View Poll Results: How often to change trans fluid and what to use? (select all that apply)
Mazda says don't change it, so don't change it! 4 3.45%
Change at ever XX,XXX miles (specify in post) 10 8.62%
Use the factory recommended 75w90 6 5.17%
Use the Gen 2 factory recommended 75w80 4 3.45%
Use Motorcraft XT-M5-QS 83 71.55%
Use Amsoil MTG or MTX (specify in post) 1 0.86%
Use Redline MT90 19 16.38%
Add friction modifier 4 3.45%
Multiple Choice Poll. Voters: 116. You may not vote on this poll
  • 1 Post By asall667
 Old 09-21-2011, 10:28 AM   #1
bast525's Avatar
Posts: 487   (View Stats)
bast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond reputebast525 has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default POLL: which trans fluid and other general Q's
I've read through a couple threads and partially kinda-sorta answered a couple of these questions but was hoping I could get some more definitive answers before I spend money and time that may not need to be spent, or skip something that I really need.
My '07 Speed 3 is sitting at 32,000 miles and I've been doing services at the dealer up til now (just oil change, tire rotation, state inspection). They recommended at my last service that I change out my transmission fluid and wanted $90. I went through the owner's manual and I can't find ANY reference to changing the fluid out at all, let alone at what mileage. After some searching here I found two passing mentions that 30,000 miles is the time to do it... but other posts indicating it is a 'lifetime fluid' and according to Mazda doesn't need to be changed and that's why it's not in the manual... So is there a general consensus that it does need to be changed and at what mileage?
My transmission generally shifts great. I have had issues with it grinding when trying to shift very quickly from 2nd to 3rd, but only rarely. I found that if I am conscious of it, when I go to shift I need to make sure NOT to actively push the shifter over from the 1-2 to 3-4 plane, rather, just let the self centering spring action move the shifter over while I just push straight up into 3rd, then it goes in smooth every time. Also, I don't know why, but with the AccessPort FFS feature I found that when I flat foot shift through the gears this also seems to have greatly helped stop the 2-3 grind. That being said... I do rarely still get the grind when I'm NOT flat foot shifting and actively push the shifter left to right from the 1-2 to 3-4 plane out of habit. Other than that, it is a little balky when very cold (we don't get much lower than 20* F in winter), but I've never driven a manual that wasn't. I have no other problems with shifting or feel.
I am considering changing the fluid myself and see a few recommendations here on what to use, Redline MT90, Amsoil MTG, and the Ford Motorcraft XT-M5-QS, as well just going with the slightly lighter 75W80 factory fil from the Gen 2's vs. the 75W90 of the Gen 1's. There is also some confusion as to whether I need to add a friction modifier for the correct functioning of the LSD or not. If I need the friction modifier, can someone post more info on where I can get this or a part number?
I would LOVE to completely eliminate the 2-3 grind... as rare as it happens, it still scares the shit outta me to think I'm damaging my trans when it DOES happen. However, I went through a similar situation with my SRT-4 and spent a lot of money trying to find the 'right fluid' that would fix the notchy shifting that that car had from the moment I drove it off the dealer lot, and found that none of fluids I tried (including Redline and Amsoil), seemed to make any difference on that car.
So does it need to be changed, how often, and what should I use?
'07 Speed 3 GT, Red, MSCAI with flow straightener, 2nd cat delete, JBR TMM, AWR RMM, and Cobb AccessPORT running custom 20% e85 tune.
bast525 is offline   Reply With Quote
 Old 09-21-2011, 10:30 AM   #2
ChicagoMike's Avatar
Posts: 97   (View Stats)
ChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond reputeChicagoMike has a reputation beyond repute
Groaned at 4 Times in 2 Posts
Grind is gone. I had the same problem. Took about a week for it to "soak in" and now it shifts like butter.
ChicagoMike
2011 MS3 Black Mica/Tech Package
K&N SRI, CP-E TIP, COBB DP, Borla AB, JBR SSP Stage 2, JBR Chrome-Molly RMM + PMM, AP Stage 2, Autotech HPFPI, ETS TMIC, ITV22's, Redline Tuning QuickLIFT PLUS hood strut system, Valentine One Blendmount Hardwired Fluids: Motorcraft XT-M5-QS transmission fluid, Mobil One "Gold Cap" Extended performance oil.
ChicagoMike is offline   Reply With Quote
 Old 09-21-2011, 10:41 AM   #3
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
+1 on the XT-M5-QS. it's the best stuff you'll find out there, and even without any friction modifier, it's pretty darn civil with the LSD whine. pretty moderate to minor when cold, and almost entirely gone when warmed up. i have tried redline and amsoil, and both caused significantly more LSD chatter. all three (redline, amsoil, and XT-M5-QS) completely eliminate the 2nd->3rd gear grind. i would recommend the motorcraft without friction modifier, because you don't want to grind to come back.
 Old 09-21-2011, 10:45 AM   #4
bast525's Avatar
I was reading the 'transmission cured' thread and the Motorcraft stuff sounded great until I got to this post:
Originally Posted by Mizzle
(quoted from the Bob is the Oil Guy website)
"That fluid, XT-M5-QS, is not GL4. It says it is suitable where GL4 is specified. It is made by Castrol and is not available in the US under the Castrol label.
Ford specifies it for use in the Contour/Mystique/Cougar/Focus MTX75S 5 speed manual transaxle. It is very nearly a 10w40 synthetic motor oil but with a very high TBN. Last I knew, Royal Purple catalogued their 10w40 synthetic motor oil as their recommended replacement although many Contour owners use RP's manual transmission oil instead. XT-M5-QS works especially well in the MTX75 transaxle, but I would be reluctant to use it in other transmissions. It's additive package falls way short of that in other gear oils"
That had go from 99% positive that I was jumping on the Motorcraft bandwagon to not being so sure...
Oh and regarding LSD whine, I ONLY get it when turning when the trans is cold. Pretty much only when pulling out of my parking spot, otherwise I don't ever hear it.
 Old 09-21-2011, 10:47 AM   #5
pewpew
well, if it's not suitable for use in our cars, then there're a lot of us who should need transmission rebuilds. since it's not the case, i wouldn't worry.
 Old 09-21-2011, 10:49 AM   #6
I use Pennzoil Synchomesh fluid. It's thinner than the Motorcraft stuff, and possibly a little too thin for summer use, but my shifts are very smooth even with the stock knob and no counterweight.
 Old 09-21-2011, 10:50 AM   #7
bast525's Avatar
hahah yeah from that other thread it seems a lot of guys do love the stuff.
What is the cause of the 2-3 grind anyways? On the SRT, it was caused by the shift forks being made of brass and bending or wearing out with hard shifting. My SRT did it on my initial drive home from the dealer lot with 7 miles on the odometer. By the time I got rid of the car at 16,000 miles it had gotten significantly worse. That, and several other problems are what prompted me to trade in on the Mazda.
EDIT: also, what about the change interval? 30k?
 Old 09-21-2011, 11:00 AM   #8
pewpew
here's the thread he's quoting, btw:
Ford Synthetic Manual Trans Fluid - Bob Is The Oil Guy
here's all the information i need to convince myself that XT-M5-QS is fine for our transmission:
Full Synthetic Manual Transmission Fluid
as for the 2->3 grind, it's mainly caused by the friction modifier. our prob is that our trans fluid lubes the LSD too, which needs to the friction modifier to make the fluid more slippery to avoid the chatter. from what i've read, the chatter isn't anything to worry about, so that leaves the other side effect of the extra slippery fluid: the synchros have a harder time gripping. in our case, the 2->3 gear synchros are the most affected. this is very bad, because whenever you grind, you're killing your synchros, so the motorcraft is probably saving you from a prematurely-worn synchro.
Last edited by Sacrilicious; 09-21-2011 at 11:00 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-21-2011, 11:16 AM   #9
bast525's Avatar
[url=http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1282963]
Fix one problem cause another... that sucks. I've probably ground it 2-3 dozen times. So far, it still shifts smoothly into 3rd, but I have no doubt I've done some damage there.
Any idea why it doesn't happen when I shift the way I described in the first post? Letting the shifter self-center to the 3-4 plane and only applying forward pressure to push up into 3rd? It never grinds when I do that no matter how quickly I shift.
Oh and thank you for the links, greatly appreciated, reading through the BITOG thread now.
 Old 09-21-2011, 11:31 AM   #10
pewpew
the way you described in the first post slows the shift down, which gives the synchro time to grip. it's only when you really shift fast that you run into trouble. regardless, you don't want that to be a potential problem, so motorcraft 4tw!
 Old 09-21-2011, 11:34 AM   #11
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
how much friction modifier are you supposed to add with the motorcraft?
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline   Reply With Quote
 Old 09-21-2011, 11:42 AM   #12
bast525's Avatar
Consensus seems to be none, if I'm reading correctly?
Sacrilicious do you have a recommendation for where to get the best deal on the Motorcraft?
The Following User Says Thank You to bast525 For This Useful Post:
Sacrilicious (09-21-2011)
 Old 09-21-2011, 11:44 AM   #13
pewpew
yes, you don't need to use any friction modifier with the motorcraft. use a few oz if you're THAT bothered by the LSD chatter, but make sure you add it 1oz at a time and check to see when you've added just enough to make the chatter disappear.
 Old 09-21-2011, 12:01 PM   #14
Ferg's Avatar
only whine i get is when im in reverse. that seems to be the only loud whine i get. i dont know if its the lsd, but thats my guess. i just want smoother shifting into second at low speeds, and better shifting in the winter. -20* F isnt unheard of here.
2008 Black Ms3 SOLD
 Old 09-21-2011, 12:04 PM   #15
Reverse is straight-cut, as opposed to the other gears which are helical. Straight-cut gears naturally whine.
kngeducate (09-24-2011)
 Old 09-21-2011, 12:20 PM   #16
bast525's Avatar
yeah reverse whine is kinda normal...
LSD whine... some guys say they have it really bad, I only rarely notice it when car is cold and I'm turning while moving. I've never had any chatter and have no idea what it would even sound like. I'll trade noise for grinding synchros any day though.
 Old 09-21-2011, 01:04 PM   #17
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
Use the Motorcraft stuff...and so far votes are 16 for this and that should tell u something
Buy 3 quarts of motorcraft stuff ($18 a quart X 3 =$54 and change it at 30k-60k-90k etc....oh and about the weight, Just use that part number u mentioned u should be fine.
Do not use FM, as rarely anyone used it and so far all have great results
Do it yourself and save $
Thanks for bring this thread up for others to follow.
weakdog85 likes this.
2007 CBM MS3 GT 66K
Mods:
--Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV----
New VVT as of 50K miles Thanks Young Mazda
New K04 Turbo as of 57K miles Thanks Young Mazda
asall667 is offline   Reply With Quote
 Old 09-21-2011, 01:16 PM   #18
pewpew
to clarify: i'm referring to the same thing when i talk about LSD "whine" vs LSD "chatter". both are referring to the whining noise when you apply power while turning.
 Old 09-21-2011, 05:12 PM   #19
Ferg's Avatar
ok. this is good shit man. ill make sure to get it as soon as necessary. and ill be letting yall know what results i get.
2008 Black Ms3 SOLD
 Old 09-24-2011, 02:51 PM   #20
amc5's Avatar
Posts: 88   (View Stats)
amc5 is just really niceamc5 is just really niceamc5 is just really niceamc5 is just really niceamc5 is just really nice
Just got my MS3 back from Mazda. They changed out alot of parts in transmission including a complete 2nd gear and synchros. Unfortunately, Now, when I turn I have whine/roar so bad it sounds like they put NO fluid in it. So loud sounds like the tire is scrapping the bumper. Especially turning right. Just makes me wonder, how could it sound that bad? There is no way it sounded that bad when it was brand new. Now I am thinking about just taking the new fluid out and putting this Motorcraft in.
amc5 is offline   Reply With Quote
 Old 09-24-2011, 03:00 PM   #21
pewpew
dude, take that shit back to them and have them do it again. there's obviously something wrong, so they need to fuckin fix it.
 Old 09-24-2011, 03:26 PM   #22
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
I run Redline. My shifts are very smooth from using the stock stuff. The only complaint is during cold weather. Shifts are a bit rought until the fluid warms up. BTW, the only thing that needs friction modifiers is the MS6s diffs.
AtTheDriveIn is offline   Reply With Quote
 Old 09-24-2011, 03:36 PM   #23
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
I changed mine today with Royal Purple 75w-90. @08.5MS3 suggested it.
The grind and diff whine are all but gone now. Like others said it should take about a week to settle in so don't expect it to go from crap to perfection right away.
______________________
Built By NATOR
Tons of Ricer Mods
09Speed3Z is offline   Reply With Quote
The Following User Says Thank You to 09Speed3Z For This Useful Post:
08.5MS3 (09-24-2011)
 Old 09-24-2011, 03:38 PM   #24
MoparGo
Lurkers
MoparGo's Avatar
Posts: n/a
Thumbs up I used...
XT-M5-QS with the Ford (4oz.) limited slip additive taking the place of the requisite amount of trans fluid. Will change again in 30k miles.
Best maintenance decision I have made thus far. No lsd chatter... zero gear grind. Works like a charm.
 Old 09-25-2011, 05:47 PM   #25
If it happens when you turn right, then it's most likely one of the CV's on the left (driver's) halfshaft.
 Old 09-26-2011, 08:14 PM   #26
amc5's Avatar
yeah, taking it back.. thought it might get quiet after fluid gets through system
 Old 09-27-2011, 01:31 PM   #27
magicka's Avatar
Posts: 520   (View Stats)
magicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the worldmagicka is the leader of the world
I also went with Royal Purple 75W-90, no modifier. It was a big improvement over the stock stuff. Next change, I'll probably give the Motorcraft honey a try.
2009 CWP MS3 GT
Rally Armor Flaps | Gen Pu Wheels | JBR 80d v1 RMM/RSB/TIGs/Boost & Bypass Tubes
TWM Full Replacement Shifter | CS SRI/TIP/Skid Plate | Koni FSD 4045 | Matt Damon OCC | Cobb DP/AP | CP-e TMIC/HPFP
PTP VVT Actuator/Injector Seals & Studs | Samco Rad Hoses | Redline Leather Shift & E-Brake Boot
BNR S3 | Stratified Boost Dial
magicka is offline   Reply With Quote
 Old 02-04-2012, 07:43 PM   #28
Ferg's Avatar
@codyb154
2008 Black Ms3 SOLD
 Old 02-05-2012, 05:17 PM   #29
maaazda's Avatar
Posts: 56   (View Stats)
maaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud ofmaaazda has much to be proud of
I am using the same mix here too no issues what so ever gear box is super quite shifting is excellent .
maaazda is offline   Reply With Quote
The Following User Says Thank You to maaazda For This Useful Post:
 Old 02-05-2012, 06:34 PM   #30
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
No surprise in this poll
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 02-06-2012, 04:56 PM   #31
2008MS3H's Avatar
Posts: 492   (View Stats)
2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world2008MS3H is the leader of the world
where are ya'll ordering the Motocraft from?
i did a search and only found a couple places that sell it. I couldn't find any of the usual stores (Autozone, Advanced, O'Reilly, etc.) that have it - found it at CFM (central florida motorsports) and one other site.
2008 MS3:
MAISONVI PISTON SHIFT KNOB - AUTOTECH INTERNALS
SURE COUNTERSHIFT - SURE SHORTCUT - SURE ANCHORS
JBR TRILOGY - JBR RSB - JBR TUBING - JBR TIP - JBR SRI - JBR EGR DELETE
HYPNOTIC TUNED
2008MS3H is offline   Reply With Quote
 Old 02-07-2012, 10:07 AM   #32
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
I went with royal purple 75w-90 been using it for on both of my transmissions now 40k miles. no modifiers where added. The 6speed trans has been drained 3times in the last year and a half and there are no signs of increased wear.
pinkcheese is offline   Reply With Quote
 Old 02-07-2012, 02:08 PM   #33
ericm979's Avatar
Posts: 165   (View Stats)
ericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond repute
I bought the Motorcraft from the local Ford dealer.
I've used Amsoil, Redline and now Motorcraft. Shifting with it is far superior to the others and to the stock fluid. Unlike the other two, there is very little whining from the limited slip (and that is probably only on my car because I used the Amsoil and Redline for too long and wore the clutches or something). Shifts when cold are much better than with the MT-90.
I have not seen any signs of wear in any of the oils I have drained. But the oil does degrade over time- both the friction modifier and the oil viscosity degrade as the molecules break apart.
I'd replace the trans oil every 30k miles or so.
Mods: AcessPort : Cobb SRI : Corksport air box : CorkSport TMIC : CNT cat back exhaust : 1G DSM BPV : Bilstein sport shocks : Progress rear anti-roll bar : OZ ultraleggera wheels
ericm979 is offline   Reply With Quote
The Following User Says Thank You to ericm979 For This Useful Post:
2008MS3H (02-07-2012)
 Old 02-10-2012, 07:42 AM   #34
falcon's Avatar
Posts: 106   (View Stats)
falcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud offalcon has much to be proud of
if you haven't been changing it at regular intervals since day one, don't ever change your fluid. Because when they take the old stuff out, its thinker due to break down, and wear materials that are in it, and the parts are going to be worn, when they put in new fluid, it to thin, and won't lubricate the already worn pieces.
I bought my car at 97k km. Had my fluid changed at 101k, and it caused some very loud diff whine when turning tight and slow, took it back to the dealership, and they tore it down, and said the diff was a mess when they opened it. I bought an extended warranty with my car through Coverage One (Wouldn't recommend unless you want a hassle) and they went out and found a used tranny with 100k on it, and they put new fluid it in, and the dealership obviously didn't tear down and inspect, cause its making the exact same noise but worse, and it clunks in 2nd and 3nd. Keep in mind mazda recommended I try changing the tranny fluid because of some stiff shifting I was having, and nobody thought to mention that it might ruin the differential....?? So I am currently fighting to get myself either a new tranny, or at least a rebuild, so that when the new fluid goes in, it can do its job.
falcon is offline   Reply With Quote
 Old 12-18-2015, 10:52 AM   #35
Jakeypoo's Avatar
Posts: 226   (View Stats)
Jakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond repute
I know 3 years old!
I'm at 111k miles and about to change for the first time with Motorcraft.. Nothing is wrong with the transmission and I was just looking for torque specs when came across this. The last post removed the warm and fuzzy feeling I normally get when I work on my car.
As usual the Internet does not disappoint with SAE masters and serviece techs contradicting each other, not to mention at least 5 theories as to what happens in this situation.
What does MSF think about this on our MS3s? Other than I should have changed it 3 times by now.
Found the torque specs and I'm about to get to work. I'll let you know if clutch goes out tomorrow.
Edit: 45miles later and still looking good. On a side note after 111k miles the factory fluid was still golden and not cloudy. I did not notice any improvement other than less chatter that has always existed on my car.
2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25.
Jakeypoo is offline   Reply With Quote
 Old 12-22-2015, 02:24 PM   #36
PurplFox's Avatar
Posts: 352   (View Stats)
PurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the worldPurplFox is the leader of the world
I think Falcon is/was confused with a slush box. In an old auto if the fluid hasn't been maintained properly, the clean fluid has a tendency to cause the clutches to slip leading to failure. Ask me how I know.
Cobb AP
JBR Tru-3.0
CNT Catted DP "Gutted"
CNT Catback
JBR 88 RMM DM PMM and TMM
3 port, Turbosmart dual port
FReaktune E33
PurplFox is offline   Reply With Quote
 Old 12-22-2015, 03:46 PM   #37
Jakeypoo's Avatar
You are probably right. I didn't like the thread ending on a sour note like that. Maybe the "never change it" votes will go up. Lol
 Old 06-24-2016, 10:15 AM   #38
bast525's Avatar
So, to follow up on this old question, I've been running the Motorcraft XT-M5-QS fluid for a couple years now and it is awesome. I have not ground 3rd on a quick shift even once with this fluid. It can be a tiny bit notchy in cold weather but otherwise it is awesome and well worth swapping to.
Video: General Lee takes on Bandit T/A in classic Hollywood car showdown [w/poll] Haltech Automotive News 0 08-26-2011 11:10 AM
Fomoco trans- axle fluid kritz 2010 MS3 - Engine, Transmission & Driveline 22 05-08-2011 07:25 PM
BREAKING: General Motors to announce Chevy Volt pricing/ordering on Tuesday [w/poll] Haltech Automotive News 0 07-26-2010 12:10 PM
Report: General Motors wants to snuff out "Chevy" nickname [w/poll] Haltech Automotive News 1 06-10-2010 02:11 AM
Page generated in 0.57523 seconds with 38 queries
