-   -   Primary O2 Sensor (http://www.mazdaspeedforums.org/forum/f10/primary-o2-sensor-91400/)
MattJackson86 09-10-2011 10:38 PM
Primary O2 Sensor
Just wanted to confirm the part number of the primary O2 sensor for a gen1 MS3. (2008.5).
I found via search it is L33X-18-8G1 and always heard the price was ~$300.
Searched OnlineMazdaParts and it said that "Part number L33X188G1 was superseded by part number L33X188G1B." and that the price was $201.52 and $157.16 online. The description of the item is "Oxygen sensor, mazdaspeed3, front, to 4/1/08 ". Whats with the 4/1/08?
Can anyone confirm this is the correct part number? Seems way cheaper than people were saying and I want to ensure its not the rear O2 sensor. Maybe this new revision is just 50% the cost...who knows.
MattJackson86 09-26-2011 10:11 PM
bump
MoparGo 09-26-2011 10:15 PM
Part numbers thread...
Does not list the superceded number, but some parts numbers info that may come in handy.
Link: http://www.mazdaspeedforums.org/foru...numbers-28485/
primary o2 - L33X188G1C
secondary o2 - L34B18861A
Call a reliable dealer in your area to confirm the O2 sensors for your car if no one pipes in here.
MattJackson86 09-26-2011 10:21 PM
Interesting...the part number on that list is L33X-18-8G1C. So that is an even later revision (probably why it mentions up to "4/1/08"). Onlinemazdaparts lists it as "Electrical - Powertrain control - Oxygen sensor Oxygen sensor, mazdaspeed3, front, from 4/1/08 2008 - 2009" so the dates match. Once again the price is only $157.16, so much cheaper than the reported $300+
Thanks!
L33X-18-8G1B - 2007-2008
L33X-18-8G1C - 08.5+
karl-hungus 09-28-2011 07:03 PM
that fucker who was cross threading them over in japan was fired on 4/1/08.
White Joint 10-13-2011 11:46 AM
just a heads up you can go to mazda and buy a primary o2 for like 215
06Speed6 10-13-2011 10:12 PM
Its about $300 for both of them.
exentix 09-03-2012 12:37 AM
zombie thread. @MattJackson86 did you end up going with this o2 sensor? had the same problem with mine this weekend. luckily we had another car sitting around with a blown turbo we stole the o2 sensor from, but now i owe him one.
claudio 09-03-2012 01:25 AM
The current part is L33X-18-8G1C
tddvrrn 09-11-2012 09:37 PM
hey, check this out. it is listing oem NGK sensors for $79.. it doesn't specify primary or secondary..
anyone have the NGK part number for the primary O2? $79 is a great price..
edit: nevermind. i searched and that is the secondary O2 sensor. the primary O2 is NGK part number 24357. NGK
further searching yields NGK oxygen sensor, NGK 24357, being sold on amazon for $140... good price for primary O2..
Tommy 11-22-2012 08:43 AM
Anyone with the gen1 actually try the NTK/NGK 24357? Rock Auto has it for $101.
G26 11-22-2012 08:47 AM
I confirmed the ntk wideband for gen 2 from rock auto is the oem gen 2 sensor for $120.
So they should be accurate for the gen 1 oem also.
Sent from my balls via my penis
Page generated in 0.17723 seconds with 11 queries
