![]() | | #1 | ![]() |
![]() Join Date: Sep 2011 Location: Rocky Hill, CT
Rep Power: 45 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score I'm looking to buy the SURE oil rig, but it doesn't come with a check valve. Now I know that the reason you need a check valve is because the OEM PCV valve doesn't seal 100% when under boost. Will not having a check valve reduce the efficiency of the OCC, meaning it will allow more crud back into the intake? Just curious because the car operates normally with the leaky PCV and most of the OCC kits can be had with or without the check valve. Also for anyone who has bought the check valve separately what valve do you use? I know some people have used a second PCV valve, but others have cheaper check valves that work equally as well. |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 10081 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,769
Groans: 98
def get a check valve dont use a second PCV buy this check valve and hose barbs from mcmaster http://www.mcmaster.com/nav/enter.as...54&pagenum=474 http://www.mcmaster.com/nav/enter.as...12&pagenum=267
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 366 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,124
Groaned at 4 Times in 2 Posts
| Not Ranked : 0 score Mazda and Mazdaspeed Oil Catch Can by Corksport Corksport is an option too, it's a little cheaper than SURE and you can get a check valve through them for $10 more. It is only listed in the Gen 2 section for some reason and I think that's what the install instructions are written for. Genjuan should be pretty close, but if you've got a MS6 you might have to get a little creative with the install. Or contact MATT DAMOND, not sure what his kits go for, but people seem to be happy with them.
__________________ Old: 2011 Red Mica Speed 3 w/tech - stocked and traded New: 2013 Dodge Journey - Family CruiserFuture: Another race car, MS6 maybe? |
![]() | | #4 | ![]() |
![]() | | #5 | ![]() |
![]() Join Date: Sep 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 294
__________________ 2008 MGM MS3 GT -- Prone to acts of jackassery |
| The Following User Says Thank You to Chief_Wiggum For This Useful Post: | jbarone (02-03-2013) |
![]() | | #6 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 8101 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,037
Groans: 121
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ |
![]() | | #7 | ![]() |
| baby squirrel sexy mofo ![]() Join Date: May 2011 Location: Portland OR
Rep Power: 1576 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,274
Groans: 185
Groaned at 16 Times in 16 Posts
Why does the MD kit have the valve on the manifold side but the JBR has it on the block side
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
![]() | | #8 | ![]() |
Groans: 121
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ | |
| The Following User Says Thank You to silvapain For This Useful Post: | breakfstincluded (10-14-2012) |
![]() | | #9 | ![]() |
Groans: 185
right, so i wonder why JBR's is the opposite
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. | |
![]() | | #10 | ![]() |
![]() Join Date: Sep 2012 Location: CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
Just ordered the Matt D one. Looking forward to installing it.
__________________ 2012 Crystal White Speed 3 w/ Tech JBR SRI | JBR TIP |
![]() | | #11 | ![]() |
![]() Join Date: Mar 2011 Location: Greenwood, SC
Rep Power: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 150
Ok, so I see that there are 3 different versions. Just different mounting points. Is the Version 1 the best solution if you have/ or will have a FMIC?
__________________ 08 MGM Speed 3=SURE Rmm/ShortCut/Anchors/Return,COBB AP/SF/TIP,TurboSmart B.O.V,BC Coilovers/SWIFT Springs,SPC R.C.A, M2 DP, CNT CBE, Autotech Internals, SSP EGR Delete, DDM 6K |
![]() | | #12 | ![]() |
![]() Join Date: Jun 2009 Location: atlanta georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
i thought the CS Catch Cans were getting there tops blown off... has this been fixed? thought the tops weren't welded.
__________________ - Hyper-Tech Tune - Mazdaspeed CAI - Hotchkiss rear Sway Bar - Street Unit Rear Motor Mount - CNT CatBack Exhaust - JBarone Short Shifter Stage II - Koni 4045 struts - Cobb Springs - CPE Turbo Inlet - DDM Tuning Low Beam/ Fog HIDS - Lamin-X Yellow Tint on Fog Lights - JBarone Black Shift Knob - JBarone mud flaps - Painted red brake calipers - Veil coating all lights - TSW Mallory Wheels - Mazdaspeed Vinyl Front only - Thule Bike Rack with 598 Criterium Bike Mount - GX-65 with Blendmount |
![]() | | #13 | ![]() |
Yeah, the tops are blowing off the cs cans. They are revising the design, but I think the problem is either their install instructions or people not using check valves because the can shouldn't be pressurized. Contact Matt Damond or Jbr, I haven't heard a single complaint about them. Tappin'
![]() | | #14 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 577 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,598
Groans: 252
You think exactly what I thought until it happened to me- http://www.mazdaspeedforums.org/foru...ailure-135275/ There SHOULD not be any need for a CV with the corksport OCC setup due to the routing.
__________________ 2011 Mazdaspeed 3- AccessPORT, Autotech HPFP Internals, AEM (Homemade) Short Intake, 3" Catless Downpipe, Cobb TIH, Corksport SSP, CPE Stage 2 RMM, Custom Saikou Michi OCC, Forge V2 BPV, MME Shifter Bushings, ITV22's 2012 Focus 1995 Mustang- Project Xcessive Force 1985 Grand Wagoneer 2009 GSXR-600 |
| The Following User Says Thank You to El_Diablo For This Useful Post: | ASHMS3 (01-14-2013) |
![]() | | #15 | ![]() |
I haven't done much research into it, is their routing different than jbr or MD? Tappin'
![]() | | #16 | ![]() |
Groans: 252
Yes, with their routing the OCC should never see any boost. They have you cap the intake manifold and route it to what used to be the factory valve cover vent which is pre-turbo and should only see vacuum in theory. Hence why they no longer offer a check valve.
![]() | | #17 | ![]() |
![]() Join Date: Sep 2012 Location: Montreal, Canada
Rep Power: 0 ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score |
![]() | | #18 | ![]() |
Installed my Matt D. OCC today. I didnt take off the hose on the pcv valve but kept it there since I could not get it off, I used a hose barb and connected the oem hose that I left to the hose in the kit. Took me a few hours but no leaks, no cels, and I'm happy about the install. Drilled a hole under the engine tray for access for draining also.
![]() | | #19 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 58 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
hi, i'm sorry if this is a dumb question, but which line do you guys use OCC for - the head cover venting, or the oil pan pcv?? |
![]() | | #20 | ![]() |
![]() Join Date: Sep 2009 Location: Orlando, FL
Rep Power: 66 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Damnit, I wish I knew this when I installed my OCC. Stock PCV ftl. Ordered check valve. Thank you.
__________________ 2008 Mazdaspeed 3 - True Red Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CPE Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass Drivetrain: Jbarone Short Shift Plate, SU Shifter Bushings, Dogbone RMM, CPE Driver MM Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings Future: Meth, VVT, BNR S3 (when the K04 blows) | |
![]() | | #21 | ![]() |
Groans: 121
| Not Ranked : 0 score Crankcase venting. You can use a second OCC for the valve cover vent if you like though.
![]() | | #22 | ![]() |
![]() Join Date: May 2013
Rep Power: 0 ![]() Thanks: 0
Does anyone know if Matt Damond is still in business? I purchased a catch can from him in April...I haven't heard anything from him. I've tried to call him a few times and left messages, I haven't heard anything back. Thanks. |
| The Following User Says Thank You to Beercules For This Useful Post: | Damond Motorsports (05-20-2013) |
![]() | | #23 | ![]() |
![]() Join Date: Aug 2012 Location: Pittsburgh, PA
Rep Power: 396 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 668
Groaned at 25 Times in 6 Posts
| Not Ranked : 0 score MATT DAMOND; He's alive (AFAIK) I've heard he just gets really busy but once he makes contact with you, you'll get it fast.
__________________ 2006 Mazdaspeed 6 (Titanium Gray) : SU TMIC || SURE RMM ||Greddy bov (full recirc.) || Eibach pro-kit || TWM STS stg 2 || Muffler Delete || CS SS Clutch line || TWM Shift boot || JBR shifter bushings || JBR Spherical Knob || Block8head dual gauge vent pod with prosport evo and glowshift gauges. 1995 Subaru SVX AWD (Polo Green) For Sale : slotted and drilled rotors, ceramic pads. 193k miles. RP oil every change. Freshly rebuilt trans. (less than 2k miles on it) Not currently inspected... So price is very negotiable |
| The Following 2 Users Say Thank You to DVM17 For This Useful Post: | Damond Motorsports (05-20-2013), silvapain (05-20-2013) |
![]() | | #24 | ![]() |
ok thanks
![]() | | #25 | ![]() |
![]() Join Date: Dec 2012 Location: Columbus, OH
Rep Power: 14 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
I was told that he is back ordered on his OCC kits, but in the process of getting more. MATT DAMOND; is a great guy and definitely still alive!
__________________ 2006 Velocity Red Mica MS6 GT |
| The Following User Says Thank You to RedRyderBB6 For This Useful Post: | Damond Motorsports (05-20-2013) |
![]() | | #26 | ![]() |
Groans: 252
| Not Ranked : 0 score His OCC supplier, Saikou Michi, said they were really backed up with orders last time I talked to the owner which was about a month ago. That might be part of the delay.
| The Following User Says Thank You to El_Diablo For This Useful Post: | Damond Motorsports (05-20-2013) |
![]() | | #27 | ![]() |
| Approved MSF Vendor ![]() Join Date: Mar 2013 Location: N Aurora, IL
Rep Power: 110 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 79
I am indeed very back ordered at the moment, due to suppliers. If it was up to me, I'd have everything stock piled, like if the world were to end.
__________________ | |
![]() | | #28 | ![]() |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 3406 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,289
Groans: 142
__________________ ![]() | |
| The Following User Says Thank You to helmetface For This Useful Post: | Damond Motorsports (05-20-2013) |
![]() | | #29 | ![]() |
Sorry for any trouble I may have caused. I'm new to MS3's and started getting worried when I couldn't contact you. I guess I do have a question about the OCCs. How long does it take for the Intake Valves to get crudded up? I heard the Audi doesn't take long and would like to avoid any associated IV servicing. It's surprising that if that's how simple the fix is, the factories don't just install them at the factory. |
| 2nd gen catch can kit? | bmannn | Gen2 MS3 General Discussion | 12 | 04-27-2011 02:39 PM |
| oil catch can | mroclimbr | Mazdaspeed3/6 General Discussion | 13 | 04-04-2011 02:20 PM |
| DIY Oil Catch Can | drewsifer86 | MazdaSpeed 3 - How-To's | 14 | 07-22-2010 08:02 PM |
| oil catch can? | nyghtryder | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 06-07-2009 06:17 PM |
| $20 catch can yay or nay? | kraz3y | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 04-30-2008 03:58 AM |
