Like Tree2Likes
 Old 04-09-2012, 08:17 PM   #1
UnamusedPunk's Avatar
Posts: 46   (View Stats)
UnamusedPunk is just really niceUnamusedPunk is just really niceUnamusedPunk is just really niceUnamusedPunk is just really niceUnamusedPunk is just really nice
Default Order of operations mod eddition?
Pretty new to the forums. I purchased a 09 Mazdaspeed3 about a month and a half ago with low milage (22k) and I have changed the transmission fluid to what the forum recomended from fords performance devision (wow it made a nice difference) and also threw on a cobb SRI.
Problem is, im really picky when it comes to how the car performs. In 5th gear and sometimes 4th with bad gasoline, i get power waves. Definitely from the cobb intake, and I wanted to know what to change on the car to get it to be smooth again. Am I forced to get a cobb access port and get it tuned?
I was thinking a TIP, and Exhaust but I don't want to exasperate the issue anymore. I was thinking of full turbo back exhaust, but I want to avoid throwing cells. Any recommendations? I just want safe power because it's also my daily.
UnamusedPunk is offline   Reply With Quote
The Following User Says NO Thank You to UnamusedPunk For This Un-useful Post:
Onelovesoccer (04-10-2012)
 Old 04-09-2012, 08:20 PM   #2
J'sSpeed3's Avatar
Posts: 722   (View Stats)
J'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the world
Groans: 76
If you're thinking of getting a full turbo back exhaust you better plan on getting an AP as well. Save yourself the trouble and get an AP now, then fuel pump internals, then test pipe or full exhaust.
| 2007 True Red Mazdaspeed 3 GT |
GO: | SURE SRI V2 | COBB TIP | CP-E FMIC | Corksport DP | Corksport CBE | Cobb AP RICHTUNED | Autotech Internals | SURE RMM | Denso ITV-22's | Turbosmart BPV |
SHOW: | Evo X Enkei's 18x8.5 +38 Painted CWP| Nitto Motivo's 225/40 | BC Racing Coilovers | SPC Camber Arms | DDM 3000k fogs | CPE Tow Plate |
J'sSpeed3 is offline   Reply With Quote
 Old 04-09-2012, 08:22 PM   #3
mrtheandrew's Avatar
Posts: 468   (View Stats)
mrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the worldmrtheandrew is the leader of the world
Neutral  -1 score
i know someone in here is hungry for brownies
mrtheandrew is offline   Reply With Quote
The Following User Says NO Thank You to mrtheandrew For This Un-useful Post:
superq7 (04-10-2012)
 Old 04-09-2012, 08:27 PM   #4
The stock fuel pump sucks? Will basic map from cobb fix the wavy power band if you go stage 1 first before applying it?
 Old 04-09-2012, 08:32 PM   #5
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
i think a wavy power band might be an indication of a problem. i have no wavy power band, and i'm sure surging is a problem that has been discussed.. have you tried searching?
what makes you think the sri causes the surging? i'd take it off, put stock airbox on, and then see if it still is 'wavy'. if it is, then you have bigger issues to fix. if not, then it's the sri and i've no clue how you'd fix that..
you may, in fact, already need internals..
good luck
 Old 04-09-2012, 08:34 PM   #6
J'sSpeed3's Avatar
Groans: 76
Most people upgrade the fuel pump internals as one of the first mods. Definitely upgrade before doing anything else especially if you are thinking of going with a downpipe. You definitely need an AP to monitor fuel pressure as well to make sure it's above 1600 at WOT. I can't speak for the stage 1 problem as I jumped to stage 2 right away.
 Old 04-09-2012, 08:34 PM   #7
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
uh surge on k04 wtf?
The Following User Says Thank You to dooderek For This Useful Post:
Broxer (04-10-2012)
 Old 04-09-2012, 08:39 PM   #8
good luck
It was deff after the SRI came on. I had the car for a while with stock airbox. Stock airbox isn't an option at the moment. I broke one of the brackets on the box when I was doing the installation.
I bought the car from the a friend. The milage is really low, and I know the guy personally. He's a MD and treated the car like a baby, it still smells new, looks brandnew, and runs like a champ. It might be bad fuel, california gets the short end of the stick when it comes to high octane.
I've searched at there are people with wavy power bands after SRI installation.
If not hopefully it blows before the warranty runs out in two years, at that point my other warranty kicks in. =D
Alright, thanks. I'll check it out. Maybe i'll start stockpiling parts over the next couple months untill I can do it all at once.
 Old 04-09-2012, 08:43 PM   #9
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groans: 79
Groaned at 34 Times in 31 Posts
I know the feeling you're talking about. The COBB SRI was my first mod too and partial throttle acceleration wasn't smooth at all with just that one mod. A tune fixed the issue.
It's well documented on these forums that you need to upgrade the pump before going stage2. But you should be fine on stage1 with the stock pump.
Last edited by Pseud0logik; 04-09-2012 at 08:43 PM. Reason: MSF Database - Automerged Doublepost
Pseud0logik is offline   Reply With Quote
 Old 04-09-2012, 08:47 PM   #10
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Cobb ap, Fuel pump, cnt downpipe, intake/inlet, 50/50 w/ dizzy tune.....done.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 04-09-2012, 08:52 PM   #11
Thanks for the reafirment that im not crazy or that my cars not totally fucked up . I will research which one is best for my needs.
you know what makes me dizzy? the acryms that come with joining a new car community forum ^_^.
 Old 04-09-2012, 09:00 PM   #12
2zz mr-s
dooderek's Avatar
Groans: 239
where do you live? nator so cal will fix your shit right up son
 Old 04-09-2012, 09:11 PM   #13
Groans: 79
You must have overlooked the stickie that explains all of them while you were diligently reading all the other stickies like a good brownie should.
Pre-School Decode Sheet
The Following 2 Users Say Thank You to Pseud0logik For This Useful Post:
Black Metal (04-10-2012), mazdafreak (04-09-2012)
 Old 04-09-2012, 09:47 PM   #14
mazdafreak's Avatar
Groans: 124
What was so confusing about that? Cobb ap ((tuning device)), fuel pump internal upgrade, cnt downpipe, intake and turbo inlet with a e85/93 mix with a dizzy tune ((by phate or bucker))
713whp/569wtq!
 Old 04-10-2012, 11:53 AM   #15
omgheyitskenny's Avatar
Posts: 185   (View Stats)
omgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond reputeomgheyitskenny has a reputation beyond repute
Groaned at 6 Times in 1 Post
^^ I don't think Cali has 93
omgheyitskenny is offline   Reply With Quote
 Old 04-10-2012, 12:29 PM   #16
Groans: 79
It doesn't matter on a mix tune, 91 will work fine. Hell, I think Bucker even uses 87 in his car.
 Old 04-10-2012, 12:30 PM   #17
The group seems like nice people. I just don't want some guy who thinks that his $350 coilovers are better than the stock setup telling me how to mod my car
boom goes the dynamite. that sticky is fantastic =D
93 octane is aparently to good for us californians.
 Old 04-10-2012, 12:55 PM   #18
2zz mr-s
dooderek's Avatar
Groans: 239
Your talking to the fastest speed in california, like I says well have your shit running in no time
 Old 04-10-2012, 01:13 PM   #19
Nice, could sure use some help with boost gauge, oil temp, digi tach guage install. Too bad you're located in SD. Wheres closest meet?
 Old 04-10-2012, 01:27 PM   #20
2zz mr-s
dooderek's Avatar
Groans: 239
murrieta, check out the nator so cal section otherwise bring your car down for one day at my place, all gauges can we done with relative ease
 Old 04-10-2012, 01:57 PM   #21
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
All Daddy Chinkus requires is buttsex...no worries, he hooked me and my car right up!
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
The Following User Says Thank You to Whiteboy For This Useful Post:
Ferg (04-10-2012)
 Old 04-10-2012, 02:50 PM   #22
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
why do you need a digital tach gauge?
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline   Reply With Quote
 Old 04-10-2012, 03:04 PM   #23
I don't need any of them, but I like where you can program the perfect time to shift into it so it flashes green or what ever color the company chooses.
 Old 04-10-2012, 03:14 PM   #24
Ferg's Avatar
get an ap. itll flash white at you telling you that you have hit your rev limit and to shift.
2008 Black Ms3 SOLD
 Old 04-10-2012, 03:20 PM   #25
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Your talking to the smallest peen in california, like I says well have your shit packed in no time
Fixed.
In all seriousness, you're in good hands with these guys.
 Old 04-10-2012, 03:56 PM   #26
Is there no all-in-one mazdaspeed parts for sale section on this forum? I see the ones regionally.
 Old 04-10-2012, 03:58 PM   #27
Whiteboy's Avatar
Groans: 142
There is but you have to be VIP to use them. This keeps scammers away
TexasSpeed3 (04-10-2012)
 Old 04-10-2012, 04:13 PM   #28
Cool, which mod do I contact to take off the VIP banner under my avatar. I donated and want access to that stuff, I just don't care for the banner.
 Old 04-10-2012, 04:37 PM   #29
2zz mr-s
dooderek's Avatar
Groans: 239
change your user groups to brown
 Old 04-10-2012, 06:00 PM   #30
Groans: 79
That will work, but if you do it people won't stop telling you to donate every time you post, so I don't recommend it.
 Old 04-10-2012, 06:22 PM   #31
I guess i'll leave it. It'd be cool if our avatar file size limit was increased a little bit for VIPers
 Old 04-10-2012, 09:31 PM   #32
Whiteboy's Avatar
Groans: 142
Shut that pie hole and enjoy the awesomeness you paid for...lol
 Old 04-11-2012, 09:08 PM   #33
i got groaned at by the guy who started a thread on running dual intercoolers. damn.
The Following User Says Thank You to mrtheandrew For This Useful Post:
bozs13 (04-12-2012)
 Old 04-12-2012, 10:23 PM   #34
so something really weird just happened. This weekend, in sunny socal I decided to take my friends to the beach, witha full car going up a hill at wide open throttle in fourth gear right at 5500 rpm, the car did a lurch forward and back then continued to go. it's like you dropped the clutch and the car did that jump. it didnt feel like transmission more like motor.
I called mazda and spoke with a tech and he said that this was prolly because of the fully load of people in my car, on a hot day, going up a hill and to try new gasoline and let them know if the problem persist, and that it was most likely the engine trying to protect its self from knocking.
well tonight I was driving and in fourth gear at WOT the same thing happened, the car did that jerk feeling right at 5500 rpm. Ive been using chevron fuel to rule out terrible gas.
I have a cobb SRI and thats the only mod on the car, it just ticked over 26k miles on the odo. do i need to install the stock airbox and take it in?
 Old 04-12-2012, 10:28 PM   #35
Groans: 79
Does the jerk feel like you've hit a wall for a split second and then everything's fine again?
 Old 04-12-2012, 10:30 PM   #36
yes? to an extent, i mean it doesnt feel like i ran into a brick wall but the car deff feels like u hit something and then everything is cosher.
 Old 04-12-2012, 10:32 PM   #37
Groans: 79
That sounds like fuel/load cut. I had the same thing a few times before I got the AP. Always in 4th or 5th at high RPM under WOT.
 Old 04-12-2012, 10:43 PM   #38
Is it bad fuel internals? does it need to be serviced? Or shitty stock tune? Don't they do R&D anymore. =[
I was hoping to put off the AP until i have the exhaust, the new internals, TP, TIP and do all at once
 Old 04-12-2012, 10:48 PM   #39
BlewisMSF11''s Avatar
Posts: 66   (View Stats)
BlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to all
Get internals or flash safemap, wavyness should go away
2010 MS3|Cobb AP| JBR RMM|Sure SRI| Sure TIP| Sure recirc hose| Turbosmart BPV|8000k HID's| JBR weighted shifter knobb| JBR Short shifter kit|
BlewisMSF11' is offline   Reply With Quote
 Old 04-12-2012, 10:49 PM   #40
Groans: 79
It's probably not your internals, but you would need logs to be sure. The stock tune isn't shitty because Mazda didn't do R&D, it's shitty because they had to make it conservative and safe. The stock tune isn't optimized for your intake, which is why you're getting load cut and jerky partial throttle acceleration. I would suggest getting an AP sooner rather than later, you can flash a stage1 map now and then go stage2 once you get your other parts installed.
EDIT: I don't recommend doing a bunch of mods at the same time anyway, it makes it difficult to tell how your car is reacting to each mod and also if something is wrong it's harder to isolate the issue.
BlewisMSF11' likes this.
HKS shuttering U.S. operations Haltech Automotive News 1 04-29-2011 04:31 PM
GM appoints VPs in International Operations Haltech Automotive News 0 07-24-2009 01:50 PM
Toyota says it may end NUMMI operations Haltech Automotive News 0 07-10-2009 06:00 PM
Page generated in 0.56105 seconds with 31 queries
