Like Tree3Likes
 Old 10-08-2013, 08:05 PM   #1
azazelthegreat's Avatar
Posts: 596   (View Stats)
azazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the world
Default Oversized bearings mazdaspeed 3 issues
I can't find the proper bearings for my car.
Ive gone through so many sets
Bought standards
then found out my crank needed to be machined
Then was told i need to order .20 oversized
Then was told that they had to go to 50MM since the crank was bent or some shit.
Ordered 50mm oversized bearings from Clevite and well this happened
Clevite said that those bearings would work. which doesn't make since Eagle says that those bearings are obviously wrong
So my question, where do i go about finding proper 50mm oversized bearings im about to say screw it and buy a new crankshaft after having my car down for almost 3 months.
azazelthegreat is offline   Reply With Quote
 Old 10-08-2013, 08:50 PM   #2
Oversized bearings were hard to find in the past and not sure that has changed. I would also look at sourcing a good crank. A bent crank - if that was the case - is not something I'd run.
atvfreek (10-09-2013), btstarcher (10-11-2013), Easter Bunny (03-12-2014)
 Old 10-08-2013, 09:24 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
There are no .5mm bearings. New crank time.
2006 Mazdaspeed 6
 Old 10-09-2013, 05:05 AM   #4
I have yet to find bearings that will work with machined crank journals. My machinist has three MZR cranks that are worthless until we find a solution.
 Old 10-09-2013, 06:22 AM   #5
He Hate Me's Avatar
Posts: 460   (View Stats)
He Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the worldHe Hate Me is the leader of the world
OEM part#: L3Y2-11-SFX is 50mm oversize.
I would like to see the numbers that are on the bearings that you currently have to make sure they are even the correct ones.
He Hate Me is offline   Reply With Quote
 Old 10-09-2013, 06:55 AM   #6
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
Those con rod bearings that you have are not for the MZR motor. They are for a 2.3L DOHC from a Ford truck. The max tunnel on those is 53MM. The ones for the MZR have a tunnel size of up to 55MM. Look in the thread in the sticky section of the Mazdaspeed 3 area. The ones for the MZR motor from Clevite is CB-1918 or CB-1925. ACL has some as well. Just check that thread for the part numbers.
But yes if the crank is not true I would not use it.
Jason
atvfreek likes this.
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 6 Users Say Thank You to SFWD 1934 For This Useful Post:
atvfreek (10-09-2013), azazelthegreat (10-09-2013), Easter Bunny (10-09-2013), El_Diablo (10-09-2013), himurax13 (10-10-2013), silvapain (10-09-2013)
 Old 10-09-2013, 07:29 AM   #7
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Jeez Kieth, you never told me the crank was actually bent. What machine shop did you go through? There aren't to many around here that can properly straighten a crank.
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
 Old 10-09-2013, 07:46 AM   #8
Andjo's Avatar
Posts: 937   (View Stats)
Andjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the worldAndjo is the leader of the world
I might have a crank for sale soon and will sell it cheap if it's any good.
GT3076 and supporting mods with Kozmic Motorsports Built motor and tune
FUTURE MODS: 6266 with V-Band everything
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
2013 TROLL CHAMPION "DYLANFYHN"
Andjo is offline   Reply With Quote
 Old 10-09-2013, 02:59 PM   #9
Ive found 2 sets.
undersized and oversized
they said it was bent, i dont think it was i think they wanted more money.
it was fine coming out of the car.
"crank was bent so we machined some more. or something along those lines"
me too but the bearings are at my buddies and hes not getting ahold of me
BEARING SET for 2010 Mazda CX-7|L3Y211SFX
How soon. like in a few days soon?
Last edited by azazelthegreat; 10-09-2013 at 02:59 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-09-2013, 03:04 PM   #10
you need UNDERsized bearings when you machine the crank journal. OVERsized bearings are for when the block side is machined.
http://www.freeasestudyguides.com/cr...nspection.html
The Following 5 Users Say Thank You to silvapain For This Useful Post:
802MS3 (02-05-2014), azazelthegreat (10-09-2013), Easter Bunny (03-12-2014), skiptowncat (10-09-2013), SLOWHATCH (10-12-2013)
 Old 10-09-2013, 03:11 PM   #11
skiptowncat's Avatar
Posts: 1,592   (View Stats)
skiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the world
Groans: 49
Groaned at 34 Times in 25 Posts
Main Crankshaft Bearings: Use Oversized or Undersized Bearing
A new day here, another thing learned.
Tuned with by
K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!!
skiptowncat is offline   Reply With Quote
 Old 10-09-2013, 03:20 PM   #12
well back to square one. Finding proper undersized bearings.
 Old 10-09-2013, 03:25 PM   #13
Jason
i actually have 1925s in my room. They are not big enough.
If im correct they are STD size
 Old 10-09-2013, 03:31 PM   #14
So, when it comes to machining, how does it go? 10 20 25 50 or 50 25 20 10?
 Old 10-09-2013, 04:05 PM   #15
Speeeeeed
06Speed6's Avatar
10 20 25 50, that is the amount of material removed.
Undersize bearings are a different story, if they ground a bent crank .5mm it is almost certainly garbage because the jounals have to be in alignment and there is almost no possibility that they didnt move the centerline while grinding.
2006 Mazdaspeed 6
silvapain (10-09-2013), SLOWHATCH (10-12-2013)
 Old 10-09-2013, 05:14 PM   #16
i really dont think it was bent. i think they were full of shit.
but anyways i think im just going to find a new crank.
anyways i cant grind off anymore even i wanted to.
I got word that my buddy knows a guy who can get special bearings made.
looking into options this week i guess
Hopefully i can snag a crank for under 500...
774 new.
Last edited by azazelthegreat; 10-09-2013 at 05:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-09-2013, 05:20 PM   #17
m4tic's Avatar
Posts: 4,928   (View Stats)
holy shit... so many things make sense now
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
The Following 2 Users Say Thank You to m4tic For This Useful Post:
He Hate Me (10-09-2013), silvapain (10-10-2013)
 Old 10-10-2013, 03:05 PM   #18
Clevite:
140 CID (2.3L) DOHC 16 Valve L4; 3.44" (87.5mm) Bore; Ford MZR
Turbocharged; Engine Code: L3T; VIN: M - sorry, no bearings for this
model.
But thats after saying the bearings (posted above) will work.
same guy.
The Following User Says Thank You to azazelthegreat For This Useful Post:
 Old 10-10-2013, 07:11 PM   #19
M900's Avatar
Posts: 8   (View Stats)
M900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to beholdM900 is a splendid one to behold
I used to grind cranks, and the first thing to check after measuring the journals is if the the crank is bent. If it is bent it needs to be checked for cracks. If not cracked it needs to be straightened, then ground. If you grind a bent crank it will come out of the grinder bent, and or the stroke will be off. So, either these guys missed the number the first time, or it came out bent. The sizes most likely go .25mm-.50mm and so on.
Paul
M900 is offline   Reply With Quote
The Following 7 Users Say Thank You to M900 For This Useful Post:
802MS3 (02-05-2014), atvfreek (10-11-2013), azazelthegreat (10-11-2013), Easter Bunny (03-12-2014), El_Diablo (10-11-2013), SLOWHATCH (10-12-2013), Tokay444 (10-12-2013)
 Old 10-11-2013, 09:30 PM   #20
SFWD 1934's Avatar
Here:
Part Details for CB-1925H:
Rod Bearing Overview
Specifications
Material: TM-77
Min. Std. Shaft Diameter:
2.0465"
51.9811MM
Max. Std. Shaft Diameter:
2.0472"
51.9989MM
Min. Vert. Oil Clearance:
.0004"
0.0102MM
Max. Vert. Oil Clearance:
.0022"
0.0559MM
Max. Wall:
.0588"
1.4935MM
Min. Brg. O.D. or Housing Bore:
2.1662"
55.0342MM
Max. Brg. O.D. or Housing Bore:
2.1667"
55.0342MM
Max. Length:
.665"
16.8910MM
Jason
www.full-race.com
The Following 2 Users Say Thank You to SFWD 1934 For This Useful Post:
 Old 10-12-2013, 06:39 AM   #21
Here:
Specifications
Material: TM-77
2.0465"
51.9811MM
2.0472"
51.9989MM
.0004"
0.0102MM
.0022"
0.0559MM
Max. Wall:
.0588"
1.4935MM
2.1662"
55.0342MM
2.1667"
55.0342MM
Max. Length:
.665"
16.8910MM
Jason
Thanks but pretty sure those are standard... I have a set I bought before I found out the crank needed machined
 Old 10-12-2013, 06:48 AM   #22
SFWD 1934's Avatar
I tried to copy over the page that had all the info from Clevite but it didn't work. So I just grabbed the basic info from those bearings. Just out of curiosity what is the part number you have for the Eagle rods?
Jason
www.full-race.com
 Old 10-12-2013, 01:21 PM   #23
Jason
not sure im not at home. The 1925s fit
 Old 10-12-2013, 05:38 PM   #24
rangergt's Avatar
Posts: 14   (View Stats)
rangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond reputerangergt has a reputation beyond repute
Groaned at 4 Times in 1 Post
That is not accurate, they are for mzr 2.3 as well just not mazdaspeed DISI mzr. All duratecs and NA MZR have a 50mm rod journal (and use clevite cb1838) and the mazdaspeed disi has a 52mm rod journal (use clevite cb1925)
Originally Posted by M900 View Post
I used to grind cranks, and the first thing to check after measuring the journals is if the crank is bent. If it is bent it needs to be checked for cracks. If not cracked it needs to be straightened, then ground. If you grind a bent crank it will come out of the grinder bent, and or the stroke will be off. So, either these guys missed the number the first time, or it came out bent. The sizes most likely go .25mm-.50mm and so on.
Paul
I agree 100%
I would also find a new machine shop to work with because they are either incompetent or dishonest or both.
2.3 duratec, 10.63 @ 130 mph, at a race weight of 3475lbs
I cannot answer PM's because I do not have enough posts, not ignoring, just can't answer.
rangergt is offline   Reply With Quote
The Following User Says Thank You to rangergt For This Useful Post:
Manny (10-13-2013)
 Old 10-12-2013, 06:21 PM   #25
I don't plan on getting anything else machined...
Rods are fine. 2 sets fit fine.
Standard and the .25s
Its a shame
 Old 10-12-2013, 10:21 PM   #26
SFWD 1934's Avatar
I just do not call the non speed motor an MZR, I just refer to it as the NA 2.3L Duratec. But when I saw those CB1838 in the pic I knew he had the wrong con rod bearings.
Jason
www.full-race.com
The Following User Says Thank You to SFWD 1934 For This Useful Post:
azazelthegreat (10-13-2013)
 Old 10-16-2013, 07:52 PM   #27
Have any leads on sourcing a crank=/
 Old 11-13-2013, 05:39 AM   #28
crutch77's Avatar
Posts: 493   (View Stats)
crutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the worldcrutch77 is the leader of the world
Its a shame
azazel, I was in the same boat as you. Rod bearing journals had to be machined to -.50mm, and then I found that there are apparently no undersize bearings to be had for our vehicles beyond -.25mm. I scoured the internet and spent half a day reading through catalogs and crossing part numbers and came across these:
ACL Race Series Bearings
The only significant difference is the overall length, which is .650" vs. stock I believe is .669". That gives you 97% of the stock width, so I wouldn't worry about that at all. They fit great in my Manley rods, and the oil gap (measured with plastigauge) came in right at .0015".
I've only got about 100 miles on my engine at this point, but it's running perfectly smooth. I'll update again after I've got more miles on, but I'm very confident at this point. This bearing crosses to all sorts of other manufacturers, and some come in sizes all the way down to -.75mm. I'll have to find the sheet I wrote all those numbers on when I get home.
Anyway, I hope it's not too late for this information to be of use to you. @silvapain, let me know what your machinist thinks.
crutch77 is offline   Reply With Quote
 Old 11-13-2013, 07:38 AM   #29
Yeah a bit late. Ordered a new crank.
550 miled into break in.
That is interesting though.
Though I have to sell my old bearings :l
Sent from my Samsung Galaxy S4.5
 Old 02-04-2014, 09:54 PM   #30
BZiggy10's Avatar
Posts: 725   (View Stats)
BZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the worldBZiggy10 is the leader of the world
How have these bearings worked for you since this post? I just went to put the bearings my machinist got me and same thing as OP had going on. I was aware that some people had problems finding the undersized bearings but I thought I was good because the machine guy is very knowledgeable.
06 MS6
Zig Built SOLD!!!!
Rebought back and continuing the mission to fully bolted top mount BT
BZiggy10 is offline   Reply With Quote
 Old 02-05-2014, 07:22 AM   #31
crutch77's Avatar
They're working wonderfully. I've got a few thousand miles on my rebuild now, and I've been pushing it hard for a while now I'm self tuning, so I've done a shitload of WOT pulls lately, and one of my map revisions was hitting 380 peak torque. Engine is running silky smooth.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it)
 Old 02-05-2014, 07:31 AM   #32
BZiggy10's Avatar
I'm going to make certain with my machine guy that mine was machined .50 under. I will see what he thinks of these if he doesn't have another solution.
You got the Manley H beam and not the H beam plus right?
06 MS6
Zig Built SOLD!!!!
Last edited by BZiggy10; 02-05-2014 at 07:31 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-05-2014, 07:59 AM   #33
BZiggy10's Avatar
@silvapain
What do yall think about this. I know a few months back you said that one of you have three cranks useless because of no bearings. If crutch77 is running fine for a couple thousand miles sounds like they should be good right?
06 MS6
Zig Built SOLD!!!!
 Old 02-05-2014, 08:04 AM   #34
BZiggy10's Avatar
and @06Speed6
06 MS6
Zig Built SOLD!!!!
 Old 02-05-2014, 08:15 AM   #35
Speeeeeed
06Speed6's Avatar
Bearings are bearings, if the OD, ID, and width work then I dont see a problem with it. Iirc our rod bearings are odd Evo bearings and our crank bearings are out of a Honda.
And I dont generally buy worn oit parts so it wasnt me haha
2006 Mazdaspeed 6
BZiggy10 (02-05-2014)
 Old 02-05-2014, 01:36 PM   #36
crutch77's Avatar
Correct.
FWIW, these ACL bearings (which I've established are slightly narrower than our stock rod bearings) are from various Subaru engines: EJ16, EJ18S, EJ20E, EJ20T, EJ22, EJ22T, EJ25, EJ25T (WRX motors )
These bearings do have tangs, as stock bearings do. They also have no oil holes, same as stock. Some of the bearings I found in my search had oil holes, some had no tangs.
Last edited by crutch77; 02-05-2014 at 01:58 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-05-2014, 01:56 PM   #37
crutch77's Avatar
@BZiggy10, here's where I ordered them from: Race-Mart Cheap, and good customer service in my experience. I was in a rush, and I called them. They talked me out of paying for expedited shipping and I ended up getting the bearings next day with standard FedEx service. YMMV, of course.
 Old 02-05-2014, 02:01 PM   #38
BZiggy10's Avatar
I will check them out. Might be ordering the with the rest of my stuff from Edge Auto with a 7% discount!!
Wow crap those are cheap. NVM just made my decision lol
06 MS6
Zig Built SOLD!!!!
Last edited by BZiggy10; 02-05-2014 at 02:01 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-06-2014, 02:02 AM   #39
Speeeeeed
06Speed6's Avatar
Correct.
Your right, it was a scooby engine.
2006 Mazdaspeed 6
 Old 02-13-2014, 05:20 PM   #40
crutch77's Avatar
@BZiggy10, how's it going? For you and anyone else following this thread who might be wondering about the health of my engine, I decided to post a log from today. This is with about 3500 miles on my rebuilt engine.
I'm in the process of self-tuning, so everybody please feel free to pick my shit apart. FWIW, my knock sensor is active to 7200 rpm.
The Following User Says Thank You to crutch77 For This Useful Post:
Oversized crank bearings tbot MazdaSpeed 3 - Engine, Transmission & Driveline 23 07-24-2015 05:20 PM
Mazdaspeed 3 2009 - need help fixing issues - fully built engine S3BAZ1091 MazdaSpeed 3 - Engine, Transmission & Driveline 289 02-11-2013 07:46 PM
Oversized crank bearings tbot MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 20 09-19-2012 02:06 PM
2007 Mazdaspeed 3 Driveline Issues Prevolution MazdaSpeed 3 - Engine, Transmission & Driveline 4 02-11-2010 07:05 PM
2006 mazdaspeed 6 tranny issues camo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 09-23-2009 08:47 AM
Page generated in 0.61014 seconds with 34 queries
