 Old 06-28-2011, 08:19 AM   #1
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
Default Powdercoating intake manifold
how do you remove the grommet/ clip from the intake manifold to powder coat the IM without melting it ?
 Old 06-28-2011, 08:46 AM   #2
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
you cant remove it and then put it back in..
.. you need to remove it and then tap/ tread a barb fitting into the intake mani and use a new hose to connect to the brake booster...
i think guys are using a 1/2"NPT threaded 3/8" barb...
I ended up painting my mani.. just masked everything off and it turned out nice.
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following 2 Users Say Thank You to jracer For This Useful Post:
Amnesiac (03-10-2015), Fobio (06-28-2011)
 Old 06-28-2011, 10:01 AM   #3
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I plan to something similar. Thanks.
-- Mario Andretti --
 Old 07-07-2013, 10:30 PM   #4
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
I would love to know how people are removing it...
to add to this thread you don't have to tap it when you can just replace it with the same part, new.
Part Number: L341-13-170
 Old 07-18-2013, 11:02 AM   #5
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
BigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the world
Groans: 56
Groaned at 6 Times in 6 Posts
That PN is for a clip for the NA 2.0/2.5... can anyone confirm it fits?
Someone else mentioned a Ford PN that fits but I can't find it
2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's
Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals
Winter Beater: 96 GMC K1500 5 speed 4x4
Needed: Driver mod
BigRedSpecial is offline   Reply With Quote
 Old 07-18-2013, 11:42 AM   #6
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Just use low temp powder. Its already used to seeing atleast 200 degrees.
2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather
2004 Mazdaspeed Miata #3142- Stock, but not for long.
Equal rights for all, special privileges for none. ~ Thomas Jefferson
 Old 07-18-2013, 11:44 AM   #7
Groans: 56
That doesn't help people buying used manifolds that don't have the fitting though
Needed: Driver mod
 Old 07-18-2013, 11:48 AM   #8
El_Diablo's Avatar
Groans: 769
That wasn't the original question & wasn't directed at you so it does solve the OP's problem.
 Old 07-18-2013, 11:51 AM   #9
The Ford part number is 3S4Z-9A475-AA
When I replaced mine I bought the Ford part from a local dealership. It can be found much cheaper online though.
The Following 5 Users Say Thank You to silvapain For This Useful Post:
BigRedSpecial (07-18-2013), BrandonRKD (03-24-2014), El_Diablo (07-18-2013), S-hendrix (08-11-2013), Vader (07-18-2013)
 Old 07-18-2013, 12:09 PM   #10
Groans: 56
Exactly what I was looking for, thanks
Needed: Driver mod
Intake manifold this, intake manifold that!!! ptperformance Mazdaspeed3/6 General Discussion 53 06-21-2010 02:51 PM
intake manifold help turd burglar MazdaSpeed 3 - Engine, Transmission & Driveline 2 05-01-2010 09:14 PM
Page generated in 0.30471 seconds with 26 queries
