 Old 09-10-2011, 10:38 PM   #1
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Default Primary O2 Sensor
Just wanted to confirm the part number of the primary O2 sensor for a gen1 MS3. (2008.5).
I found via search it is L33X-18-8G1 and always heard the price was ~$300.
Searched OnlineMazdaParts and it said that "Part number L33X188G1 was superseded by part number L33X188G1B." and that the price was $201.52 and $157.16 online. The description of the item is "Oxygen sensor, mazdaspeed3, front, to 4/1/08 ". Whats with the 4/1/08?
Can anyone confirm this is the correct part number? Seems way cheaper than people were saying and I want to ensure its not the rear O2 sensor. Maybe this new revision is just 50% the cost...who knows.
 Old 09-26-2011, 10:11 PM   #2
bump
 Old 09-26-2011, 10:15 PM   #3
MoparGo
Lurkers
MoparGo's Avatar
Posts: n/a
Arrow Part numbers thread...
Does not list the superceded number, but some parts numbers info that may come in handy.
Link: http://www.mazdaspeedforums.org/foru...numbers-28485/
primary o2 - L33X188G1C
secondary o2 - L34B18861A
Call a reliable dealer in your area to confirm the O2 sensors for your car if no one pipes in here.
The Following User Says Thank You to For This Useful Post:
MattJackson86 (09-26-2011)
 Old 09-26-2011, 10:21 PM   #4
Interesting...the part number on that list is L33X-18-8G1C. So that is an even later revision (probably why it mentions up to "4/1/08"). Onlinemazdaparts lists it as "Electrical - Powertrain control - Oxygen sensor Oxygen sensor, mazdaspeed3, front, from 4/1/08 2008 - 2009" so the dates match. Once again the price is only $157.16, so much cheaper than the reported $300+
Thanks!
L33X-18-8G1B - 2007-2008
L33X-18-8G1C - 08.5+
The Following User Says Thank You to MattJackson86 For This Useful Post:
 Old 09-28-2011, 07:03 PM   #5
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
that fucker who was cross threading them over in japan was fired on 4/1/08.
The Following User Says Thank You to karl-hungus For This Useful Post:
MattJackson86 (09-28-2011)
 Old 10-13-2011, 11:46 AM   #6
White Joint's Avatar
Posts: 125   (View Stats)
White Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to beholdWhite Joint is a splendid one to behold
just a heads up you can go to mazda and buy a primary o2 for like 215
2009 Mazdaspeed3. Yellowspeed Racing Coils, Dominant Engineering Camber Arms, Cp-E Manifold, Tial MVS38, SSP Dumptube, Turbo XS Downpipe, Turbo XS RP with SPracing Boost Activated Cutout, Turbo XS CBE, Turbo XS CAI, Turbo XS hybrid BOV, Turbo XS FMIC, TWM Short Shifter, CP-E Rear mount Stage1, Cp-E Driverside Motor Mount, Cp-E Passengers Motor Mount, COBB AP V2, Grimmspeed Boost solenoid, Cobb TIP, Bnoon Banjo Bolt, PTP Smokey turbo Fix Pill
RICHTUNE.... ??? WHP.... ??? WTQ =
White Joint is offline   Reply With Quote
 Old 10-13-2011, 10:12 PM   #7
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Its about $300 for both of them.
2006 Mazdaspeed 6
 Old 09-03-2012, 12:37 AM   #8
exentix's Avatar
Posts: 1,568   (View Stats)
exentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the world
Groans: 46
Groaned at 15 Times in 6 Posts
zombie thread. @MattJackson86 did you end up going with this o2 sensor? had the same problem with mine this weekend. luckily we had another car sitting around with a blown turbo we stole the o2 sensor from, but now i owe him one.
exentix is offline   Reply With Quote
 Old 09-03-2012, 01:25 AM   #9
claudio's Avatar
Posts: 128   (View Stats)
claudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond reputeclaudio has a reputation beyond repute
The current part is L33X-18-8G1C
claudio is offline   Reply With Quote
 Old 09-11-2012, 09:37 PM   #10
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
hey, check this out. it is listing oem NGK sensors for $79.. it doesn't specify primary or secondary..
anyone have the NGK part number for the primary O2? $79 is a great price..
edit: nevermind. i searched and that is the secondary O2 sensor. the primary O2 is NGK part number 24357. NGK
further searching yields NGK oxygen sensor, NGK 24357, being sold on amazon for $140... good price for primary O2..
 Old 11-22-2012, 08:43 AM   #11
Tommy's Avatar
Posts: 2,309   (View Stats)
Groans: 155
Anyone with the gen1 actually try the NTK/NGK 24357? Rock Auto has it for $101.
Tommy is offline   Reply With Quote
 Old 11-22-2012, 08:47 AM   #12
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
I confirmed the ntk wideband for gen 2 from rock auto is the oem gen 2 sensor for $120.
So they should be accurate for the gen 1 oem also.
Sent from my balls via my penis
The Following 3 Users Say Thank You to G26 For This Useful Post:
deadlandxtreme (11-22-2012), Tokay444 (03-24-2013), Zbrit00x (03-30-2013)
New Primary O2 Sensor wakeboarddude MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 05-13-2010 04:00 PM
Primary o2 sensor part # oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 1 08-22-2008 07:56 PM
Page generated in 0.32317 seconds with 28 queries
