Like Tree3Likes
 Old 05-23-2014, 09:12 AM   #41
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
wtf first of all you fucks are confusing two different types of occ's.
you cannot run a vented occ from IM to PCV because you will cause a massive vacuum leak. (pull)
You can run a vented OCC from valve cover (push)
for that matter you could just stick a hose on there and point it down.
 Old 05-23-2014, 01:03 PM   #42
Lex2007's Avatar
Posts: 574   (View Stats)
Originally Posted by dooderek View Post
wtf first of all you fucks are confusing two different types of occ's..
You need to take your meds...you have not achieved the therapeutic dose.
The Following User Says Thank You to Lex2007 For This Useful Post:
aromig (05-23-2014)
 Old 08-12-2014, 05:22 PM   #43
leka's Avatar
Posts: 144   (View Stats)
leka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to beholdleka is a splendid one to behold
Hello dead thread!
one question about the JBR vented catch can (stage 2) , i have it already installed.
Right now i have this kit installed on my car, but there is oil leaking. Only thing i could think of is the drain valve is open. but when i "closed it" if it was opened in the first place, it caused my turbo to leak :S..
i got oil all over my turbo and got a lot of smoke going from my exhaust
I will lift the car on Thursday and change my clutch so i'm asking, which if these catch can drain valve is closed?
also the check valve, where should it point? toward the catch can or the PCV?
my routing is at states in the manual. one tube is going to the PCV and one is going to the valve cover from the lower point of the catch can with a T connection, and the top exit on the catch can is VTA
thanks in advance
leka is offline   Reply With Quote
 Old 08-12-2014, 06:02 PM   #44
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
@leka; you have your routing all wrong, it should be from the crank case to the cc then to the intake manifold. check valve goes to the intake manifold, lets air go into it.
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Fjager is offline   Reply With Quote
 Old 08-12-2014, 06:04 PM   #45
leka's Avatar
I'm running vta, I'm suppose to run it to the valve cover
Mazdaspeed 6 2006
Sp63 Longblock with Mahle and manly, ported head, keyed crank and cams, stiffer springs, GTX2867R IWG, Freaks intake 4 inch,Autotech Internals, Stratified Ebc + GA, CP-E injector seals, CS Custom pipes FMIC, Snow performance stage2 100% meth, Cp-E decatted downpipe, Custom Catback with VareX mufflers, EGR Delete, SURE TMM+PMM+RMM, South Bend Clutch Stage3 Daily, CS rear diff mount, TurbineTech Front diff mount, CS rear swaybar, Racingbeat rear Endlinks, Matt Damond PS cooler, JBR OCC Stage 2, Bosch 3 bar MAP w/ PNP Harness, BC coilovers, Tenzo R Type M 19" 235/35, Sure Shortshift, Xcarlink, Speed performance Aux fan control, Synchronic DV BOV, DBA front rotor, Ebc yellow stuff(FR), EBC greenstuff (R), Stoptech brakelines and Finally, Tuned By Lex @ Stratified
Current INFO : tuning is paused due the winter.
Waiting to be installed: Cp-e exhaust manifold stock flange with MVR 44 external wastegate and dump tube.
 Old 08-12-2014, 06:16 PM   #46
Fjager's Avatar
So your running both the crank case and valve cover to a T then to the CC, then to a filter at the CC for VTA. You don't even need a check valve in that situation.
FMIC W/DIY Sprayer
CPE DP
 Old 08-12-2014, 06:20 PM   #47
leka's Avatar
No, I'm running as I wrote before, PCV and valve cover as a T connection. crank case is closed.
But as i'm thinking right now i think I have the check valve toward the catch can, and need someone to correct me if it is wrong.
also as the pictures shows, left and right, which of these are actually closed?
 Old 08-12-2014, 06:23 PM   #48
Fjager's Avatar
Crank case closed is wrong. that's why your blowing oil into your turbo. Also a T for pcv to valve cover makes no sense. your trying to pull all the pressure through your crank case is dumb. that and the T means your not filtering anything, it's going straight back into the intake.
FMIC W/DIY Sprayer
CPE DP
 Old 08-12-2014, 06:28 PM   #49
leka's Avatar
Thanks for the reply, but this picture is taken from the manual
The crank case is closed, and it's runing to the pcv and the valve cover. Also I actually have oil runing inside my fmic piping. And I do not have a valve cover connection to the intake
Mazdaspeed 6 2006
 Old 08-12-2014, 06:41 PM   #50
Fjager's Avatar
Once again, wrong. Uninstall everything. Actually try to read the directions when you try to install it again, cuz your all kinds of fucked up.
FMIC W/DIY Sprayer
CPE DP
 Old 08-12-2014, 06:45 PM   #51
leka's Avatar
I feel like fucked up.. could you be kind and tell me the routing including the check valve with the vta please? I have the version 2 of the jbr. I feel lost with this manual..
Mazdaspeed 6 2006
 Old 08-12-2014, 07:00 PM   #52
Fjager's Avatar
http://www.jamesbaroneracing.com/sup...uctions-v3.pdf
http://www.jamesbaroneracing.com/sup...nstruction.pdf
Read those two. I don't know what instructions you got, but this will be a start.
Basically you will block off the intake manifold port, route the crank case and valve cover together to a T then to the CC and then the CC will go VTA. READ READ READ.
Also I would just take out the Check Valve, it's useless now with VTA.
FMIC W/DIY Sprayer
CPE DP
Last edited by Fjager; 08-12-2014 at 07:00 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-12-2014, 07:07 PM   #53
leka's Avatar
I will probably make you mad. But I miss understood the pcv is actually connected to the T on the catch can and to the valve cover. The intake port is blocked.. but I think the problem here is actually the check valve is wrong direction. Would that have that effekt on the turbo?
And I'm sorry for that miss understanding.
Just need to know the direction of the check valve.
Regards
Mazdaspeed 6 2006
 Old 08-12-2014, 07:10 PM   #54
Fjager's Avatar
Yes, it would because it would block all air from going to the catch can.
if your not going to remove it. make sure it is facing toward the catch can.
And yes pressure building with nowhere to go in your engine is bad, for everything.
FMIC W/DIY Sprayer
CPE DP
 Old 08-12-2014, 07:15 PM   #55
leka's Avatar
Ok, so I will remove the check valve, if it's as you say, useless. But you could not tel about the drain valve which is open and which is closed?
I have 350whp mazdaspeed 6 and i don't know these basic things, I shouldn't have this car
Mazdaspeed 6 2006
 Old 08-12-2014, 07:18 PM   #56
Fjager's Avatar
Right tight, left loose.
FMIC W/DIY Sprayer
CPE DP
 Old 08-12-2014, 08:27 PM   #57
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world
Why run the vented setup?
"under construction"
2012FailWheelDrive is offline   Reply With Quote
 Old 08-13-2014, 07:53 PM   #58
aromig's Avatar
Posts: 289   (View Stats)
aromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the worldaromig is the leader of the world
If you're running a crazy amount of hp over stock, it relieves all that extra pressure better
Sent from my GS3 running CM11, via FapDaCock
"I apologize for nothing!" - Hedonismbot
aromig is offline   Reply With Quote
 Old 08-14-2014, 01:55 PM   #59
haha yea I know. I think OP would be fine with a sealed configuration though. I had just one sealed can when i had my gtx3071 at ~400hp and it worked perfect. Now that I'm built I am running dual cans with the perm plate just to be safe.
 Old 08-14-2014, 01:57 PM   #60
leka's Avatar
To clear things upp, when the threads are visible on the drain plug, it means that it is closed, and when not visible it's open.
Mazdaspeed 6 2006
 Old 08-14-2014, 02:16 PM   #61
aromig's Avatar
That sounds like quite the nice setup. I guess a vta might be functionally comparable to that, but less money?
 Old 02-12-2015, 08:51 AM   #62
shmallz92's Avatar
Posts: 11   (View Stats)
shmallz92 has a little shameless behaviour in the past
QUESTION!!! i just bought a helix catch can (check valve included on the side) i have no bracket, bought it second hand but in amazing condition. now i need to know the thread size/pitch for the bolts and locking nuts to mount this fcker. the bracket i can bend and make myself with an aluminum flat bar.
08 MS3 JBR short ram, straight piped exh
shmallz92 is offline   Reply With Quote
 Old 02-12-2015, 09:50 AM   #63
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
Is you question that you need help figuring out what mount and hardware you should fabricate?
I ended up using two of these to mount my CC:
http://www.siliconeintakes.com/liqui...ket-p-715.html
2.5"-5.5" diameters available.
Mattyhawk1 is offline   Reply With Quote
 Old 02-12-2015, 10:18 AM   #64
shmallz92's Avatar
Yeah but actually forget that. I'll just cross thread or drill new holes and fit them. No one has a straight answer about installing a catch can. The stock pcv on an 08? Why do you need one at all after having a catch can with check valve attached. And why does corksort show hoses from the bottom as normal and then a third hose from the valve hose down to the catch can as well. I mean what the fuck????!!! No one has one fucking solution and straight answer
 Old 02-13-2015, 08:47 PM   #65
Mattyhawk1's Avatar
I used JBR installation guide to mount mine, check that one out.
 Old 06-01-2019, 10:15 PM   #66
Adam.kennedy23's Avatar
Posts: 1   (View Stats)
Adam.kennedy23 is an unknown quantity at this point
Just bought my genpu ms3. Previous owner provided a cozmic vented occ that isn't installed yet. Is there any advantage or disadvantage to running that as opposed to something like the JBR occ?
Adam.kennedy23 is offline   Reply With Quote
 Old 06-04-2019, 11:08 AM   #67
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Vented catch cans only work with strategically placed check valves OR if the entire crankcase ventilation system is isolated from the intake system.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
2nd gen catch can kit? bmannn Gen2 MS3 General Discussion 12 04-27-2011 03:39 PM
oil catch can mroclimbr Mazdaspeed3/6 General Discussion 13 04-04-2011 03:20 PM
DIY Oil Catch Can drewsifer86 MazdaSpeed 3 - How-To's 14 07-22-2010 09:02 PM
oil catch can? nyghtryder MazdaSpeed 3 - Engine, Transmission & Driveline 10 06-07-2009 07:17 PM
$20 catch can yay or nay? kraz3y MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-30-2008 04:58 AM
Page generated in 0.45740 seconds with 30 queries
