![]() | | #1 | ![]() |
| Alittle Faster ![]() ![]() Join Date: May 2008 Location: Cape Coral, FL
Rep Power: 6078 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,006
(Thread Starter) | Not Ranked : 0 score ![]() Currently have: ![]() PTP Tranny Motor Mount (TMM) Top Speed Rear Motor Mount (RMM) Top Speed Passenger Side Motor Mount (PMM) TurbineTech Front Motor Mount (FMM) PTP Kicker Motor Mount (KMM) My motor shouldn't move any now hahahaha. Quality and welds as same as their TMM. Here is what it comes with: The 3 factory threaded holes on the block. Start the mounting of the block bracket and three supplied bolts with some Loc-Tite on it. Torque it down manly style. Do the same for the subframe bracket, two bolts. Now drill using smaller bit to 1/4" bit for the third small nut and bolt on the subframe. You will go thru two sandwiched layers of metal. Put in the connecting rod/bushing, do not tighten yet. The other end of it you can see a gap on both sides of the heim joint. You can adjust within the subframe bracket, but when you tighten it down the ears of the bracket will come together and will not allow it to spin on the inside, so I opted to use NATOR washers (I only had 5 of them) to take up the space/gap. Therefore I could keep adjusting it again with out removing the entire rod/bushing. ![]() Torque the reamining bushing and heim joint bolts/nuts, also the jam nut on the heim joint. I opted to pull the engine slightly back for the tension before tighten all down and jam nut last. Finished! ENJOY! ![]() Will have some reveiw/results later. 100 miles so far. I get no idle vibs. Taking off you will feel the vibs, little more than you want. Very little at cruising. Launching seems to help alittle. Also awaiting the break-in period of 500-1000 miles still. Last edited by bioevolve; 10-21-2009 at 09:34 AM. |
| The Following 10 Users Say Thank You to bioevolve For This Useful Post: | flyrevs2 (10-17-2009), Fobio (10-17-2009), Frequentflyer (10-17-2009), hnda etr (10-17-2009), mouse0330 (10-17-2009), nyghtryder (10-18-2009), ptperformance (10-26-2009), skeeter149 (10-17-2009), superskaterxes (10-18-2009), wankular (10-18-2009) |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5716 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score I'm not sure why you natorized the heim joint side with the washers.... you said you did it so you CAN spin the heim joint? or prevent it from spinning? or to take up the space between the bracket and the joint?
__________________ ![]() [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to hnda etr For This Useful Post: | bioevolve (10-17-2009) |
| Driver ![]() Join Date: May 2008 Location: Toronto
Rep Power: 1986 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,158
Groans: 44
| Not Ranked : 0 score I'd say he did it to prevent the 2 "ears" from coming together fromm the tightening, which would make it impossible to spin the helm joint while it's mounted to make adjustments.
__________________ ![]() DONE . Cobb AP 22-psi Self-Tuned . ATP GT3071 . CP-e 3.25" MAF+4" inlet . Denso ITV-24 . CP-e HPFP . CP-e FMIC . Turbosmart Ultimate BPV . 50/50 Meth w/ M5 nozzle . PTP IM Spacer+EGR delete . GrimmSpeed EBCS 3-port . SteedSpeed Mani . CP-e TBE . Greddy OCC w/ 2nd PCV valve . F2 BSD + oil-pan baffle . Hawk HP+ pads . Goodridge SS brake lines w/ Ford Super Dot 4 . Cobb Springs+FSB . Tri-Point RSB+Endlinks . Koni Yellows . KMAC Camber Plates . 60mm Boost Gauge . TWM Complete Shifter w/ JBR SSP+weight . CP-e RMM+PTP trans+kicker mount . Sparco Harness Bar w/ MOMO 4-pt harness . Rays/Volks 57F 18x8.5" +45mm 235/40/18 Hankook V12 . BBS RK 17x8" +45mm 235/45/17 RA1/R6 . OEM Snowflakes w/ 215/50/17 Nitto NT-SN1 . 3rd in CSCS 2009 Time Attack Championship - Super Street FWD . 360whp/390wtrq . SOON . 3-bar MAP sensor . MSpeed Tuning & Diagnostics - The Street Lab is ALWAYS OPEN FOR BUSINESS "It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." -- Mario Andretti -- |
![]() | | #4 | ![]() |
Groans: 90
| Not Ranked : 0 score Ahh... that makes sense...
![]() | | #5 | ![]() |
| Banned ![]() Join Date: Feb 2009 Location: Inland Empire
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 937
Groans: 701
| Not Ranked : 0 score That setup actually looks pretty schweet, but how does it feel!? |
![]() | | #6 | ![]() |
![]() Join Date: Aug 2008 Location: Fort Walton Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,903
Groans: 639
Groaned at 39 Times in 29 Posts
| Not Ranked : 0 score I bet women come really quick on that car.
__________________ "Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." Most people would have just called it "wrong-wheel drive." |
![]() | | #7 | ![]() |
Idle I feel no different, awaiting a test drive. Yes they do, super vibrator lol. | |
![]() | | #8 | ![]() |
![]() Join Date: May 2009
Rep Power: 372 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 558
| Not Ranked : 0 score does it really vibrate a lot ? I'm about ready to pull the trigger and get one of these, but I don't want more vibes. Maybe someone else can post up a review after they get it installed.
__________________ 2013 Mazdaspeed3 Gen2 Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount |
| The Following User Says Thank You to flyrevs2 For This Useful Post: | bioevolve (10-17-2009) |
![]() | | #9 | ![]() |
![]() Join Date: May 2009 Location: Browns Mills/NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 739
| Not Ranked : 0 score I would imagine that the more tension you place on the engine the more likely youll feel the vibs, however you should be able to dial it in to almost zero vibs.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS NATOR PA |
| The Following User Says Thank You to nyghtryder For This Useful Post: | bioevolve (10-17-2009) |
![]() | | #10 | ![]() |
![]() Join Date: Aug 2008 Location: Puyallup, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score Looks frickin sweet |
| The Following User Says Thank You to mazdarati For This Useful Post: | bioevolve (10-17-2009) |
![]() | | #11 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score god i do love bioevolve write ups... so detailed, so clear and so many quedtions answered!!! yes!!!
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
| The Following User Says Thank You to skeeter149 For This Useful Post: | bioevolve (10-17-2009) |
![]() | | #12 | ![]() |
| Not Ranked : 0 score awsome pics and write up !!!! Now how are the vibes since you have been rockin this for a bit now ?
| The Following User Says Thank You to flyrevs2 For This Useful Post: | bioevolve (10-19-2009) |
![]() | | #13 | ![]() |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score Nice writeup. How necessary is that little allen bolt? It seems tiny compared to the others.
__________________ 2009 MS3 sport MGM |
| The Following User Says Thank You to wankular For This Useful Post: | bioevolve (10-19-2009) |
![]() | | #14 | ![]() |
(Thread Starter) | Not Ranked : 0 score 100 miles so far. I get no idle vibs. Taking off you will feel the vibs, little more than you want. Very little at cruising. Launching seems to help alittle. Also await the break-in period of 500-1000 miles still. |
![]() | | #15 | ![]() |
(Thread Starter) | Not Ranked : 0 score 300+ miles so far, vibs have lessened some. Forgot to mention, at first it amplified my deceleration vibs a bit, but as the miles go by it lessens. |
| The Following User Says Thank You to bioevolve For This Useful Post: | ptperformance (10-26-2009) |
![]() | | #16 | ![]() |
Groans: 90
| Not Ranked : 0 score I just got my kit and John's now including a metal spacer with it to keep the ears from bending inwards too much.. Question though, I noticed the 2 black bolts that go into the crossmember didn't have nuts to go with them... Are the crossmember holes threaded then? Also, if I do the install with the car up on ramps, will that cause the motor to tilt too far backwards do you think? Thanks for the great write up!
| The Following User Says Thank You to hnda etr For This Useful Post: | bioevolve (10-24-2009) |
![]() | | #17 | ![]() |
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score Yes they're threaded. I doubt the spacers will work for you - it doesn't line up centered. Look at bioevolve's pics and you can see that. I should have used one spacer and the rest washers, but after popping the spacers out I forgot and just used washers. Of course, I popped them out inside so never tried it with them on. I hope you got a lotta tools - I damn near failed with just basic hand tools - those engine side bolts are a bitch to reach from the ground and torque up good. I was curious about the engine rocking and it being a pain to adjust, but with a tranny and rear mount mine doesn't move much so I just lined it up as it was. I get a little noise from somewhere when lugging in first gear. I have to lug it to get into the garage. It's a weird noise - sort of a chirpy groan? Maybe I tightened the bushing bolt too much - I put 50 lbs on it. It sounds like it's coming from the glove box lol, which made me panic about the passenger side mount, but it looks okay. I dunno ... This mount feels like the rear mount in my Si. Kind of buzzes a little and everything feels nice and tight. I'm sure it will break in with the 60 duro, but right now, no big vibes or anything. I already got the deceleration vibes from the tranny mount and they're no worse, maybe even a little snubbed now.
__________________ ![]() |
| The Following User Says Thank You to fjames For This Useful Post: | bioevolve (10-24-2009) |
![]() | | #18 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yes, fjames is right just use some Loc-Tite on those bolts. Car ramps won't move/lean the engine back any. There is alittle more space on the driver side on the heim joint within the bracket ears. Yes, you will get vib noises from the glove box side. It's resonating thru that side of the subframe. You could try lubing the engine side bushing if you are hear a chirping/squeaking noise. Tightening the engine side bolts is easier with the type of wrench I'm using in the picture. |
| The Following User Says Thank You to bioevolve For This Useful Post: | hnda etr (10-24-2009) |
![]() | | #19 | ![]() |
Groans: 90
| Not Ranked : 0 score Just got done installing my kit tonight. Initial impressions are that this is a solidly made kit. Nice welding, heavy gauge metal, perfect fitment! Also, looks like PTP might have revised the design a bit - just on the "neck" part- whereas on bioevolve's and fjames' kits, the heim joint sits centered between the neck "ears", my heim joint lined up more to the side. This allowed the ~1/4" spacer to fit perfectly on the opposite side. Once tightened down, the ears barely bent inwards, maybe 5 degrees per side. Leaves plent of space to lift the heim joint in and out to adjust. I tried putting in a really thin washer on the side opposite the spacer, but it was a bitch to get in and I decided that it wasn't necessary. I took off my Weapon-R ETD a couple days ago because I couldn't stand the vibrations it was causing, sound/felt like the whole cabin was shaking apart. I haven't driven with the new kicker mount yet, but just from idling I can barely tell it's there! Definitley better than the ETD! I'll do a little driving later tonight, so I'll have a better idea of how it drives later. Edit: If anybody's wondering, you'll need a 15mm and a 19mm IIRC. Thanks to bioevoleve's post above this one, I got the angled wrenches like in his pic and had 0 problems with the install - sorry fjames ;-) Edit2: I have all 3 SU Mounts, and my motor wouldn't budge! I can't imagine the car being on the ramps causing any movement of the motor - I don't know how bioevolve moved his motor to pre-tension it! I mean I couldn't move mine a C-hair and I'm not a small guy! Edit3: I just reread bioevolve's and fjames' posts, and it looks like their heim joints are off to the side just like mine. Mine was perfect with the spacer John included though, not sure why your guys' weren't...
__________________ ![]() [SIGPIC][/SIGPIC] Last edited by hnda etr; 10-24-2009 at 08:32 PM. |
| The Following 4 Users Say Thank You to hnda etr For This Useful Post: |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cuz he read my thread and added the peice lol. |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Ha, I was going to go get one of those angle wrenches, but it's a 20-50 mile round trip to get anywhere from where I live and I didn't get motivated to install until about 10:30 at night. I'm so tempted to put the stock tranny mount back, just to quiet things down. But it feels so tight now, of a piece, I don't know - maybe this is the best combination of mounts (rear, tranny, kicker.) So far so good anyhow.
| The Following User Says Thank You to fjames For This Useful Post: | bioevolve (10-25-2009) |
![]() | | #22 | ![]() |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
Groans: 105
| Not Ranked : 0 score thanks for the updates guys, please post more impressions! |
| The Following User Says Thank You to xcoldricex For This Useful Post: | bioevolve (10-25-2009) |
![]() | | #23 | ![]() |
Groans: 90
| Not Ranked : 0 score Driving, can't feel the additional vibes, at idle, I feel a slight amount... When the AC compressor turns on though, that's when I feel the most vibes - still not an obnoxious amount though.
| The Following User Says Thank You to hnda etr For This Useful Post: | bioevolve (10-26-2009) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score i feel that those 2 bolts that are in the block wont hold there should be one more on the bottom....cant have everything |
| The Following User Says Thank You to wisniaPl For This Useful Post: | bioevolve (10-26-2009) |
![]() | | #25 | ![]() |
Groans: 90
| Not Ranked : 0 score WTF? There are 3 bolts on the block ginger... Read the post!
| The Following 2 Users Say Thank You to hnda etr For This Useful Post: | bioevolve (10-26-2009), ptperformance (10-26-2009) |
![]() | | #26 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
We did add some additional part to the kit due to a few trying to "tighten" down the lock nut and bolt to bend the tabs in, they are not suppose to be tightend down like that and the new directions as well as parts detail this in the kit.
Yep, 3 bolts... hows the mount working out for you and what are your impressions so far? Remember, if you want to get rid of the wheel hop you will want to prelaod the mount .250 of an inch and work your way up from there to see if it get better or worse. To everyone reading this thread.... you need one of these mount if your going to track your car or mount sticky tires to your rims. These make the biggest difference if you have sticky tires or you have slicks on the car. I would get track restults with the mount but we are closed until April of next year. I will let the others that have gotten the mount installed verfiy the gains from it. | |||
| The Following User Says Thank You to ptperformance For This Useful Post: | bioevolve (11-05-2009) |
![]() | | #27 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| The Following User Says Thank You to Erich For This Useful Post: | bioevolve (11-05-2009) |
![]() | | #28 | ![]() |
__________________ ![]() | |
| The Following User Says Thank You to fjames For This Useful Post: | bioevolve (11-05-2009) |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score 1000+ miles so far. Vibz have lessened about 40%-50%. Vibz are tolerable, shifting engagement of the wheels/tires to the road are more solid. Lauching is still better than before. Still need a real traction bar setup for this car. |
![]() | | #30 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 944
Groans: 127
Groaned at 40 Times in 31 Posts
| Not Ranked : 0 score Bio, do you haz track times with this new mm setup? I am anxious to see what your 60 looks like now that you are putting more of that power down. |
| The Following User Says Thank You to kilik2 For This Useful Post: | bioevolve (11-05-2009) |
![]() | | #31 | ![]() |
Groans: 44
| Not Ranked : 0 score Can someone pls elaborate on how to "play with the mount" to tune out vibes?
| The Following User Says Thank You to Fobio For This Useful Post: | bioevolve (11-05-2009) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hopefully this month or the next I will have track times. A group of us are going soon. Don't forget I have air bags in the back coils, those should help out even more on the 60's. Uhhhhh Air Lift Kit 1000 |
![]() | | #33 | ![]() |
![]() Join Date: Nov 2008 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
Groans: 40
| Not Ranked : 0 score I think the great thing about this mount is that it's kinda like a "2nd string Motor Mount" or at least that's how I think of it. It balances out the weight on the engine, it puts less strain on the other three and if one of the original three do fail, you have this as a backup. I'll pick one up in the spring. Car drives like turd in the winter anyways.
__________________ CP-E SRI / Forge BPV / Corksport TP / Corksport CBE |
| The Following User Says Thank You to toprock For This Useful Post: | bioevolve (11-05-2009) |
![]() | | #34 | ![]() |
But when you push or pull the engine with the heim joint adjusted out or in to match your push or pull setting, you will get more vibz. Example: Pulling the bottom of the motor toward the subframe, extend your heim joint. Will cause more vibs. Also in going the other way. But like I mentions about leaving the engine where it sits and lining up the heim joint with that current space you have between the engine and subframe will give you least tension/vibz. There is no lower vib setting than that. Unless you don't use it lol. | |
| The Following User Says Thank You to bioevolve For This Useful Post: | Fobio (11-05-2009) |
![]() | | #35 | ![]() |
Groans: 44
| Not Ranked : 0 score I've gotten it installed now...less noisy than the medieval passeeger mount I had for awhile, but you can definitely feel some extra vibes at idle and decel...no problem by me, but I think it accentuates the secondary vibrations of doing the BSD. car is much more sure footed...at least 50% less torque steer for me, and less hop...but it wasn't like I was hopping too bad before anyway now. 1st to 2nd and to 3rd shifts also seems smoother...
| The Following User Says Thank You to Fobio For This Useful Post: | bioevolve (11-09-2009) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Sorry there is a How To in our section on the mount.
| The Following User Says Thank You to ptperformance For This Useful Post: | bioevolve (02-22-2012) |
![]() | | #37 | ![]() |
I just want a four point link drag launch setup for daily driving lol. | |
![]() | | #38 | ![]() |
![]() Join Date: Nov 2009 Location: MA
Groaned at 25 Times in 11 Posts
| Not Ranked : 0 score Super back-from-the-dead bump. I just heard about this mount/part today and was wondering if more people have tried this mount? For any of the original posters in this thread who are still around, how has the mount held up? Any negative long term effects noticed? |
| The Following User Says Thank You to PureDrive For This Useful Post: | bioevolve (02-22-2012) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Still as happy with it as I was day 1. My car has now dynoed at 640HP and been daily driven at 500+. |
| The Following User Says Thank You to Erich For This Useful Post: | bioevolve (02-22-2012) |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score It was great when I had it on the car. |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/one-those-ptp-kicker-mounts-installed-40195/ | ||||
| Mazda esitleb - Mazda 3 MPS : Mazda mudelid - Page 12 | This thread | Refback | 05-02-2013 07:26 AM | |
| Mazda esitleb - Mazda 3 MPS : Mazda mudelid - 12 | This thread | Refback | 08-13-2011 05:04 AM | |
| what should i get | This thread | Refback | 01-06-2011 10:21 PM | |
| Mazda esitleb - Mazda 3 MPS : Mazda mudelid - 13 | This thread | Refback | 04-05-2010 11:36 AM | |
| PTP Kicker Mount Review | This thread | Refback | 03-25-2010 11:39 PM | |
| PTP Kicker Mount Review | This thread | Refback | 02-16-2010 06:37 AM | |
| PTP Kicker Mount Review - TorontoMazda3 | This thread | Refback | 11-09-2009 10:37 AM | |
| PTP Kicker Mount Review - TorontoMazda3 | This thread | Refback | 11-08-2009 10:18 PM | |
| Kicker mounts, they are ready! | ptperformance | Mazdaspeed3/6 General Discussion | 70 | 11-09-2009 09:41 AM |
| installed medievals side and tranny mounts today | allmotor95pgt | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 07-30-2009 07:40 AM |
| StreetUnit Side Mounts Installed | aaronc7 | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 04-01-2009 12:24 AM |
| Will a kicker Kicker ZX1000.1 be enough for a 12" jlw7 plus another audio question. | 09speed3 | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 03-09-2009 09:47 PM |
| SU Side Engine Mounts Completed & Installed | Grim | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 10-30-2008 02:29 PM |
