  • 1 Post By stockms3
 Old 02-11-2017, 10:35 PM   #1
ThatJuanMS3's Avatar
Posts: 38   (View Stats)
ThatJuanMS3 has a spectacular aura aboutThatJuanMS3 has a spectacular aura about
Default Oil leak
So for the past couple weeks I've had a very annoying oil leak. It seems to be coming from the right of the pcv or above to the right of the oil filter . In the picture the pcv cover is that black thing to the right and the bottom of the car would be to the left. Crappy picture because of how uncomfortable it is in there. Where could this oil be coming from? Options?
ThatJuanMS3 is offline   Reply With Quote
 Old 02-11-2017, 10:54 PM   #2
mituc's Avatar
Posts: 3,511   (View Stats)
Groans: 111
Get a new PCV, a new PCV housing gasket and a new IM to head gasket, pull the IM and the PCV, replace them, and see how things go after that.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 02-11-2017, 11:55 PM   #3
i just swapped the PCV and the PCV housing gasket. i checked the IM gasket and it seems fine. the leak seems to come from just above and slightly to the right of the oil filter, around that cylinder shaped thing which i have no clue what it is. it kind of looks like it is shooting up but im not completely sure.
 Old 02-12-2017, 08:00 AM   #4
mituc's Avatar
Groans: 111
That cylinder shaped thing is the oil filter housing from what you're describing. There are some o-rings and seals there, maybe one let go.
 Old 02-12-2017, 04:12 PM   #5
Could this be The issue?
 Old 02-12-2017, 05:36 PM   #6
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
It could be. Replace and see if it helps. The rust is pretty normal i think that part is exposed so it is natural that the lower parts rusts.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
The Following User Says Thank You to stockms3 For This Useful Post:
ThatJuanMS3 (02-12-2017)
 Old 02-13-2017, 08:13 PM   #7
So the new gasket didn't really do much. The leak drips down and ends here. Any ideas? Picture is flipped sorry
 Old 02-13-2017, 09:51 PM   #8
mituc's Avatar
Groans: 111
Maybe that's transmission oil... how does your pivot shaft area looks like? The pivot shaft seal is known to let go after a while.
 Old 02-13-2017, 10:00 PM   #9
I can see the oil drop on my dipstick so idk if that would be it.
In this picture you can see the oil is coming from the right of the PCV. It's near the egr tube that goes into the IM.
 Old 02-14-2017, 12:07 AM   #10
stockms3's Avatar
Groans: 74
Another thing you can try is using dye. It is pretty easy to use. You need dye, UV light and yellow safety glasses.
It would definitely help you to pin point the leak. Otherwise, clean the whole area then run the car for a few minutes and try to find the source. Start at the top and work your way down. It is quite hard to help you from the pictures.
ThatJuanMS3 likes this.
MD1032 (02-14-2017)
 Old 05-21-2017, 03:46 PM   #11
Batmzr's Avatar
Posts: 4   (View Stats)
Batmzr is an unknown quantity at this point
Default Similar problem driver side of engine
I think I have a similar problem. The oil seems to be collecting above the transmission at the top as well. I attached some pictures. Even look at the tray ,only collecting the on the driver side .
Batmzr is offline   Reply With Quote
 Old 05-21-2017, 06:57 PM   #12
Bingo's Avatar
Posts: 736   (View Stats)
Groaned at 9 Times in 7 Posts
Glad you read your welcome PM about your first post.
Also that is not the same as OP's. You have this: HOW-TO: shaft pivot seal replaced
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 04-16-2018, 06:57 PM   #13
update, engine was on its way out. it was blow by mixed with seals giving out, just dropped a new engine in and its all good.
Boost leak testing, possibly Wastegate/Actuator leak AgentWh0 2010 MS3 - Troubleshoot/Diagnostics 0 08-04-2015 11:29 AM
air leak somewhere Keefer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-15-2015 10:11 PM
Please Help... Oil Leak... rx7fc3s87 MazdaSpeed 3 - Engine, Transmission & Driveline 5 03-29-2013 04:31 AM
Oil leak. Please help fcfanatic Miata - Engine, Transmission, Driveline 5 07-13-2010 12:25 AM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 12:06 PM
Page generated in 0.33118 seconds with 25 queries
