 Old 09-21-2008, 11:02 AM   #41
Lymerock's Avatar
Posts: 1,436   (View Stats)
Originally Posted by ev0nstispanka View Post
n it should slide off guys???
yes, if you have all 10 nuts off the head and all 4 nuts/studs removed from the turbo, it will easily slide straight back
you may have to give it a gentle wack to unseat it from the head side gasket
 Old 09-21-2008, 11:16 AM   #42
ev0nstispanka's Avatar
Posts: 358   (View Stats)
ev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud ofev0nstispanka has much to be proud of
alright well i owe myself the day off...im tired n i spent the entire saturday on that..so today is Football n chips...GO Dolphins!! I'll go @ it tomorrow. u think my car is fine if i leave it with the VC off..the hood is closed and the turbo outlet is covered with a ziplock bag and so is the other silicone hose that goes to the stock TMIC. .
ev0nstispanka is offline   Reply With Quote
 Old 09-21-2008, 11:21 AM   #43
 Old 09-21-2008, 11:26 AM   #44
Lymerock's Avatar
i lay rags across the valve train to keep dust and shit from sticking to the oil
otherwise you are fine
 Old 09-21-2008, 11:31 AM   #45
damn...(sighs of relief). thanks and i'll be back on the thread tomorrow..hopefully posting pix with the PG mani installed. thanks bro.
 Old 09-21-2008, 11:31 AM   #46
and GRIM
 Old 09-21-2008, 01:19 PM   #47
MS3 Ventura's Avatar
Posts: 172   (View Stats)
MS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant futureMS3 Ventura has a brilliant future
If you take off the valve cover, do you have to add a sealant, or anything like that, or just bolt it back down?
MS3 Ventura is offline   Reply With Quote
 Old 09-21-2008, 01:23 PM   #48
Lymerock's Avatar
it just bolts right down
the only thing to do as a precaution is take a rag and wipe the gasket mating surface on top of the head clean, wiping from inside to outside
there can be sand buildup around there and it would suck to get any of that under the cover gasket or worse into the head while you are putting it on and moving it around to line up the bolts
 Old 09-21-2008, 06:29 PM   #49
Got it. Thanks. I'm installing my ceramic coated PG manifold next weekend. Unfortunately the dp will have to come later.
 Old 09-21-2008, 06:48 PM   #50
dont forget you have to tighten the VC bolts in a certain order. just make sure u go in a star pattern back and forth across the VC so it tightens evenly.
 Old 09-21-2008, 11:03 PM   #51
Got it. Thanks for the info.
 Old 09-22-2008, 05:10 AM   #52
ms3guy22's Avatar
Posts: 530   (View Stats)
ms3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond repute
i'd hold off on the mani install till you get the dp. the dp install will be so much easier that way. trust me.
I hate my mazdaspeed3 more than anything else in this world!
ms3guy22 is offline   Reply With Quote
 Old 09-22-2008, 05:53 AM   #53
SgtP's Avatar
Posts: 2,130   (View Stats)
Groans: 106
thats an understatement lol. id do the same.
13.2@111
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 09-22-2008, 06:50 AM   #54
Why is it so much easier?
 Old 09-22-2008, 08:10 AM   #55
Lymerock's Avatar
with the manifold out of the way, you have much much better access to the nuts/studs on the turbo
my take on it is this. removing the stock manifold sucks, do it now and get it out of the way. when you install the new manifold use 10.9 bolts in the turbo, ditch the studs. Use good high temp antiseize when installing those bolts.
now when you get the dp, uninstalling the manifold will be cake.
removing a stock manifold and stock dp in one day will wear your nerves thin if you dont have an install or two under the belt already
 Old 09-22-2008, 10:38 AM   #56
Thanks for the advice. I'm going to take this approach.
 Old 09-22-2008, 11:41 AM   #57
redrocketz's Avatar
Posts: 1,122   (View Stats)
redrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond reputeredrocketz has a reputation beyond repute
it takes me 20 minutes tops to pull off an aftermarket manifold so not really a big deal.
redrocketz is offline   Reply With Quote
 Old 09-22-2008, 07:27 PM   #58
ms3guy22's Avatar
oohh look at me mr handy man struting my stuff around newbs!
j/k
PG Manifold SLS MS3 MazdaSpeed 3/6 - Turbo Induction 39 04-19-2008 01:11 AM
Page generated in 0.36305 seconds with 27 queries
