-   -   occ (http://www.mazdaspeedforums.org/forum/f10/occ-6334/)
fdkss03 06-05-2008 06:40 AM
occ
These questions are for those running occ's...
How often is it to be drained?
Could you go with the home depot occ and leave the filter (stone) in it, add a check valve to the line and be set?
Wwhere can you get the hose from? Hose that will not collapse.
bova 06-05-2008 07:00 AM
if you check the stick for my install i have listed good hose. also i would not go with the home depot catch can because some who have tried had them break from the oil and "fuel" mixture that enters them. i'm not saying a diy can isn't bad but i dont think i would want to skimp on this and end up throwing your money away.
fdkss03 06-05-2008 07:40 AM
i did the home depot one in my srt and everything worked fine... the oil/gas mixture didnt harm anything. I accually have one layin in my garage, all i need at the moment is the hose.
I would do this just to test and see if that corrects the smoking issues. Then I will replace it with a nice occ.
bova 06-05-2008 07:42 AM
so far my car has not smoked since adding the catch can.
Page generated in 0.16228 seconds with 11 queries
