PTP windage tray and BSD i got around to doing this project on friday. it was pretty simple...just tedius. there are a thousand bolts on that damn oil pan. when you think you have them all and start prying the pan, and it wont come off....look around, there is another bolt. then repeat until you get all of them !! once the bolts are all off the pan comes of very easily with nothing more than a flat screwdriver. the hammer in plug from PTP is great and simple to install. i just put a dab of gray silicone on it and smashed that bitch in there !! then i installed the new baffle/windage tray in the oil pan. again super easy. simply remove the bolts holding the original end baffles off, then install the new full size piece using the original bolts/holes. nothing to it !! i drove the car today trying to shake out some of the bugs... (still a few left, i did about 5 projects over winter) and it drives smoother than inticipated. my car always has some vibed/noise from my stiff TRZ mounts, and i heard the BSD mod adds vibration so i was expecting it to feel like a Harley ! now the last time the car was driven it was november, so its been a while... the car actually feels smoother than i remember. maybe i am just nuts, but i dont feel any extra vibes that for sure. the car definately revs quicker though. that is VERY noticeable. it jumps into boost faster as a result too. overall... great mod i think. i didnt buy it for the free revs though. i bought it because many people believe the BS is the cause of blown engine on higher power cars. oh... the car also takes just over 7 quarts of oil to fill now !! |
What kinda gasket maker did you use? I've notice everyone using the grey version. I like to use the RED RTV Gasket maker on all my vehicles. |
I used grey. It is designed for areas with a high torque seal (lots of close spaced bolts) and it is also much more oil resistant than most sealants. It is ideal for oil pans IMO. |
i have some stuff from volvo that i love i use it on my personl engine reseals now, its not messy at all and it only takes a small amount to seal timing cover or oil pan etc. its pretty pricey though. |
Nice mod I think i'm gonna do this eventually too. |
no its not, its a volvo sealant, its red and thin and looks like glue it take shardly any of it to seal it its no where near as messy and with only the little bit you use you don't get the sealant on the outside when the pieces are fitted together. Granted this stuff is about 60 bucks a tube if you were to pay for it. the stuff your thinking of is like what honda uses where it comes out of a larger nozzle and is gray./ |
I ended up just using good old permaseal ultra gray. It seems to be doing the job. I gooped the hell out of it to be sure. I made sure it oozed out slightly all the way around. That way i know i didnt miss a spot !! |
how did the actual balance shaft assembly look? any noticeable wear or discoloration? |
http://www.accessconnect.com/images/81160.jpg PERMATEX High Temp RTV Silicone Gasket Maker Formulated for hi-temp applications, or heavy-duty use (such as towing, etc.). Replaces almost any cut gasket. Makes reliable "formed-in-place" gaskets that resist cracking, shrinking and migrating caused by thermal cycling. Coats pre-cut gaskets to increase reliability. Temperature range-75°F to 650°F intermittent; resists auto and shop fluids. First generation 1970-1980 gasket maker. Valve covers, oil pans, timing covers, water pumps, thermostat housings, transmission pans. Part#81160 http://images.orgill.com/200x200/7173974.jpg Designed for high torque applications, predominantly Japanese designs requiring a unique RTV gasket. Exceeds manufacturers performance requirements. Low odor, noncorrosive. Outstanding oil resistance. Guaranteed not to leak. Temperature range -65 degreesF to 650 degrees F intermittent; resists auto and shop fluids and vibration. Applications include valve covers, oil pans, intake manifold end seals, timing covers, water pumps and thermostat housings. This RTV Gasket Maker is one of many top quality items in our Gasket Sealer department. Part#82194 They seems to be about the same.:dance: |
im due for a change now after driving to sebring and back this weekend and want to do this and the spin on filter kit |
i just did bsd on saturday night. good shit. i noticed on increased vibes or anything. i didn't really notice anything. i used grey rtv |
Now that i've put some miles on it i can notice some vibration increase. Its onky when hard on the throttle between 4-5500k rpm. Not at all horrible, but it is there. |
| All times are GMT -7. The time now is 01:08 AM. |
