![]() | | #41 | ![]() |
![]() Join Date: Jul 2013 Location: Fort Mitchell, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score
__________________ 06 MS6 Zig Built SOLD!!!! Rebought back and continuing the mission to fully bolted top mount BT |
![]() | | #42 | ![]() |
![]() Join Date: Jan 2011 Location: Indianapolis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 232
| Not Ranked : 0 score Good deal. How are you planning to keep the crank from moving while you torque the crank pulley bolt?
__________________ 2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it) |
![]() | | #43 | ![]() |
| Not Ranked : 0 score I did real well when I swapped my VVT with the motor in the car still. I used the small hole and put the pin in to keep the crank at TDC, had a bolt holding the actual crank pulley, my wife stepped on the brake with the car in 6th gear, and I used a 36" pry bar and wedged the crank pulley so it wouldn't move while hitting it with the air impact in small bursts. Shit sounds like a lot but I didn't want to buy the crank holding tool and I didn't want anything to fail lol.
![]() | | #44 | ![]() |
I would also HIGHLY recommend a Torque to Angle gauge if you don't already have one. I bought this one and it performed flawlessly.
__________________ 2008.5 MS3 GT | Forged | Self-Built, Self-Tuned | E85 | Torque (lots of it) | |
![]() | | #45 | ![]() |
| Not Ranked : 0 score I don't really know what a torque angle gauge is, never used one before. Does it just tell you when you've hit the 90* mark? Nice tool by the way lol. What is it just a 1/4" or 1/8" piece of steel with a couple bolts? Genius!
![]() | | #46 | ![]() |
The torque to angle gauge is a nice repeatable way to hit the angle you're shooting for. Especially important on the main bolts and head bolts. It's important to be consistent with the clamping force on all those bolts. Eyballing it or using sharpie to mark a ballpark target doesn't cut it. Follow the procedures in the manual to a T (unless you're using ARP studs, then follow those instructions )With all the money you put into a rebuild, it would be silly not to have this important tool. Auto parts stores carry them.
![]() | | #47 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| Not Ranked : 0 score Omg torquing a crank bolt with an impact, tell me that I didnt just read that.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
![]() | | #48 | ![]() |
This is what I did for my VVT. If I am completely wrong please let me know and I will change the way I do it when I finish rebuilding the engine here in the next couple weeks.
__________________ 06 MS6 Zig Built SOLD!!!! Rebought back and continuing the mission to fully bolted top mount BT | ||
![]() | | #49 | ![]() |
For the main/head bolts, though, you need to follow instructions to the letter, with as much precision as you are able. This is especially true if you plan to push your engine significantly past stock power levels. Any bore distortion caused by uneven clamp will cause uneven wear and at a minimum lead to bad compression. Add higher heat by pushing your engine hard and you'll have contact between your piston skirts and cylinder walls. Bad things can happen. Now that I've hopefully scared you a little, assembling your short block isn't particularly hard. You just need to be very meticulous.
![]() | | #50 | ![]() |
| Not Ranked : 0 score Well I always take my time and do things right. ARP studs are easy to install any way. I've already done my Mains and about to finish up the pistons and put the head on tonight; depending on how much I drink that is.... I feel like 06SPEED6 thinks I just threaded the crank bolt and hit it with the impact until I thought it was good-n-tight lol
__________________ 06 MS6 Zig Built SOLD!!!! Rebought back and continuing the mission to fully bolted top mount BT Last edited by BZiggy10; 02-14-2014 at 04:05 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #51 | ![]() |
| The Following User Says Thank You to crutch77 For This Useful Post: | BZiggy10 (02-16-2014) |
![]() | | #52 | ![]() |
| Not Ranked : 0 score So how's it going?
![]() | | #53 | ![]() |
![]() Join Date: Jul 2013 Location: Streetsboro ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
------------------------------------ One last thing for this thread since it seems like a good information thread, I have all my over sized bearings still. I was never able to return them Last edited by azazelthegreat; 03-12-2014 at 06:29 PM. Reason: MSF Database - Automerged Doublepost | |||
![]() | | #54 | ![]() |
| Not Ranked : 0 score Good man almost 200 miles on the new engine and it feels great. Those bearings really saved me. How is yours running?
The crank bolt I just torqued it to 70 drew the vertical line and used a breaker bar to do the 90*. It actually wasn't as hard as I thought it would be. I'm actually upset I didn't key the crank though now after seeing exactly what is holding the timing chain in place. Next time I have my crank out it will get keyed. (unless it can be done while in the block, I have no clue haven't really done research but that would be awesome)
| The Following User Says Thank You to BZiggy10 For This Useful Post: | azazelthegreat (03-15-2014) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Glad to hear it! Mine is running beautifully. 4,500 miles in now.
| The Following User Says Thank You to crutch77 For This Useful Post: | BZiggy10 (03-13-2014) |
![]() | | #56 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson | |
![]() | | #57 | ![]() |
| Not Ranked : 0 score Yea kind of figured not being that it would need to be machined out and the timing cover would have to be off as well. Oh well maybe another time. I've never done a supercharger kit or anything how does pinning it work.
![]() | | #58 | ![]() |
Groans: 769
| Not Ranked : 0 score Removing the timing cover isn't that big of a deal in the car. For pinning, you'll slip a drill fixture collar over the crank snout, cinch it down with the locating screws to keep it from walking and then drill a hole into the crankshaft to a predetermined depth. From there you insert a dowl pin into the hole and of course you'll have to have a crank pulley that will slip over this pin.
![]() | | #59 | ![]() |
| Not Ranked : 0 score OK that makes sense. Does any one ever do two, three or even four dowel pins for more strength? I just can't see much strength coming from just the one pin. I've seen woodruff keys snap in diesel motors.
![]() | | #60 | ![]() |
Groans: 769
| Not Ranked : 0 score These aren't diesels... Typically one or two pins at most as they're made out of tool steel.
![]() | | #61 | ![]() |
| Not Ranked : 0 score Lol I know they aren't but some are making as much power as the diesel engines I've seen breaking woodruff keys. I would just have more peace of mind with at least two. I'm pretty sure I'm going to do this when I go BT
![]() | | #62 | ![]() |
| Not Ranked : 0 score You replaced the three friction washers on the crank, right? You should be fine unless your eventually target HP is WAY up there.
![]() | | #63 | ![]() |
| Not Ranked : 0 score Yes I sure did. I just don't like the thought of only those friction washers are holding the sprockets by pressure alone. Reassurance and a fool proof plan is always nice to have.
![]() | | #64 | ![]() |
Groans: 769
| Not Ranked : 0 score There are 1k+hp LSx's using pin kits... you're over thinking it. These aren't woodruff keys, and while some MS cars might be able to make the HP of a diesel, they're not making the torque.
![]() | | #65 | ![]() |
It's all good though. I will put two pins in and no one will ever have to know I went overboard on a sub 500AWHP car lol.
![]() | | #66 | ![]() |
Groans: 769
| Not Ranked : 0 score But they are subject to severe use and abuse. Thats also just one particular vehicle, not all vehicles snap woodruff keys. Again, there are a ton of SBF powered mustangs that are doing just fine at over 1k hp.
![]() | | #67 | ![]() |
| Not Ranked : 0 score These threads are really starting to bother me. 1: Horsepower and crank slip are not related - at all 2: Domestics key cranks for several reasons depending on the engine, most have far inferior designs and really need to be pined. 3: I was going to make a set of aftermarket friction washers and I didn't because I found that they are almost certainly over rated for our engine from the factory. The washers aren't the problem.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | phate (03-24-2014) |
![]() | | #68 | ![]() |
I understand that you probably know a ton more than I do but coming into a thread mad because someone has less knowledge saying that it bothers you then not giving an explanation to what you are talking about is messed up.
![]() | | #69 | ![]() |
| Not Ranked : 0 score Crank slip is almost certainly related to softer metals being used in the oil pump and timing sprockets on the crank. Once used, the metal they are made of permanently deforms (crushes) to the shape of the friction washers. You can feel the knife edge on the friction washer mating surfaces on both sprockets. Since the friction washers are smaller than the mating surfaces of the sprockets, the second time around the sprockets crush against each other and the friction washer is not properly crushed. The friction washer is basically a shim that is coated in diamond dust, the dust embeds itself in the shim and the opposing mating surface when properly clamped. The strength of that embedment is dependent on the depth of the embedment and the strength of the metal that the dust is embedded into. Proper clamp absolutely requires that both surfaces be absolutely flat at a microscopic level. When reusing the sprockets (compounding the soft metal issue), the old sprockets are pitted from the previous friction washer and do not provide a flat surface for the new washers to grip. In the case of the cams, the camshaft itself is fairly soft and after having seen quite a few cams now, the cams pretty severely wear from the friction washers used there but they don't seem to deform like the sprockets do. If you cannot see obvious machine marks on the cams mating surface, ide advise getting the surface machined and polished.
![]() | | #70 | ![]() |
| Not Ranked : 0 score That does make a lot of sense. Thank you for explaining. I never even looked at my sprockets for impressions left by the friction washer. I only cleaned mine up and slapped them on.
![]() | | #71 | ![]() |
| Not Ranked : 0 score Here is the web page for our shims EKagrip® friction-enhancing shims with electroless nickel dispersion surfaces
| The Following User Says Thank You to 06Speed6 For This Useful Post: | BZiggy10 (03-24-2014) |
| Oversized crank bearings | tbot | MazdaSpeed 3 - Engine, Transmission & Driveline | 23 | 07-24-2015 05:20 PM |
| Mazdaspeed 3 2009 - need help fixing issues - fully built engine | S3BAZ1091 | MazdaSpeed 3 - Engine, Transmission & Driveline | 289 | 02-11-2013 07:46 PM |
| Oversized crank bearings | tbot | MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline | 20 | 09-19-2012 02:06 PM |
| 2007 Mazdaspeed 3 Driveline Issues | Prevolution | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 02-11-2010 07:05 PM |
| 2006 mazdaspeed 6 tranny issues | camo | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 09-23-2009 08:47 AM |
