 Old 10-12-2008, 08:38 AM   #1
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Default Ordered new oil...
so i cant find any Penzoil Platinum 5w40 around my neck of the woods... So i had to order online, take it in the ass and pay $14 to ship it.
Pennzoil Synthetic 5W40 European Formulation $32... Add the tax and im being raped. I have to see if i can get one of these stores to order it from now on.
 Old 10-12-2008, 08:43 AM   #2
MS6_Auburn_Fan's Avatar
Posts: 481   (View Stats)
MS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the worldMS6_Auburn_Fan is the leader of the world
What made you decide with 5W40?
MS6_Auburn_Fan is offline   Reply With Quote
 Old 10-12-2008, 08:48 AM   #3
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
I figure i want to try a 40wt with a hot engine and see what happens with the oil ingestion through the pcv.
 Old 10-12-2008, 09:04 AM   #4
Post your results if turns out that it helps. I've had a OCC sitting in my closet for about six months waiting for me to install.
 Old 10-12-2008, 09:07 AM   #5
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
i just put in 10w-30.. i might try 10w-40 next =(
Buildabong is offline   Reply With Quote
 Old 10-12-2008, 09:12 AM   #6
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
10wt is your cold start up wt. I wouldnt expect anything to change... the 40 wt i think is the better option. I may even try a 0-50 after this.
 Old 10-12-2008, 09:13 AM   #7
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
i know 10w30 should be the same as 5w30 once the engine is hot...but since i put in 10w30 all my smoking has stopped... it only seemed to smoke before at idle, when the engine wasn't fully warmed up, though.
 Old 10-12-2008, 09:16 AM   #8
Buildabong's Avatar
Groans: 213
0-50? hum... i use to put 0-40 in my passat 1.8t lol aint 0 a european thing? cause my friends dad all he has is vw's and they all have 0-40.. even his old school eurovan
 Old 10-12-2008, 09:24 AM   #9
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
it might have stopped because they don't have to add as many additives to a 10w30 since its not going to be as viscous at a cold temperature.
i'll be going to a 5w40 amsoil euro spec to see if it resolves the smoking issue i have after installing downpipe.
 Old 10-12-2008, 09:35 AM   #10
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
ive been running a 40 wt for a long time...you guys will be fine...i actually wanna try a staright 40 next
 Old 10-12-2008, 10:13 AM   #11
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
i run 0/50 in my 5.4 and ill tell you, that is some good fuckin oil. Did a tear down at 45,000 and not a mar on a bearing. I live in Ca, it doenst get cold enough to worry about having 5/10 or 20 wt for startup purposes.
I prefer euro spec oil though.
 Old 10-12-2008, 10:20 AM   #12
Frequentflyer's Avatar
Posts: 1,954   (View Stats)
It's hard to find 5W-40 in anything. 15W-40 is the popular one. I wish Wally World would carry 5W-40 PP because the last time I was there, it was $19 for a 5 quart jug, which comes out to $3.80 a quart. I'll be changing my Rotella T syn 5W-40 in another 1k miles or so and I'll probably do an analysis. I'm just over 10k miles on the car right now and this will be my 3rd change since the car was new, so I expect the motor to be near broken in. The Rotella is $22 for 4 quarts at WM. At $5.50 a quart, it's definitely not as good of a deal as PP.
08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny!
 Old 10-12-2008, 10:22 AM   #13
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Well, i may move to a 10/40 due to costs... paying shipping and tax to CA for PP makes it rather inexpensive, just to run Amsoil in this fucker. Oil is ordered, so im going to try it.
 Old 10-12-2008, 10:41 AM   #14
bova's Avatar
Groans: 45
haha you gotta hit up ebay for oil and use that microsoft live 30% off. i got 6 quarts for amsoil 5w-40 euro for $40. still kind of expensive for oil but cheap for amsoil.
 Old 10-12-2008, 12:08 PM   #15
MadOzodi's Avatar
Posts: 686   (View Stats)
MadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the worldMadOzodi is the leader of the world
I know you feel like it's rapage, but paying extra $$$ for oil that you know has worked flawlessly on another engine for 45k miles is worth it. A little extra every 4-5k miles for longevity and peace of mind down the road is good.
07 COSMIC BLUE MS3 GT
00 OBSIDIAN BLACK TRIUMPH LEGEND TT 900 - gone, but not forgotten
09 PACIFIC BLUE TRIUMPH SPRINT ST 1050 - SOLD
11 BLACK SUZUKI GSX-R750 - totaled
11 BLACK SUZUKI GSX-R750 - totaled...again
*OFFICIALLY RETIRED FROM TWO WHEELS*
MadOzodi is offline   Reply With Quote
 Old 10-12-2008, 01:19 PM   #16
MazdaMan13's Avatar
Posts: 532   (View Stats)
MazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to behold
what type of pp would you recommend for the northeast?
MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) no power-shifting
DON'T SLEEP ON THE MAZDA...:phillyb:
JDM PARKING LOL
MazdaMan13 is offline   Reply With Quote
 Old 10-15-2008, 04:53 PM   #17
Doc
Doc's Avatar
Posts: 526   (View Stats)
Doc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the world
Groans: 35
im running a RP 10-40
Our Australian manulas give us a range of oils to use for this engine.. one of which is the reccomended 10W-40!..
No complaints..
Doc
Doc is offline   Reply With Quote
 Old 10-15-2008, 06:31 PM   #18
No complaints..
Doc
Go figure. It's amazing how many people think a 40 weight oil is way too thick for this car. "Back in the day", when turbocharged cars were more numorous (mid 80's into the 90's), it was not uncommon to use 10W-40 or even 20W-50 in them. Thanks to emissions and fuel economy standards imposed on the car manufacturers, they've been going with thinner and thinner oils. They know most people in the USA can't keep a car for longer than 4 or 5 years before buying a new one and by that time the car is out of warranty, so they're willing to accept the risk of increased engine wear.
Are your cars rated for 18 mpg city and 26 mpg highway "Down Unda"?
 Old 10-15-2008, 06:35 PM   #19
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
can't wait to see the UOA on that rotella...
xcoldricex is offline   Reply With Quote
 Old 10-16-2008, 06:43 AM   #20
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
The reason we no longer use 20W-50 like in the old days is that engine manufacturing has taken a step up with tighter tolerances, etc...
The tighter the tolerance, the thinner the oil is needed.
Back in the 80's, we used 20W-50 to compensate for tolerances...
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline   Reply With Quote
 Old 10-16-2008, 06:44 AM   #21
AutoXRacer's Avatar
Shit, I pay $98 for a case of Red Line... $40 is a bargin...
 Old 10-17-2008, 07:44 AM   #22
Doc
Doc's Avatar
Groans: 35
we have a different rating system my friend.
However the car is rated to 10.2L/100km's
maybe you can find another car like an evo 10 we have here and compare our system to yours.
I like the idea of a 40.. i think a 50 is a little too heavy at 6k
CHeers mate!
Doc
 Old 10-17-2008, 08:07 AM   #23
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
I ran castol syntec 5w-50 in my gsr its whole life
 Old 10-17-2008, 08:08 AM   #24
gsrtype1's Avatar
Groans: 102
u need a lighter wieght when starting your engine 5-10. you want the oil to be thin at start up so it gets in their and protects fast, thats the purpose of multi wieght oil..
 Old 10-17-2008, 08:32 AM   #25
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
I run amsoil signature series 0w30 by preference.
I have had a few oil changes sneak up on me (like w/ the turbo swap) and have used the Q full synth, and castrol full synth. ive messed around with oil weights (5w30, 0w30, 10w40), and at no time have i noticed a difference. when the car smoked, it smoked with any oil, any weight. now it doesnt cuz i put in the turbo.
i have penzoil platinum 5w30 waiting to go in when i pull the turbo to port the wastegate... lets just say im not looking forward to that... who knows, it may happen tonight...
 Old 10-18-2008, 01:33 AM   #26
CHeers mate!
Doc
So that'd be 2.695 gallons per 62.137 statute miles or 23.056mpg. Sounds like an average and probably pretty accurate. Maybe they make your MS3's with looser tolerances. I think not.
 Old 10-18-2008, 03:27 AM   #27
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
jmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the world
Groans: 162
I've run both the Amsoil SSO and the Euro 5w-40 in mine since 1K miles. I've got just over 16K on the car now. I've been super happy with both. Never used any noticable amount of oil between changes and have just a few ounces in the OCC at each change. I went to the 5w-40 merely because I just don't feel 30wt is heavy enough in any turbo car especially in our summer heat here. I get 22-23 MPG in the city and 29-30 on the highway no matter which oil I use or how hard I drive the car.
jmhinkle is offline   Reply With Quote
Pre-ordered the Accessport MidwestSpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 46 06-03-2012 07:40 PM
New WHEELS/SHOES ordered! Laloosh MazdaSpeed 3/6 - Wheels & Tires 28 08-14-2008 03:33 AM
Ordered new tires! MS3-oholic MazdaSpeed 3/6 - Wheels & Tires 25 06-07-2008 10:18 PM
Ordered my new BOV. Synchronic. mazdaspeedjay MazdaSpeed 3/6 - Turbo Induction 11 04-26-2008 04:11 PM
Page generated in 0.44629 seconds with 34 queries
