-   -   Passenger Side Axle Removal Help (http://www.mazdaspeedforums.org/forum/f10/passenger-side-axle-removal-help-175010/)
sheltbh 08-05-2014 08:52 AM
I am in the middle of replacing my clutch and am to the point of popping out my axles. I have read everything and looked at every diagram and I must be missing something. On the passenger side removal I have disconnected the bracket and popped the axle loose from the transmission. But I cannot for the life of me figure out how to remove it; it will slide about a 1/2 inch away from the tranny but then hits up against the pulley tensioner on the engine. I am on a gen 1, so do I need to remove the belt and tensioner or is there a trick I am missing? :thinking:
Jtaylor 08-05-2014 09:14 AM
Refer to this thread:
http://www.mazdaspeedforums.org/foru...clutch-102245/
sheltbh 08-05-2014 09:19 AM
JTaylor, thanks for the link but that is actually the thread I am going off of. That DIY or any of the others I have found mention removing the tensioner. But I see absolutely no way to squeeze it out with the tensioner still on the block?
Gr8Speed 08-05-2014 09:22 AM
Then remove the tensioner...
Vader 08-05-2014 09:30 AM
The bracket on the axle shaft, should swivel around. Did you try that?
I had zero issues getting it to clear the block. Gen 1 also.
sheltbh 08-05-2014 10:39 AM
The bracket doesn't swivel in the least! Must be rusted on, I will try to swivel it and if it doesn't looks like time to remove the pulley. Thanks!
Vader 08-05-2014 11:51 AM
It will swivel. Just break it loose, and you should be good to go.
Page generated in 0.17192 seconds with 11 queries
