Oil Catch Can Question Hey everyone, I'm planning on getting a catch can before it gets too cold outside to install it but before I do I had a few questions. I'm looking to buy the SURE oil rig, but it doesn't come with a check valve. Now I know that the reason you need a check valve is because the OEM PCV valve doesn't seal 100% when under boost. Will not having a check valve reduce the efficiency of the OCC, meaning it will allow more crud back into the intake? Just curious because the car operates normally with the leaky PCV and most of the OCC kits can be had with or without the check valve. Also for anyone who has bought the check valve separately what valve do you use? I know some people have used a second PCV valve, but others have cheaper check valves that work equally as well. |
def get a check valve dont use a second PCV buy this check valve and hose barbs from mcmaster http://www.mcmaster.com/nav/enter.as...54&pagenum=474 http://www.mcmaster.com/nav/enter.as...12&pagenum=267 |
Mazda and Mazdaspeed Oil Catch Can by Corksport Corksport is an option too, it's a little cheaper than SURE and you can get a check valve through them for $10 more. It is only listed in the Gen 2 section for some reason and I think that's what the install instructions are written for. Genjuan should be pretty close, but if you've got a MS6 you might have to get a little creative with the install. Or contact @MATT DAMOND, not sure what his kits go for, but people seem to be happy with them. |
Why does the MD kit have the valve on the manifold side but the JBR has it on the block side |
Tapadatass |
right, so i wonder why JBR's is the opposite |
Just ordered the Matt D one. Looking forward to installing it. |
Ok, so I see that there are 3 different versions. Just different mounting points. Is the Version 1 the best solution if you have/ or will have a FMIC? |
i thought the CS Catch Cans were getting there tops blown off... has this been fixed? thought the tops weren't welded. |
Yeah, the tops are blowing off the cs cans. They are revising the design, but I think the problem is either their install instructions or people not using check valves because the can shouldn't be pressurized. Contact Matt Damond or Jbr, I haven't heard a single complaint about them. Tappin' |
You think exactly what I thought until it happened to me- http://www.mazdaspeedforums.org/foru...ailure-135275/ There SHOULD not be any need for a CV with the corksport OCC setup due to the routing. |
I haven't done much research into it, is their routing different than jbr or MD? Tappin' |
Yes, with their routing the OCC should never see any boost. They have you cap the intake manifold and route it to what used to be the factory valve cover vent which is pre-turbo and should only see vacuum in theory. Hence why they no longer offer a check valve. |
Installed my Matt D. OCC today. I didnt take off the hose on the pcv valve but kept it there since I could not get it off, I used a hose barb and connected the oem hose that I left to the hose in the kit. Took me a few hours but no leaks, no cels, and I'm happy about the install. Drilled a hole under the engine tray for access for draining also. |
hi, i'm sorry if this is a dumb question, but which line do you guys use OCC for - the head cover venting, or the oil pan pcv?? |
Does anyone know if Matt Damond is still in business? I purchased a catch can from him in April...I haven't heard anything from him. I've tried to call him a few times and left messages, I haven't heard anything back. Thanks. |
@MATT DAMOND; He's alive (AFAIK) I've heard he just gets really busy but once he makes contact with you, you'll get it fast. |
ok thanks |
I was told that he is back ordered on his OCC kits, but in the process of getting more. @MATT DAMOND; is a great guy and definitely still alive! |
Sorry for any trouble I may have caused. I'm new to MS3's and started getting worried when I couldn't contact you. I guess I do have a question about the OCCs. How long does it take for the Intake Valves to get crudded up? I heard the Audi doesn't take long and would like to avoid any associated IV servicing. It's surprising that if that's how simple the fix is, the factories don't just install them at the factory. |
Oil catch can You guys that already have catch cans.....did it cut down on blow by out the tail pipe ....if so , by alot or......? And which one do you have ....I was thinking James Barone.....just wish it had a dipstick or something to see how full it is |
If you mean soot/carbon... then it will not remedy that either. A tune will help it. Read up a bit more. |
How do i purchase an OCC from MATT DAMON? Thanks |
I'd call his agent. He probably handles all of Matt's mundane tasks. Dude is probably busy with his acting career. However, if you want a @MATT DAMOND; kit I'd look at his website here or mention him, as I just did. |
what about this catchcan: Large VMS Aluminum Oil Reservoir Catch Can Tank with Breather Filter Baffled Red | eBay It has a breather filter on top. Is that supposed to be an alternative to a check valve by allowing it to vent to atmosphere? |
The check valve is used when you run from the crankcase to the intake. That way your not boosting your crankcase and oil catch can.. lol There is a thread that goes into great detail about oil catch cans vented/non-vented. You should read up more on what route you want to go. |
wtf first of all you fucks are confusing two different types of occ's. you cannot run a vented occ from IM to PCV because you will cause a massive vacuum leak. (pull) You can run a vented OCC from valve cover (push) for that matter you could just stick a hose on there and point it down. |
2 Attachment(s) Hello dead thread! one question about the JBR vented catch can (stage 2) , i have it already installed. Right now i have this kit installed on my car, but there is oil leaking. Only thing i could think of is the drain valve is open. but when i "closed it" if it was opened in the first place, it caused my turbo to leak :S.. i got oil all over my turbo and got a lot of smoke going from my exhaust I will lift the car on Thursday and change my clutch so i'm asking, which if these catch can drain valve is closed? also the check valve, where should it point? toward the catch can or the PCV? my routing is at states in the manual. one tube is going to the PCV and one is going to the valve cover from the lower point of the catch can with a T connection, and the top exit on the catch can is VTA thanks in advance |
@leka; you have your routing all wrong, it should be from the crank case to the cc then to the intake manifold. check valve goes to the intake manifold, lets air go into it. |
So your running both the crank case and valve cover to a T then to the CC, then to a filter at the CC for VTA. You don't even need a check valve in that situation. |
But as i'm thinking right now i think I have the check valve toward the catch can, and need someone to correct me if it is wrong. also as the pictures shows, left and right, which of these are actually closed? |
Crank case closed is wrong. that's why your blowing oil into your turbo. Also a T for pcv to valve cover makes no sense. your trying to pull all the pressure through your crank case is dumb. that and the T means your not filtering anything, it's going straight back into the intake. |
The crank case is closed, and it's runing to the pcv and the valve cover. Also I actually have oil runing inside my fmic piping. And I do not have a valve cover connection to the intake http://img.tapatalk.com/d/14/08/13/a7ygy8am.jpg |
Once again, wrong. Uninstall everything. Actually try to read the directions when you try to install it again, cuz your all kinds of fucked up. |
http://www.jamesbaroneracing.com/sup...uctions-v3.pdf http://www.jamesbaroneracing.com/sup...nstruction.pdf Read those two. I don't know what instructions you got, but this will be a start. Basically you will block off the intake manifold port, route the crank case and valve cover together to a T then to the CC and then the CC will go VTA. READ READ READ. Also I would just take out the Check Valve, it's useless now with VTA. |
And I'm sorry for that miss understanding. [emoji53] Just need to know the direction of the check valve. Regards |
Yes, it would because it would block all air from going to the catch can. if your not going to remove it. make sure it is facing toward the catch can. And yes pressure building with nowhere to go in your engine is bad, for everything. |
I have 350whp mazdaspeed 6 and i don't know these basic things, I shouldn't have this car [emoji52] |
Right tight, left loose. |
Why run the vented setup? |
Sent from my GS3 running CM11, via FapDaCock |
To clear things upp, when the threads are visible on the drain plug, it means that it is closed, and when not visible it's open. |
QUESTION!!! i just bought a helix catch can (check valve included on the side) i have no bracket, bought it second hand but in amazing condition. now i need to know the thread size/pitch for the bolts and locking nuts to mount this fcker. the bracket i can bend and make myself with an aluminum flat bar. 08 MS3 JBR short ram, straight piped exh |
Is you question that you need help figuring out what mount and hardware you should fabricate? I ended up using two of these to mount my CC: http://www.siliconeintakes.com/liqui...ket-p-715.html 2.5"-5.5" diameters available. |
Yeah but actually forget that. I'll just cross thread or drill new holes and fit them. No one has a straight answer about installing a catch can. The stock pcv on an 08? Why do you need one at all after having a catch can with check valve attached. And why does corksort show hoses from the bottom as normal and then a third hose from the valve hose down to the catch can as well. I mean what the fuck????!!! No one has one fucking solution and straight answer |
I used JBR installation guide to mount mine, check that one out. |
Just bought my genpu ms3. Previous owner provided a cozmic vented occ that isn't installed yet. Is there any advantage or disadvantage to running that as opposed to something like the JBR occ? |
Vented catch cans only work with strategically placed check valves OR if the entire crankcase ventilation system is isolated from the intake system. |
| All times are GMT -7. The time now is 07:46 AM. |
