-   -   Please Help... Oil Leak... (http://www.mazdaspeedforums.org/forum/f10/please-help-oil-leak-140435/)
rx7fc3s87 03-14-2013 11:22 PM
Sorry I don't have any pictures but I can explain the area. Oil absolutely everywhere so I degreased and pressure washed everything. The next day I had oil coming down my A/C compresso onto my oil pan. It looks like it's coming from underneath the intake manifold but it is not the oil seperator. I have it on a lift with spot lights lighting the mother fucker up and I can't quite pin point it. It has to besomething that can leak severly because it was all over the motor, trans, control arms, axle, crossmember.... ugh.... help give me an idea?
cocoanton 03-14-2013 11:42 PM
Is the oil dipstick in place? It's possible it sprays out oil through there and it ends up looking like it leaks from somewhere else
Nitr0EngiE 03-14-2013 11:51 PM
might be valve cover or possibly the black pcv box cracked.
rx7fc3s87 03-15-2013 08:12 AM
Okay thanks! I swear I have to unbolt the Intake Manifold to see anything. Do you think I should fill it up with oil and start it. Have somebody hold the RPM at 2k and look for the leak. I have the car on a lift. I am privliged to have access to everything at the shop I work at!
7mileshome 03-28-2013 01:45 PM
Thread still alive? Is your car still leaking ? Just wondering if you have discovered anything as I have had a similar issue.
**Nevermind, I found the other thread**
cocoanton 03-29-2013 05:31 AM
For reference, OP has a problem with dipstick popping out. Continues in this thread http://www.mazdaspeedforums.org/foru...d.php?t=141459
Page generated in 0.17302 seconds with 11 queries
