 Old 10-12-2014, 06:35 PM   #1
spinixguy's Avatar
Posts: 27   (View Stats)
spinixguy is a jewel in the roughspinixguy is a jewel in the roughspinixguy is a jewel in the rough
Default OEM transmission fluid
Anyone know what the name, or part number, is for the original fill transmission fluid for the ms3?
I am going to swap out the fluid and I am probably going with the motocraft, but I would like to check out the specs on the oem fluid. So far the only thing I have found was some Mazda 4x4 diff fluid.
spinixguy is offline   Reply With Quote
 Old 10-12-2014, 07:03 PM   #2
JSmith's Avatar
Posts: 706   (View Stats)
Groans: 106
Groaned at 6 Times in 6 Posts
Have you tried here?
Finding OEM Mazda Part Numbers
What year vehicle? I think Mazda changed the "recommendation" once or twice.
The Following User Says Thank You to JSmith For This Useful Post:
spinixguy (10-13-2014)
 Old 10-13-2014, 08:21 AM   #3
spinixguy's Avatar
My ms3 is a 2008 and thanks for the links, but after searching each I am still without a part number.
 Old 10-13-2014, 09:02 AM   #4
rabble rabble
802MS3's Avatar
Posts: 5,317   (View Stats)
Groans: 221
I don't know if Mazda actually has a specific part number. We commonly use the Ford Motorcraft XT-M5-QS fluid. I switched to that when I did my clutch about 5000mi from the original fluid, and it has been doing fine.
'08 CWP MS3 w/ T3 3071r
 Old 10-13-2014, 09:08 AM   #5
spinixguy's Avatar
I am starting to agree with you that there isn't a part number for the fluid. Seems that every shop tends to do their own thing and they just try and follow Mazdas spec. Strange though as I have found several part numbers for automatic fluid. Just nothing for the manuals.
 Old 10-13-2014, 09:58 AM   #6
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
There is no part number. They simply specify grade and viscosity.
From the service manual:
Agent_Orange is offline   Reply With Quote
The Following User Says Thank You to Agent_Orange For This Useful Post:
speed23 (10-13-2014)
 Old 10-13-2014, 10:04 AM   #7
spinixguy's Avatar
well, guess that is that then. Thanks all.
transmission fluid change ottoblotto CX-7 > Engine, Transmission & Driveline 35 09-25-2017 07:31 AM
Enough Transmission fluid? mxrider518 2010 MS3 - Engine, Transmission & Driveline 5 07-01-2013 08:49 AM
Transmission fluid question MazdaSpeed3NY MazdaSpeed 3 - Engine, Transmission & Driveline 1 07-19-2012 11:43 AM
Transmission Fluid Crazyspeed3 Mazdaspeed3/6 General Discussion 6 12-23-2011 06:32 PM
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A Haltech Automotive News 0 05-15-2009 03:10 PM
Page generated in 0.27616 seconds with 23 queries
