 Old 10-18-2009, 08:21 PM   #41
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
ebrake only. our ebrakes are mechanical over hydraulic so if your ebrake doesnt hold the car, your rear brakes arent doing shit anyways and you need to get em fixed.
reddeerspeed3 is offline   Reply With Quote
 Old 10-18-2009, 09:42 PM   #42
Drewmugx5t's Avatar
Posts: 18   (View Stats)
Drewmugx5t will become famous soon enough
e-brake and in gear, car doesn't move. Only time to use just the gear is when you are letting the brakes cool after a lapping session on the track as not to warp the rotors. I have seen my friends RX-8 in the neighbors front yard because he didn't set it well enough.
Drewmugx5t is offline   Reply With Quote
 Old 01-01-2010, 08:52 PM   #43
nue
nue's Avatar
Posts: 110   (View Stats)
nue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud of
Well good news is that I realized that it's not my clutch that's bad. Bad news is that my compression might be shot since after rummaging around a bit, I realized my car is definitely trying to turn itself over while in gear since it lurches itself backwards slowly... Oh well. Let's pray that it doesn't mean I'm going boom. That and I need to get my rear brakes re tightened.
Does transmission ratios have anything to do with compression? Nobody's said anything about this yet but I'm fairly suspect of it since this car has a higher 1st gear ratio than my other MT's yet, they hold just fine on an incline while this one does not, granted, this car is also something of a hippo.
nue is offline   Reply With Quote
 Old 01-05-2010, 07:58 AM   #44
shpankey's Avatar
Posts: 496   (View Stats)
eBrake only here. Unless on a steep incline then I do a gear and turn my wheels into the curb. But 99% of the time it's just eBrake.
09 Speed 3 GT
Parking brake light? blaggah MazdaSpeed 3/6 - Suspension & Brakes 7 08-05-2009 02:07 PM
Parking for MJ Memorial -- Really Hot Spots Haltech Celeberty Smut 0 07-06-2009 01:00 PM
FAIL: Multi-level Parking in NYC Haltech Automotive News 0 04-10-2009 05:50 PM
Page generated in 0.24207 seconds with 23 queries
