 Old 04-01-2009, 09:56 AM   #41
Greyspeed3's Avatar
Posts: 21   (View Stats)
Greyspeed3 will become famous soon enough
Looks good
Greyspeed3 is offline   Reply With Quote
The Following User Says Thank You to Greyspeed3 For This Useful Post:
bioevolve (04-01-2009)
 Old 04-02-2009, 03:39 PM   #42
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
500+ mile update:
Sound seems to be getting alittle deeper. Tips are getting sut on them, I'm running a little rich lol.
Since the exhaust is now breathing better, my boost is steadily creeping and now I get boost cut around 5400-5800rpms 20-21psi & 22-24psi spikes!!!!!!! Did several runs to verify it wasn't a fluke. This is with Stage2 91 103.
Guess I will have to step down to Stage 1+SF 91 103 now until I get ATR for the AP.
Row #21 is where it cut on me.
The Following 2 Users Say Thank You to bioevolve For This Useful Post:
DeadWayt (04-03-2009), miguelbates (04-02-2009)
 Old 04-03-2009, 12:13 PM   #43
DeadWayt's Avatar
Posts: 186   (View Stats)
DeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the worldDeadWayt is the leader of the world
Do you have an aftermarket downpipe or a gutted cat? Surprised it made a big enough difference that you started creeping/cutting.
*Edit: Picture clearly shows you don't have a test pipe. Sorry.*
'08.5 MS3 GT -- Metropolitan Grey
www.speedsportlife.com
DeadWayt is offline   Reply With Quote
 Old 04-03-2009, 01:59 PM   #44
Alittle Faster
bioevolve's Avatar
I have a gutted stock test pipe on.
 Old 04-03-2009, 02:51 PM   #45
DeadWayt's Avatar
Do you have any useful logs from before the CBE install? It's not that I don't believe what you're saying, I'm just surprised that a cat-back made that much of a difference in restriction.
 Old 04-03-2009, 07:58 PM   #46
Alittle Faster
bioevolve's Avatar
Here are 2 from 2 days before the CBE install.
The Following User Says Thank You to bioevolve For This Useful Post:
miguelbates (04-03-2009)
 Old 04-04-2009, 07:34 PM   #47
badams118's Avatar
Posts: 821   (View Stats)
badams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the worldbadams118 is the leader of the world
Groaned at 126 Times in 71 Posts
Originally Posted by bioevolve View Post
500+ mile update:
I think stage one is only going to cause your boost to increase.
2011 WRX | Cobb AP | Cobb DP | SPT CBE | AEM CAI
Whiteline F/R Sways | SPT SSK | TWM M1 Abrams
badams118 is offline   Reply With Quote
The Following User Says Thank You to badams118 For This Useful Post:
bioevolve (04-05-2009)
 Old 04-05-2009, 05:53 PM   #48
Alittle Faster
bioevolve's Avatar
You're right, it did that same thing but not so high on the boost. It cut between row 19 & 20 at a lower rpm.
Went to stage 2+SF 91 103 for now, have not WOT yet. Awaiting 100 miles and key cycles.
 Old 04-06-2009, 12:10 PM   #49
DeadWayt's Avatar
And judging by your IATs, you can't blame cold weather.
 Old 04-06-2009, 01:24 PM   #50
Alittle Faster
bioevolve's Avatar
LOL, true! 80f-95f here in FLorida.
miguelbates (04-06-2009)
 Old 04-07-2009, 06:19 PM   #51
PaPaSpeed's Avatar
Posts: 602   (View Stats)
PaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the world
Bio said "Only thing I didn't like was the regular clamp, would have liked a band clamp or something better. Anyhooo it still got the job done for now."
I'm considering the Racing Beat exhaust. I wanted to ask you if you think this stainless clamp form jegs would work instead of the one supplied?
Would the 3" size be the one to get?
JEGS Preformed Stainless Steel Exhaust Band Clamps - JEGS
Thanks
CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic.
PaPaSpeed is offline   Reply With Quote
 Old 04-07-2009, 09:26 PM   #52
Alittle Faster
bioevolve's Avatar
That should work, I was looking at that on Jeg's and Summit Racing. Might order me one to try out also.
 Old 04-13-2009, 12:54 PM   #53
Alittle Faster
bioevolve's Avatar
Still getting overboost, just got a cel P0234 overboost condition. Beta to the Final maps stage 1 thru stage 2, tried 6 different maps.
I just took out 2 shims from Forge BPV with Blue spring, hopefully that will fix it. We'll see in the next couple of days, if not, change to the yellow spring with 2 shims and go down from there. That should help with holding boost lower throughout the rpm range right?
19-21psi upto 5000-5500rpms is great until I hit boost cut lol.
 Old 04-13-2009, 03:59 PM   #54
miguelbates's Avatar
Posts: 689   (View Stats)
miguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the world
i lost my springs the damn thing came with it and i misplaced the f***ing box..FAIL
miguelbates is offline   Reply With Quote
 Old 04-13-2009, 05:04 PM   #55
Alittle Faster
bioevolve's Avatar
Sorry to hear.
If I can't remedy the problem by friday, I will put the stocked catted TP back in to create some more back pressure and slow the stock turbo down.
 Old 04-13-2009, 08:18 PM   #56
rofl!^^^
hopefully you get it resolved
 Old 04-17-2009, 08:08 AM   #57
Alittle Faster
bioevolve's Avatar
Update: Now I have the stock catted test pipe back on, Sounds to alittle more quiet lol. 11'ish megs WMV:
http://www.freedomcomputers.net/ms3/rbcbe/rbcbe3.wmv
Will have to drive it after restting the ecu, hopefully it will fix my overboost condition. 2 shims and blue spring back in the Forge BPV. I know I could use a BC, but don't have one in hand so the stock catted tp should work. We'll see.
 Old 04-18-2009, 03:34 AM   #58
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
Hey Bio, did you check to see how well lubed the forge is when you changed the spring/shims? Could be sticking?
Arrowpoint is offline   Reply With Quote
The Following User Says Thank You to Arrowpoint For This Useful Post:
bioevolve (04-18-2009)
 Old 04-18-2009, 07:44 AM   #59
Alittle Faster
bioevolve's Avatar
Yeah, that was the first thing (relubed the piston and o-rings) I did before switching out shims and springs lol.
 Old 04-24-2009, 04:47 PM   #60
Alittle Faster
bioevolve's Avatar
Ok put the on Beta Stage 1 93 103r and it has calmed down the overboost, I will have to play with ATR with the Stage 2 stuff later.
Got a 3" step band clamp off ebay:
Checking fitment.
Putting together down by the Y-pipe part makes it alot easier than trying to put it together at the joint.
Slide it up and start torquing lightly and you hold it in place then snug that thing down hard.
Done. I like this WAY better than a regular exhaust clamp.
I had to smash this heat sheild down to get my ratchet , extension, swivel & socket on.
It bends back nicely lol. Enjoy!
The Following 3 Users Say Thank You to bioevolve For This Useful Post:
Crossbow (04-25-2009), miguelbates (04-25-2009), PaPaSpeed (04-24-2009)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f10/racing-beat-catback-exhaust-installed-24280/
Forum Mazda Performance Series - Zobacz temat - [3BK] wymiana ukladu wydechowego This thread Refback 05-04-2011 04:39 AM
racing beat exhaust whiteyms3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 03-27-2009 08:53 PM
Racing Beat Cat Back jlocurto Mazdaspeed3/6 General Discussion 5 01-25-2009 06:15 PM
Racing Beat Cat Back jlocurto MazdaSpeed 3 - Engine, Transmission & Driveline 8 01-17-2009 10:39 AM
Now Stocking RPMC Turbo Inlets and Racing Beat Exhausts for MS3 CaptainKRM Mazdaspeed3/6 General Discussion 45 11-13-2008 03:24 PM
Page generated in 0.40268 seconds with 26 queries
