2007 speed3 78k. summer car. cobb rmm. twm solid shifter bushings, AP3, CS power series stage 2 intake, autotech hpfp, ebay race pipe, Freektune OTS+ 93 and e85 maps
danb is offline   Reply With Quote
 Old 10-11-2017, 05:13 PM   #3
jmettee's Avatar
Posts: 43   (View Stats)
jmettee has a spectacular aura aboutjmettee has a spectacular aura aboutjmettee has a spectacular aura about
Bearing, probably an idler pulley by the way it sounds to me.
danb likes this.
jmettee is offline   Reply With Quote
The Following User Says Thank You to jmettee For This Useful Post:
dandydaniel (10-13-2017)
 Old 10-12-2017, 03:31 PM   #4
Db09ms3's Avatar
Posts: 21   (View Stats)
Db09ms3 will become famous soon enough
Remove the accessory belt and spin them pulleys around. Listen for odd sounds or slight scraping. Heck, you can even feel and wiggle a pulley or two to verify! Check the belt too.
Db09ms3 is online now   Reply With Quote
The Following User Says Thank You to Db09ms3 For This Useful Post:
Throttle noise/ engine noise under28world 2010 MS3 - Engine, Transmission & Driveline 9 05-04-2015 05:25 PM
Noise coming from the transmission I think... itskbo MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-15-2013 07:43 PM
Hissing noise coming from under the dash Boostaholik Gen2 MS3 General Discussion 3 10-04-2012 06:13 AM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 02:30 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Page generated in 0.23761 seconds with 23 queries
