![]() | | #241 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not spraying fuel on the valves combined with heat bakes the mixture on. Nothing new here. Having a non contaminated intake stream is great but that means the PCV system can't vent into the manifold which is like so for emissions purposes. We're talking about blowing motors here however. I experienced a repeatable KR spike of 5-7 on the hwy going WOT after driving for 20 minutes. This was on the stock tune and bolt-ons with boost spiking above 20psi. Swapped to an FMIC, pulled back 3 degrees of VVT advance, and my boost does not spike above 18-19psi. Guess what? No more KR spike no matter how I floor it and after how long of a hwy drive. Quelling the boost spike through tuning and the FMIC (more lag means control system controlled spike better) meant a slower boost ramp-up with a lower overall spike and it put me below the detonation threshold. Everything else about the car stayed the same. So now I know the car is working correctly and not detonating. This is what I'm trying to get across to people. Keep KR at bay, keep spikes low (esp at low RPM), get a fuel pump for higher boost, and the motor will be just fine. EDIT: The DISI motor is very efficient and relatively high compression. This is why we make the great stock torque we do (back to the OP of this thread). But that great high compression and efficiency also results in a lower detonation threshold. |
| The Following 3 Users Say Thank You to Lex For This Useful Post: |
![]() | | #242 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
If people talking about the combustion chambers getting hot during cruise don't know the actual details and are making assumptions, well that is not through testing. Have you tested a completely failed PCV system to see how much oil it in facts sucks up? Do you know for sure that a failed PCV system will cause a hydrolock condition? Yes, but we need to address what causes the detonation. Just saying that they detonate does nothing, fixing the problem is key to making the motors last a long time. Is it safe to say that oil vapors or oil accumulation is happening in these motors? If so, wouldn't addressing this issue first be a starting point to addressing the problem? | |
| The Following User Says Thank You to ptperformance For This Useful Post: | FORZDA 1 (05-06-2010) |
![]() | | #243 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^ Yes, hwy cruise causes high EGTs. Not as high as sustained WOT, but higher than in-city driving. |
![]() | | #244 | ![]() |
![]() ![]() , so according to you knock is causing detonation. If that were the case, when on the dyno you would see the power fall off... but wait... we don't see the TQ fall off in the lower RPM's. So, help me and others understand what is happening. I have seen 50 + DISI motors on the dyno all of them from fully built to bone stock. I have yet to see a car loose TQ due to knock or detonation on the dyno.Lex, have you confirmed your finding on whether or not you changes made to the tune actually helped the motor? Have you dynoed it with the old tune, then your changes made? If what your saying is in fact causing the problem, everyone should be able to get their car to see no knock and we will never see another blown motor on the site, right? Last time I checked people making those few changes are still blowing motors and they are not blowing under WOT, its only after long non-agreessive driving and then rolling into the throttle, most of the time they never even make it to peak boost before the motor destroy's itself. That my friend, has nothing to do with peak this or TQ that, its something else inducing the detonation or causing a hydrolock condition. You have personally verified this? You have an EGT gauge on your car or are we making assumptions? If you do, I want to see video proof of such testing. 2 miles in the city and then 2 miles on the freeway should suffice. I will take the peaks and lows generate an average and then compair the two. This only seems fair to test this way so we can confirm the results. Last edited by ptperformance; 05-06-2010 at 03:00 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #245 | ![]() |
Groans: 79
| Not Ranked : 0 score Cruise is usually just a bit under WOT. Quick search on evom:
Sorry i don't have time to search more, but yes... they are hot during cruise. And those are port injection motors, where the fuel gets to atomize in the heads intake ports, cooling them off and also cooling the combustion chamber off more than us. We have an injector squirting in a localized area in the combustion chamber during cruise, which cools off that localized area quite nicely, but allows the remainder of the chamber to heat soak. This is what lex has been saying for some time.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |||
![]() | | #246 | ![]() |
| Not Ranked : 0 score And we need actual EGT testing not calculated DH or Cobb numbers. Those are calculated numbers and will not be a fair representation of the results. |
![]() | | #247 | ![]() |
![]() Join Date: Apr 2010 Location: Albuquerque nm
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,516
wow a complete blow up. thats nuts. i hardly ever go in 6th gear unless im on the free way and i normally am going at least 80 so no worries. Thanks for the explaination though, the more i know the better off i am. Last edited by Cosmic3MPS; 05-06-2010 at 07:17 PM. | |
| The Following 2 Users Say Thank You to knarfies For This Useful Post: | djuosnteisn (05-06-2010), gtarman77787 (05-06-2010) |
![]() | | #248 | ![]() |
Groans: 79
But even then, power drops due to pulled timing are more than obvious on a dyno. Maybe you should read back through your 50+ dyno sheets and data logs again. Also, since you seem to be demanding so much proof, maybe it's time to give us some proof of the endless hours of mad scientist testing you've been doing for the past 2 years. Last bit of experimentation proof i've seen from you was when you were squirting meth through an intake manifold while it was off the car, with no air being blown through it, and no simulation of intake valves, etc etc. Lets see the goods from your oil pooling proof plz
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #249 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score For the oil hydrolocking, I think it is more likely the oil collecting in the PCV box on the side of the block being moved in a single event then the oil in the bottom of the IM. |
| The Following User Says Thank You to Erich For This Useful Post: | FORZDA 1 (05-06-2010) |
![]() | | #250 | ![]() |
![]() ![]() . So no one has taken the time to verify what the actual EGT's are, am I getting this right? So much for proper testing, .Yes, Lex says a lot but what are his testing parameters? What has he done up to this point to prove his therory's? What I am getting from this is there were a lot of steps skipped to verify the actual causes of the problem. Making assumptions is going to cause more harm than good. Complete proper testing so your not giving smoking mirrors and false info to the forums members. Ding, then you get a "snap vacuum" that collects all the oil in one event and bingo... you have your hydrolock. Last edited by ptperformance; 05-06-2010 at 03:12 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #251 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm getting tired of repeating myself John. I have confirmed that my changes have lowered spikes and prevented the detonation I was seeing. Period. I did not add any baffles, pills, cow shit, etc. to achieve this. The changes I made were logical John, logical. I lowered the boost ramp-up and decreased dynamic compression ratio. No need to be a mad scientist to figure this one out. The more torque the stock motor makes (esp at low RPM), the closer it is to the detonation threshold unless you move that threshold up in a number of ways including octane, meth, cooler charge, lower dynamic compression (VVT), etc. Again, logic. I am sure you can run 110 octane and make the rods bend without detonation with enough torque. This is true for any motor. The REASON you don't see rods break at WOT is because the forged rods have a tendency to bend before shattering. That's WHY they let go at part throttle. This is why you have people with pulsating clutches and this is why I see motors with more than 1 bent rod in them. I am sure you have seen the same. By the way "knock" and detonation are synonyms.
![]() | | #252 | ![]() |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
AAAAAARRRRRRRRGGGGGGGHHHHHHH...! You guys are talking in "absolutes" rather than degrees of effect. ![]() Please come to some compromise and let's make some progress. WTF! Am I playing the voice of sanity here! We are all DOOMED!!!!!
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy | |
| The Following 3 Users Say Thank You to FORZDA 1 For This Useful Post: |
![]() | | #253 | ![]() |
John, where are the blowing CX7s, Foci, Mazda3s .... millions of cars with the same PCV system we have??? Fuck, Ford should be bankrupt. The Duratec they have been selling for a DECADE is doomed - fucking snap vacuum that happens in every car that rolls on the throttle. Someone call headquarters ... oh ... wait ... I don't want to sound like an idiot. | |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | djuosnteisn (05-06-2010), FORZDA 1 (05-06-2010) |
![]() | | #254 | ![]() |
Maybe Lex or you should get on the dyno and confirm it yourselfs? Maybe this is where proper testing goes into making a correct statement about your efforts vs speculating about what the cyl temps are, how much knock is causing damage, and what the real problem is. I have done my testing, I have my proof, I have torn down multiple motors, I have gotten my hands dirty and have my results. This is why I am in here to keep those that don't do proper testing on their toes! We tested the nozzle location with air moving through the manifold, it was only 200 CFM but there was air moving through it. I have a new blower here that will move 880 CFM, that we will be doing more testing with. I will hook up a head this time to the manifold and we will open and close the valves (with the stock cam) as needed for this test. This way we will complete "proper testing" of the part. But I really don't know why this was brought up, are we feeling a little butt hurt because someone is asking for "proof"? And this is your way of having a tantrum? We do our testing, now so should you. Oil pooling in the intake manifold is easy, just pull your t-body off the car and take a look. Ding, oil in the intake. | |
![]() | | #255 | ![]() |
![]() Join Date: Aug 2008 Location: Red Deer, AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,362
| Not Ranked : 0 score why dont you two just agree that you both think the other guy is an idiot and get back to the business of making HP. k thanks bye
__________________ |
![]() | | #256 | ![]() |
Groans: 79
You think i'm adverse to getting factual data? Really? I mean, really? Not only do i go the extra mile to get factual data, i post it up and digest it with the community as a whole. I've been lucky enough to do the legwork on some of the most beneficial factual data this forum has gotten. I say legwork, because it was the community that added the value and understanding to the facts i gathered. I don't just say i've got gobs of testing, and have seen 50+ blown motors and tuned 1 billion DISIs on the dyno, and claim claim claim and talk talk talk. I post up the facts. All you post up are claims. I backed up the claim of cruising EGT's with factual data from another platform. I don't have an EGT gauge right now, much less a running car (though its getting very very close ). But when i do you bet your ass i'll post up a shit load of data.Show us your data mr. call everyone else out. IMO you have the burden of proving your claims, cause your the one selling snake oil unitl proof is shown. Show us the pools of oils, and the pictures, and the videos of all your testing. Then i'll happily stfu and agree with you.
![]() | | #257 | ![]() |
| Banned ![]() Join Date: Feb 2010 Location: Waste Milford North JerZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,140
Groans: 444
Groaned at 154 Times in 97 Posts
| Neutral : 0 score i think you guys should just get together instead of bitching each other out and trying to prove each other wrong -- instead of trying to prove someone wrong, you two are obviously smart as fuck -- smarter than 99.9% of the people in here... put your goddamn brains together and figure this damn thing out -- so all of us can have peace of mind, and we wont have to read thru 38 pages of back and forth bickering honestly, you guys are smart as fuck -- i love reading what you have to write up but i think you two could have a huge fucking breakthrough if you just worked together -- put your findings in one spot... and make some damn money off idiots like me who will read thru 7 pages of you guys talking and will buy something that you say will ultimately FIX this problem |
| The Following 7 Users Say Thank You to gtarman77787 For This Useful Post: | djuosnteisn (05-06-2010), FreeFlyFreak (05-06-2010), kgb (05-06-2010), leadf00t (05-10-2010), MPSdriver (05-10-2010), ridenfish39 (05-06-2010), Swearingen (05-12-2010) |
![]() | | #258 | ![]() |
(Thread Starter) | Not Ranked : 0 score Also don't forget to get Ford and Mazda on that conference call. They'd love to see how their motor fails.
| The Following User Says Thank You to Lex For This Useful Post: | kgb (05-06-2010) |
![]() | | #259 | ![]() |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
Groaned at 57 Times in 47 Posts
| Not Ranked : 0 score During my 4 hour tune session Tim Bailey effectively lowered my boost at the lower RPM's as per our discussions about running safe tunes for the turbo MZR DISI. Less load down low means less chance to go boom. You lose a little bit of torque between 2500-3500 but we can all agree that we shouldn't be going WOT below 3k at a very minimum. AMIRITE? PS: Willy Nelson's one remaining lung has more breath than the K04.
| The Following 4 Users Say Thank You to triplejumper18 For This Useful Post: |
![]() | | #260 | ![]() |
| Not Ranked : 0 score I don't think we will know what exactly is happening in that PCV box unless we can get a clear plastic cover with the same design as the stock cover and a camera/light on it to watch what is happening under different conditions. I don't think it is a matter of a snap vacuum event, but rather an almost perfect storm of conditions occurring. |
![]() | | #261 | ![]() |
Groans: 79
Funny thing is, it's 99.9% figured out. I think lex hit the nail on the head. Just heed his warnings which are speckled throughout this thread and your motor will live a long and healthy life.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 05-06-2010 at 03:36 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #262 | ![]() |
But I am just trying to help the community. I had broken engine parts shipped to me at my expense and no gain just to study and understand what is going on. I have had many lengthy discussions with people who have blown. In the end think about it logically. The stock grocery getter Mazda 3 has the same system and does not blow part throttle. The CX7 doesn't either. It's MS3s and 6s that are modified. However, it happens a lot at "part throttle" which any MS3 or CX7 or Mazda 3 can be at. Yet they are fine. If that is not a compelling argument I don't know what is. | |
![]() | | #263 | ![]() |
Groans: 196
| Neutral : +1 score Oh yeah, your boom boom chances are decreased if you don't mod and drive this thing like a 16 year old with a 1992 Civic with automatic transmission.
![]() | | #264 | ![]() |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
Groaned at 589 Times in 386 Posts
| Not Ranked : 0 score i've been spiking and kr'ing for 36,000 miles while others have not been spiking or kr'ing in much less mileage yet they go boom and i don't. theories theories theories. |
![]() | | #265 | ![]() |
Though not as sure, I am still fairly certain the Eazy's car experienced the same thing. Beyond those two, I don't really have enough information to be making guesses. I can also say there was a good amount of oil in the PCV box on my car when I pulled the cover to move the PCV valve to the valve cover. Judging by the oil stains in the box, what was in there wasn't close to the highest the level had been. Like I said, I would be curious to know what goes on with the oil in the box under different conditions. Though I can't think of how, I wouldn't put it out of the realm of possibility that modifying the car has an effect on that. | |
![]() | | #266 | ![]() |
Groans: 79
| Not Ranked : 0 score Who was it that posted up how much oil it would actually take to hydro lock a motor? I forget, but IIRC that amount was sobering. Like it took ALOT of oil.
![]() | | #267 | ![]() |
(Thread Starter) | Not Ranked : 0 score That's funny, because Eazy tells the story much differently ... involving a boost spike .... hmmmmm .... damn snap vacuum
![]() | | #268 | ![]() |
| Not Ranked : 0 score Yeah, which is why I said less sure. I do know that the cylinder with the bent rod was drenched in oil and the other three were basically dry, but there could be other reasons for that. |
![]() | | #269 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Kent, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,649
Groaned at 32 Times in 14 Posts
Why do only ONE of you guys have to be right. You both have good points, both are plausible. At this time there is no way to prove anything, so why not (instead of bickering and fighting amongst ourselves) work together.... Neither you or John are claiming your theory is true for all blown motors. Get over your ego, and put your problem solving skills to finding a fix, instead of what childish comeback to post. My guess? it's a bit of both. Last edited by Eazy; 05-06-2010 at 04:16 PM. | |
![]() | | #270 | ![]() |
(Thread Starter) | Not Ranked : 0 score ^ A long break build up oil? What is that? Oil does not just build up because the car was on a break. Anyhow, I'm done here, like I said, I have nothing to gain here, people should make up their own minds, the info is all out there. |
![]() | | #271 | ![]() |
| Not Ranked : 0 score Sorry, I guess I missed a comma.... "A long break, building up oil"... you know, like Johns theory.... oil builds up in the PCV. I know you're not that dumb. (I actually think you're pretty smart, just stubborn about contradicting your ideas) |
![]() | | #272 | ![]() |
Anyways, I am not going to argue an illogical point anymore. John called me a pussy in the other thread, so I better go take the sand out of my vagina. I'll tell you this though. If it were me, I would not trust John within 10 feet of my car. Be careful and make your own decisions, it is your money. His track record of failed product after failed product, and "proven, tested, idea" after idea that failed speak for themselves. | |
| The Following User Says Thank You to Lex For This Useful Post: | ms3077 (05-06-2010) |
![]() | | #273 | ![]() |
We have the experience, we have blown motors, we are working on a fix. This means we have more first hand knowledge about the issue at hand. Not only this but as Lex stated, there are no other cars that make the amount of TQ (like the SRT, LOL) at the lower RPM bands like the Mazda, yet Lex clearly stated that the rods were just as strong as the SRT's. I proved that point "WRONG" and they are simply ignoring that I made that obvious to them. They choose to avoid the challenges and cover it up with "I did this and it worked on my car". Well congrats to it working on one fucking car, here is your cookie. Now go out and prove that it works on 100's of these cars and people might believe what you have to say, vs blowing smoke to all the members of this site that are taking what they are saying as truth. | |
| The Following User Says Thank You to ptperformance For This Useful Post: | reddeerspeed3 (05-06-2010) |
![]() | | #274 | ![]() |
From your comment, you obviously don't understand John's theory, so how the fuck can you argue against it? LOL
Like John said, you talk and talk and talk.... and change the subject/divert attention/revert to 12 years old whenever someone does what you do and ask for proof. | ||
![]() | | #275 | ![]() |
| Not Ranked : 0 score That may be the design intent, but the design is flawed. Oil can collect and stay in the upper portion of the box (my car had been off for hours by the time I pulled the cover) and I would also be willing to bet it can accumulate quicker then it drains. |
![]() | | #276 | ![]() |
| The Following 3 Users Say Thank You to For This Useful Post: |
![]() | | #277 | ![]() |
So we are going to result to attacking my testing, is that because yours is lacking or because you butt hurt now?
What am I selling (here is when you get to step on your dick)? I am not selling anything for this fix (yet), we have to prove it to you two idiots first (LOL). Dude, really? GO PULL YOUR INTAKE MANIFOLD OR T-BODY OFF YOUR OWN CAR AFTER A LONG DRIVE, THIS SHOULD BE GOOD ENOUGH VERIFICATION FOR YOU. If I start posting pictures, or hosting vidoe you are just going to say that I poured the oil into the intake. I would rather have those that have posted the pictures here on the site speak the truth for what it is, oil collects in the intake and I think that has been proven by many more then myself. Last, look at the contempt in your word use, look at how pissed you are that I came in here to challenge your findings and posted solid proof that Lex was wrong and I have yet to hear you or Lex address the rod or TQ down low of the SRT4, HE WAS WRONG YOU TARD, NO MAN THE FUCK UP AND ADMIT IT!
Justify your reason however you want, you were wrong in your first post and you have taken your frustrations out on me because of that. You have made childish posts, you have made justifictaions, you have avoided the questions that were posted for you. Paint that picture and you have someone that has all the questions and answers to a therory, but not one solution. What good is that to the members of this forum? | |||||
![]() | | #278 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lol, yes, I am sure you understand it very well along with the multiple bend axis theory. Believe what you want. Go ahead and spike some more to 25+psi on stock rods and see how well it all holds together. The proof is right in front of you yet you ignore it. Pills that blow dipsticks, injector seals that leak, fuel pumps that seize, meth that sprays in only a couple of cylinders ... should I go on? I think Lenny was very spot on with the snake oil comment. What can I say, guy calls it like it is.
![]() | | #279 | ![]() |
Injectors seals that leak on higher HP cars, well didn't see that coming but we revised that for the higher HP guys, we have a solution tested and should be putting it to the real world here in a few days. Fuel pumps that seize, well I will give you that one but that was MFG'ing issue that was not anticipated. Who else made a fuel pump for the Mazda market (not some VW drop in part)? Have you confirmed the WI point problems, we will be testing it here soon and showing the cyl distribution per cyl to "prove" to the members of this site. Have you done anything to back anyone one of these so called "failed" products? Last edited by ptperformance; 05-06-2010 at 05:27 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #280 | ![]() |
Groans: 79
Wow John, just wow. Good luck in life hombre. Thanks for showing us all the light, and how a motor works. I believe anything you say. Also, john. If the pooling oil was such a commonality, why the hell did you design a freeze plug water injection?
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 05-06-2010 at 07:46 PM. Reason: MSF Database - Automerged Doublepost | ||
| FYI: Carrillo Rods vs. Factory Rods | JimmyMac | MazdaSpeed 3 - Engine, Transmission & Driveline | 45 | 02-20-2009 10:07 AM |
| Chicago 2009: SHO History - The real reason Ford had Yamaha's V6 lying around | Haltech | Automotive News | 1 | 02-12-2009 12:27 PM |
| The CPe Store is for real... Its GO TIME people. | phailerider | Custom Performance Engineering (cp-e.com) | 14 | 10-20-2008 10:56 AM |
| Real photo of the real Volt powertrain mule | Haltech | Automotive News | 0 | 04-17-2008 01:40 PM |
