Like Tree2Likes
 Old 04-12-2012, 10:58 PM   #41
BlewisMSF11''s Avatar
Posts: 66   (View Stats)
BlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to allBlewisMSF11' is a name known to all
Originally Posted by Pseud0logik View Post
EDIT: I don't recommend doing a bunch of mods at the same time anyway, it makes it difficult to tell how your car is reacting to each mod and also if something is wrong it's harder to isolate the issue.
Fist bump on that comment
Pseud0logik likes this.
2010 MS3|Cobb AP| JBR RMM|Sure SRI| Sure TIP| Sure recirc hose| Turbosmart BPV|8000k HID's| JBR weighted shifter knobb| JBR Short shifter kit|
BlewisMSF11' is offline   Reply With Quote
 Old 04-12-2012, 11:00 PM   #42
UnamusedPunk's Avatar
Posts: 46   (View Stats)
UnamusedPunk is just really niceUnamusedPunk is just really niceUnamusedPunk is just really niceUnamusedPunk is just really niceUnamusedPunk is just really nice
It's probably not your internals, but you would need logs to be sure. The stock tune isn't shitty because Mazda didn't do R&D, it's shitty because they had to make it conservative and safe. The stock tune isn't optimized for your intake, which is why you're getting load cut and jerky partial throttle acceleration. I would suggest getting an AP sooner rather than later, you can flash a stage1 map now and then go stage2 once you get your other parts installed.
Alright, so having only a SRI is okay for stage 1 map? I shouldnt get a mid pipe aswell?
UnamusedPunk is offline   Reply With Quote
 Old 04-12-2012, 11:07 PM   #43
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groans: 79
Groaned at 34 Times in 31 Posts
COBBs map download site
You can download the map notes from that site which goes into detail about what supporting mods you need to run each map.
They have a map specifically for your otherwise stock car with an intake. Did you see my mention in the for sale thread? AP for $450 is a solid deal. JUMP ON IT SON!
Pseud0logik is offline   Reply With Quote
 Old 04-13-2012, 12:34 PM   #44
I did! that guy sold that so quick. i'll keep looking. thanks for the information guys!
 Old 04-14-2012, 11:02 PM   #45
Uninspiring Canyon Photos of White Speed3 On Stockers! finally posted pics. anyone in LA hit me up, i got suby frieds but no speed3 friends
 Old 07-03-2012, 02:59 PM   #46
Lexx3D's Avatar
Posts: 4   (View Stats)
Lexx3D is an unknown quantity at this point
Originally Posted by UnamusedPunk View Post
Is it bad fuel internals? does it need to be serviced? Or shitty stock tune? Don't they do R&D anymore. =[
I was hoping to put off the AP until i have the exhaust, the new internals, TP, TIP and do all at once
I had the exact same thing happening to my GEN2 after installing an aftermarket intake ( K&N RAM ).
I happen to have the AP and sent multiple logs to everybody starting from COBB and even K&N, and ended up refunding the intake because nobody came up with a straight answer as to why it was happening.
Logs indicated everything from low fuel pressure ( 800s ), to waste gate opening etc, but nobody could figure out which caused what, and how to fix it.
Some blamed it on an air leak, but if anybody ever installed a K&N SRI - it's kinda hard to screw it up and have a leak. Some said it was CDFP failing, but it wouldn't happen with stock airbox, on either stage 0 or 1 tunes, and the car is only at 10k Miles...
Things to check are definitely air leaks and fuel pressure! So you may want to get an AP for that.
One way I've found I can easily replicate the issue - is to pull 3rd gear all the way from 25-ish MPH all the way up to 7x, and it is guaranteed to happen around 5200 RPM
Lexx3D is offline   Reply With Quote
HKS shuttering U.S. operations Haltech Automotive News 1 04-29-2011 04:31 PM
GM appoints VPs in International Operations Haltech Automotive News 0 07-24-2009 01:50 PM
Toyota says it may end NUMMI operations Haltech Automotive News 0 07-10-2009 06:00 PM
Page generated in 0.28077 seconds with 23 queries
