| bnoon | 04-12-2009 04:12 PM | Quote:
Originally Posted by ptperformance
(Post 201668)
Thanks for the write up on the install, give a few days to see if the windage tray helps with the smoking issue. What weight oil did you put back in the motor after the install?
Next, we are working on an issue with the smoking turbo issues but I am kind of stumped with what I am finding out, if you want to pop into our section and check out what we have found, it might be some help to have you post up what you have done to try and fix the smoking turbo issues. Thanks. | 0-40 Royal Purple is what's in it now and does the best that I've tried, and it's not even that it smokes less than other oils (which it does seem to do) it's that it SMELLS better when it does burn, LOL! I think I'm going to try a Rotella diesel oil (or other diesel oil) next time as I hear it has better detergents to avoid the solvent washing problem that the DISI seems to have. I've had 2 UOA's done and both were 1.2% or higher fuel content and were visually thinner than they should be at 3000 miles or less. All have been black in color, even the oil change I did at 1700 miles.
What I'm hoping is to find with this windage tray is longer oil life. If nothing else, I know it's got to help having more oil in the pan due to the bsd, along with treating the oil better by not beating the snot out of it with the rods at high rpm. I'll follow up at 1000 or so miles to see how it's doing... |
