Please help!!! Hello, My name is Jeremy and I have 2006 mazdaspeed 6. I have a problem that no mechanical tech can figure out. My car is doing something that's hard to explain so bare with me. I have started to get a stuttering when my turbo first spools. My car is running real Tuff until it snaps out of the stuttering. If I'm at 2000 rpm in any gear and I stand on it, the car feels like it falls on its face for a good second or so then it spools hard and pulls great. When my car does this I get a little puff of black smoke from both exhaust. About a year ago Illinois got hit hard with water. I had to drive through some good sized puddles and in wondering if that's it. I am not getting any check engine lights or anything. I have had the egr valve replaced and bought a new air filter. I have been to three mechanical shops and everyone said it runs fine. I think its because they don't have an answer. I have ran sea foam through it also with no improvement. Thanks for the help. Jeremy. |
Did you clean the MAF sensor? Also don't floor the engine at 2k rpms. |
so much fail here. ^^^^ what triple said dont load it up under 3k rpms |
I have to echo what Triple said. Don't floor the car under 3k. It sounds like you're running extremely rich for some reason. Do you have accessport? |
if you're under 3k and you floor it, it's gonna take a second for the turbo to spool up, that's normal. |
Also, check dealer for latest ECU reflashes available. That, and what everyone else said. |
go WOT in 3rd gear anywhere above 3k rpm. does it still stutter? |
to O/P clean your MAF (mass air flow sensor), disconnect your negative battery terminal for about 20 minutes and then re-connect it. Finally and i think i speak for anyone of MSF, Dont fuckin smash the pedal till you at least see 4k. Do you think you drive a fuckin mustang or somethin? flooring it at 2K and shit, boy you need a role model! |
thats all |
So since your DJ tune what are you revving out to now a days with your setup? |
Before investigating further, are there any CELs that are thrown? The second thing to do to investigate is to get a datalogging device such as a Dashhawk or COBB AP and datalog the event capturing RPM, boost, fuel trims, knock retard, timing, fuel pressure, load, mass air flow. Then we can investigate further in a scientific manner. Otherwise, you'll just do things like clean MAF, change plugs, etc that may or may not help the issue. |
I'm only revving out to about 6300. If I had a bigger hotside on my turbo, I could rev out further, but the turbo just isn't efficient past that point when you're running 27 psi |
| All times are GMT -7. The time now is 07:50 AM. |
