I guess your right if you spent 8G on the car already, but does everyone need to spend that much money to get to the point where they need (or could use) additional injectors? From what I understand, these cars run into fuel problems very quick. Spend 2G's on a bigger turbo and instantly you could use more fuel. How many IM's are already out there? how many of the people spending 8G's on their motor are running stock IM's. I'm not trying to start an argument or anything, just asking some questions since I'm new to the mazda scene. :wiggle: |
Spend 2G's on a gt3071/gt3076/gt3582--expect to spend ~$5000 on a new bottom end within a year... Quote:
did anyone read the new book "quoting for dummies"???? BRB....almost done |
sorry for the double post...i guess they dont show up right away. |
i didnt get that far yet....only on chapter 2 have you thought about changing your name to Dhooosh ? |
let me find my knee so I can slap it:nana: |
Thats kinda funny that a stock ecotec block can hold 500+ hp but the mazda block that has forged internals cant make it past 300-350. :pat: how many have blown up bottom ends? |
But how many blocks did different companies blow up to get to that number with the ecotec?? I doubt very much they just hit 500 hp out of the gate with no issues along the way... The difference here is that mazda has never been big in the tuner industry, and until DCR stepped in we didn't really have any companies with the experience and resources to actually tear these motors down and determine why we are blowing them. All we had was a group of well motivated individuals pushing the platform...and that will never make the kind of progress that a dedicated shop can... Ultimatelty after DCR is finished we may have a proven mod path that makes it safe to push 400+ through the stock bottom end, but as of now we're just not there... |
there are a lot of rod failures out there but you rarely get the full story as to what happened I don't think this platform has the ability to produce power to justify building a forged short block which is why I stopped my project I'm sure things will change at some point but for right now same ole' |
what is DCR doing? I thought I had seen at least 1 manifold? midevil maybe? |
They are going to tear apart several of these motors and heads and determine why they are failing, and figure out how to fix the issues, and then manufacture parts to fix the problems... Pailrider just picked up two longblocks from me yesterday, one was knocking, and the other had low compression in two cylinders.. Quote:
WOW .. 22k into your Cobalt? I am guessing you took a HUGE hit on that one when you got rid of it. |
Mind you i put 60 thousand miles on this car in two years 11 of whihc the car was broken and at the dealer. I had 1500 miles on it with in the first 3 days learning to drive stick and in 1 year exact 30 thousand miles. The car fax shows this aswell. mine was an 05 with a complete 06 interior swaped into it new trans built from ground up since they had no spare saab trannies back then. Gears 1, 3 and 5 needed to be replaced new diff since it karate kicked out the side of the trans case new trans case front and rear. clutch flywheel pressure plate 3 axles 5 motor mounts 3 dp with cats 1 mani 1 complete header back system 3 02 sensors whole knew rebuilt head, valve train (droped 5 valves and 3 lifters), and one exhaust cam since im some how cracked that in half. new aftertercooler new aftercooler pump Needed new piston rings once my oil started to look the color of peanut butter from the coolant mixing in but I decided the cobalt had enough and it now sits in PA where no one is stupid enfough to buy it cause of its mechanical history. I kept all the dealer shop receipts cause it was was a real work of art. I'll say this this mazda has EARNED the right to be parted out back to stock for surviving having me as its owner. Beside not being able to make big numbers on this motor i have no real complaints. Cars sturdy as fuck. |
I have put on and took off (tried) several different parts for this car....... even ran decent times at the track, but ANY car that has less than 15K miles on it and smokes like these do either deserve a motor swap or to be euthenized. Damn you Mazda lol....... That was the breaking point for me. New car that smokes like a chimney, no thanks. Anyway, sorry for the rant, I have no idea what I am talking about. Back to your regularly scheduled arguing........ OH! I almost forgot! Randy, you still have that GTI of yours? You could do a motor swap with that baby, since APR has DI all figured out! In that instance you would be able to retain the soul of DI and have the power of an SRT-4! Call DCR and tell them to stop what they are doing! |
Need Fueling Solution On Custom GT35RTurbo + Supporting Mods - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com nice little read on my vw board. usp is doing port injection now and has moved on past their low pressure upgrade for the 600whp gti. i think it was unreliable dyno queen, and they are moving on. theyve been posting more and more here ond on vortex about their auxilary system with the custom manifold and secondary injectors. im telling you. EVERY DI car is gonna end up doing this. they just have too. |
i sat in a caliber srt4 at the auto show, why didnt i get that dam car idk |
2 cars |
But I don't count I won't have had it on that long owell..... http://tbn3.google.com/images?q=tbn:...bishi-logo.jpg HOLLA! Whoosh and Loosh looks like I might have a toy to kick you both up and don't the track with this year after all. I'll probably be busting you both up too with only a welded diff and some mud and snow tires. |
actually theres a bt speed6 here that is on stock internals, stock fuel pump, since 2006 |
The atp options weren't even out back then I think. So proof or Ban.... |
share or Snailburt will attack!!!! you got a 1G talon or eclipse....right?:blackeye: |
| All times are GMT -7. The time now is 06:53 AM. |
