-   -   Over torqued spark plugs? help! (http://www.mazdaspeedforums.org/forum/f10/over-torqued-spark-plugs-help-57909/)
streetrage 05-30-2010 10:47 PM
Hello all! I checked out my plugs today, and I torqued them to 20 ft lbs. I later realized that this is too much. Should I loosen the plugs and torque them to 10 or so, or is it ok to leave them at 20?
thanks!
Alex
mtnrunner 05-30-2010 11:01 PM
Leave them at 20. as long as you dont strip them your fine.
streetrage 05-30-2010 11:26 PM
what the stock setting anyways? Some say 16, some say 10, others say 8.. anyone know the maximum torque specs?
streetrage 05-31-2010 01:46 AM
mtnrunner 05-31-2010 01:58 AM
i have never used a torque wrench on a spark plug so i just go snug. i have never had a problem with that but i have a pretty good feeling about how much to tighten things.
NCZ13 05-31-2010 03:29 AM
I finger tighten my spark plugs, than use the socket wrench and tighten it literally with my pinky.
zx2man 05-31-2010 03:53 AM
just hand tight em and then with your socket wrench..just give it alittle snug..like 1/4 turn...thats all you really need..doesnt take much to seat em good, more than that and you risk stripping shit..which is a bad thing..been doing that for years and has worked for me.
Qtip 05-31-2010 05:22 AM
Factory spec is 8-10 ft lbs.
karl-hungus 05-31-2010 06:10 AM
leave them alone, cowboy.
memin 05-31-2010 06:23 AM
I always snug those and never had a problem, just leave them alone as long they are not strip.
streetrage 05-31-2010 09:19 AM
Great! Thank you all for your input! I'm gonna loosen them a little, since I havent really driven the car since I put the plugs in.... I dont want to risk them messing up the head when the engine gets hot!
thanks again!
Alex
smakdown61 05-31-2010 05:28 PM
They are tapered so tightening more than snug plus 1/4 turn to lock doesn't do anything but potential strip.
streetrage 06-01-2010 11:40 PM
thanks for all your help everyone! I'm gonna order a new set of plugs since these are the original "fomoco" plugs on this engine with 70k miles!
super_pablo_ 06-01-2010 11:46 PM
next time... tighten with hand, then another 1/8 of a turn with a wrench and ull be good to go
06Speed6 06-02-2010 02:04 AM
The general rule that I use on plugs is I dont tighten them using the handle of the wrench, I hold the ratchet part of the wrench and tighten it about as tight as I can get it with my wrist. I am fairly strong and I know they are torqued to less than 15'lb.
It doesnt damage an engine to under torque a spark plug because even a loose plug will seal 90+% and it cannot back out with our coil on plug system or a spark plug wire that has a boot.
Page generated in 0.16925 seconds with 11 queries
