Like Tree30Likes
 Old 01-20-2016, 11:53 AM   #1
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Default RD Motorsports "8 Puck" Clutch
I'm in the beginning process of doing some preventative clutch maintenance (~45k on an old school 6 puck) or have one on hand in case I blow it out at the dragon.
My friend @maisonvi; being the deal seeker that he is pointed me to this:
RD Motorsports
Clutch kit w/ pressure plate, TOB, and alignment tool for $275 shipped. Claims to hold 550 ft lb of torque (assume at the wheels from their description) and utilizes an ACT flywheel (this is extra but I could have my Streetlite resurfaced for cheap). No shit.
This 8 puck design can be seen in the Southbend Stage 3 Endurance here:
SBC Stage 3 endurance Mazdaspeed Clutch
I asked the question to the folks at RD Motorsports if they have had extensive miles on any of these guys at high power (I'd assume they do at this point) and how the engagement / daily driveability of these are / how heavy is the pedal really. I haven't heard back yet, but if they come back and say its better than a 6 puck in X categories then I might have to give it a shot.
Has anyone run these or know anyone that runs them with good or bad results? I have yet to find anything about them on MSF yet so I figured now would be a good time to start a discussion on what seems like a great clutch on paper.
@Mazdazilla6; I'm sure you're interested in this topic as well.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
The Following 4 Users Say Thank You to HawkeyeGeoff For This Useful Post:
maisonvi (01-20-2016), Mazdazilla6 (01-20-2016), MD1032 (01-21-2016), WetzMS3 (01-20-2016)
 Old 01-20-2016, 12:13 PM   #2
dawgincustoms's Avatar
Posts: 243   (View Stats)
dawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the worlddawgincustoms is the leader of the world
Hello there.
I have about 30 of these kits in circulation between the midwest and overseas. I first started working on a clutch after wasting a act 6puck in 10k miles. Over the past 2 years the clutch has evolved. In the beginning it was repucking the factory disc and using a heavier pp. Then I changed to a new disk setup. I have changed to an upgraded compound to hold more power. The pp is a 2800lb pressure plate and is prolly the heaviest on the market. For the speed6 I do a reinforcement for the top of the pedal to keep from cracking. With the adjustability of the pedal in the speed6 it can be dialed in and although it is heavier then stock it is still easy to drive and slipable. I personally have used it on a shop car making 500/515 and been at the track multiple times runing 1.6 to 1.7 60ft times without issue. The speed3 is a little more finicky with the added pressure. I have seen some slave cylinders not be able to hold. I have tried adding a spacer to the fork which seems to help the issue. I have looked into going to a wilwood slave but as I dont have a speed3 myself to play with have not had the time to pkay with that option. I have used a clutch setup for about 40k miles and then resurfaced it as I had it out changing the setup. It still had plenty of life left at that time. Any other questions just ask.
Thanks,
Ron
RD Motorsportz
dawgincustoms is offline   Reply With Quote
The Following 8 Users Say Thank You to dawgincustoms For This Useful Post:
CMajor (01-25-2016), Hammology (02-02-2016), HawkeyeGeoff (01-20-2016), maisonvi (01-20-2016), Mazdazilla6 (01-20-2016), Micha (01-22-2016), Tomas (02-25-2016), Vansquish (01-20-2016)
 Old 01-20-2016, 12:14 PM   #3
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
You mean interested, like this?
http://www.mazdaspeedforums.org/foru...ch-kit-197798/
Mazdazilla6 and HawkeyeGeoff like this.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
The Following 3 Users Say Thank You to WetzMS3 For This Useful Post:
 Old 01-20-2016, 12:24 PM   #4
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Lolol, yes Geoff I'm interested. I mentioned it to Ken yesterday when I was interrogating him yesterday about his clutch setup.
Taylor (don't remember his msf name) and I were thinking if we can get enough people interested we might be able to work out a group buy at a small discount.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
HawkeyeGeoff (01-20-2016), maisonvi (01-20-2016), WetzMS3 (01-20-2016)
 Old 01-20-2016, 12:28 PM   #5
maisonvi's Avatar
Posts: 3,490   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 75
@MiUnicorn;
Sent from my SM-G900V using Tapatalk
Franken Turbo, built motor, meth.
DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more.
"Your signature should just say, I'm the shit." -LynzeC
maisonvi is offline   Reply With Quote
The Following 2 Users Say Thank You to maisonvi For This Useful Post:
HawkeyeGeoff (01-20-2016), Mazdazilla6 (01-20-2016)
 Old 01-20-2016, 12:31 PM   #6
robander3's Avatar
Posts: 143   (View Stats)
robander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant futurerobander3 has a brilliant future
If a group buy is put together I'll be interested.
08 MS3 DD (Sold)
06 Dodge Dakota, V6, 6 speed, 4x4
07 MS6 w/engine block VTA mod (currently going built block, etc)
robander3 is offline   Reply With Quote
The Following User Says Thank You to robander3 For This Useful Post:
 Old 01-20-2016, 12:35 PM   #7
LSMS3TMB's Avatar
Posts: 51   (View Stats)
LSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud ofLSMS3TMB has much to be proud of
In 4 deets. I'm pretty much set on purchasing a SouthBend stage 3 Endurance. But if this looks promising I may be swayed.
2011 LSM Mazdaspeed3 w/tech
JBR SRI+TIH and RSB // AT HPFP // AP V3 // Bosch 3bar // ATP catless downpipe // Ultimate Racing catback // Treadstone TR8 FMIC Kit // ATP GTX3076 // Kozmic Oil Feed // SP63 Vented Oil Cap // AquaMist HFS-3.1 // CorkSport Injector Seals // Corksport Short Throw Shifter and 85A RMM // Damond Motorsports Short Shift Plate // CP-E TiaL QR BPV // H&R 15mm spacers // H&R Coilovers // SPC Camber arms // WhiteLine front and rear adjustable end links // Muteki SR48s Red
Hypnotic Tuned
93+Meth- 402whp/384wtq
Sold.
LSMS3TMB is offline   Reply With Quote
 Old 01-20-2016, 12:45 PM   #8
I guess the only thing that is swaying me is that it is "the heaviest on the market". After running this old 6 puck for a year, it really takes the fun out of around the town driving. Race caring its totally fine. I guess really I don't think i will get legit answers on this topic unless someone chimes in about having used both and the difference.
The Following User Says Thank You to HawkeyeGeoff For This Useful Post:
LSMS3TMB (01-20-2016)
 Old 01-20-2016, 12:55 PM   #9
LSMS3TMB's Avatar
I caught that as well. I really like the idea that the S3 Enduro is similar in weight as OEM. If this RD pressure plate is really that heavy I think it would be a deal breaker for me.
Hypnotic Tuned
Sold.
 Old 01-20-2016, 12:55 PM   #10
I'm not turned off by a heavy clutch. I've driven an ACT 6 puck ms3 and comparing it to my pop's 2014 camaro with an LS7 clutch, the camaro is more stiff IMO and has just as much, if not more, as an on/off feel and I still felt comfortable dailying it while I visited him.
The biggest factors for me are:
- Holding 500wtq
- Good price
- Has a decent life to it (assuming you drive properly)
If money was no object I'd go SB any day but I can't justify the price that it is. Right now the only other option I see viable is the ACT kit.
robander3 likes this.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-20-2016, 01:02 PM   #11
MiUnicorn's Avatar
Posts: 45   (View Stats)
MiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond reputeMiUnicorn has a reputation beyond repute
I'm definitely interested, I need to figure out what sort of power I'll be running as to not limit my power with this clutch. But definitely interested
Sent from my SM-N910V using Tapatalk
MiUnicorn is offline   Reply With Quote
The Following User Says Thank You to MiUnicorn For This Useful Post:
 Old 01-20-2016, 01:05 PM   #12
- Holding 500wtq
- Good price
You probably drove the new version of it, which is about 1/2 the weight of the old one and realistically very similar to the weight of an OEM weight. LS7 is a much lighter, much easier to modulate clutch than a sub 2013/2014 6 puck.
 Old 01-20-2016, 01:06 PM   #13
If it's rated properly, this should hold all the torque a 3582 will throw at it (assuming you haven't switched turbos lol). Generally, the bigger you go in turbo size, the bigger the difference will be between peak hp and peak tq with hp being the higher of the two.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-20-2016, 01:09 PM   #14
Oh it should hold for sure. NP.
At this point it's just me being a clutch snob.
 Old 01-20-2016, 01:09 PM   #15
Yea I'd put money on it's a new version. That was this past summer so not too long ago and the clutch was new. The heaviest clutch I've felt is @phate;'s FX400, even still, if I had to I could tolerate that.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-20-2016, 01:12 PM   #16
WetzMS3's Avatar
Groans: 430
For what it's worth, ACT rates the common 6 puck kit with streetlite flywheel at 530 ft/lbs.
ZX5-HDR6 // Advanced Clutch Technology
I think pedal feel has a lot to do with which car the clutch is going into, so it may be hard to get a good reference point there. If pedal stiffness is not much of an issue for you, or there is no guarantee of sorts that this clutch feels drastically lighter, I'd go with the proven design rated slightly higher.
2013 MS3 Black Mica
The Following 4 Users Say Thank You to WetzMS3 For This Useful Post:
HawkeyeGeoff (01-20-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-20-2016), Micha (01-22-2016)
 Old 01-20-2016, 01:16 PM   #17
There is no doubt there. Hydraulic efficiency and how much routing/hose is used plays a roll into how it feels as well as the weight of the vehicle.
That being said, I about shit myself when I felt your 6 puck for the first time and @maisonvi; not even making a blip of complaint with his either. I feel like I'm just a crying bitch until I realized they changed the material and pressure plate LOL
The Following 3 Users Say Thank You to HawkeyeGeoff For This Useful Post:
Mauro_Penguin (01-25-2016), Mazdazilla6 (01-20-2016), WetzMS3 (01-20-2016)
 Old 01-20-2016, 01:20 PM   #18
I'd feel comfortable running the RD kit. It's made by a reputable company so no issues there. But if it's hold like an ACT, but costs $300 less then I can deal with possibly a stiffer pedal.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
The Following 2 Users Say Thank You to Mazdazilla6 For This Useful Post:
Easter Bunny (01-20-2016), WetzMS3 (01-20-2016)
 Old 01-20-2016, 01:21 PM   #19
Braver man than me. Better start doing some leg presses man.
MiUnicorn likes this.
 Old 01-20-2016, 01:23 PM   #20
MiUnicorn's Avatar
Alright, I'm going in blind as far as hp/torque numbers are concerned. All I know is my internals are rated to about 600 so I'd like to sit between 550-600hp.
 Old 01-20-2016, 01:39 PM   #21
maisonvi's Avatar
Groans: 75
I will say his 6-puck is much heaver than my 6-puck. That said, Geoff is still a cry baby.
The Following 3 Users Say Thank You to maisonvi For This Useful Post:
HawkeyeGeoff (01-20-2016), Mazdazilla6 (01-20-2016), WetzMS3 (01-20-2016)
 Old 01-20-2016, 02:04 PM   #22
For those guys with the heavy pedal feel. My girl drives speeds as well and drives on this clutch with heels. I use a heavier plate to aid in the segmented disc. I am not a fan of pucked clutches for daily drivers. They are to on off. Origionally I made this setup for myself and then ran it in a few friends cars and everyone started to fall in love with it. Most of the speeds in the Cincinnati area with replaced clutches run my setup and some have a couple years on them and see time at mid ohio, autox, and plenty of street racing. I would like to test the segmented setup in a car making between 630 and 730 hp and 550 to 600 ft bls. As on a bigger tirbo the tq comes in a little later and I suspect the kevlar material will hold it but cannt confirm that yet. My setup previously made 515 ft lbs at about 4150 rpms. The BNR s3 setup I ran for the end of the year was over 400 ft lbs at 3750 and stayed till 5200 peaking about 420 ft lbs at 4100. And that setup got beat on a lot.
The Following 2 Users Say Thank You to dawgincustoms For This Useful Post:
 Old 01-20-2016, 02:20 PM   #23
Ah. So it is Kevlar....just like the SB Stage 3 endurance. Interesting. So that will probably give everyone a sense of the engagement (good engagement in general).
I have someone coming up from Cinnci for a rally in March I believe. I can give my impressions on it then...or if NATOR OH holds a meet in Toledo. Or if Ron wants to hold a meet and get some beers. Whatever! I really really want to feel this clutch. I guess it should be mentioned that I do this for a living as well. LOL That's why I'm such a clutch snob. Sorry in advance.
The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post:
dawgincustoms (01-20-2016), Mazdazilla6 (01-20-2016)
 Old 01-20-2016, 02:53 PM   #24
865ms3's Avatar
Posts: 2,602   (View Stats)
865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world865ms3 is the leader of the world
I plan to go with one of these when my 6 puck dies. Ron is a good dude and will take care of you. He beats the shit out of his personal car. I can tell you for sure its been ran through the paces haha.
Brent
Mazda Dragon Camp - Event Coordinator
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
865ms3 is offline   Reply With Quote
The Following 2 Users Say Thank You to 865ms3 For This Useful Post:
 Old 01-20-2016, 03:40 PM   #25
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Man up you puss.....Do some leg presses and build up the thigh muscles!!
Realgib3 and Easter Bunny like this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 8 Users Say Thank You to SilverDemon For This Useful Post:
Easter Bunny (01-20-2016), Etipp98 (01-20-2016), HawkeyeGeoff (01-20-2016), maisonvi (01-20-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-20-2016), MD1032 (01-21-2016), WetzMS3 (01-20-2016)
 Old 01-20-2016, 04:48 PM   #26
OH SHIIIIIIIIT!!! Look who it is I should be ashamed. LOL
@Mazdazilla6; I think after some comments made on the book of faces, I think this is the way to go. We should set up a group buy if Ron would entertain it.
There's a dude that owns a MS3 w/ a old style 6 puck and this on his 6. Says the difference is significant in weight and engagement, so that's probably good enough for me TBH at that price.
Mazdazilla6 (01-20-2016), MD1032 (01-21-2016), SilverDemon (01-20-2016)
 Old 01-20-2016, 05:55 PM   #27
I had a glance at that when I had a min in the shop tonight.
I'm all for helping set up a group buy but I'm not in any financial situation to go spending money right now so I'll have to hold off til spring and just pay full price. I don't really know what's required to set up the GB (assuming Ron wants to) and I'm not sure how active @Raider; is currently.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 01-20-2016, 06:15 PM   #28
I do not mind working a group buy for these. It would have to be for the clutch itself, "disk, pressure plate, tob, and alignment tool". I could entertain doing the flywheel if you guys wanted to as I can prolly get a touch better pricing but shipping is prolly what will get some peeps on that. Most times I dont have enough wiggle room in prices as I try and keep things cheaper to start with as 90% of my profit is building cars. However I can work this for the community to help get some more out there.
Who all is down for a group buy?
Mazdazilla6 and davychronic like this.
The Following 3 Users Say Thank You to dawgincustoms For This Useful Post:
HawkeyeGeoff (01-21-2016), Mazdazilla6 (01-20-2016), robander3 (01-21-2016)
 Old 01-20-2016, 06:19 PM   #29
I think just the clutch kit minus the flywheel would be fine. There's plenty of places people can get an ACT flywheel and I imagine it'd be less of a hassle for you not to have to get them and then get them to other people. Plus those who already have an ACT kit will probably just have the flywheel resurfaced so they won't need one.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
dawgincustoms (01-20-2016), HawkeyeGeoff (01-21-2016)
 Old 01-20-2016, 07:39 PM   #30
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Count me in on group buy
How about that basketball game Geoff, must have been heartbreaking for you.
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
 Old 01-21-2016, 06:12 AM   #31
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
I am familiar with the vendor, and we are talking in the staff section about low-volume shops/members and a "grass roots" type setup.
As for allowing a GB, they are supposed to be VIP only. But since the company is going to do offer a discount, and I know the vendor is not someone like the Sandal Shop, or other ghetto scammer scumbag stuff, then go for it. If the owner of this forum has a problem with it, he will act.
The Following 8 Users Say Thank You to Raider For This Useful Post:
blackms3_71 (01-21-2016), dawgincustoms (01-21-2016), Easter Bunny (01-22-2016), HawkeyeGeoff (01-21-2016), maisonvi (01-21-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-21-2016), WetzMS3 (01-21-2016)
 Old 01-21-2016, 06:40 AM   #32
robander3's Avatar
Count me in as well, speed6
08 MS3 DD (Sold)
 Old 01-21-2016, 06:51 AM   #33
Tight. @Mazdazilla6; you want to talk with Ron and include me or do you want me to get it going?
 Old 01-21-2016, 06:52 AM   #34
REBarker's Avatar
Posts: 24   (View Stats)
REBarker is just really niceREBarker is just really niceREBarker is just really niceREBarker is just really niceREBarker is just really nice
Will this clutch kit work with a fidanza flywheel or just the act?
Sent from my SM-G920P using Tapatalk
REBarker is offline   Reply With Quote
 Old 01-21-2016, 06:53 AM   #35
Seems like just ACT, but the company that he works with might be able to make one that will work with the Fidenza. I think they did that in the past.
 Old 01-21-2016, 06:57 AM   #36
Group buy rules for Vendors
1) Group buy shall have a start date and end date.
2) A list of members will be shown in the GB thread and updated accordingly by the organizer of the GB.
3) Price of the item WILL be posted in the GB post.
4) Organizer of the Group Buy will be responsible for keeping the members up to date.
5) The post of the GB will contain descriptive information pertaining to the sale of that item.
Rules per the sticky ^.
Before we go setting this up I think we would should get an interested list going. If you're interested copy the list and add your name. I'm going to start it with everyone who's already said they're interested.
1. HawkeyeGeoff
2. Robander3
3. MiUnicorn
4. davychronic
5. 865ms3(?)
6. LSMS3TMB(?)
I'm totally open to help set up the group buy but I'm not sure we're really allowed to moderate it since we're not the ones selling it, I believe it's up to Ron. With that said, if he needs any assistance I'm open to help.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
Last edited by Mazdazilla6; 01-21-2016 at 07:03 AM. Reason: MSF Database - Automerged Doublepost
The Following 5 Users Say Thank You to Mazdazilla6 For This Useful Post:
dawgincustoms (01-21-2016), Easter Bunny (01-22-2016), HawkeyeGeoff (01-21-2016), maisonvi (01-21-2016), robander3 (01-21-2016)
 Old 01-21-2016, 08:46 AM   #37
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
I bought this setup like 6 months ago, maybe more, but haven't gotten to drive it yet (since my car hates me and wants me to die a slow and painful death). At this point, I can only say the pedal feel is essentially exactly like the ACT -puck I had.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
 Old 01-21-2016, 08:47 AM   #38
MiUnicorn's Avatar
Was your 6 puck a sprung or unsprung disk?
 Old 01-21-2016, 08:52 AM   #39
ZX299's Avatar
Posts: 149   (View Stats)
ZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond repute
If it can be done with the fidanza flywheel I'm definitely interested.
2007 Mazdaspeed 6 GT: JBR Shift knob, Circuitworks catless downpipe & 3.5" custom dual exhaust, JBR TRU 3.5" intake, GTX3076, XSPower V3 manifold, Autotech internals, Accessport V3, Damond Motorsports Full EGR delete, DM Dual OCC kit, CXracing FMIC. AWR 88 Duro RMM, GFB Respons TMS.
ZX299 is offline   Reply With Quote
 Old 01-21-2016, 08:58 AM   #40
Realgib3's Avatar
Groans: 52
Sprung, but that should have no bearing on pedal pressure, since it uses the same PP.
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
Easter Bunny (01-22-2016), Mauro_Penguin (01-25-2016), Mazdazilla6 (01-21-2016), WetzMS3 (01-21-2016)
"Thunderbolt" New Jersey Motorsports Park HPDE October 2010 JBR JAMES BARONE RACING 4 11-16-2010 05:56 AM
Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] Haltech Automotive News 0 08-04-2009 09:40 AM
Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" Haltech Automotive News 0 04-14-2009 01:40 PM
Suzuki SX4t: "t" is for turbo, courtesy of Road Race Motorsports Haltech Automotive News 1 04-23-2008 11:51 AM
Page generated in 0.62751 seconds with 34 queries
