Racing Beat CBE Installed. Got this thing installed today, thanks to wassup61 - PG vendor (Thanks Jeff for the deal and speedy shipping!) He has restored my outlook on PG thru him. http://www.freedomcomputers.net/ms3/rbcbe/rbcbe0.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe1.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe2.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe3.JPG Only thing I didn't like was the regular clamp, would have liked a band clamp or something better. Anyhooo it still got the job done for now. http://www.freedomcomputers.net/ms3/rbcbe/rbcbe4.JPG I was gonna try to remove the stock exhaust in one peice and saw that it was just to much work lol. So I pulled out the sawsaw. :silly: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe5.JPG Made the cut. Now becareful and try not to make the cut going toward the gas tank like I did and almost popped a hole in the tank, ooppssy. So everyone else should cut going toward the driver side, away from the gas tank lol.:nono: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe6.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe7.JPG Back stock part removed. Make sure you use some WD-40 on the rubber hangers, will make the job easier. http://www.freedomcomputers.net/ms3/rbcbe/rbcbe8.JPG Remove the support plate 12mm bolts, unbolt the stock remaining cbe from stock test pipe. 14mm nuts or the whole spring stud, which ever one gives first lol. (My test pipe is gutted).:boobies: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe9.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe10.JPG Get the RB CBE first section into the rubber hangers and bolt it up to the Stock Test Pipe (or whatever you got). http://www.freedomcomputers.net/ms3/rbcbe/rbcbe11.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe12.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe13.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe14.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe15.JPG Now remove the stock bracket/brace for the rear rubber hanger (last one in the back). 10mm bolt. Replace it with one supplied by RB. It helps keep the dual outlets steady and from hitting the bumper sides of the exhaust outlet. Now make sure you snug the clamp supplied to the front and rear peice together. Set where you want the tips to be in out and leveled. Then tighten alittle bit at a time until it grips, check spacing and levelness again. Keep doing that until you get it where you want it tight. http://www.freedomcomputers.net/ms3/rbcbe/rbcbe16.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe17.JPG Before you start putting the plate/brace back up, clean the whole exhaust. All the finger prints, sut, grease, wd-40, pb blaster or whatever off the exhaust, you don't want them to be permenantly burned on it lol. http://www.freedomcomputers.net/ms3/rbcbe/rbcbe18.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe19.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe20.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe21.JPG I have set mine alittle in so the tips don't stick out as far. I didn't go back more because you don't want the rubber hanger rubbing on that sharp edge. :wink1: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe22.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe23.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe24.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe25.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe26.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe27.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe28.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe29.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe30.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe31.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe32.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe33.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe34.JPG Here is a short vid at idle and rev ups for now 22'ish megs WMV: http://www.freedomcomputers.net/ms3/...bestanding.wmv I reset the ECU and cranked it up, WOW it was quiet like stock. Warmed up about 5 minutes and started to rev it, still WOW quiet as stock. Have not test drove it for droning or anything like that yet. I will have sound vids up this weekend, when I have some more time with my new GoPro Cameras!!!!!. Enjoy!. :boobies::tongue3: Here are some videos: No drone, it's more quieter than stock lol. Sorry no outside vidz, was by myself on that and was raining out. Boring and about 29'ish megs WMV: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe2.wmv 94'ish megs WMV: http://www.freedomcomputers.net/ms3/...f2bdbaffle.wmv Update: Now I have the stock catted test pipe back on. 11'ish megs WMV: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe3.wmv |
you don't wait around when you get your parts do you? great write up. |
I am interested in your reports for drone. RB has always made quality parts. Nice buy! |
Wow! That really looks nice! Looking forward to hearing how it sounds and what your impressions are. |
Damn, it looks even better in person! This is seriously a sexy time exhaust, bio, when you get on it, it will be just the right volume. I am glad you like it. Let me know if you need anything else. Jeff at PG |
its quieter than stock you and no drone... you will find out soon... |
Looks good! Probably the only exhaust I am considering. |
Yah, now that the Cobb is out of the equation, this would be the one for me if I decide to ditch the stocker. Me likey quiet. Only thing I wish was different was retention of the single tip. Minor quibble though, all things considered. Looking forward to clips and further impressions. Awesome writeup, thanks much! |
Yeah it was either COBB or RB and COBB has Discontinued theirs, so RacingBeat gotz my monies. :neener: |
I LOVE those tips! |
Doesnt look bad at all. Wish the tips were a little larger in diameter if i was going with the system. Looks solid and the huge resonator and triple stacked muffler is going to keep it quiet :) |
is this a 3 inch exhaust? |
Well, in their description it states 3" O.D. But still bigger than stock. Since I have this on, with a gutted stock test pipe do I now have sorta a TBE now??? LOL. |
Great write up and install. Im just not sure if im a fan of the dual tipps. But Otherwise great job being diff |
I love dual tips-- very euro. is it just me or does that muffler look IDENTICAL to the one of the Cobb system? I am waiting for my mild steel HKS to rust through so I have an excuse to get a quieter system. |
+1 the dual tip looks AWESOME, grats on the new exhaust. |
Thank's a ton for the photos and feedback! Appreciate it! |
bio can you take some more pictures from afar? i'm interested in knowing how it looks like from about 5-10ft |
+1 |
http://www.freedomcomputers.net/ms3/rbcbe/rbcbe27.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe28.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe29.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe30.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe31.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe32.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe33.JPG http://www.freedomcomputers.net/ms3/rbcbe/rbcbe34.JPG Here is a short vid at idle and rev ups for now 22'ish megs WMV: http://www.freedomcomputers.net/ms3/...bestanding.wmv |
Man that sure looks sharp. I gotta get one. |
Racing Beat has always made quality products. I used to have alot of RB's stuff on my Miata. Their exhausts always have beautiful welds and come nicely polished. I'm not a big fan on the dual tips at all, but it's a nice exhaust. |
They should have bent the tips up a little so it would sit flush in that little pocket. |
So, has the volume picked up after a couple days? |
What kind of power gains can you expect from this system? |
Here are some videos: No drone, it's more quieter than stock lol. Sorry no outside vidz, was by myself on that and was raining out. Boring and about 29'ish megs WMV: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe2.wmv 94'ish megs WMV: http://www.freedomcomputers.net/ms3/...f2bdbaffle.wmv |
Remember I do have a gutted stock test pipe on there also. Quote:
I put mine in Saturday night and my sentiments echo bio's exactly. It's quieter at cruise, at idle, and on deceleration, but has a much snarlier, more aggressive tone when you're really getting on it. This exhaust really mellows out the boomy bass note that comes into the cabin with the stock CBE, especially when lifting off the throttle around 3,000RPM. I'd recommend this in a heartbeat to anybody who wants something tame for DDing but aggressive when you're putting the foot down. I put about 150 miles on it this weekend and I'm very, very pleased so far. This is how the car should have sounded from the factory. :fing02: And thanks to Jeff @ PG for the deal. |
so indeed it is quieter than stock CBE? when i first bought my ms3, i thought i was crazy....but when people started to ride along with me...they were like "u already put exhaust on this thing?" thats how damn loud this stock cbe is...LOL |
I put mine on over a week ago on my turbo xs stealthback (catless downpipe and race pipe), and even on there with no cats, the exhaust is pretty damn quiet. Still ZERO noise inside the cabin with zero drone, but on the outside after breaking it in for about 200 miles, boy did the exhaust open up. Its deep and aggressive but smooth and toned down. I am actually contemplating deleting the resonator infront of the muffler to get some more noise. But it does sound great, sounds like a wrx from behind. Can't hear it revving up inside the car, but when you stand behind, damn it sounds sick. Very very happy with this exhaust. |
This will be the cbe i get if i ever get one for my lonely cpe dp... I think the dual tips are more stock looking to someone like a cop than the stock large single tip. I wanna see pics of it dirty as fuck with soot from the exhaust....Bioevolve your write-ups are great I love reading them. pics ftw |
is it just me....or is the unequal length not looking good? just my preference |
I like it. |
sick! the dual tips is very different! good write up / post! +1 |
the offset tips mimmick the look of a porsche's exhaust. I love it personally. As for the black soot build up, its nothing like the stock. It just gives the pipes a brownish gold color, it doesnt turn it into black chalk like the stock tip. Weird. |
And Crossbow, lemme know if you want a ride-along. |
DeadWayt, Might have to take you up on that offer one of these nice weekends! Thanks for all the feedback guys. |
Looks good |
500+ mile update: Sound seems to be getting alittle deeper. Tips are getting sut on them, I'm running a little rich lol. Since the exhaust is now breathing better, my boost is steadily creeping and now I get boost cut around 5400-5800rpms 20-21psi & 22-24psi spikes!!!!!!! Did several runs to verify it wasn't a fluke. This is with Stage2 91 103. Guess I will have to step down to Stage 1+SF 91 103 now until I get ATR for the AP. Row #21 is where it cut on me. http://www.freedomcomputers.net/ms3/boostcut0.JPG http://www.freedomcomputers.net/ms3/boostcut1.JPG |
Do you have an aftermarket downpipe or a gutted cat? Surprised it made a big enough difference that you started creeping/cutting. *Edit: Picture clearly shows you don't have a test pipe. Sorry.* |
I have a gutted stock test pipe on. |
Do you have any useful logs from before the CBE install? It's not that I don't believe what you're saying, I'm just surprised that a cat-back made that much of a difference in restriction. |
Here are 2 from 2 days before the CBE install. http://www.freedomcomputers.net/ms3/log2.JPG http://www.freedomcomputers.net/ms3/log3.JPG |
http://www.freedomcomputers.net/ms3/log4.JPG Went to stage 2+SF 91 103 for now, have not WOT yet. Awaiting 100 miles and key cycles. |
LOL, true! 80f-95f here in FLorida.:wavey: |
Bio said "Only thing I didn't like was the regular clamp, would have liked a band clamp or something better. Anyhooo it still got the job done for now." I'm considering the Racing Beat exhaust. I wanted to ask you if you think this stainless clamp form jegs would work instead of the one supplied? Would the 3" size be the one to get? JEGS Preformed Stainless Steel Exhaust Band Clamps - JEGS Thanks |
That should work, I was looking at that on Jeg's and Summit Racing. Might order me one to try out also. |
Still getting overboost, just got a cel P0234 overboost condition. Beta to the Final maps stage 1 thru stage 2, tried 6 different maps. I just took out 2 shims from Forge BPV with Blue spring, hopefully that will fix it. We'll see in the next couple of days, if not, change to the yellow spring with 2 shims and go down from there. That should help with holding boost lower throughout the rpm range right? 19-21psi upto 5000-5500rpms is great until I hit boost cut lol. |
i lost my springs :( the damn thing came with it and i misplaced the f***ing box..FAIL |
If I can't remedy the problem by friday, I will put the stocked catted TP back in to create some more back pressure and slow the stock turbo down. :hitwithrock: |
hopefully you get it resolved |
Update: Now I have the stock catted test pipe back on, Sounds to alittle more quiet lol. 11'ish megs WMV: http://www.freedomcomputers.net/ms3/rbcbe/rbcbe3.wmv Will have to drive it after restting the ecu, hopefully it will fix my overboost condition. 2 shims and blue spring back in the Forge BPV. I know I could use a BC, but don't have one in hand so the stock catted tp should work. We'll see. |
Hey Bio, did you check to see how well lubed the forge is when you changed the spring/shims? Could be sticking? |
Ok put the on Beta Stage 1 93 103r and it has calmed down the overboost, I will have to play with ATR with the Stage 2 stuff later. Got a 3" step band clamp off ebay: http://www.freedomcomputers.net/ms3/...bandclamp0.JPG http://www.freedomcomputers.net/ms3/...bandclamp1.JPG Checking fitment. http://www.freedomcomputers.net/ms3/...bandclamp2.JPG Putting together down by the Y-pipe part makes it alot easier than trying to put it together at the joint. http://www.freedomcomputers.net/ms3/...bandclamp3.JPG Slide it up and start torquing lightly and you hold it in place then snug that thing down hard. http://www.freedomcomputers.net/ms3/...bandclamp4.JPG Done. I like this WAY better than a regular exhaust clamp. http://www.freedomcomputers.net/ms3/...bandclamp5.JPG http://www.freedomcomputers.net/ms3/...bandclamp6.JPG I had to smash this heat sheild down to get my ratchet , extension, swivel & socket on. http://www.freedomcomputers.net/ms3/...bandclamp7.JPG It bends back nicely lol. Enjoy! http://www.freedomcomputers.net/ms3/...bandclamp8.JPG |
| All times are GMT -7. The time now is 07:11 AM. |
