  • 1 Post By Db09ms3
 Old 01-05-2020, 06:39 PM   #1
rudydecc's Avatar
Posts: 113   (View Stats)
rudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud ofrudydecc has much to be proud of
Default Oil leak - recommended fixes
Have a slight oil leak on top of the valve cover. Itís been there for a while (4-6 years, and in someways maybe longer 🤷🏼ó♂️).
Any idea on where it would be from and what it would cost to fix it? I think itís the oil pressure sensor, but thatís just a guess.
File Type: jpeg B34229F0-476D-4FC8-BD3E-5021F1AA3A49.jpeg (1.00 MB, 11 views)
2008 Mazdaspeed3 GT ::COBB STS/Turbo Inlet/AP/SW/BPV, Fujita F5 CAI, CP-E RMM/DP/CBE/FMIC, TWM Shifter Bushings/JBR Side Mounts::
2019 Audi Q7
rudydecc is offline   Reply With Quote
 Old 01-06-2020, 10:56 AM   #2
Db09ms3's Avatar
Posts: 531   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 104
Looks like the vvt solenoid seal is leaking.
https://edgeautosport.com/mazda-oem-...d-6-2006-2013/
kwambe5 likes this.
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
cyclist20 (01-06-2020)
 Old 01-07-2020, 03:10 PM   #3
Jeff23spl's Avatar
Posts: 2,198   (View Stats)
but to change it you have to lift the v cover and get a new vc seal with it...and a can or 2 of brake cleaner...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Db09ms3 (01-08-2020)
 Old 01-08-2020, 09:21 AM   #4
Db09ms3's Avatar
Groans: 104
YAS, dis.
Stockish
P0126 fixes dubunderpar MazdaSpeed 3 - Engine, Transmission & Driveline 17 11-12-2015 01:16 AM
Boost leak testing, possibly Wastegate/Actuator leak AgentWh0 2010 MS3 - Troubleshoot/Diagnostics 0 08-04-2015 12:29 PM
Injen CAI Fixes keychain12 Mazdaspeed3/6 General Discussion 15 03-18-2013 12:00 PM
Injen CAI Fixes keychain12 MazdaSpeed 3/6 - Turbo Induction 1 03-13-2013 06:07 PM
COBB/TWM/OTHER FIXES bioevolve MazdaSpeed 3 - Engine, Transmission & Driveline 11 09-06-2008 02:29 PM
Page generated in 0.24762 seconds with 23 queries
