 Old 04-23-2008, 08:39 AM   #41
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
Originally Posted by enganear View Post
Is there any proof the sky is falling on the MS3 DISI? The pictures at the beginning of this thread are not specifically identified as DISI pics.
-enganear
the sky isn't falling but everytime your car is in VAC, NOT BOOST your oil catch tank and PCV is allowing oil to enter your intake manifold thus contaminating your intake valves
I have proof, I've seen it and the only option you have is adding the OCC between yoiur PCV and intake mani
the sooner, the better in terms of pre-existing build up
Don't bother trying to vent the OEM oil seperator as you "need" the vacuum draw from the intake mani to properly evacuate the crankcase
The Following User Says Thank You to whoosh@Realtune For This Useful Post:
dadasracecar (04-26-2008)
 Old 04-23-2008, 08:30 PM   #42
Betelgeuse's Avatar
Posts: 355   (View Stats)
Betelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant futureBetelgeuse has a brilliant future
Groaned at 4 Times in 2 Posts
Ok, I check my oil at least once a week so if my engine is drawing in some oil then I should see a dip in the level, right? Well my level dips only a few millimeters if that on the dipstick after 3k miles so it must be a tiny tiny bit.
I don't know, I think it's too early to speculate on these engines. I'd love to see some more tear down pics.
Cobb SRI // Cobb Shifter Weight // TWM Bushings // TWM STS // TWM type R weighted shift knob // Medieval Rear Mount // Darkstar Passenger Mount
Betelgeuse is offline   Reply With Quote
 Old 04-23-2008, 08:34 PM   #43
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
So im intrigued by this seafoam stuff. What do you think it will accomplish if its introduced into the manifold?
Hype? or can it clean it out and keep it clean.
phailerider is offline   Reply With Quote
 Old 04-23-2008, 08:38 PM   #44
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Seafoam is amazing stuff. Take a gun you have fired for years. Yea, you think that shit is clean dont you? Taking precious care of your barrel on such... Not a chance in hell my gun is dirty, right? Toss some seafoam down the barrel and see how much shit comes out...
This stuff cleans motors
BTW.. Yank off the pvc valve and poor 1/3 the can down the vacuum line. 1/3 in the oil cap and 1/3 in the fuel tank. Done deal.
 Old 04-24-2008, 11:26 AM   #45
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
a how to would be nice with pictures on where to put the stuff
- i wouldnt mind doing this every 10k or so to keep things clean inside
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 04-28-2008, 11:38 AM   #46
AG.
AG.'s Avatar
Posts: 659   (View Stats)
AG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the world
+1
2008 Sunlight Silver GT - Cobb SRI, HKS BOV Recirc, SU Test Pipe, TWM Shifter Bushings, 35%/5% Tint, Parrot Bluetooth Unit, Decals | To Come - Boost Gauge, Springs+Sways, CBExhaust, Wheels
AG. is offline   Reply With Quote
 Old 05-15-2008, 05:27 PM   #47
Meder's Avatar
Posts: 1,065   (View Stats)
Meder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the worldMeder is the leader of the world
Is this my only choice for a fix besides WI? How hard are these cans to install for someone without a lot of car experiance? Does the OCC completely solve the problem when done correctly?
Meder is offline   Reply With Quote
 Old 05-15-2008, 07:28 PM   #48
winniep's Avatar
Posts: 333   (View Stats)
winniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the world
I had an OCC on my 2005 SRT-4 and you would be amazed at how much crap that can will collect. Thankfully, I installed it at like 1500 miles. Now just got to get one going on the MS3. sitting at 10,150 miles right now and can only imagine how gunked up everything is in just this short span...........
The fastest MS3 in the whole garage...
winniep is offline   Reply With Quote
 Old 05-15-2008, 07:32 PM   #49
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
then why dont you install one?
Grim is offline   Reply With Quote
 Old 05-16-2008, 10:09 PM   #50
winniep's Avatar
"Now got to get one going on the MS3". That means I am going to install one Just finding the time is a PITA these days. Also got to find me a decent can and locate the PCV and routing ( a little different on this car than on most.......). Then to figure out if i should use a check valve or not.
 Old 05-16-2008, 10:26 PM   #51
Exhaust Depot's Avatar
Posts: 331   (View Stats)
Exhaust Depot has much to be proud ofExhaust Depot has much to be proud ofExhaust Depot has much to be proud ofExhaust Depot has much to be proud ofExhaust Depot has much to be proud ofExhaust Depot has much to be proud ofExhaust Depot has much to be proud ofExhaust Depot has much to be proud ofExhaust Depot has much to be proud of
Good find.
Exhaust Depot is offline   Reply With Quote
 Old 05-16-2008, 10:43 PM   #52
surfwagon's Avatar
Posts: 456   (View Stats)
surfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the world
I've been watching Grim's avatar for the past 10 minutes
2012 G37S; 7 speed paddle shifters
2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold
1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold
surfwagon is offline   Reply With Quote
 Old 05-16-2008, 11:22 PM   #53
Grim's Avatar
lol
 Old 05-17-2008, 08:18 PM   #54
winniep's Avatar
I was gonna type something up about that, but my hands were nowhere near the keyboard for a while there........................
 Old 05-19-2008, 12:23 AM   #55
parapdrapa's Avatar
Posts: 27   (View Stats)
parapdrapa is an unknown quantity at this point
You should not notice much change in your oil level. My LS2 GTO would use about .5 quarts per oil change most of it was blow-by. out of that .5qts i would have maybe 3-4 tablespoons of oil in the catch can. That engine is known to be more of an oil eater that most.. This is my first turbo car so i could be wrong... I have 500 mi on my MS3 and i hope to get a catch can on it first thing.. followed by pimpin window tint
parapdrapa is offline   Reply With Quote
 Old 05-19-2008, 12:48 PM   #56
AG.
AG.'s Avatar
that looks like the chick that plays the wii naked...from gizmodo...not that ive seen it or anything
 Old 05-19-2008, 01:02 PM   #57
AG.
AG.'s Avatar
HA! Found it!.....not that i knew exactly where to look or anything...just happened to stumble upon it....
Very NSFW Video: Beautiful Topless Girl Playing Wii - Part 2
The Following User Says Thank You to AG. For This Useful Post:
sweetpickles (05-19-2008)
 Old 05-19-2008, 03:09 PM   #58
sweetpickles's Avatar
Posts: 375   (View Stats)
sweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the worldsweetpickles is the leader of the world
Mother... I just posted that URL in another thread >.< Either way, good shit
sweetpickles is offline   Reply With Quote
 Old 06-13-2008, 12:40 AM   #59
ztuner's Avatar
Posts: 554   (View Stats)
ztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the world
Originally Posted by ptperformance View Post
Diesel engines run at lower temps and have much cooler intake charges, next they don't have a vacuum source that sucks oil into the intake manifold. If them did I suspect that they would have the same issues. .
Sorry you are just plain WRONG turbo diesels run much hotter than comparable gas engines an they do have pcv systems just like gas engines. They also run much higher boost and static compression. Diesel cly temps are 2 to 3 x that of gas engines and so are their egts's.
The problem you see is primarily a bad pcv design.
Harry
ztuner is offline   Reply With Quote
 Old 06-13-2008, 01:14 AM   #60
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
i think Ford's pcv designs suck period, on everything they build.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/omg-sucks-all-us-4580/
Is this really a big problem? - Mazda Forums This thread Refback 06-13-2008 12:03 PM
Is this really a big problem? - Mazda Forums This thread Refback 06-13-2008 10:09 AM
Is this really a big problem? - Mazda Forums This thread Refback 06-13-2008 09:54 AM
Is this really a big problem? - Mazda Forums This thread Refback 06-13-2008 07:37 AM
Is this really a big problem? - Mazda Forums This thread Refback 06-13-2008 07:30 AM
Is this really a big problem? - Mazda Forums This thread Refback 06-13-2008 07:18 AM
OMG the stock turbo sucks!!! ptperformance Mazdaspeed3/6 General Discussion 71 07-18-2008 03:40 PM
This design sucks... read on. ptperformance Mazdaspeed3/6 General Discussion 131 04-30-2008 11:54 AM
Page generated in 0.38972 seconds with 34 queries
