-   -   Oil Catch Can Question (http://www.mazdaspeedforums.org/forum/f10/oil-catch-can-question-127156/)
dooderek 05-23-2014 09:12 AM
wtf first of all you fucks are confusing two different types of occ's.
you cannot run a vented occ from IM to PCV because you will cause a massive vacuum leak. (pull)
You can run a vented OCC from valve cover (push)
for that matter you could just stick a hose on there and point it down.
Lex2007 05-23-2014 01:03 PM
Originally Posted by dooderek (Post 2593560)
wtf first of all you fucks are confusing two different types of occ's..
You need to take your meds...you have not achieved the therapeutic dose.
leka 08-12-2014 05:22 PM
Hello dead thread!
one question about the JBR vented catch can (stage 2) , i have it already installed.
Right now i have this kit installed on my car, but there is oil leaking. Only thing i could think of is the drain valve is open. but when i "closed it" if it was opened in the first place, it caused my turbo to leak :S..
i got oil all over my turbo and got a lot of smoke going from my exhaust
I will lift the car on Thursday and change my clutch so i'm asking, which if these catch can drain valve is closed?
also the check valve, where should it point? toward the catch can or the PCV?
my routing is at states in the manual. one tube is going to the PCV and one is going to the valve cover from the lower point of the catch can with a T connection, and the top exit on the catch can is VTA
thanks in advance
Fjager 08-12-2014 06:02 PM
@leka; you have your routing all wrong, it should be from the crank case to the cc then to the intake manifold. check valve goes to the intake manifold, lets air go into it.
leka 08-12-2014 06:04 PM
I'm running vta, I'm suppose to run it to the valve cover
Fjager 08-12-2014 06:16 PM
So your running both the crank case and valve cover to a T then to the CC, then to a filter at the CC for VTA. You don't even need a check valve in that situation.
leka 08-12-2014 06:20 PM
No, I'm running as I wrote before, PCV and valve cover as a T connection. crank case is closed.
But as i'm thinking right now i think I have the check valve toward the catch can, and need someone to correct me if it is wrong.
also as the pictures shows, left and right, which of these are actually closed?
Fjager 08-12-2014 06:23 PM
Crank case closed is wrong. that's why your blowing oil into your turbo. Also a T for pcv to valve cover makes no sense. your trying to pull all the pressure through your crank case is dumb. that and the T means your not filtering anything, it's going straight back into the intake.
leka 08-12-2014 06:28 PM
Thanks for the reply, but this picture is taken from the manual
The crank case is closed, and it's runing to the pcv and the valve cover. Also I actually have oil runing inside my fmic piping. And I do not have a valve cover connection to the intake
http://img.tapatalk.com/d/14/08/13/a7ygy8am.jpg
Fjager 08-12-2014 06:41 PM
Once again, wrong. Uninstall everything. Actually try to read the directions when you try to install it again, cuz your all kinds of fucked up.
leka 08-12-2014 06:45 PM
I feel like fucked up.. could you be kind and tell me the routing including the check valve with the vta please? I have the version 2 of the jbr. I feel lost with this manual.. [emoji45]
Fjager 08-12-2014 07:00 PM
http://www.jamesbaroneracing.com/sup...uctions-v3.pdf
http://www.jamesbaroneracing.com/sup...nstruction.pdf
Read those two. I don't know what instructions you got, but this will be a start.
Basically you will block off the intake manifold port, route the crank case and valve cover together to a T then to the CC and then the CC will go VTA. READ READ READ.
Also I would just take out the Check Valve, it's useless now with VTA.
leka 08-12-2014 07:07 PM
I will probably make you mad. But I miss understood the pcv is actually connected to the T on the catch can and to the valve cover. The intake port is blocked.. but I think the problem here is actually the check valve is wrong direction. Would that have that effekt on the turbo?
And I'm sorry for that miss understanding. [emoji53]
Just need to know the direction of the check valve.
Regards
Fjager 08-12-2014 07:10 PM
Yes, it would because it would block all air from going to the catch can.
if your not going to remove it. make sure it is facing toward the catch can.
And yes pressure building with nowhere to go in your engine is bad, for everything.
leka 08-12-2014 07:15 PM
Ok, so I will remove the check valve, if it's as you say, useless. But you could not tel about the drain valve which is open and which is closed?
I have 350whp mazdaspeed 6 and i don't know these basic things, I shouldn't have this car [emoji52]
Fjager 08-12-2014 07:18 PM
Right tight, left loose.
2012FailWheelDrive 08-12-2014 08:27 PM
Why run the vented setup?
aromig 08-13-2014 07:53 PM
If you're running a crazy amount of hp over stock, it relieves all that extra pressure better
Sent from my GS3 running CM11, via FapDaCock
2012FailWheelDrive 08-14-2014 01:55 PM
haha yea I know. I think OP would be fine with a sealed configuration though. I had just one sealed can when i had my gtx3071 at ~400hp and it worked perfect. Now that I'm built I am running dual cans with the perm plate just to be safe.
leka 08-14-2014 01:57 PM
To clear things upp, when the threads are visible on the drain plug, it means that it is closed, and when not visible it's open.
aromig 08-14-2014 02:16 PM
That sounds like quite the nice setup. I guess a vta might be functionally comparable to that, but less money?
shmallz92 02-12-2015 08:51 AM
QUESTION!!! i just bought a helix catch can (check valve included on the side) i have no bracket, bought it second hand but in amazing condition. now i need to know the thread size/pitch for the bolts and locking nuts to mount this fcker. the bracket i can bend and make myself with an aluminum flat bar.
08 MS3 JBR short ram, straight piped exh
Mattyhawk1 02-12-2015 09:50 AM
Is you question that you need help figuring out what mount and hardware you should fabricate?
I ended up using two of these to mount my CC:
http://www.siliconeintakes.com/liqui...ket-p-715.html
2.5"-5.5" diameters available.
shmallz92 02-12-2015 10:18 AM
Yeah but actually forget that. I'll just cross thread or drill new holes and fit them. No one has a straight answer about installing a catch can. The stock pcv on an 08? Why do you need one at all after having a catch can with check valve attached. And why does corksort show hoses from the bottom as normal and then a third hose from the valve hose down to the catch can as well. I mean what the fuck????!!! No one has one fucking solution and straight answer
Mattyhawk1 02-13-2015 08:47 PM
I used JBR installation guide to mount mine, check that one out.
Adam.kennedy23 06-01-2019 10:15 PM
Just bought my genpu ms3. Previous owner provided a cozmic vented occ that isn't installed yet. Is there any advantage or disadvantage to running that as opposed to something like the JBR occ?
Fstrnyou 06-04-2019 11:08 AM
Vented catch cans only work with strategically placed check valves OR if the entire crankcase ventilation system is isolated from the intake system.
Page generated in 0.20086 seconds with 11 queries
